Hi, I recently started using a Piinebook Pro which comes installed with Manjero. During the initial setup I made mistake and chose the UK keyboard layout when my machine actually has a US layout keyboard. This manifests itself most annoyingly when I press SHIFT + 2 expecting an @ and get a ".
I can change this by going into System Settings > Keyboard Settings and selecting English (US), though this change is reverted when ever I reboot. How can I make this change permanent, so when I reboot I always come back to the same keyboard layout.
I’ve also tried following some of the instructions on the Arch Keyboard Config article
https wiki [dot] archlinux [dot] org/index [dot] php/Linux_console/Keyboard_configuration
I assume you are using KDE Plasma, go to System Settings > Input Devices > tab Layouts and add the preferred layout. I had the same issue yesterday and this solved it
Yeah, updating through the UI as recommended solved my problem. The issue was that I was changing the Manjaro keyboard settings, though not the Input Devices > tab Layouts settings
Well, that’s at least “curious” to me because that’s the only way I’m seeing of changing these settings here on the Manjaro that I’m currently running.
How were you doing these changes before? Is there another method?
