y42nn
#1
Hey! I’m running manjaro KDE plasma on an Hp omen laptop (with a windows 10 dualboot) and I’m encountering some network issues
The wifi feels very unstable and the upload/download are often at 0 as you can see in the linked picture
Here are my drivers
mhwd -l ✔
> 0000:01:00.0 (0302:10de:1c8d) Display controller nVidia Corporation:
NAME VERSION FREEDRIVER TYPE
video-hybrid-intel-nvidia-prime 2021.11.04 false PCI
video-hybrid-intel-nvidia-470xx-prime 2021.11.04 false PCI
video-hybrid-intel-nvidia-390xx-bumblebee 2021.11.26 false PCI
video-nvidia 2021.11.04 false PCI
video-nvidia-470xx 2021.11.04 false PCI
video-nvidia-390xx 2021.11.26 false PCI
> 0000:05:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
network-r8168 2016.04.20 true PCI
> 0000:00:02.0 (0300:8086:591b) Display controller Intel Corporation:
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
and here are my network info
inxi -Nazy ✔
Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:095a class-ID: 0280
vendor: Hewlett-Packard driver: r8168 v: 8.050.03-NAPI modules: r8169 pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 05:00.0
Device-3: Intel Bluetooth wireless interface type: USB driver: btusb
bus-ID: 1-7:5 chip-ID: 8087:0a2a class-ID: e001
Thanks by advance for your help!
brahma
#2
your wifi is this:
and the r8168 is for ethernet…
post full system info:
inxi -Fazv7
and disable fast boot in bios - you may not have this option;
and disable fast startup in windows;
and test again
y42nn
#3
Thank you for your answer!
here are my full system infos
inxi -Fazv7 ✔
Kernel: 5.15.85-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=e98b2505-324f-4f80-b9bf-c1682286dd1e rw quiet
udev.log_priority=3
Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: HP product: OMEN by HP Laptop v: Type1ProductConfigId
Mobo: HP model: 8259 v: 83.72 serial: <superuser required> UEFI: Insyde
v: F.55 date: 07/01/2020
ID-1: BAT0 charge: 45.8 Wh (100.0%) condition: 45.8/45.8 Wh (100.0%)
volts: 17.1 min: 15.4 model: Hewlett-Packard Primary type: Li-ion
serial: N/A status: full
RAM: total: 7.65 GiB used: 2.54 GiB (33.3%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: Intel Core i5-7300HQ bits: 64 type: MCP arch: Kaby Lake
gen: core 7 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 9 microcode: 0xF0
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
desc: 1x6 MiB
Speed (MHz): avg: 1200 min/max: 800/3500 scaling: driver: intel_pstate
governor: powersave cores: 1: 1200 2: 1200 3: 1200 4: 1200 bogomips: 20004
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
disabled
prctl and seccomp
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: Intel HD Graphics 630 vendor: Hewlett-Packard driver: i915
v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:591b
class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Hewlett-Packard
driver: nvidia v: 525.60.11 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2022-12) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 2 speed: 5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1c8d class-ID: 0302
Device-3: Cheng Uei Precision Industry (Foxlink) HP Wide Vision HD
integrated webcam type: USB driver: uvcvideo bus-ID: 1-4:3
chip-ID: 05c8:038e class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.6 compositor: kwin_x11 driver: X:
loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa dri: iris
gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1013x285mm (39.88x11.22")
s-diag: 1052mm (41.43")
Monitor-1: HDMI-1-0 pos: right res: 1920x1080 dpi: 90
size: 544x303mm (21.42x11.93") diag: 623mm (24.52") modes: N/A
Monitor-2: eDP-1 pos: primary,left res: 1920x1080 hz: 60 dpi: 142
size: 344x194mm (13.54x7.64") diag: 395mm (15.55") modes: N/A
API: OpenGL v: 4.6 Mesa 22.3.1 renderer: Mesa Intel HD Graphics 630 (KBL
GT2) direct render: Yes
Device-1: Intel CM238 HD Audio vendor: Hewlett-Packard driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a171 class-ID: 0403
Device-2: NVIDIA GP107GL High Definition Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:0fb9 class-ID: 0403
Sound API: ALSA v: k5.15.85-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.63 running: yes
Local Storage: total: 931.51 GiB used: 83.76 GiB (9.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM049-2GH172
type: HDD rpm: 7200 serial: <filter> rev: RXM3 scheme: GPT
ID-1: / raw-size: 265.2 GiB size: 259.98 GiB (98.03%)
used: 83.68 GiB (32.2%) fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: e98b2505-324f-4f80-b9bf-c1682286dd1e
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 79.4 MiB (31.0%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: D430-3A3A
ID-1: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/sda3 maj-min: 8:3 size: 666.04 GiB fs: ntfs label: Windows
uuid: 0CA899A3A8998C38
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Hub-2: 1-1:2 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 1-1.1:4 info: Razer USA Goliathus type: Mouse,Keyboard
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 1532:0c01 class-ID: 0300
Device-2: 1-1.2:6 info: Razer USA RZ01-0213 Gaming Mouse [Lancehead
Tournament Edition] type: Mouse,Keyboard driver: hid-generic,usbhid
interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 500mA chip-ID: 1532:0060
class-ID: 0300
Device-3: 1-1.3:8 info: Keychron Q2 type: Keyboard,HID
power: 500mA chip-ID: 3434:0113 class-ID: 0300
Device-4: 1-1.4:7 info: Razer USA Laptop Stand Chroma type: Mouse,Keyboard
power: 500mA chip-ID: 1532:0f0d class-ID: 0300
Device-5: 1-4:3 info: Cheng Uei Precision Industry (Foxlink) HP Wide
Vision HD integrated webcam type: Video driver: uvcvideo interfaces: 2
rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 05c8:038e class-ID: 0e02
serial: <filter>
Device-6: 1-7:5 info: Intel Bluetooth wireless interface type: Bluetooth
Hub-3: 2-0:1 info: Super-speed hub ports: 8 rev: 3.0 speed: 5 Gb/s
Hub-4: 2-1:2 info: Genesys Logic GL3523 Hub ports: 4 rev: 3.1
speed: 5 Gb/s chip-ID: 05e3:0620 class-ID: 0900
System Temperatures: cpu: 47.0 C pch: 39.5 C mobo: N/A
Processes: 226 Uptime: 26m wakeups: 1 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: pm: pacman pkgs: 1601 libs: 401 tools: pamac,yay pm: flatpak
pkgs: 0 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.24
what’s strange is that in mhwd -l, I don’t seem to have the intel wifi driver installed
I’ll try disabling fast boot and fast startup
iwlwifi is in the kernel and doesn’t need to be installed additionally.
You could try a few power settings. Check the arch wiki for this.
brahma
#5
yes you have the driver:
so if disabling fast boot and fast startup didnt helped, try switching kernel…
also provide output from:
rfkill list
