Hello friend!
earlier I installed virtualbox on my computer, but I found a problem that enable nested VT-X/AMD-V is greyed on the option, so i enabled SVM option on the bios and checked with command :
LC_ALL=C lscpu | grep Virtualization
and the result is :
Virtualization: AMD-V
and then i forced the vm to enable the option with :
VBoxManage modifyvm “Arch 2” --nested-hw-virt on
and then the output :
WARNING: The vboxdrv kernel module is not loaded. Either there is no module
available for the current kernel (5.10.15-1-MANJARO) or it failed to
load. Please recompile the kernel module and install it bysudo /sbin/vboxconfig You will not be able to start VMs until this problem is fixed.
VBoxManage: error: Could not find a registered machine named ‘Arch 2’
VBoxManage: error: Details: code VBOX_E_OBJECT_NOT_FOUND (0x80bb0001), component VirtualBoxWrap, interface IVirtualBox, callee nsISupports
VBoxManage: error: Context: “FindMachine(Bstr(a->argv[0]).raw(), machine.asOutParam())” at line 546 of file VBoxManageModifyVM.cpp
Can someone explain what is this?
Processor : AMD Ryzen 5 3400G
GPU : Vega 11
Kernel : 5.10.15-1
DE : KDE 5.20.5
