Software.manjaro.org expired certificate
Hi,
following up on the discover. manjaro .org certificate expiry, 5 days later, software .manjaro .org is also expired, would be great if that was updated.
Since you’re using Let’s Encrypt, why not use Certbot to automate the updates?
Cheers.
It is set to automate updates, however cron jobs don’t account for errors when renewing, it is solved now.
