Slow wifi speeds, inxi shows that intel ax200 is down, desktop computer is using stock dual band card
Morning everyone,
I’ve been using Manjaro for about a week or two and noticed that my wifi speeds were less than on my windows partition, runing the inxi-v7azy command shows me the two wifi cards that are installed in my system, becuase why wouldn’t I have two in my cobbled together stack. However, the intel AX200 that I normally use for wifi (stupid wifi 6 router) is shown in a down state and the stock intel card which is still used for bluetooth is handling both but not very well.
I couldn’t find the options to choose between the cards in settings, I’ve tried adding the driver files from intel to the config files themselves and I’ve turned fast boot and secure boot off. I’ve not seen anything on the forum recently that would make me think its a kernel issue but it could be.
Below is my system info from the v7azy commmand. I’ve used linux before but these are my fist steps with manjaro. Thanks for any help you can give.
inxi -v7azy         ✔
  Kernel: 6.1.41-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    root=UUID=43d487f3-6fa0-4934-9323-e358ecc55973 rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.6 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2 dm: SDDM
  Type: Desktop System: Tactus product: Customised Horizon-M 1a PC v: N/A
    serial: <superuser required>
  Mobo: Gigabyte model: B550M DS3H AC v: x.x serial: <superuser required>
    BIOS: American Megatrends LLC. v: F15c date: 05/11/2022
  Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K270
    serial: <filter> charge: 100% (should be ignored) rechargeable: yes
    status: discharging
  System RAM: total: 16 GiB available: 15.47 GiB used: 2.19 GiB (14.1%)
  Info: model: AMD Ryzen 5 4500 bits: 64 type: MT MCP arch: Zen 2 gen: 3
    level: v3 note: check built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
    model-id: 0x60 (96) stepping: 1 microcode: 0x8600106
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
    desc: 2x4 MiB
  Speed (MHz): avg: 2089 high: 3600 min/max: 1400/4208 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3600 2: 1400
    3: 1400 4: 1717 5: 3298 6: 1400 7: 1400 8: 3055 9: 1400 10: 1400 11: 3600
    12: 1400 bogomips: 86277
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
    pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
    rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
    sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
    tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
    wbnoinvd wdt x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt
  Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
    protection
  Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
    always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: NVIDIA GA106 [Geforce RTX 3050] vendor: Gigabyte driver: nvidia
    v: 535.86.05 alternate: nouveau,nvidia_drm non-free: 535.xx+
    status: current (as of 2023-07) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 8
    link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0
    chip-ID: 10de:2507 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.2
    compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
    screens: 1
  Screen-1: 0 s-res: 1360x768 s-dpi: 31 s-size: 1114x629mm (43.86x24.76")
    s-diag: 1279mm (50.37") monitors: <missing: xrandr>
  API: OpenGL v: 4.6.0 NVIDIA 535.86.05 renderer: NVIDIA GeForce RTX
    3050/PCIe/SSE2 direct-render: Yes
  Device-1: NVIDIA GA106 High Definition Audio vendor: Gigabyte
    driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max:
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:228e
    class-ID: 0403
  Device-2: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
    speed: 16 GT/s bus-ID: 08:00.1 chip-ID: 1002:1637 class-ID: 0403
  Device-3: AMD Family 17h/19h HD Audio vendor: Gigabyte
    link-max: gen: 4 speed: 16 GT/s bus-ID: 08:00.6 chip-ID: 1022:15e3
    class-ID: 0403
  API: ALSA v: k6.1.41-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.75 status: off with: wireplumber status: active
    tools: pw-cli,wpctl
  Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
  IF: wlp4s0 state: down mac: <filter>
  Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 05:00.0
    chip-ID: 8086:24fb class-ID: 0280
  Device-3: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
    lanes: 1 port: e000 bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp6s0 state: down mac: <filter>
  Device-1: Intel Wireless-AC 3168 Bluetooth driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:4 chip-ID: 8087:0aa7
    class-ID: e001
  Local Storage: total: 2.27 TiB used: 15.93 GiB (0.7%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: MSI model: M390 500GB
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: EHFM31.1 temp: 27.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2UB102
    tech: HDD rpm: 7200 serial: <filter> fw-rev: 0001 scheme: GPT
  ID-1: / raw-size: 97.66 GiB size: 95.56 GiB (97.86%) used: 15.93 GiB (16.7%)
    fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
    uuid: 43d487f3-6fa0-4934-9323-e358ecc55973
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 450 MiB fs: ntfs label: WINRE
    uuid: 1E0257B60257921F
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 260 MiB fs: vfat label: SYSTEM
    uuid: DE58-2611
  ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 366.78 GiB fs: ntfs
    label: Windows uuid: 705058E65058B516
  ID-5: /dev/nvme0n1p5 maj-min: 259:5 size: 629 MiB fs: ntfs label: N/A
    uuid: 380EF4B40EF46C6E
  ID-6: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
  ID-7: /dev/sda2 maj-min: 8:2 size: 1.82 TiB fs: ntfs
    label: Big ol' fashioned uuid: A6A8A237A8A205C1
  Device-1: 1-2:2 info: Logitech Unifying Receiver type: keyboard,mouse,HID
    driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
    chip-ID: 046d:c52b class-ID: 0300
  Device-2: 1-5:3 info: Logitech G203 LIGHTSYNC Gaming Mouse type: mouse,HID
    lanes: 1 mode: 1.1 power: 300mA chip-ID: 046d:c09d class-ID: 0300
    serial: <filter>
  Device-3: 1-9:4 info: Intel Wireless-AC 3168 Bluetooth type: bluetooth
    mode: 1.1 power: 100mA chip-ID: 8087:0aa7 class-ID: e001
  Device-4: 1-10:5 info: Integrated Express RGB LED Controller type: HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:5702 class-ID: 0300
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 5-2:2 info: Wacom CTE-640 [Graphire4 (6x8)] type: mouse
    driver: usbhid,wacom interfaces: 1 rev: 1.0 speed: 1.5 Mb/s (183 KiB/s)
    lanes: 1 mode: 1.0 power: 40mA chip-ID: 056a:0016 class-ID: 0301
  Hub-6: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
  System Temperatures: cpu: 31.6 C mobo: N/A gpu: nvidia temp: 42 C
  Processes: 296 Uptime: 2m wakeups: 2 Init: systemd v: 253 default: graphical
  tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: 1192
  pm: pacman pkgs: 1186 libs: 367 tools: pamac pm: flatpak pkgs: 6 Shell: Zsh
  v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.28
Hi and welcome to the Forum :+1:
According to [SOLVED] Wifi very slow - Intel(R) Dual Band Wireless AC 3168 / Newbie Corner / Arch Linux Forums, you need to use wpa_supplicant instead of iw
(Research via a search engine helps) :face_with_hand_over_mouth:
When you mention things like that it is advisable to give concrete data of what you did and where. eg. file contents or program output, so the readers who want/can help you can check if you made a mistake.
Just in case your bluetooth on that device doesn’t work: https://superuser.com/questions/1568192/intel-dual-band-wireless-ac-3168-bluetooth-in-debian-10-dont-work#1568872
Welp, thanks for all your help and the warm welcome. I’ve got this working now so I’ll close it and hopefully if someone has the same noob issues as me they can use this to help.
I have two wifi adaptors, one can’t handle wifi6, one can. if your internet speed is slow, check in the list of networks that you can connect to that you are connecting with the correct adaptor…
such a simple obvious solution, that I didn’t even notice or consider it.
If your wifi worked fine and then stopped working, this could well be the issue
