I can’t connect to the 5gz signal and the 2.5gz is quite slow (reaches about 2mbps). I have dual boot with windows and there it works normally (reaches more than 100mbps).
inxi -N:
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8168
Device-2: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter driver: rtw_8821ce
inxi -v7azy
Kernel: 5.10.102-1-MANJARO x86_64 bits: 64 compiler: N/A
root=UUID=f2fe6683-cd78-4121-9bb4-25daa5b1ab25 rw quiet apparmor=1
Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.1 info: latte-dock wm: kwin_x11
dm: SDDM Distro: Manjaro Linux
Type: Laptop System: ASUSTeK product: TUF Gaming FX705DT_FX705DT v: 1.0
serial: <filter>
Mobo: ASUSTeK model: FX705DT v: 1.0 serial: <filter>
UEFI: American Megatrends v: FX705DT.316 date: 01/28/2021
ID-1: BAT0 charge: 46.6 Wh condition: 48.3/64.1 Wh (75%) volts: 16.8/15.6
model: FX70542 type: Li-ion serial: N/A status: Charging
Device-1: apple_mfi_fastcharge model: N/A serial: N/A charge: N/A
status: N/A
RAM: total: 7.64 GiB used: 3.41 GiB (44.7%)
Topology: Quad Core model: AMD Ryzen 5 3550H with Radeon Vega Mobile Gfx
bits: 64 type: MT MCP arch: Zen+ family: 17 (23) model-id: 18 (24)
stepping: 1 microcode: 8108102 L2 cache: 2048 KiB bogomips: 33551
Speed: 1267 MHz min/max: 1400/2100 MHz boost: enabled Core speeds (MHz):
1: 1242 2: 1252 3: 1695 4: 1444 5: 1249 6: 1298 7: 1316 8: 1281
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca
mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme
smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce
topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt
disabled, RSB filling
Device-1: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: ASUSTeK
driver: nvidia v: 510.54 alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:1f91
Device-2: AMD Picasso vendor: ASUSTeK driver: amdgpu v: kernel
bus ID: 05:00.0 chip ID: 1002:15d8
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus ID: 3-1:2 chip ID: 13d3:56a2 serial: <filter>
Display: x11 server: X.Org 1.20.9 compositor: kwin_x11 driver: amdgpu,nvidia
FAILED: ati unloaded: modesetting,nouveau alternate: fbdev,nv,vesa
display ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 128 size: 382x215mm (15.0x8.5")
diag: 438mm (17.3")
OpenGL: renderer: AMD RAVEN (DRM 3.40.0 5.10.102-1-MANJARO LLVM 10.0.1)
v: 4.6 Mesa 20.1.8 direct render: Yes
Device-1: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus ID: 01:00.1 chip ID: 10de:10fa
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus ID: 05:00.6 chip ID: 1022:15e3
Sound Server: ALSA v: k5.10.102-1-MANJARO
vendor: ASUSTeK driver: r8168 v: 8.049.02-NAPI modules: r8169 port: e000
bus ID: 02:00.0 chip ID: 10ec:8168
vendor: AzureWave driver: rtw_8821ce v: N/A modules: rtw88_8821ce port: d000
bus ID: 04:00.0 chip ID: 10ec:c821
IF: wlp4s0 state: up mac: <filter>
IF-ID-1: enp5s0f3u3c4i2 state: down mac: <filter>
Local Storage: total: 476.94 GiB used: 34.81 GiB (7.3%)
ID-1: /dev/nvme0n1 vendor: Intel model: SSDPEKNW512G8 size: 476.94 GiB
block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
serial: <filter> rev: 002C scheme: GPT
ID-1: / raw size: 81.80 GiB size: 80.02 GiB (97.82%) used: 34.78 GiB (43.5%)
fs: ext4 dev: /dev/nvme0n1p5 label: N/A
uuid: f2fe6683-cd78-4121-9bb4-25daa5b1ab25
ID-2: /boot/efi raw size: 260.0 MiB size: 256.0 MiB (98.46%)
used: 28.0 MiB (11.0%) fs: vfat dev: /dev/nvme0n1p1 label: SYSTEM
uuid: E851-1186
ID-1: /dev/nvme0n1p2 size: 16.0 MiB fs: <superuser/root required> label: N/A
uuid: N/A
ID-2: /dev/nvme0n1p3 size: 394.03 GiB fs: ntfs label: OS
uuid: E08852F28852C726
ID-3: /dev/nvme0n1p4 size: 850.0 MiB fs: ntfs label: RECOVERY
uuid: D07C3FAD7C3F8D6A
Hub: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0 speed: 480 Mb/s
chip ID: 1d6b:0002
Device-1: 1-2:2 info: Razer USA DeathAdder Elite type: Mouse,Keyboard
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
chip ID: 1532:005c
Device-2: 1-3:3 info: Apple iPhone 5/5C/5S/6/SE type: Still Imaging
driver: ipheth,usbfs interfaces: 3 rev: 2.0 speed: 480 Mb/s
chip ID: 05ac:12a8 serial: <filter>
Device-3: 1-4:4 info: IMC Networks Bluetooth Radio type: Bluetooth
driver: N/A interfaces: 2 rev: 1.1 speed: 12 Mb/s chip ID: 13d3:3530
serial: <filter>
Hub: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
chip ID: 1d6b:0003
Hub: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s
chip ID: 1d6b:0002
Device-1: 3-1:2 info: IMC Networks USB2.0 HD UVC WebCam type: Video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s chip ID: 13d3:56a2
serial: <filter>
Device-2: 3-2:3 info: Logitech Wireless Receiver type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
chip ID: 046d:c542
Hub: 4-0:1 info: Full speed (or root) Hub ports: 1 rev: 3.1 speed: 10 Gb/s
chip ID: 1d6b:0003
System Temperatures: cpu: 51.1 C mobo: N/A gpu: amdgpu temp: 51 C
Fan Speeds (RPM): cpu: 2400
Processes: 291 Uptime: 16m Init: systemd v: 246 Compilers: gcc: 10.2.0
clang: N/A Packages: 1274 pacman: 1265 lib: 348 flatpak: 0 snap: 9
Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.05
New Manjaro user ![]()
