Hello everyone. I’ve been having some issues with the wifi on Manjaro lately. I’ve tried upgrading and downgrading the kernel from 5.8 to 5.10 to 5.9 and there has been no improvement, so that’s not the issue. Right now my wifi looks like this in the network-manager applet:
As you can see my wifi has split in two… twice! And the connection is fairly unreliable too.
This driver is pretty unreliable, and before I modprobed 88x2ce my wifi used to drop every 20 minutes for about 2-3 minutes. I’ve not been able to install any other modules or probes on my copy of Manjaro.
Any ideas? Please tell me if there’s any more information I need to provide.
I’d delete all four of the “Cecilie” connections and then add a new connection to that Network.
just to clean things up …
It’s strange that you seem to have two wlan interfaces:
wlan1 and wlp2s0
With the currently active driver rtl88x2ce that interface is called wlan1
I wonder where the wlp2s0 interface comes from.
Is it different hardware? - if has got a different MAC.
But that could be due to MAC randomization done by NetworkManager.
Don’t know.
You mentioned:
You seem to use two different drivers/use two separate wlan-adapters?
If that is so:
blacklist one of them
so that only the one you want/need is loaded.
Seems like only rtl88x2ce is loaded, weird, why is my wifi split in two then? The connection has also dropped til mere nonexistence, I can barely play watch youtube videos anymore Idk if you know but any pointers would be helpful.
I used journalctl -f to document the network manager log while trying to connect to the wifi after deleting all the connections and if I connect to wlan0 or wlp2s0 the program ends up spamming
and the wifi refuses to connect, on wlp2s0 it ends up saying no secrets have been provided. Really confusing issue so far, I’ve been struggling with this wifi card for a while now. Posting this through mobile tethering Going to try rebooting to see if it at least brings my poopy near-unusable wifi back for a moment.
I’d remove/deinstall the module that you now still have but don’t intend to use.
you have these two
rtl8812au
rtl8821ce
one is not used, not even loaded
but:
if I have problems, I start eliminating possible factors.
You earlier said … you modprobed it …
yet, the network seemed to have at least somehow worked before that/without that module loaded
from what you described …
This is all unclear to me.
Can you be sure that this is the right module and it is supposed to be working with your card?
Is it?
To me it looks like you have two entries because you used two different drivers.
One is old, the other newer …
Delete all of the connections and create a new one.
Someone else might be more knowledgable than me.
edit:
it appears that this driver rtw88
should work
You should only need to use the dkms built driver rtl8821ce
if you use non-standard kernels
perhaps installing an LTS kernel and using that - or a 5.10 or 5.11 kernel - will give different results.
I have no way of removing these, neither pacman -R not pamac remove can find them.
My network has been having issues for a while now. The rtl88x2ce driver has subpar performance so I’ve been trying to change it to rtw88 or something similar, but I haven’t been able to do so. The latest consequence was the splitting of the wifi into wlan1 and wlp2s0.
I don’t know how
I’ve tried deleting the connections but it still appears as two separate wifi connections, wlan1 and wlp2s0 even when I’m not connected to it.
I can try installing rtw88, but to avoid conflict I need to uninstall rtl88x2ce, which I don’t know how to either, as again, neither pacman -R or pamac remove can find it. Do you know how I could find out what package the driver is installed with for removal?
Update! I managed to merge the two wifis back using the instructions for rtw88 here GitHub - lwfinger/rtw88 and blacklisting rtl88x2ce and the other conflicting drivers. Idk if my wifi has been improved but now we’re at least back to somewhere legible, thanks for the help Nachlese
