Hi,
I am getting GNU GRUB console after start. If I write “exit” into the console and press enter then I get classic GRUB menu with systems (Manjoro Linux…). So everything works fine Manjaro boot but I have to write “exit” after every PC start. I’ve tried to run update-grub command it does not help. How can I fix GRUB to boot without the console? Thanks.
My GRUB version is (GRUB) 2.04~manjaro
update-grup output:
Found linux image: /boot/vmlinuz-5.9-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.9-x86_64.img
Found initrd fallback image: /boot/initramfs-5.9-x86_64-fallback.img
Found Windows Boot Manager on /dev/nvme0n1p2@/efi/Microsoft/Boot/bootmgfw.efi
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
done
