[Solved] Netis WF 2190 USB WiFi
Hi,
I’ve tried to install Netis WF 2190. I use this AUR package: rtl88xxau-aircrack-dkms-gi
Everything works before reinstalling Manjaro. After reinstall (Manjaro KDE Plasma 20.2) I can not see any WiFi. I’ve tried another AUR drivers for rtl8812au too but without success. Do you have an idea how to make it work? Thank you.
inxi -N
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169
           Device-2: HMD Global Tethering Network Interface type: USB driver: rndis_host
           Device-3: Realtek RTL8812AU 802.11a/b/g/n/ac 2T2R DB WLAN Adapter type: USB driver: usb- network
dmesg
[    2.990049] usb 4-1: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[    3.009802] usb 4-1: Int endpoint with wBytesPerInterval of 512 in config 1 interface 0 altsetting 0 ep 133: setting to 64
[    3.011771] acpi_cpufreq: overriding BIOS provided _PSD data
[    3.011801] usb 4-1: New USB device found, idVendor=0bda, idProduct=8812, bcdDevice= 0.00
[    3.011803] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    3.011805] usb 4-1: Product: 802.11n NIC
[    3.011806] usb 4-1: Manufacturer: Realtek
[    3.011807] usb 4-1: SerialNumber: 123456
lsusb
Bus 004 Device 008: ID 17ef:1015 Lenovo TP USB 3.0 Ultra Dock
Bus 004 Device 007: ID 17e9:4340 DisplayLink ThinkPad USB 3.0 Ultra Dock
Bus 004 Device 006: ID 17ef:1014 Lenovo TP USB 3.0 Ultra Dock
Bus 004 Device 002: ID 0bda:8812 Realtek Semiconductor Corp. RTL8812AU 802.11a/b/g/n/ac 2T2R DB WLAN Adapter
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 009: ID 045e:00db Microsoft Corp. Natural Ergonomic Keyboard 4000 V1.0
Bus 003 Device 008: ID 17ef:1015 Lenovo TP USB 3.0 Ultra Dock
Bus 003 Device 010: ID 145f:020c Trust Trust Ergo Mouse
Bus 003 Device 011: ID 046d:c21d Logitech, Inc. F310 Gamepad [XInput Mode]
Bus 003 Device 007: ID 17ef:1014 Lenovo TP USB 3.0 Ultra Dock
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 2e04:c008 HMD Global Tethering Network Interface
Remove and reinstall the drivers, reboot. I find that usually works.
My mistake. There was Unable to install module rtl88xxau/r1137.2686ea8 for kernel 5.9.16-1-MANJARO: Missing kernel headers. in AUR log. Last line was Transaction successfully finished. so I did not check lines before.
