SmartCard Reader
Hi, i’m having troubles installing my HID Omnikey 3121. i have installed the drivers, pcsc_tools, and my browser doesn’t want to use the device, but when i run pcsc scan it works just fine.
Hello,
Have you also installed the AUR (en) - omnikey_ifdokccid
and then did you enabled the service?
systemctl enable pcscd.service
And once you reboot, all should be fine.
Sorry for the late reply, i just tried it and it still doesn’t want to log me in. Maybe FYI i’m using Brave browser if that helps
You can definitely try a different browser and see if that one works.
I got it working before, and i don’t want to try another browser at all
