I’m trying to install OCRmyPDF, which is only available for Manjaro through snap (I guess it could be installed manually somehow but it is beyond my python knowledge to do it). So, the snap install says it has worked correctly, and I can use the --help option ok. But when I try to run it properly I get
GPL Ghostscript 9.55.0: Can't find initialization file ghostscript.py:118
gs_init.ps
and indeed my ghostscript version is 10.02.00. What is the best tactic in this situation? I really don’t want to downgrade my ghostscript.
Thanks for any advice
Graham
