Hi every one,
I’m having issues running Eclipse recently.
After a few minutes running the IDE, I get the following error :
Unhandled event loop exception
No more handles
More details about the issue below.
I installed Eclipse(2012-19) via Snap and use OpenJDK8
Do you have any idea what could be the problem ?
Thank you for your time !
Adrien
Exception stack trace
org.eclipse.swt.SWTError: No more handles at org.eclipse.swt.SWT.error(SWT.java:4746) at org.eclipse.swt.SWT.error(SWT.java:4635) at org.eclipse.swt.SWT.error(SWT.java:4606) at org.eclipse.swt.graphics.Cursor.<init>(Cursor.java:217) at org.eclipse.swt.widgets.Display.getSystemCursor(Display.java:2858) at org.eclipse.e4.ui.workbench.renderers.swt.SashLayout.lambda$1(SashLayout.java:85) at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:216) at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:89) at org.eclipse.swt.widgets.Display.sendEvent(Display.java:5676) at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1423) at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4935) at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:4429) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1160) at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:338) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1049) at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:155) at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:660) at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:338) at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:559) at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:154) at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:150) at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:203) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:255) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:657) at org.eclipse.equinox.launcher.Main.basicRun(Main.java:594) at org.eclipse.equinox.launcher.Main.run(Main.java:1465) at org.eclipse.equinox.launcher.Main.main(Main.java:1438)
Session Data
eclipse.buildId=4.14.0.I20191210-0610 java.version=1.8.0_292 java.vendor=Oracle Corporation BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=fr_FR Framework arguments: -product org.eclipse.epp.package.java.product Command-line arguments: -os linux -ws gtk -arch x86_64 -product org.eclipse.epp.package.java.product
