How do I install all of them?
I can’t install them with the packages ttf-ms-fonts and ttf-ms-win10 because they don’t exist anymore.
are - where they always were - in AUR.
First you should update:
pamac upgrade -a
The fonts can be installed via
pamac build ttf-ms-fonts
or
pamac build ttf-ms-win10
They are conflicting, so you have to decide.
As mentioned by @cscs, check carefully if it’s legal for you to use the win10 fonts.
Thanks for the reply.
I just found that same solution in another forum, but this doesn’t include all the fonts. Are there other packages?
I guess these?
https://aur.archlinux.org/packages/?O=0&SeB=nd&K=ttf-ms&outdated=&SB=n&SO=a&PP=50&do_Search=Go
(of course to mention again - these arent necessarily legal depending on your local laws and whether you own a microsoft license, etc … a number of the packages require you to have access to your own fonts from some install media)
Thanks for replying
I’m a bit confused here. ttf-ms-win10 seems to contain all the fonts that I need, but I can’t build it with the pamac command. I get the following error:
** (pamac:88896): CRITICAL **: 21:24:20.364: g_ptr_array_get_length: assertion ‘self != NULL’ failed
cp: cannot stat ‘/var/lib/pacman/sync/*.files’: No such file or directory
Resolving dependencies…
Checking inter-conflicts…
To build (1):
ttf-ms-win10 10.0.18362.116-2 AUR
Edit build files : [e]
Apply transaction ? [e/y/N]
Please read the PKGBUILD.
(which you should be doing for any AUR package)
https://aur.archlinux.org/cgit/aur.git/tree/PKGBUILD?h=ttf-ms-win10
tidbit:
# BUILD INSTRUCTIONS:
# Please note, that usage of Microsoft fonts outside running Windows
# system is prohibited by EULA (although in certain countries EULA is invalid).
# Please consult Microsoft license before using fonts.
# You can acquire fonts either from an installed and up-to-date Windows 10
# system or the most recent install medium.
# On the installed Windows 10 system fonts are usually located in
# C:\Windows\Fonts
# and license file is
# C:\Windows\System32\Licenses\neutral\_Default\Core\license.rtf
# How to acquire fonts from Windows 10 install medium...
(I will also leave this here: Arch User Repository - Manjaro)
Hi thanks for replying. I do have a valid license and found all the fonts and the license in the corisponding folders. However I was still not able to build these even after placing all the fonts and the license in the /var/lib/pacman/sync/ folder. I don’t really know what I am doing wrong.
According to the error it can’t find my fonts.
I’m really at my limit here. I uses the git clone and pasted all files in the same folder as the
PKGBUILD file. I also commented out the the packages that I don’t need and ran this command, which skips SHA checks, since only a few fonts didn’t match.
makepkg -s -f --skipinteg
However after building it. I still could not select the fonts in LibreOffice, so I guess they were not really installed in a “clean way”. Where did I go wrong?
Thank you! That seems to have solved it!
