After the last update of 3 days ago the Snap applications are utterly dead on LTS kernel 5.4.85.
Upon launching them I get, for instance:
[gtromano@gae-manj ~]$ skype
cannot query current apparmor profile: Invalid argument
This happens to be the same for all the other snap packages. Respectively, I have tested: Spotify, Zoom.
apparmor is running. Upon asking the aa-status
I get:
apparmor module is loaded.
28 profiles are loaded.
27 profiles are in enforce mode.
/usr/bin/akonadiserver
/usr/lib/snapd/snap-confine
/usr/lib/snapd/snap-confine//mount-namespace-capture-helper
/var/lib/snapd/snap/core/10577/usr/lib/snapd/snap-confine
/var/lib/snapd/snap/core/10577/usr/lib/snapd/snap-confine//mount-namespace-capture-helper
/var/lib/snapd/snap/snapd/10492/usr/lib/snapd/snap-confine
/var/lib/snapd/snap/snapd/10492/usr/lib/snapd/snap-confine//mount-namespace-capture-helper
dovecot-script-login
lsb_release
mariadbd_akonadi
mysqld_akonadi
nvidia_modprobe
nvidia_modprobe//kmod
php-fpm
postgresql_akonadi
snap-update-ns.core
snap-update-ns.overleaf
snap-update-ns.skype
snap-update-ns.ubports-installer
snap-update-ns.zoom-client
snap.core.hook.configure
snap.overleaf.overleaf
snap.ubports-installer.ubports-installer
snap.zoom-client.hook.configure
snap.zoom-client.zoom-client
torbrowser_firefox
torbrowser_tor
1 profiles are in complain mode.
snap.skype.skype
0 profiles are in kill mode.
0 profiles are in unconfined mode.
0 processes have profiles defined.
0 processes are in enforce mode.
0 processes are in complain mode.
0 processes are unconfined but have a profile defined.
0 processes are in mixed mode.
0 processes are in kill mode.
Any ideas on how to solve this?
Cheers
