[Solved]How long have I been using my distro
Hello,
I need to check when I installed my distro? Is there any way of checking this on Linux?
Actually, I represent Linux to my friend as proof of how much stable Linux which I have been using for almost more than 2 years without any reinstallation. (knock on wood :cowboy_hat_face:)
I searched Ddg and google but I can’t found a notable thing.
So Is there any counter in Linux or Log file
My distro Manjaro Cinnamon.
awk -F “[” ‘NR==1 {print $2;}’ /var/log/pacman.log
stat /
stat -c '%w' /
for smaller :wink:
(PS @nigelwarning you must fix your quotes for yours to work)
awk: fatal: invalid regexp: Unmatched [, [^, [:, [., or [=: /“[[/
bash: }’: command not found
(base) [axe@axe-20aws2t12n ~]$ awk -F “[” ‘NR==1 {print $2;}’ /var/log/pacman.log
(base) [axe@axe-20aws2t12n ~]$ awk -F “[]” ‘NR==1 {print $2;}’ /var/log/pacman.log
(base) [axe@axe-20aws2t12n ~]$ awk -F “” ‘NR==1 {print $2;}’ /var/log/pacman.log
awk: fatal: invalid regexp: Unmatched [, [^, [:, [., or [=: /“”/
awk: fatal: invalid regexp: Invalid regular expression: /“[/
stat /
File: /
Size: 4096 Blocks: 16 IO Block: 4096 directory
Device: 804h/2052d Inode: 2 Links: 19
Access: (0755/drwxr-xr-x) Uid: ( 0/ root) Gid: ( 0/ root)
Access: 2020-05-19 21:34:21.696916911 +0300
Modify: 2020-11-23 01:11:32.028290063 +0300
Change: 2020-11-23 01:11:32.028290063 +0300
Birth: 2020-05-19 21:32:08.000000000 +0300
stat -c ‘%w’ /
Yeah It is work, but as if show the latest big update time
@tuxmanjarino @cscs
Then that probably means somehow you reinstalled over or reformated root or similar.
I suppose you could check your users home instead?
stat -c '%w' ~
[edit … oh … those quotes got me too. hah. fixed]
What @cscs said, maybe you 've used a backup mechanism.
You may find more info in the archived forum for example:
/edit: or this one:
(base) [axe@axe-20aws2t12n ~]$ stat -c ‘%w’ ~axe
‘2020-04-28 22:51:15.603701161 +0300’
looks better by the way I checked the creation time of any first file like music,Docs as you said home.
But how can I check this
Its so interesting…
(base) [axe@axe-20aws2t12n ~]$ sudo tune2fs -l /dev/sda2 | grep “created”
[sudo] password for axe:
Filesystem created: Wed Feb 12 18:58:25 2020
we’re digging deeper and deeper :grin:
I started questioning myself Should I did this? :thinking:
But I don’t know how to use backup
Sorry, I’m a little different person who doesn’t use these.
@cscs @tuxmanjarino @nigelwarning
Thanks for all of the answers.
I accept this one as best answer
