Hi there, I just switched to manjaro at the weekend. So far it has been a pleasant experience except a very slow wifi connection. Here is my system info:
System: Kernel: 5.14.10-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0 Desktop: KDE Plasma 5.22.5
tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Machine: Type: Desktop Mobo: Micro-Star model: MPG Z390I GAMING EDGE AC (MS-7C04) v: 1.0 serial: <filter>
UEFI: American Megatrends v: 1.80 date: 05/25/2020
CPU: Info: 6-Core model: Intel Core i5-9400F bits: 64 type: MCP arch: Kaby Lake note: check rev: A cache:
L2: 9 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 34814
Speed: 995 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 995 2: 800 3: 800 4: 800 5: 800 6: 800
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
vendor: ASRock driver: amdgpu v: kernel bus-ID: 03:00.0 chip-ID: 1002:731f class-ID: 0300
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: amdgpu resolution: 1920x1080
s-dpi: 96
OpenGL: renderer: AMD Radeon RX 5700 XT (NAVI10 DRM 3.42.0 5.14.10-1-MANJARO LLVM 12.0.1)
v: 4.6 Mesa 21.2.3 direct render: Yes
Audio: Device-1: Intel Cannon Lake PCH cAVS vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: Advanced Micro Devices [AMD/ATI] Navi 10 HDMI Audio driver: snd_hda_intel v: kernel
bus-ID: 03:00.1 chip-ID: 1002:ab38 class-ID: 0403
Sound Server-1: ALSA v: k5.14.10-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Network: Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:a370 class-ID: 0280
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI driver: r8169
v: kernel port: 3000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp5s0 state: down mac: <filter>
Bluetooth: Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB driver: btusb v: 0.8
bus-ID: 1-14:4 chip-ID: 8087:0aaa class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running rfk-block: hardware: no
software: yes address: see --recommends
Drives: Local Storage: total: 1.84 TiB used: 653.91 GiB (34.7%)
ID-1: /dev/nvme0n1 vendor: A-Data model: SX8200PNP size: 953.87 GiB speed: 31.6 Gb/s lanes: 4
type: SSD serial: <filter> rev: 42AZS6AC temp: 34.9 C scheme: GPT
ID-2: /dev/sda vendor: SanDisk model: SDSSDH3 1T00 size: 931.51 GiB speed: 6.0 Gb/s type: SSD
serial: <filter> rev: 00RL scheme: GPT
Partition: ID-1: / size: 937.53 GiB used: 133.24 GiB (14.2%) fs: ext4 dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.4 MiB used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1
Swap: Alert: No swap data was found.
Sensors: System Temperatures: cpu: 41.0 C mobo: N/A gpu: amdgpu temp: 46.0 C mem: 48.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Info: Processes: 234 Uptime: 38m wakeups: 0 Memory: 15.57 GiB used: 2.21 GiB (14.2%) Init: systemd v: 249
Compilers: gcc: 11.1.0 Packages: pacman: 1259 Shell: Zsh v: 5.8 default: Bash v: 5.1.8
running-in: konsole inxi: 3.3.08
I tried the fix suggested in a previous thread on this topic, creating the file /etc/modprobe.d/iwlwifi.conf with the contents
options iwlwifi bt_coex_active=0 swcrypto=1 11n_disable=8
I also tried disabling IPv6 by setting it to ‘ignored’ in the Connections section of the KDE system settings and hard resetting the router (as I have seen those tips in other threads). None of these fixes seemed to work.
I have confirmed the internet speed over wifi is performing as it should on another device. I am not able to permanently connect via wired ethernet. However, I tried this and got the full speed I expected to see.
Curiously, I downloaded a game through steam and at certain points saw download speeds equal to the maximum I saw on windows. Zoom, the software centre and firefox, however, behave in line with the measured download speed.
Also, using the speed test by ookla website I saw upload speeds at the normal level for the connection. The download speeds seem to be either 1/3 or 1/2 of the expected value, depending on what server the speed test tool connects to. That they are fairly precise fractions suggests there is some connection parameter I could tweak to get this sorted.
Any thoughts on this welcome and apologies if I failed to follow the proper posting beginners guide - I promise I tried!
