johnd
1 December 2022 10:16
1
I have been using Linux for many years and now moving to Manjaro.
I have a Brother MFC 9340CDW printer.
On previous *buntu desktops I have gone https://support.brother.com/g/b/downloadhowto.aspx?c=us_ot&lang=en&prod=mfc9340cdw_all&os=127&dlid=dlf006893_000&flang=4&type3=625 and followed the instructions:
But for ARCH (Manjaro) there is no support for install.
I found [https://aur.archlinux.org/packages/brother-mfc-9340cdw ]
I have downloaded the files from here.
Right now I am unsure what needs to happen with them to get them installed so I can pick up my printer model.
Note - I have also tried to just install the printer via the add printer using IP address etc, but this specific printer is not listed. I believe it is a local (Australia Only) version.
Getting this printer to work is now my yes/no for ARCH Manjaro going forward.
Thanks in advance.
Hi @johnd , and welcome!
johnd:
Brother MFC 9340CDW
The driver for that printer is in the AUR:
$ pamac search 9340
brother-mfc-9340cdw 1.1.2_1-2 AUR
LPR and CUPS driver for the Brother MFC-9340CDW
So can be installed using:
pamac build brother-mfc-9340cdw
Please also see:
Hope it helps!
Zesko
1 December 2022 11:37
4
If you want to setup some scanner driver of Brother MFC printer:
SUMMARIZATION of how to install Scanner for brother printer
For example. To make the Scanner Brother MFC-L5750DW run via “Scanning to PC directly from Scanner” or “Scanning directly from PC with a Scanning software”, e.g. simple-scan, these steps should be considered:
This solution is not based on me but on @Zesko .
But there are so many questions and answer in the preceding conversations it should be very helpful for a searcher to have summarization.
1. Check what is the correct scanner dri…
