Hello People,
I got a very confusing problem with the Wi-Fi on my fresh install of Manjaro. My download speed is roughly hitting 2Mbps, despite being between 30…40Mbps in the live-session. Ping and upload speeds seem fine in both systems (Ping: 15…30ms | Upload: 10…17Mbps). Also with cable my LAN is hitting top values (Ping: 16…30ms | Download: >250Mbps | Upload: >24Mbps).
I already tried comparing the live-session with my installed system, but as far as I can tell both are using the ath9k
-driver and the same 5.9.16-1-MANJARO
-kernel. Although I had to switch back to it on my installed system from the 5.10.23-1-MANJARO
-kernel, but it didn’t solve the problem, alhtough at one point the speed was shortly back up at 30…40Mbps, but this didn’t last. I also tried a variety of other kernels (5.10.26
, 5.11.10
, 5.4.108
, 4.19.183
, 4.14.22
), but there where no changes worth noting. I also checked live-sessions of other OSs like EndeavourOS, Bluestar Linux, ArcoLinux and Artix Linux, but it’s the same all along. The Wi-Fi is just working fine on the live-sessions.
My inxi
-output is as follows:
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=0c4f928e-f663-494f-9746-59b1340bcc02 rw quiet udev.log_priority=3
Desktop: KDE Plasma 5.21.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Acer product: Aspire E1-572G v: V2.13 serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Acer model: EA50_HW v: V2.13 serial: <filter> UEFI: Insyde v: 2.13
date: 11/21/2013
ID-1: BAT1 charge: 16.6 Wh (100.0%) condition: 16.6/37.0 Wh (44.8%)
volts: 16.7 min: 14.8 model: SANYO AL12A32 type: Li-ion serial: <filter>
status: Full
RAM: total: 7.66 GiB used: 3.91 GiB (51.0%)
Info: Dual Core model: Intel Core i5-4200U bits: 64 type: MT MCP
arch: Haswell family: 6 model-id: 45 (69) stepping: 1 microcode: 26 cache:
L2: 3 MiB bogomips: 18366
Speed: 2281 MHz min/max: 800/2600 MHz Core speeds (MHz): 1: 2281 2: 2295
3: 2295 4: 2286
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2 bts
clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm
dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase
fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce md_clear mmx
monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good
sdbg sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid xsave
xsaveopt xtopology xtpr
Type: l1tf
Device-1: Intel Haswell-ULT Integrated Graphics
vendor: Acer Incorporated ALI driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:0a16 class-ID: 0300
Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430 / Radeon
520 Mobile]
vendor: Acer Incorporated ALI driver: radeon v: kernel alternate: amdgpu
bus-ID: 03:00.0 chip-ID: 1002:6660 class-ID: 0380
Device-3: Chicony HD WebCam (Acer) type: USB driver: uvcvideo bus-ID: 2-8:3
chip-ID: 04f2:b3f6 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
loaded: ati,intel,radeon unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4400 (HSW GT2)
v: 4.5 Mesa 21.0.1 compat-v: 3.0 direct render: Yes
Device-1: Intel Haswell-ULT HD Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:0a0c
class-ID: 0403
Device-2: Intel 8 Series HD Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9c20
class-ID: 0403
Sound Server-1: ALSA v: k5.9.16-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.24 running: no
Device-1: Broadcom NetXtreme BCM57786 Gigabit Ethernet PCIe
vendor: Acer Incorporated ALI driver: tg3 v: kernel port: 4040
bus-ID: 01:00.0 chip-ID: 14e4:16b3 class-ID: 0200
IF: enp1s0f0 state: down mac: <filter>
Device-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
vendor: Lite-On driver: ath9k v: kernel port: 4040 bus-ID: 02:00.0
chip-ID: 168c:0036 class-ID: 0280
Device-1: Lite-On Atheros AR3012 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 2-5:4 chip-ID: 04ca:300b class-ID: e001
Message: No LVM data was found.
Local Storage: total: 931.51 GiB used: 440.48 GiB (47.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10JPVX-22JC3T0
rotation: 5400 rpm serial: <filter> rev: 1A01 scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GUA0N rev: 1.00
dev-links: cdrom
ID-1: / raw-size: 32 GiB size: 31.2 GiB (97.50%) used: 7.65 GiB (24.5%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: Root
uuid: 0c4f928e-f663-494f-9746-59b1340bcc02
used: 296 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: SYSTEM-EFI
uuid: AA28-E087
ID-3: /home raw-size: 881.6 GiB size: 866.69 GiB (98.31%)
used: 432.83 GiB (49.9%) fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: Home
uuid: e5cff958-6efd-4ccb-9718-ab1fb578dd06
ID-1: /dev/sda3 maj-min: 8:3 size: 17.6 GiB fs: swap label: Swap
uuid: 38b15890-6274-43cf-9c5f-f38694f3905e
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:8000 class-ID: 0900
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 9 rev: 2.0
Device-1: 2-5:4 info: Lite-On Atheros AR3012 Bluetooth type: Bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 100mA
Device-2: 2-8:3 info: Chicony HD WebCam (Acer) type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b3f6
Hub-4: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 48.0 C mobo: N/A gpu: radeon temp: 40.0 C
Processes: 180 Uptime: 2h 08m wakeups: 2 Init: systemd v: 247
tool: systemctl Compilers: gcc: N/A Packages: pacman: 1033 lib: 286
Shell: Bash v: 5.1.0 running-in: konsole inxi: 3.3.03
I will provide the output of my system in the live-session also, after I have booted into it again.
I want to mention, that I consider myself a linux and manjaro beginner and maybe got things wrong diagnosing my system, so please feel free to double check and ask redundant questions. I will go through steps again, I think I’ve taken already, if you ask me to do so. This said, I want to thank you in advance for your help, time and patience
