Hello guys,
I’m new to Manjaro and Arch based distribution and I’m starting to falling in love with them.
I’ve a little problem related to keyboard arrow keys. I’m trying to navigate through text (eg using LibreOffice), but if I keep pressed an arrow key, the cursor moves only once on arrow direction.
Agree with @megavolt (unless it doesn’t fix your problem )
You can also get to keyboard settings via Settings Manager and select Keyboard. Under Typing Settings there is a checkbox Enable key repeat. This assumes the desktop is XFCE.
For Plasma/KDE, from the command line: kcmshell5 kcm_keyboard
Or, System Settings > Input Devices > Keyboard and check the Keyboard Repeat section.
If by chance this doesn’t work:
Which desktop?
All applications or just libreoffice?
What’s the output of the command: xset -q | grep repeat
Hi Guys, thank you for your answers. The issue was related to the value associated to the second slide on Keyboard Repeat section. It was set to one. I moved it to the max value on it works fine now.
