I wanted to install the CD ripper fre:ac via snap. but I get the following error message:
snap install fre:ac
error: cannot install “fre:ac”: invalid instance name: invalid snap name: “fre:ac”
Is there a solution to install the program after all?
snap install fre:ac
RTFM (Read the Friendly Manual)
Install fre:ac
To install fre:ac, simply use the following command:
sudo snap install freac
– Install fre:ac on Manjaro Linux using the Snap Store | Snapcraft
Thank you very much
