Hi,
i ran “sudo snap install eiskaltdcpp”
on latest Manjaro (based on Arch, kernel 5.8.16-2-MANJARO) but when i then click the installed app menu entry to launch it, nothing happens (other snap app works good). I quickly looked into /var/log/ dmesg, journalctl and do not see anything related.
Do you have any suggestion? Also which DirectConnect (DC++) client do you suggest? I was unable to find any in official or AUR repo :-/ (eiskaltdcpp-gtk/qt is in AUR but building failed)
Thank you for your replies, though the Snap should be ready to run it, because I am launching other Snap powered app without problem. I tried yours mentioned commands and it not made it working.
I forgot i could try to run it from command line to discover some details. And indeed there are some errors, though i am unsure if it is supposed to be run like that:
$ eiskaltdcpp
Qt: Session management error: Authentication Rejected, reason : None of the authentication protocols specified are supported and host-based authentication failed
Installing handler for: Segmentation fault
Installing handler for: Aborted
Installing handler for: Bus error
Installing handler for: Terminated
Signal handlers installed.
Loading: Hash database
Loading: Shared Files
Loading: Download Queue
Loading: Users
UserList icons has been loaded
Application icons has been loaded
Fontconfig warning: FcPattern object weight does not accept value [40 210)
Catching signal : Segmentation fault
