Hello,
Yesterday tried to install “Build” (Don’t know if it’s the same thing )“LibreWolf” via Add/Remove Software center. It took very long time and at the end crashed.
- So much packages is it normal?
- Is it normal that it taking so much time (~50 min)?
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=210207dd-6d70-408c-bfe8-6df47a03f89c rw iommu=soft quiet
Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: LENOVO product: 20UH002DMH v: ThinkPad T14s Gen 1
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: 20UH002DMH serial: <filter> UEFI: LENOVO
v: R1CET58W(1.27 ) date: 10/20/2020
39:11.68 clang-11: warning: argument unused during compilation: '-D SHLIB_PREFIX="lib"' [-Wunused-command-line-argument]
39:11.68 clang-11: warning: argument unused during compilation: '-D SHLIB_VERSION="3"' [-Wunused-command-line-argument]
39:11.68 clang-11: warning: argument unused during compilation: '-D SOFTOKEN_SHLIB_VERSION="3"' [-Wunused-command-line-argument]
39:11.68 clang-11: warning: argument unused during compilation: '-D RIJNDAEL_INCLUDE_TABLES' [-Wunused-command-line-argument]
39:11.68 clang-11: warning: argument unused during compilation: '-D MP_API_COMPATIBLE' [-Wunused-command-line-argument]
39:11.68 clang-11: warning: argument unused during compilation: '-D HAVE_INT128_SUPPORT' [-Wunused-command-line-argument]
39:11.68 clang-11: warning: argument unused during compilation: '-D FREEBL_LOWHASH' [-Wunused-command-line-argument]
39:11.68 clang-11: warning: argument unused during compilation: '-D FREEBL_NO_DEPEND' [-Wunused-command-line-argument]
39:11.68 clang-11: warning: argument unused during compilation: '-D MP_IS_LITTLE_ENDIAN' [-Wunused-command-line-argument]
39:11.68 clang-11: warning: argument unused during compilation: '-D NSS_BEVAND_ARCFOUR' [-Wunused-command-line-argument]
39:11.68 clang-11: warning: argument unused during compilation: '-D MPI_AMD64' [-Wunused-command-line-argument]
39:11.68 clang-11: warning: argument unused during compilation: '-D MP_ASSEMBLY_MULTIPLY' [-Wunused-command-line-argument]
39:11.68 clang-11: warning: argument unused during compilation: '-D NSS_USE_COMBA' [-Wunused-command-line-argument]
39:11.68 clang-11: warning: argument unused during compilation: '-D USE_HW_AES' [-Wunused-command-line-argument]
39:11.68 clang-11: warning: argument unused during compilation: '-D INTEL_GCM' [-Wunused-command-line-argument]
39:11.68 clang-11: warning: argument unused during compilation: '-D NSS_FIPS_DISABLED' [-Wunused-command-line-argument]
39:11.68 clang-11: warning: argument unused during compilation: '-D NSS_NO_INIT_SUPPORT' [-Wunused-command-line-argument]
39:11.68 clang-11: warning: argument unused during compilation: '-D NSS_X86_OR_X64' [-Wunused-command-line-argument]
39:11.68 clang-11: warning: argument unused during compilation: '-D NSS_X64' [-Wunused-command-line-argument]
39:11.68 clang-11: warning: argument unused during compilation: '-D NSS_USE_64' [-Wunused-command-line-argument]
39:11.68 clang-11: warning: argument unused during compilation: '-D SEED_ONLY_DEV_URANDOM' [-Wunused-command-line-argument]
39:11.68 clang-11: warning: argument unused during compilation: '-D USE_UTIL_DIRECTLY' [-Wunused-command-line-argument]
39:11.68 clang-11: warning: argument unused during compilation: '-D NO_NSPR_10_SUPPORT' [-Wunused-command-line-argument]
39:11.68 clang-11: warning: argument unused during compilation: '-D SSL_DISABLE_DEPRECATED_CIPHER_SUITE_NAMES' [-Wunused-command-line-argument]
39:11.68 clang-11: warning: argument unused during compilation: '-D LINUX2_1' [-Wunused-command-line-argument]
39:11.68 clang-11: warning: argument unused during compilation: '-D LINUX' [-Wunused-command-line-argument]
39:11.68 clang-11: warning: argument unused during compilation: '-D linux' [-Wunused-command-line-argument]
39:11.68 clang-11: warning: argument unused during compilation: '-D _DEFAULT_SOURCE' [-Wunused-command-line-argument]
39:11.68 clang-11: warning: argument unused during compilation: '-D _BSD_SOURCE' [-Wunused-command-line-argument]
39:11.68 clang-11: warning: argument unused during compilation: '-D _POSIX_SOURCE' [-Wunused-command-line-argument]
39:11.68 clang-11: warning: argument unused during compilation: '-D SQL_MEASURE_USE_TEMP_DIR' [-Wunused-command-line-argument]
39:11.68 clang-11: warning: argument unused during compilation: '-D HAVE_STRERROR' [-Wunused-command-line-argument]
39:11.68 clang-11: warning: argument unused during compilation: '-D XP_UNIX' [-Wunused-command-line-argument]
39:11.68 clang-11: warning: argument unused during compilation: '-D _REENTRANT' [-Wunused-command-line-argument]
39:11.69 clang-11: warning: argument unused during compilation: '-D NSS_DISABLE_DBM' [-Wunused-command-line-argument]
39:11.69 clang-11: warning: argument unused during compilation: '-D NSS_DISABLE_LIBPKIX' [-Wunused-command-line-argument]
39:11.69 clang-11: warning: argument unused during compilation: '-D NDEBUG' [-Wunused-command-line-argument]
39:13.38 In file included from <built-in>:2:
39:13.38 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/libavutil_visibility.h:16:
39:13.38 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/libavutil/log.h:25:
39:13.38 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/libavutil/avutil.h:296:
39:13.38 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/libavutil/common.h:105:
39:13.38 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/config.h:45:
39:13.38 /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/config_unix64.h:219:9: warning: 'HAVE_LINUX_PERF_EVENT_H' macro redefined [-Wmacro-redefined]
39:13.38 #define HAVE_LINUX_PERF_EVENT_H 0
39:13.38 ^
39:13.38 /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/obj/mozilla-config.h:57:9: note: previous definition is here
39:13.38 #define HAVE_LINUX_PERF_EVENT_H 1
39:13.38 ^
39:13.46 1 warning generated.
39:13.50 1 warning generated.
39:13.54 In file included from <built-in>:2:
39:13.54 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/libavutil_visibility.h:16:
39:13.54 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/libavutil/log.h:25:
39:13.54 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/libavutil/avutil.h:296:
39:13.54 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/libavutil/common.h:105:
39:13.54 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/config.h:45:
39:13.54 /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/config_unix64.h:219:9: warning: 'HAVE_LINUX_PERF_EVENT_H' macro redefined [-Wmacro-redefined]
39:13.54 #define HAVE_LINUX_PERF_EVENT_H 0
39:13.54 ^
39:13.54 /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/obj/mozilla-config.h:57:9: note: previous definition is here
39:13.54 #define HAVE_LINUX_PERF_EVENT_H 1
39:13.54 ^
39:13.60 In file included from <built-in>:2:
39:13.60 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/libavutil_visibility.h:16:
39:13.60 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/libavutil/log.h:25:
39:13.60 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/libavutil/avutil.h:296:
39:13.60 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/libavutil/common.h:105:
39:13.60 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/config.h:45:
39:13.60 /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/config_unix64.h:219:9: warning: 'HAVE_LINUX_PERF_EVENT_H' macro redefined [-Wmacro-redefined]
39:13.60 #define HAVE_LINUX_PERF_EVENT_H 0
39:13.60 ^
39:13.60 /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/obj/mozilla-config.h:57:9: note: previous definition is here
39:13.60 #define HAVE_LINUX_PERF_EVENT_H 1
39:13.60 ^
39:13.72 In file included from <built-in>:2:
39:13.72 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/libavutil_visibility.h:16:
39:13.72 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/libavutil/log.h:25:
39:13.72 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/libavutil/avutil.h:296:
39:13.72 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/libavutil/common.h:105:
39:13.72 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/config.h:45:
39:13.72 /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/config_unix64.h:219:9: warning: 'HAVE_LINUX_PERF_EVENT_H' macro redefined [-Wmacro-redefined]
39:13.72 #define HAVE_LINUX_PERF_EVENT_H 0
39:13.72 ^
39:13.72 /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/obj/mozilla-config.h:57:9: note: previous definition is here
39:13.72 #define HAVE_LINUX_PERF_EVENT_H 1
39:13.72 ^
39:13.82 1 warning generated.
39:13.87 1 warning generated.
39:13.97 In file included from <built-in>:2:
39:13.97 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/libavutil_visibility.h:16:
39:13.97 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/libavutil/log.h:25:
39:13.97 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/libavutil/avutil.h:296:
39:13.97 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/libavutil/common.h:105:
39:13.97 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/config.h:45:
39:13.97 /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/config_unix64.h:219:9: warning: 'HAVE_LINUX_PERF_EVENT_H' macro redefined [-Wmacro-redefined]
39:13.97 #define HAVE_LINUX_PERF_EVENT_H 0
39:13.97 ^
39:13.97 /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/obj/mozilla-config.h:57:9: note: previous definition is here
39:13.97 #define HAVE_LINUX_PERF_EVENT_H 1
39:13.97 ^
39:14.00 In file included from <built-in>:2:
39:14.00 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/libavutil_visibility.h:16:
39:14.00 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/libavutil/log.h:25:
39:14.00 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/libavutil/avutil.h:296:
39:14.00 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/libavutil/common.h:105:
39:14.00 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/config.h:45:
39:14.00 /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/config_unix64.h:219:9: warning: 'HAVE_LINUX_PERF_EVENT_H' macro redefined [-Wmacro-redefined]
39:14.00 #define HAVE_LINUX_PERF_EVENT_H 0
39:14.00 ^
39:14.00 /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/obj/mozilla-config.h:57:9: note: previous definition is here
39:14.00 #define HAVE_LINUX_PERF_EVENT_H 1
39:14.00 ^
39:14.01 1 warning generated.
39:14.13 In file included from <built-in>:2:
39:14.13 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/libavutil_visibility.h:16:
39:14.13 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/libavutil/log.h:25:
39:14.13 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/libavutil/avutil.h:296:
39:14.13 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/libavutil/common.h:105:
39:14.13 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/config.h:45:
39:14.13 /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/config_unix64.h:219:9: warning: 'HAVE_LINUX_PERF_EVENT_H' macro redefined [-Wmacro-redefined]
39:14.13 #define HAVE_LINUX_PERF_EVENT_H 0
39:14.13 ^
39:14.13 /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/obj/mozilla-config.h:57:9: note: previous definition is here
39:14.13 #define HAVE_LINUX_PERF_EVENT_H 1
39:14.13 ^
39:14.84 In file included from <built-in>:2:
39:14.84 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/libavutil_visibility.h:16:
39:14.84 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/libavutil/log.h:25:
39:14.84 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/libavutil/avutil.h:296:
39:14.84 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/libavutil/common.h:105:
39:14.85 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/config.h:45:
39:14.85 /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/config_unix64.h:219:9: warning: 'HAVE_LINUX_PERF_EVENT_H' macro redefined [-Wmacro-redefined]
39:14.85 #define HAVE_LINUX_PERF_EVENT_H 0
39:14.85 ^
39:14.85 /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/obj/mozilla-config.h:57:9: note: previous definition is here
39:14.85 #define HAVE_LINUX_PERF_EVENT_H 1
39:14.85 ^
39:15.47 In file included from <built-in>:2:
39:15.47 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/libavutil_visibility.h:16:
39:15.47 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/libavutil/log.h:25:
39:15.47 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/libavutil/avutil.h:296:
39:15.47 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/libavutil/common.h:105:
39:15.47 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/config.h:45:
39:15.47 /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/config_unix64.h:219:9: warning: 'HAVE_LINUX_PERF_EVENT_H' macro redefined [-Wmacro-redefined]
39:15.47 #define HAVE_LINUX_PERF_EVENT_H 0
39:15.47 ^
39:15.47 /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/obj/mozilla-config.h:57:9: note: previous definition is here
39:15.47 #define HAVE_LINUX_PERF_EVENT_H 1
39:15.47 ^
39:15.79 1 warning generated.
39:15.93 In file included from <built-in>:2:
39:15.93 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/libavutil_visibility.h:16:
39:15.93 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/libavutil/log.h:25:
39:15.93 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/libavutil/avutil.h:296:
39:15.93 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/libavutil/common.h:105:
39:15.93 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/config.h:45:
39:15.93 /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/config_unix64.h:219:9: warning: 'HAVE_LINUX_PERF_EVENT_H' macro redefined [-Wmacro-redefined]
39:15.93 #define HAVE_LINUX_PERF_EVENT_H 0
39:15.93 ^
39:15.93 /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/obj/mozilla-config.h:57:9: note: previous definition is here
39:15.93 #define HAVE_LINUX_PERF_EVENT_H 1
39:15.93 ^
39:15.94 1 warning generated.
39:16.08 In file included from <built-in>:2:
39:16.08 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/libavutil_visibility.h:16:
39:16.08 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/libavutil/log.h:25:
39:16.08 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/libavutil/avutil.h:296:
39:16.08 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/libavutil/common.h:105:
39:16.08 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/config.h:45:
39:16.08 /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/config_unix64.h:219:9: warning: 'HAVE_LINUX_PERF_EVENT_H' macro redefined [-Wmacro-redefined]
39:16.08 #define HAVE_LINUX_PERF_EVENT_H 0
39:16.08 ^
39:16.08 /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/obj/mozilla-config.h:57:9: note: previous definition is here
39:16.08 #define HAVE_LINUX_PERF_EVENT_H 1
39:16.08 ^
39:16.35 In file included from <built-in>:2:
39:16.35 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/libavutil_visibility.h:16:
39:16.35 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/libavutil/log.h:25:
39:16.35 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/libavutil/avutil.h:296:
39:16.35 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/libavutil/common.h:105:
39:16.35 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/config.h:45:
39:16.35 /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/config_unix64.h:219:9: warning: 'HAVE_LINUX_PERF_EVENT_H' macro redefined [-Wmacro-redefined]
39:16.35 #define HAVE_LINUX_PERF_EVENT_H 0
39:16.35 ^
39:16.35 /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/obj/mozilla-config.h:57:9: note: previous definition is here
39:16.35 #define HAVE_LINUX_PERF_EVENT_H 1
39:16.35 ^
39:18.02 In file included from <built-in>:2:
39:18.02 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/libavutil_visibility.h:16:
39:18.02 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/libavutil/log.h:25:
39:18.02 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/libavutil/avutil.h:296:
39:18.02 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/libavutil/common.h:105:
39:18.02 In file included from /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/config.h:45:
39:18.02 /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/media/ffvpx/config_unix64.h:219:9: warning: 'HAVE_LINUX_PERF_EVENT_H' macro redefined [-Wmacro-redefined]
39:18.02 #define HAVE_LINUX_PERF_EVENT_H 0
39:18.02 ^
39:18.02 /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/obj/mozilla-config.h:57:9: note: previous definition is here
39:18.02 #define HAVE_LINUX_PERF_EVENT_H 1
39:18.02 ^
39:18.09 1 warning generated.
39:18.21 1 warning generated.
39:18.23 1 warning generated.
39:18.97 1 warning generated.
39:19.02 security/nss/lib/freebl/libfreeblpriv3.so
39:20.95 1 warning generated.
39:23.50 1 warning generated.
39:23.53 1 warning generated.
39:24.04 1 warning generated.
39:24.10 media/ffvpx/libavcodec/libmozavcodec.so
39:30.18 Compiling webrender_bindings v0.1.0 (/var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/gfx/webrender_bindings)
42:34.09 Compiling gkrust v0.1.0 (/var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/toolkit/library/rust)
54:33.17 error: could not compile `gkrust`
54:33.17 Caused by:
54:33.17 process didn't exit successfully: `/usr/bin/rustc --crate-name gkrust toolkit/library/rust/lib.rs --error-format=json --json=diagnostic-rendered-ansi --crate-type staticlib --emit=dep-info,link -C opt-level=2 -C panic=abort -C embed-bitcode=no -Clto --cfg 'feature="cubeb-remoting"' --cfg 'feature="cubeb_pulse_rust"' --cfg 'feature="gecko_profiler"' --cfg 'feature="gecko_profiler_parse_elf"' --cfg 'feature="glean"' --cfg 'feature="glean_with_gecko"' --cfg 'feature="moz_memory"' --cfg 'feature="moz_places"' --cfg 'feature="new_cert_storage"' --cfg 'feature="quantum_render"' --cfg 'feature="simd-accel"' --cfg 'feature="webgpu"' --cfg 'feature="webrtc"' --cfg 'feature="with_dbus"' -C metadata=b423a50142a1ba68 -C extra-filename=-b423a50142a1ba68 --out-dir /var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/obj/x86_64-unknown-linux-gnu/release/deps --target x86_64-unknown-linux-gnu -C linker=/var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/build/cargo-linker -L dependency=/var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/obj/x86_64-unknown-linux-gnu/release/deps -L dependency=/var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/obj/release/deps --extern gkrust_shared=/var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/obj/x86_64-unknown-linux-gnu/release/deps/libgkrust_shared-cff74860f3bd4d29.rlib --extern mozglue_static=/var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/obj/x86_64-unknown-linux-gnu/release/deps/libmozglue_static-d93f0f431db2e855.rlib --extern mozilla_central_workspace_hack=/var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/obj/x86_64-unknown-linux-gnu/release/deps/libmozilla_central_workspace_hack-8f62346e0eb73c49.rlib --extern swgl=/var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/obj/x86_64-unknown-linux-gnu/release/deps/libswgl-d70f8e5577883215.rlib -C opt-level=2 -C debuginfo=2 --cap-lints warn -Cembed-bitcode=yes -C profile-generate=/var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/obj -C codegen-units=1 -L native=/usr/lib -L native=/var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/obj/x86_64-unknown-linux-gnu/release/build/lmdb-rkv-sys-682c636f0f3d93dd/out -L native=/var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/obj/x86_64-unknown-linux-gnu/release/build/mozglue-static-9e8bf948c1807ef6/out -L native=/var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/obj/dist/bin -L native=/var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/obj/security/nss/lib/nss/nss_nss3 -L native=/var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/obj/security/nss/lib/ssl/ssl_ssl3 -L native=/var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/obj/config/external/nspr/pr -L native=/var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/obj/x86_64-unknown-linux-gnu/release/build/swgl-53c8852728ed2848/out` (signal: 9, SIGKILL: kill)
54:33.19 make[4]: *** [/var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/config/makefiles/rust.mk:319: force-cargo-library-build] Error 101
54:33.19 make[3]: *** [/var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/config/recurse.mk:72: toolkit/library/rust/target] Error 2
54:33.19 make[2]: *** [/var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/config/recurse.mk:34: compile] Error 2
54:33.19 make[1]: *** [/var/tmp/pamac-build-user/librewolf/src/firefox-84.0.2/config/rules.mk:355: default] Error 2
54:33.20 make: *** [client.mk:89: build] Error 2
54:33.22 272 compiler warnings present.
Config object not found by mach.
Configure complete!
Be sure to run |mach build| to pick up any changes
==> ERROR: A failure occurred in build().
Aborting...
Pasted end of build message since all text is too big and unable to attach .txt file.
