I recently bought the card that i mentioned above and i cant get it working. I searched for drivers for hours and i cant get a working one. Can somebody help me please?
This is the lspci result:
01:00.0 Network controller: Broadcom Inc. and subsidiaries BCM4360 802.11ac Wireless Network Adapter (rev 03)
If everything will be ok then make it permanent. Create /etc/modules-load.d/b43.conf:
b43
blacklist bcma
If this not work you can also use broadcom-wl driver, you need to install version for your kernel and headers, but there also may be needed to add some modules to blacklist, see wiki for details.
Unplug device before modprobe commands or use -f, force flag. You can also try only with file. Or ignore all and try with broadcom-wl drivers. You have many possibilities
