I discovered this part later on when playing with grub default haha.
But also the script was to force the computer to choose s2idle. the system defaults to deep(s3)
I’ll give the older kernel a try, if it doesn’t work should I try ubuntu? a couple different versions? and if one of those ubuntu versions does work how difficult do you think it would be to find the patches that ubuntu applies and make them work with arch?
the remainder of this post is from after switching kernels
I tried with linux54 and linux419 as that was the oldest one offered to me. I’ll try with a fiew of the other fives to make sure the problem persists but so far no change. I did notice however that some of those bluetooth errors and other things I was seeing in dmesg appear to have gone away with the 419 kernel but I’m not certain that was the kernel or the reinstall
I’m going to add the dmesg output for everything since suspend and then also just the whole dmesg output since the system had only been up for 40 seconds before running it. It’s still incredibly dense and rather long but I’ve been looking through it seeing if maybe there are any clues as to what’s going wrong before the suspend command is given. I think the only relevant looking error in dmesg is at 26.776012
where there’s an error in resume but that’s related to the usb hub so I’m not sure if it’s actually something I should take seriously
Is my next step after trying the remaining 5** kernels to try the different versions of ubuntu from around the time of my device? also that link you added looks correct here’s the output of inxi -M
for model info
Type: Laptop System: LENOVO product: 20L50018US v: ThinkPad T480
Mobo: LENOVO model: 20L50018US v: SDK0J40697 WIN serial: L1HF8A900EB
UEFI: LENOVO v: N24ET76W (1.51 ) date: 02/27/2024
(note: I tested suspend a couple of times, it’s difficult to see where one starts/stops I think I actually included two tests in the suspend only dmesg output)
Suspend Only Dmesg Out:
[ 25.199975] PM: suspend entry (deep)
[ 25.199977] PM: Syncing filesystems ... done.
[ 25.211465] Freezing user space processes ... (elapsed 0.015 seconds) done.
[ 25.227025] OOM killer disabled.
[ 25.227026] Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
[ 25.228185] Suspending console(s) (use no_console_suspend to debug)
[ 25.298507] e1000e: EEE TX LPI TIMER: 00000011
[ 25.658213] ACPI: EC: interrupt blocked
[ 25.978217] ACPI: Preparing to enter system sleep state S3
[ 25.987411] ACPI: EC: event blocked
[ 25.987412] ACPI: EC: EC stopped
[ 25.987414] PM: Saving platform NVS memory
[ 25.987425] Disabling non-boot CPUs ...
[ 26.049978] smpboot: CPU 1 is now offline
[ 26.108769] smpboot: CPU 2 is now offline
[ 26.148758] smpboot: CPU 3 is now offline
[ 26.199328] smpboot: CPU 4 is now offline
[ 26.248664] smpboot: CPU 5 is now offline
[ 26.298572] smpboot: CPU 6 is now offline
[ 26.338554] smpboot: CPU 7 is now offline
[ 26.344504] ACPI: Low-level resume complete
[ 26.344549] ACPI: EC: EC started
[ 26.344549] PM: Restoring platform NVS memory
[ 26.345153] Enabling non-boot CPUs ...
[ 26.345186] x86: Booting SMP configuration:
[ 26.345187] smpboot: Booting Node 0 Processor 1 APIC 0x2
[ 26.345597] cache: parent cpu1 should not be sleeping
[ 26.345732] CPU1 is up
[ 26.345753] smpboot: Booting Node 0 Processor 2 APIC 0x4
[ 26.346158] cache: parent cpu2 should not be sleeping
[ 26.346301] CPU2 is up
[ 26.346319] smpboot: Booting Node 0 Processor 3 APIC 0x6
[ 26.346725] cache: parent cpu3 should not be sleeping
[ 26.346876] CPU3 is up
[ 26.346892] smpboot: Booting Node 0 Processor 4 APIC 0x1
[ 26.347372] cache: parent cpu4 should not be sleeping
[ 26.347703] CPU4 is up
[ 26.347721] smpboot: Booting Node 0 Processor 5 APIC 0x3
[ 26.348122] cache: parent cpu5 should not be sleeping
[ 26.348284] CPU5 is up
[ 26.348300] smpboot: Booting Node 0 Processor 6 APIC 0x5
[ 26.348701] cache: parent cpu6 should not be sleeping
[ 26.348874] CPU6 is up
[ 26.348892] smpboot: Booting Node 0 Processor 7 APIC 0x7
[ 26.349301] cache: parent cpu7 should not be sleeping
[ 26.349484] CPU7 is up
[ 26.355288] ACPI: Waking up from system sleep state S3
[ 26.464754] ACPI: EC: interrupt unblocked
[ 26.772491] ACPI: EC: event unblocked
[ 26.776012] xhci_hcd 0000:3c:00.0: xHC error in resume, USBSTS 0x401, Reinit
[ 26.776017] usb usb3: root hub lost power or was reset
[ 26.776020] usb usb4: root hub lost power or was reset
[ 26.887080] usb 2-3: Disable of device-initiated U1 failed.
[ 26.890543] usb 2-3: Disable of device-initiated U2 failed.
[ 27.120539] usb 2-3: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[ 27.300351] usb 1-8: reset high-speed USB device number 3 using xhci_hcd
[ 27.630465] usb 1-7: reset full-speed USB device number 2 using xhci_hcd
[ 27.879683] thunderbolt 0000:06:00.0: control channel starting...
[ 27.879687] thunderbolt 0000:06:00.0: starting TX ring 0
[ 27.879698] thunderbolt 0000:06:00.0: enabling interrupt at register 0x38200 bit 0 (0x0 -> 0x1)
[ 27.879700] thunderbolt 0000:06:00.0: starting RX ring 0
[ 27.879710] thunderbolt 0000:06:00.0: enabling interrupt at register 0x38200 bit 12 (0x1 -> 0x1001)
[ 27.890328] acpi LNXPOWER:01: Turning OFF
[ 27.890978] OOM killer enabled.
[ 27.890979] Restarting tasks ...
[ 27.893134] Bluetooth: hci0: Bootloader revision 0.0 build 26 week 38 2015
[ 27.893338] done.
[ 27.894097] Bluetooth: hci0: Device revision is 16
[ 27.894100] Bluetooth: hci0: Secure boot is enabled
[ 27.894102] Bluetooth: hci0: OTP lock is enabled
[ 27.894104] Bluetooth: hci0: API lock is enabled
[ 27.894106] Bluetooth: hci0: Debug lock is disabled
[ 27.894109] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[ 27.900638] Bluetooth: hci0: Found device firmware: intel/ibt-12-16.sfi
[ 27.920033] usb 1-9: USB disconnect, device number 4
[ 27.945916] PM: suspend exit
[ 27.950199] pci_bus 0000:06: Allocating resources
[ 27.950212] pci_bus 0000:3c: Allocating resources
[ 27.950272] pci_bus 0000:06: Allocating resources
[ 27.950283] pci_bus 0000:3c: Allocating resources
[ 28.070261] e1000e: enp0s31f6 NIC Link is Down
[ 28.071191] IPv6: ADDRCONF(NETDEV_UP): enp0s31f6: link is not ready
[ 28.080035] usb 1-9: new full-speed USB device number 5 using xhci_hcd
[ 28.272090] usb 1-9: New USB device found, idVendor=06cb, idProduct=009a, bcdDevice= 1.64
[ 28.272092] usb 1-9: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[ 28.272093] usb 1-9: SerialNumber: a6fd98866605
[ 28.310330] IPv6: ADDRCONF(NETDEV_UP): enp0s31f6: link is not ready
[ 28.316653] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready
[ 28.878752] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready
[ 29.483585] Bluetooth: hci0: Waiting for firmware download to complete
[ 29.484145] Bluetooth: hci0: Firmware loaded in 1554709 usecs
[ 29.484352] Bluetooth: hci0: Waiting for device to boot
[ 29.497187] Bluetooth: hci0: Device booted in 12658 usecs
[ 29.502049] Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-12-16.ddc
[ 29.505154] Bluetooth: hci0: Applying Intel DDC parameters completed
[ 32.201938] wlp3s0: authenticate with c0:94:35:6d:6a:3d
[ 32.214944] wlp3s0: send auth to c0:94:35:6d:6a:3d (try 1/3)
[ 32.221749] wlp3s0: authenticated
[ 32.230138] wlp3s0: associate with c0:94:35:6d:6a:3d (try 1/3)
[ 32.237118] wlp3s0: RX AssocResp from c0:94:35:6d:6a:3d (capab=0x1011 status=0 aid=5)
[ 32.240499] wlp3s0: associated
[ 32.256591] IPv6: ADDRCONF(NETDEV_CHANGE): wlp3s0: link becomes ready
[ 32.299390] wlp3s0: Limiting TX power to 30 (30 - 0) dBm as advertised by c0:94:35:6d:6a:3d
[ 34.663994] wlp3s0: deauthenticating from c0:94:35:6d:6a:3d by local choice (Reason: 3=DEAUTH_LEAVING)
[ 34.674516] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready
[ 34.752343] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready
[ 35.038069] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready
[ 35.055246] PM: suspend entry (deep)
[ 35.055248] PM: Syncing filesystems ... done.
[ 35.060696] Freezing user space processes ... (elapsed 0.099 seconds) done.
[ 35.160230] OOM killer disabled.
[ 35.160232] Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
[ 35.161692] Suspending console(s) (use no_console_suspend to debug)
[ 35.231674] e1000e: EEE TX LPI TIMER: 00000011
[ 35.610995] thunderbolt 0000:06:00.0: stopping RX ring 0
[ 35.611153] ACPI: EC: interrupt blocked
[ 35.611199] thunderbolt 0000:06:00.0: disabling interrupt at register 0x38200 bit 12 (0x1001 -> 0x1)
[ 35.611229] thunderbolt 0000:06:00.0: stopping TX ring 0
[ 35.611241] thunderbolt 0000:06:00.0: disabling interrupt at register 0x38200 bit 0 (0x1 -> 0x0)
[ 35.611260] thunderbolt 0000:06:00.0: control channel stopped
[ 35.921307] ACPI: Preparing to enter system sleep state S3
[ 35.930400] ACPI: EC: event blocked
[ 35.930402] ACPI: EC: EC stopped
[ 35.930403] PM: Saving platform NVS memory
[ 35.930414] Disabling non-boot CPUs ...
[ 35.972984] smpboot: CPU 1 is now offline
[ 36.011817] smpboot: CPU 2 is now offline
[ 36.051806] smpboot: CPU 3 is now offline
[ 36.112379] smpboot: CPU 4 is now offline
[ 36.151683] smpboot: CPU 5 is now offline
[ 36.191609] smpboot: CPU 6 is now offline
[ 36.231579] smpboot: CPU 7 is now offline
[ 36.236721] ACPI: Low-level resume complete
[ 36.236768] ACPI: EC: EC started
[ 36.236768] PM: Restoring platform NVS memory
[ 36.237372] Enabling non-boot CPUs ...
[ 36.237405] x86: Booting SMP configuration:
[ 36.237406] smpboot: Booting Node 0 Processor 1 APIC 0x2
[ 36.237824] cache: parent cpu1 should not be sleeping
[ 36.237949] CPU1 is up
[ 36.237971] smpboot: Booting Node 0 Processor 2 APIC 0x4
[ 36.238391] cache: parent cpu2 should not be sleeping
[ 36.238525] CPU2 is up
[ 36.238541] smpboot: Booting Node 0 Processor 3 APIC 0x6
[ 36.238961] cache: parent cpu3 should not be sleeping
[ 36.239105] CPU3 is up
[ 36.239121] smpboot: Booting Node 0 Processor 4 APIC 0x1
[ 36.239611] cache: parent cpu4 should not be sleeping
[ 36.239938] CPU4 is up
[ 36.239957] smpboot: Booting Node 0 Processor 5 APIC 0x3
[ 36.240374] cache: parent cpu5 should not be sleeping
[ 36.240528] CPU5 is up
[ 36.240544] smpboot: Booting Node 0 Processor 6 APIC 0x5
[ 36.240960] cache: parent cpu6 should not be sleeping
[ 36.241124] CPU6 is up
[ 36.241141] smpboot: Booting Node 0 Processor 7 APIC 0x7
[ 36.241558] cache: parent cpu7 should not be sleeping
[ 36.241735] CPU7 is up
[ 36.247529] ACPI: Waking up from system sleep state S3
[ 36.349311] ACPI: EC: interrupt unblocked
[ 36.463991] thunderbolt 0000:06:00.0: control channel starting...
[ 36.463995] thunderbolt 0000:06:00.0: starting TX ring 0
[ 36.464006] thunderbolt 0000:06:00.0: enabling interrupt at register 0x38200 bit 0 (0x0 -> 0x1)
[ 36.464009] thunderbolt 0000:06:00.0: starting RX ring 0
[ 36.464019] thunderbolt 0000:06:00.0: enabling interrupt at register 0x38200 bit 12 (0x1 -> 0x1001)
[ 36.656268] ACPI: EC: event unblocked
[ 36.659091] xhci_hcd 0000:3c:00.0: xHC error in resume, USBSTS 0x401, Reinit
[ 36.659095] usb usb3: root hub lost power or was reset
[ 36.659098] usb usb4: root hub lost power or was reset
[ 36.770867] usb 2-3: Disable of device-initiated U1 failed.
[ 36.774331] usb 2-3: Disable of device-initiated U2 failed.
[ 37.004366] usb 2-3: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[ 37.184210] usb 1-7: reset full-speed USB device number 2 using xhci_hcd
[ 37.514121] usb 1-8: reset high-speed USB device number 3 using xhci_hcd
[ 37.774220] acpi LNXPOWER:01: Turning OFF
[ 37.774784] OOM killer enabled.
[ 37.774786] Restarting tasks ...
[ 37.775699] Bluetooth: hci0: Bootloader revision 0.0 build 26 week 38 2015
[ 37.776710] Bluetooth: hci0: Device revision is 16
[ 37.776713] Bluetooth: hci0: Secure boot is enabled
[ 37.776716] Bluetooth: hci0: OTP lock is enabled
[ 37.776718] Bluetooth: hci0: API lock is enabled
[ 37.776723] Bluetooth: hci0: Debug lock is disabled
[ 37.776727] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[ 37.776734] Bluetooth: hci0: Found device firmware: intel/ibt-12-16.sfi
[ 37.776804] done.
[ 37.803802] usb 1-9: USB disconnect, device number 5
[ 37.829406] PM: suspend exit
[ 37.853910] pci_bus 0000:06: Allocating resources
[ 37.853923] pci_bus 0000:3c: Allocating resources
[ 37.854197] pci_bus 0000:06: Allocating resources
[ 37.854208] pci_bus 0000:3c: Allocating resources
[ 37.953833] usb 1-9: new full-speed USB device number 6 using xhci_hcd
[ 38.092776] e1000e: enp0s31f6 NIC Link is Down
[ 38.094743] IPv6: ADDRCONF(NETDEV_UP): enp0s31f6: link is not ready
[ 38.145754] usb 1-9: New USB device found, idVendor=06cb, idProduct=009a, bcdDevice= 1.64
[ 38.145756] usb 1-9: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[ 38.145756] usb 1-9: SerialNumber: a6fd98866605
[ 38.333990] IPv6: ADDRCONF(NETDEV_UP): enp0s31f6: link is not ready
[ 38.335981] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready
[ 38.510203] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready
[ 39.332971] Bluetooth: hci0: Waiting for firmware download to complete
[ 39.333735] Bluetooth: hci0: Firmware loaded in 1522458 usecs
[ 39.333809] Bluetooth: hci0: Waiting for device to boot
[ 39.346759] Bluetooth: hci0: Device booted in 12711 usecs
[ 39.346765] Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-12-16.ddc
[ 39.349823] Bluetooth: hci0: Applying Intel DDC parameters completed
[ 41.857347] wlp3s0: authenticate with c0:94:35:6d:6a:3d
[ 41.868866] wlp3s0: send auth to c0:94:35:6d:6a:3d (try 1/3)
[ 41.876428] wlp3s0: authenticated
[ 41.883787] wlp3s0: associate with c0:94:35:6d:6a:3d (try 1/3)
[ 41.890964] wlp3s0: RX AssocResp from c0:94:35:6d:6a:3d (capab=0x1011 status=0 aid=4)
[ 41.893228] wlp3s0: associated
[ 41.910601] IPv6: ADDRCONF(NETDEV_CHANGE): wlp3s0: link becomes ready
[ 41.976189] wlp3s0: Limiting TX power to 30 (30 - 0) dBm as advertised by c0:94:35:6d:6a:3d
[ 43.895863] thunderbolt 0000:06:00.0: stopping RX ring 0
[ 43.895874] thunderbolt 0000:06:00.0: disabling interrupt at register 0x38200 bit 12 (0x1001 -> 0x1)
[ 43.895893] thunderbolt 0000:06:00.0: stopping TX ring 0
[ 43.895902] thunderbolt 0000:06:00.0: disabling interrupt at register 0x38200 bit 0 (0x1 -> 0x0)
[ 43.895911] thunderbolt 0000:06:00.0: control channel stopped
[trentdalton@HandSoup ~]$
Full Dmesg Out:
[ 0.000000] Linux version 4.19.313-1-MANJARO (builduser@fv-az890-432) (gcc version 13.2.1 20240417 (GCC)) #1 SMP Fri May 3 03:59:06 UTC 2024
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-4.19-x86_64 root=UUID=eec05705-b4f1-44fd-b26e-f53d19c9637e rw quiet apparmor=1 security=apparmor udev.log_priority=3
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] Centaur CentaurHauls
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x0000000000057fff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000000058000-0x0000000000058fff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000059000-0x000000000008bfff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000008c000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000003fffffff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000040000000-0x00000000403fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000040400000-0x000000007f258fff] usable
[ 0.000000] BIOS-e820: [mem 0x000000007f259000-0x000000007f25afff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000007f25b000-0x000000007ff1cfff] usable
[ 0.000000] BIOS-e820: [mem 0x000000007ff1d000-0x000000007ff1dfff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000007ff1e000-0x0000000083538fff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000083539000-0x0000000083539fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x000000008353a000-0x000000008353afff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000008353b000-0x000000008e8f3fff] usable
[ 0.000000] BIOS-e820: [mem 0x000000008e8f4000-0x000000008e9b9fff] type 20
[ 0.000000] BIOS-e820: [mem 0x000000008e9ba000-0x000000008ff2bfff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000008ff2c000-0x000000008ff99fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x000000008ff9a000-0x000000008fffefff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x000000008ffff000-0x000000008fffffff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000090000000-0x0000000097ffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000098600000-0x000000009c7fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fe010000-0x00000000fe010fff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x00000004617fffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] efi: EFI v2.50 by Lenovo
[ 0.000000] efi: SMBIOS=0x8f04e000 SMBIOS 3.0=0x8f04b000 ACPI=0x8fffe000 ACPI 2.0=0x8fffe014 MPS=0x8f448000 ESRT=0x8eed8000 MEMATTR=0x895d3018
[ 0.000000] SMBIOS 3.0.0 present.
[ 0.000000] DMI: LENOVO 20L50018US/20L50018US, BIOS N24ET76W (1.51 ) 02/27/2024
[ 0.000000] tsc: Detected 2100.000 MHz processor
[ 0.003460] tsc: Detected 2112.000 MHz TSC
[ 0.003460] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.003463] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.003478] last_pfn = 0x461800 max_arch_pfn = 0x400000000
[ 0.003484] MTRR default type: write-back
[ 0.003485] MTRR fixed ranges enabled:
[ 0.003487] 00000-9FFFF write-back
[ 0.003489] A0000-BFFFF uncachable
[ 0.003490] C0000-FFFFF write-protect
[ 0.003491] MTRR variable ranges enabled:
[ 0.003494] 0 base 00C0000000 mask 7FC0000000 uncachable
[ 0.003496] 1 base 00A0000000 mask 7FE0000000 uncachable
[ 0.003497] 2 base 009C000000 mask 7FFC000000 uncachable
[ 0.003498] 3 base 009A000000 mask 7FFE000000 uncachable
[ 0.003499] 4 disabled
[ 0.003500] 5 disabled
[ 0.003501] 6 disabled
[ 0.003501] 7 disabled
[ 0.003502] 8 disabled
[ 0.003503] 9 disabled
[ 0.005710] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.005986] last_pfn = 0x90000 max_arch_pfn = 0x400000000
[ 0.022093] esrt: Reserving ESRT space from 0x000000008eed8000 to 0x000000008eed80b0.
[ 0.022107] Scanning 1 areas for low memory corruption
[ 0.022115] Using GB pages for direct mapping
[ 0.023537] Secure boot disabled
[ 0.023539] RAMDISK: [mem 0x35e05000-0x36ef9fff]
[ 0.023545] ACPI: Early table checksum verification disabled
[ 0.023549] ACPI: RSDP 0x000000008FFFE014 000024 (v02 LENOVO)
[ 0.023555] ACPI: XSDT 0x000000008FFBB188 000114 (v01 LENOVO TP-N24 00001510 PTEC 00000002)
[ 0.023564] ACPI: FACP 0x000000008FFF2000 0000F4 (v05 LENOVO TP-N24 00001510 PTEC 00000002)
[ 0.023572] ACPI: DSDT 0x000000008FFCB000 022607 (v02 LENOVO SKL 00000000 INTL 20160527)
[ 0.023578] ACPI: FACS 0x000000008FF47000 000040
[ 0.023582] ACPI: SSDT 0x000000008FFF8000 00432B (v02 LENOVO DptfTabl 00001000 INTL 20160527)
[ 0.023586] ACPI: UEFI 0x000000008FF5C000 000042 (v01 LENOVO TP-N24 00001510 PTEC 00000002)
[ 0.023591] ACPI: SSDT 0x000000008FFF4000 0030E4 (v02 LENOVO SaSsdt 00003000 INTL 20160527)
[ 0.023596] ACPI: SSDT 0x000000008FFF3000 0005C6 (v02 LENOVO PerfTune 00001000 INTL 20160527)
[ 0.023602] ACPI: HPET 0x000000008FFF1000 000038 (v01 LENOVO TP-N24 00001510 PTEC 00000002)
[ 0.023607] ACPI: APIC 0x000000008FFF0000 00012C (v03 LENOVO TP-N24 00001510 PTEC 00000002)
[ 0.023611] ACPI: MCFG 0x000000008FFEF000 00003C (v01 LENOVO TP-N24 00001510 PTEC 00000002)
[ 0.023615] ACPI: ECDT 0x000000008FFEE000 000053 (v01 LENOVO TP-N24 00001510 PTEC 00000002)
[ 0.023619] ACPI: SSDT 0x000000008FFC9000 001CA3 (v02 LENOVO RVP7Rtd3 00001000 INTL 20160527)
[ 0.023624] ACPI: SSDT 0x000000008FFC8000 00021C (v01 LENOVO Rmv_Batt 00001000 INTL 20160527)
[ 0.023628] ACPI: SSDT 0x000000008FFC6000 00163C (v02 LENOVO ProjSsdt 00000010 INTL 20160527)
[ 0.023632] ACPI: BOOT 0x000000008FFC5000 000028 (v01 LENOVO TP-N24 00001510 PTEC 00000002)
[ 0.023636] ACPI: BATB 0x000000008FFC4000 00004A (v02 LENOVO TP-N24 00001510 PTEC 00000002)
[ 0.023640] ACPI: SLIC 0x000000008FFC3000 000176 (v01 LENOVO TP-N24 00001510 PTEC 00000002)
[ 0.023645] ACPI: SSDT 0x000000008FFC1000 0017AE (v02 LENOVO CpuSsdt 00003000 INTL 20160527)
[ 0.023649] ACPI: SSDT 0x000000008FFC0000 00056D (v02 LENOVO CtdpB 00001000 INTL 20160527)
[ 0.023653] ACPI: SSDT 0x000000008FFBF000 000678 (v02 LENOVO UsbCTabl 00001000 INTL 20160527)
[ 0.023658] ACPI: LPIT 0x000000008FFBE000 000094 (v01 LENOVO TP-N24 00001510 PTEC 00000002)
[ 0.023662] ACPI: WSMT 0x000000008FFBD000 000028 (v01 LENOVO TP-N24 00001510 PTEC 00000002)
[ 0.023666] ACPI: SSDT 0x000000008FFBC000 0001D8 (v02 LENOVO HdaDsp 00000000 INTL 20160527)
[ 0.023671] ACPI: SSDT 0x000000008FFFD000 0004FC (v02 LENOVO TbtTypeC 00000000 INTL 20160527)
[ 0.023675] ACPI: SSDT 0x000000008FFBA000 0002D1 (v02 LENOVO Wwan 00000001 INTL 20160527)
[ 0.023679] ACPI: DBGP 0x000000008FFB9000 000034 (v01 LENOVO TP-N24 00001510 PTEC 00000002)
[ 0.023683] ACPI: DBG2 0x000000008FFB8000 000054 (v00 LENOVO TP-N24 00001510 PTEC 00000002)
[ 0.023688] ACPI: MSDM 0x000000008FFB7000 000055 (v03 LENOVO TP-N24 00001510 PTEC 00000002)
[ 0.023692] ACPI: DMAR 0x000000008FFB6000 0000A8 (v01 LENOVO TP-N24 00001510 PTEC 00000002)
[ 0.023696] ACPI: ASF! 0x000000008FFB5000 0000A0 (v32 LENOVO TP-N24 00001510 PTEC 00000002)
[ 0.023701] ACPI: FPDT 0x000000008FFB4000 000044 (v01 LENOVO TP-N24 00001510 PTEC 00000002)
[ 0.023705] ACPI: UEFI 0x000000008FF44000 00013E (v01 LENOVO TP-N24 00001510 PTEC 00000002)
[ 0.023709] ACPI: Reserving FACP table memory at [mem 0x8fff2000-0x8fff20f3]
[ 0.023711] ACPI: Reserving DSDT table memory at [mem 0x8ffcb000-0x8ffed606]
[ 0.023713] ACPI: Reserving FACS table memory at [mem 0x8ff47000-0x8ff4703f]
[ 0.023714] ACPI: Reserving SSDT table memory at [mem 0x8fff8000-0x8fffc32a]
[ 0.023715] ACPI: Reserving UEFI table memory at [mem 0x8ff5c000-0x8ff5c041]
[ 0.023717] ACPI: Reserving SSDT table memory at [mem 0x8fff4000-0x8fff70e3]
[ 0.023718] ACPI: Reserving SSDT table memory at [mem 0x8fff3000-0x8fff35c5]
[ 0.023719] ACPI: Reserving HPET table memory at [mem 0x8fff1000-0x8fff1037]
[ 0.023721] ACPI: Reserving APIC table memory at [mem 0x8fff0000-0x8fff012b]
[ 0.023722] ACPI: Reserving MCFG table memory at [mem 0x8ffef000-0x8ffef03b]
[ 0.023724] ACPI: Reserving ECDT table memory at [mem 0x8ffee000-0x8ffee052]
[ 0.023725] ACPI: Reserving SSDT table memory at [mem 0x8ffc9000-0x8ffcaca2]
[ 0.023726] ACPI: Reserving SSDT table memory at [mem 0x8ffc8000-0x8ffc821b]
[ 0.023728] ACPI: Reserving SSDT table memory at [mem 0x8ffc6000-0x8ffc763b]
[ 0.023729] ACPI: Reserving BOOT table memory at [mem 0x8ffc5000-0x8ffc5027]
[ 0.023731] ACPI: Reserving BATB table memory at [mem 0x8ffc4000-0x8ffc4049]
[ 0.023732] ACPI: Reserving SLIC table memory at [mem 0x8ffc3000-0x8ffc3175]
[ 0.023733] ACPI: Reserving SSDT table memory at [mem 0x8ffc1000-0x8ffc27ad]
[ 0.023735] ACPI: Reserving SSDT table memory at [mem 0x8ffc0000-0x8ffc056c]
[ 0.023736] ACPI: Reserving SSDT table memory at [mem 0x8ffbf000-0x8ffbf677]
[ 0.023738] ACPI: Reserving LPIT table memory at [mem 0x8ffbe000-0x8ffbe093]
[ 0.023739] ACPI: Reserving WSMT table memory at [mem 0x8ffbd000-0x8ffbd027]
[ 0.023741] ACPI: Reserving SSDT table memory at [mem 0x8ffbc000-0x8ffbc1d7]
[ 0.023742] ACPI: Reserving SSDT table memory at [mem 0x8fffd000-0x8fffd4fb]
[ 0.023744] ACPI: Reserving SSDT table memory at [mem 0x8ffba000-0x8ffba2d0]
[ 0.023745] ACPI: Reserving DBGP table memory at [mem 0x8ffb9000-0x8ffb9033]
[ 0.023747] ACPI: Reserving DBG2 table memory at [mem 0x8ffb8000-0x8ffb8053]
[ 0.023748] ACPI: Reserving MSDM table memory at [mem 0x8ffb7000-0x8ffb7054]
[ 0.023749] ACPI: Reserving DMAR table memory at [mem 0x8ffb6000-0x8ffb60a7]
[ 0.023751] ACPI: Reserving ASF! table memory at [mem 0x8ffb5000-0x8ffb509f]
[ 0.023753] ACPI: Reserving FPDT table memory at [mem 0x8ffb4000-0x8ffb4043]
[ 0.023754] ACPI: Reserving UEFI table memory at [mem 0x8ff44000-0x8ff4413d]
[ 0.023769] ACPI: Local APIC address 0xfee00000
[ 0.023874] No NUMA configuration found
[ 0.023875] Faking a node at [mem 0x0000000000000000-0x00000004617fffff]
[ 0.023882] NODE_DATA(0) allocated [mem 0x4617fc000-0x4617fffff]
[ 0.023934] Zone ranges:
[ 0.023935] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.023937] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.023939] Normal [mem 0x0000000100000000-0x00000004617fffff]
[ 0.023940] Device empty
[ 0.023942] Movable zone start for each node
[ 0.023942] Early memory node ranges
[ 0.023944] node 0: [mem 0x0000000000001000-0x0000000000057fff]
[ 0.023945] node 0: [mem 0x0000000000059000-0x000000000008bfff]
[ 0.023946] node 0: [mem 0x0000000000100000-0x000000003fffffff]
[ 0.023948] node 0: [mem 0x0000000040400000-0x000000007f258fff]
[ 0.023949] node 0: [mem 0x000000007f25b000-0x000000007ff1cfff]
[ 0.023950] node 0: [mem 0x000000007ff1e000-0x0000000083538fff]
[ 0.023950] node 0: [mem 0x000000008353b000-0x000000008e8f3fff]
[ 0.023951] node 0: [mem 0x000000008ffff000-0x000000008fffffff]
[ 0.023953] node 0: [mem 0x0000000100000000-0x00000004617fffff]
[ 0.024910] Zeroed struct page in unavailable ranges: 33670 pages
[ 0.024913] Initmem setup node 0 [mem 0x0000000000001000-0x00000004617fffff]
[ 0.024916] On node 0 totalpages: 4127866
[ 0.024917] DMA zone: 64 pages used for memmap
[ 0.024918] DMA zone: 72 pages reserved
[ 0.024920] DMA zone: 3978 pages, LIFO batch:0
[ 0.025093] DMA32 zone: 9044 pages used for memmap
[ 0.025094] DMA32 zone: 578800 pages, LIFO batch:63
[ 0.051989] Normal zone: 55392 pages used for memmap
[ 0.051990] Normal zone: 3545088 pages, LIFO batch:63
[ 0.198304] Reserving Intel graphics memory at [mem 0x9a800000-0x9c7fffff]
[ 0.198711] ACPI: PM-Timer IO Port: 0x1808
[ 0.198713] ACPI: Local APIC address 0xfee00000
[ 0.198724] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 0.198726] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[ 0.198727] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[ 0.198728] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[ 0.198729] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[ 0.198729] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[ 0.198730] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
[ 0.198731] ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
[ 0.198732] ACPI: LAPIC_NMI (acpi_id[0x09] high edge lint[0x1])
[ 0.198733] ACPI: LAPIC_NMI (acpi_id[0x0a] high edge lint[0x1])
[ 0.198734] ACPI: LAPIC_NMI (acpi_id[0x0b] high edge lint[0x1])
[ 0.198735] ACPI: LAPIC_NMI (acpi_id[0x0c] high edge lint[0x1])
[ 0.198736] ACPI: LAPIC_NMI (acpi_id[0x0d] high edge lint[0x1])
[ 0.198737] ACPI: LAPIC_NMI (acpi_id[0x0e] high edge lint[0x1])
[ 0.198738] ACPI: LAPIC_NMI (acpi_id[0x0f] high edge lint[0x1])
[ 0.198739] ACPI: LAPIC_NMI (acpi_id[0x10] high edge lint[0x1])
[ 0.198768] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[ 0.198771] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.198773] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.198776] ACPI: IRQ0 used by override.
[ 0.198777] ACPI: IRQ9 used by override.
[ 0.198781] Using ACPI (MADT) for SMP configuration information
[ 0.198783] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.198789] TSC deadline timer available
[ 0.198790] smpboot: Allowing 8 CPUs, 0 hotplug CPUs
[ 0.198843] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.198847] PM: Registered nosave memory: [mem 0x00058000-0x00058fff]
[ 0.198850] PM: Registered nosave memory: [mem 0x0008c000-0x000fffff]
[ 0.198853] PM: Registered nosave memory: [mem 0x40000000-0x403fffff]
[ 0.198857] PM: Registered nosave memory: [mem 0x7f259000-0x7f25afff]
[ 0.198860] PM: Registered nosave memory: [mem 0x7ff1d000-0x7ff1dfff]
[ 0.198863] PM: Registered nosave memory: [mem 0x83539000-0x83539fff]
[ 0.198864] PM: Registered nosave memory: [mem 0x8353a000-0x8353afff]
[ 0.198867] PM: Registered nosave memory: [mem 0x8e8f4000-0x8e9b9fff]
[ 0.198869] PM: Registered nosave memory: [mem 0x8e9ba000-0x8ff2bfff]
[ 0.198869] PM: Registered nosave memory: [mem 0x8ff2c000-0x8ff99fff]
[ 0.198870] PM: Registered nosave memory: [mem 0x8ff9a000-0x8fffefff]
[ 0.198874] PM: Registered nosave memory: [mem 0x90000000-0x97ffffff]
[ 0.198875] PM: Registered nosave memory: [mem 0x98000000-0x985fffff]
[ 0.198876] PM: Registered nosave memory: [mem 0x98600000-0x9c7fffff]
[ 0.198877] PM: Registered nosave memory: [mem 0x9c800000-0xf7ffffff]
[ 0.198878] PM: Registered nosave memory: [mem 0xf8000000-0xfbffffff]
[ 0.198879] PM: Registered nosave memory: [mem 0xfc000000-0xfe00ffff]
[ 0.198879] PM: Registered nosave memory: [mem 0xfe010000-0xfe010fff]
[ 0.198880] PM: Registered nosave memory: [mem 0xfe011000-0xffffffff]
[ 0.198883] [mem 0x9c800000-0xf7ffffff] available for PCI devices
[ 0.198885] Booting paravirtualized kernel on bare hardware
[ 0.198889] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.408093] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:8 nr_node_ids:1
[ 0.408436] percpu: Embedded 51 pages/cpu s172032 r8192 d28672 u262144
[ 0.408450] pcpu-alloc: s172032 r8192 d28672 u262144 alloc=1*2097152
[ 0.408452] pcpu-alloc: [0] 0 1 2 3 4 5 6 7
[ 0.408491] Built 1 zonelists, mobility grouping on. Total pages: 4063294
[ 0.408492] Policy zone: Normal
[ 0.408494] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.19-x86_64 root=UUID=eec05705-b4f1-44fd-b26e-f53d19c9637e rw quiet apparmor=1 security=apparmor udev.log_priority=3
[ 0.415531] Calgary: detecting Calgary via BIOS EBDA area
[ 0.415534] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[ 0.480026] Memory: 16066676K/16511464K available (12300K kernel code, 1361K rwdata, 3628K rodata, 1628K init, 3692K bss, 444788K reserved, 0K cma-reserved)
[ 0.481431] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.481453] Kernel/User page tables isolation: enabled
[ 0.505007] ftrace: allocating 35528 entries in 139 pages
[ 0.531789] ftrace: allocated 139 pages with 4 groups
[ 0.532059] rcu: Hierarchical RCU implementation.
[ 0.532061] rcu: RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=8.
[ 0.532063] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[ 0.535620] NR_IRQS: 20736, nr_irqs: 2048, preallocated irqs: 16
[ 0.536082] Console: colour dummy device 80x25
[ 0.536088] console [tty0] enabled
[ 0.536169] ACPI: Core revision 20180810
[ 0.536921] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635855245 ns
[ 0.536952] hpet clockevent registered
[ 0.536994] APIC: Switch to symmetric I/O mode setup
[ 0.536997] DMAR: Host address width 39
[ 0.536998] DMAR: DRHD base: 0x000000fed90000 flags: 0x0
[ 0.537007] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap 1c0000c40660462 ecap 19e2ff0505e
[ 0.537008] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[ 0.537034] DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
[ 0.537036] DMAR: RMRR base: 0x0000008f47f000 end: 0x0000008f49efff
[ 0.537037] DMAR: RMRR base: 0x0000009a000000 end: 0x0000009c7fffff
[ 0.537040] DMAR-IR: IOAPIC id 2 under DRHD base 0xfed91000 IOMMU 1
[ 0.537041] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[ 0.537042] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[ 0.538766] DMAR-IR: Enabled IRQ remapping in x2apic mode
[ 0.538768] x2apic enabled
[ 0.538782] Switched APIC routing to cluster x2apic.
[ 0.543100] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.586965] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x1e71785e5dd, max_idle_ns: 440795244814 ns
[ 0.586985] Calibrating delay loop (skipped), value calculated using timer frequency.. 4224.00 BogoMIPS (lpj=21120000)
[ 0.587020] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.587020] ENERGY_PERF_BIAS: View and update with x86_energy_perf_policy(8)
[ 0.587080] CPU0: Thermal monitoring enabled (TM1)
[ 0.587119] process: using mwait in idle threads
[ 0.587122] Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8
[ 0.587123] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0, 1GB 4
[ 0.587128] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.587131] Spectre V2 : WARNING: Unprivileged eBPF is enabled with eIBRS on, data leaks possible via Spectre v2 BHB attacks!
[ 0.587136] Spectre V2 : Mitigation: Enhanced / Automatic IBRS
[ 0.587136] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.587137] Spectre V2 : Spectre v2 / PBRSB-eIBRS: Retire a single CALL on VMEXIT
[ 0.587138] RETBleed: Mitigation: Enhanced IBRS
[ 0.587147] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 0.587147] Spectre V2 : User space: Mitigation: STIBP via seccomp and prctl
[ 0.587150] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[ 0.587264] MDS: Mitigation: Clear CPU buffers
[ 0.587265] TAA: Mitigation: Clear CPU buffers
[ 0.587265] MMIO Stale Data: Mitigation: Clear CPU buffers
[ 0.587275] SRBDS: Mitigation: Microcode
[ 0.587289] GDS: Mitigation: Microcode
[ 0.587307] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.587308] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.587309] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[ 0.587310] x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
[ 0.587311] x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
[ 0.587316] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.587317] x86/fpu: xstate_offset[3]: 832, xstate_sizes[3]: 64
[ 0.587318] x86/fpu: xstate_offset[4]: 896, xstate_sizes[4]: 64
[ 0.587320] x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using 'compacted' format.
[ 0.599095] Freeing SMP alternatives memory: 32K
[ 0.601927] pid_max: default: 32768 minimum: 301
[ 0.603812] Security Framework initialized
[ 0.603814] Yama: becoming mindful.
[ 0.603916] AppArmor: AppArmor initialized
[ 0.606549] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes)
[ 0.607864] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.607994] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.608034] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.614311] smpboot: CPU0: Intel(R) Core(TM) i7-8650U CPU @ 1.90GHz (family: 0x6, model: 0x8e, stepping: 0xa)
[ 0.614626] Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full-width counters, Intel PMU driver.
[ 0.614687] ... version: 4
[ 0.614688] ... bit width: 48
[ 0.614689] ... generic registers: 4
[ 0.614690] ... value mask: 0000ffffffffffff
[ 0.614691] ... max period: 00007fffffffffff
[ 0.614692] ... fixed-purpose events: 3
[ 0.614693] ... event mask: 000000070000000f
[ 0.614808] rcu: Hierarchical SRCU implementation.
[ 0.616609] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.616961] smp: Bringing up secondary CPUs ...
[ 0.616967] x86: Booting SMP configuration:
[ 0.616967] .... node #0, CPUs: #1 #2 #3 #4
[ 0.632892] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[ 0.632892] TAA CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/tsx_async_abort.html for more details.
[ 0.632892] MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
[ 0.632892] #5 #6 #7
[ 0.649941] smp: Brought up 1 node, 8 CPUs
[ 0.649941] smpboot: Max logical packages: 1
[ 0.649941] smpboot: Total of 8 processors activated (33792.00 BogoMIPS)
[ 0.658038] devtmpfs: initialized
[ 0.658038] x86/mm: Memory block size: 128MB
[ 0.663533] PM: Registering ACPI NVS region [mem 0x83539000-0x83539fff] (4096 bytes)
[ 0.663533] PM: Registering ACPI NVS region [mem 0x8ff2c000-0x8ff99fff] (450560 bytes)
[ 0.663533] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.663533] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.663533] pinctrl core: initialized pinctrl subsystem
[ 0.663533] RTC time: 14:59:12, date: 05/23/24
[ 0.667751] NET: Registered protocol family 16
[ 0.668074] audit: initializing netlink subsys (disabled)
[ 0.668112] audit: type=2000 audit(1716476352.140:1): state=initialized audit_enabled=0 res=1
[ 0.668112] cpuidle: using governor ladder
[ 0.668112] cpuidle: using governor menu
[ 0.668112] Simple Boot Flag at 0x47 set to 0x1
[ 0.668112] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.668112] ACPI: bus type PCI registered
[ 0.668112] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.668112] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[ 0.668112] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[ 0.668112] PCI: Using configuration type 1 for base access
[ 0.670201] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.670201] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.670201] ACPI: Added _OSI(Module Device)
[ 0.670201] ACPI: Added _OSI(Processor Device)
[ 0.670201] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.670201] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.670201] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.670201] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.779845] ACPI: 13 ACPI AML tables successfully acquired and loaded
[ 0.780250] ACPI: EC: EC started
[ 0.780250] ACPI: EC: interrupt blocked
[ 0.782834] ACPI: \: Used as first EC
[ 0.782836] ACPI: \: GPE=0x16, EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.782838] ACPI: \: Used as boot ECDT EC to handle transactions
[ 0.797505] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[ 0.887566] ACPI: Dynamic OEM Table Load:
[ 0.887583] ACPI: SSDT 0xFFFF9E1E4ED86000 0005EE (v02 PmRef Cpu0Ist 00003000 INTL 20160527)
[ 0.888049] ACPI: \_PR_.PR00: _OSC native thermal LVT Acked
[ 0.888379] ACPI: Dynamic OEM Table Load:
[ 0.888379] ACPI: SSDT 0xFFFF9E1E4E8D7000 0003FF (v02 PmRef Cpu0Cst 00003001 INTL 20160527)
[ 0.888909] ACPI: Dynamic OEM Table Load:
[ 0.888921] ACPI: SSDT 0xFFFF9E1E4E8FD3C0 0000BA (v02 PmRef Cpu0Hwp 00003000 INTL 20160527)
[ 0.889540] ACPI: Dynamic OEM Table Load:
[ 0.889552] ACPI: SSDT 0xFFFF9E1E4ED81800 000628 (v02 PmRef HwpLvt 00003000 INTL 20160527)
[ 0.897944] ACPI: Dynamic OEM Table Load:
[ 0.897962] ACPI: SSDT 0xFFFF9E1E4EDD3000 000D14 (v02 PmRef ApIst 00003000 INTL 20160527)
[ 0.899993] ACPI: Dynamic OEM Table Load:
[ 0.899993] ACPI: SSDT 0xFFFF9E1E4E886800 000317 (v02 PmRef ApHwp 00003000 INTL 20160527)
[ 0.900000] ACPI: Dynamic OEM Table Load:
[ 0.900000] ACPI: SSDT 0xFFFF9E1E4E8D4C00 00030A (v02 PmRef ApCst 00003000 INTL 20160527)
[ 0.900800] ACPI: Interpreter enabled
[ 0.900902] ACPI: (supports S0 S3 S4 S5)
[ 0.900904] ACPI: Using IOAPIC for interrupt routing
[ 0.900983] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.902338] ACPI: Enabled 8 GPEs in block 00 to 7F
[ 0.910300] ACPI: Power Resource [PUBS] (on)
[ 0.910840] acpi PNP0C0A:01: ACPI dock station (docks/bays count: 1)
[ 0.964791] ACPI: Power Resource [WRST] (on)
[ 0.966218] ACPI: Power Resource [PXP] (on)
[ 0.988502] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e])
[ 0.988512] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[ 0.997551] acpi PNP0A08:00: _OSC: platform does not support [AER]
[ 0.999721] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME PCIeCapability LTR]
[ 0.999722] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[ 1.001920] PCI host bridge to bus 0000:00
[ 1.001920] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 1.001920] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 1.001920] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 1.001920] pci_bus 0000:00: root bus resource [mem 0x9c800000-0xf7ffffff window]
[ 1.001920] pci_bus 0000:00: root bus resource [mem 0xfd000000-0xfe7fffff window]
[ 1.001920] pci_bus 0000:00: root bus resource [bus 00-3e]
[ 1.001920] pci 0000:00:00.0: [8086:5914] type 00 class 0x060000
[ 1.001920] pci 0000:00:02.0: [8086:5917] type 00 class 0x030000
[ 1.001920] pci 0000:00:02.0: reg 0x10: [mem 0xeb000000-0xebffffff 64bit]
[ 1.001920] pci 0000:00:02.0: reg 0x18: [mem 0xa0000000-0xafffffff 64bit pref]
[ 1.001920] pci 0000:00:02.0: reg 0x20: [io 0xe000-0xe03f]
[ 1.001920] pci 0000:00:02.0: BAR 2: assigned to efifb
[ 1.002565] pci 0000:00:04.0: [8086:1903] type 00 class 0x118000
[ 1.002583] pci 0000:00:04.0: reg 0x10: [mem 0xec240000-0xec247fff 64bit]
[ 1.004354] pci 0000:00:08.0: [8086:1911] type 00 class 0x088000
[ 1.004372] pci 0000:00:08.0: reg 0x10: [mem 0xec250000-0xec250fff 64bit]
[ 1.006036] pci 0000:00:14.0: [8086:9d2f] type 00 class 0x0c0330
[ 1.006063] pci 0000:00:14.0: reg 0x10: [mem 0xec230000-0xec23ffff 64bit]
[ 1.006146] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ 1.008022] pci 0000:00:14.2: [8086:9d31] type 00 class 0x118000
[ 1.008050] pci 0000:00:14.2: reg 0x10: [mem 0xec251000-0xec251fff 64bit]
[ 1.009739] pci 0000:00:16.0: [8086:9d3a] type 00 class 0x078000
[ 1.009765] pci 0000:00:16.0: reg 0x10: [mem 0xec252000-0xec252fff 64bit]
[ 1.009845] pci 0000:00:16.0: PME# supported from D3hot
[ 1.011646] pci 0000:00:1c.0: [8086:9d10] type 01 class 0x060400
[ 1.011757] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 1.013533] pci 0000:00:1c.6: [8086:9d16] type 01 class 0x060400
[ 1.013648] pci 0000:00:1c.6: PME# supported from D0 D3hot D3cold
[ 1.015415] pci 0000:00:1d.0: [8086:9d18] type 01 class 0x060400
[ 1.015509] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[ 1.017282] pci 0000:00:1d.2: [8086:9d1a] type 01 class 0x060400
[ 1.017380] pci 0000:00:1d.2: PME# supported from D0 D3hot D3cold
[ 1.019158] pci 0000:00:1f.0: [8086:9d4e] type 00 class 0x060100
[ 1.020990] pci 0000:00:1f.2: [8086:9d21] type 00 class 0x058000
[ 1.021008] pci 0000:00:1f.2: reg 0x10: [mem 0xec24c000-0xec24ffff]
[ 1.022759] pci 0000:00:1f.3: [8086:9d71] type 00 class 0x040300
[ 1.022794] pci 0000:00:1f.3: reg 0x10: [mem 0xec248000-0xec24bfff 64bit]
[ 1.022833] pci 0000:00:1f.3: reg 0x20: [mem 0xec220000-0xec22ffff 64bit]
[ 1.022897] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[ 1.024724] pci 0000:00:1f.4: [8086:9d23] type 00 class 0x0c0500
[ 1.024779] pci 0000:00:1f.4: reg 0x10: [mem 0xec253000-0xec2530ff 64bit]
[ 1.024831] pci 0000:00:1f.4: reg 0x20: [io 0xefa0-0xefbf]
[ 1.026626] pci 0000:00:1f.6: [8086:15d7] type 00 class 0x020000
[ 1.026656] pci 0000:00:1f.6: reg 0x10: [mem 0xec200000-0xec21ffff]
[ 1.026775] pci 0000:00:1f.6: PME# supported from D0 D3hot D3cold
[ 1.028598] pci 0000:00:1c.0: PCI bridge to [bus 01]
[ 1.029172] pci 0000:03:00.0: [8086:24fd] type 00 class 0x028000
[ 1.029280] pci 0000:03:00.0: reg 0x10: [mem 0xec100000-0xec101fff 64bit]
[ 1.029904] pci 0000:03:00.0: PME# supported from D0 D3hot D3cold
[ 1.030810] pci 0000:00:1c.6: PCI bridge to [bus 03]
[ 1.030816] pci 0000:00:1c.6: bridge window [mem 0xec100000-0xec1fffff]
[ 1.030921] pci 0000:04:00.0: [8086:15c0] type 01 class 0x060400
[ 1.030994] pci 0000:04:00.0: enabling Extended Tags
[ 1.031086] pci 0000:04:00.0: supports D1 D2
[ 1.031088] pci 0000:04:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.031261] pci 0000:00:1d.0: PCI bridge to [bus 04-3c]
[ 1.031267] pci 0000:00:1d.0: bridge window [mem 0xd4000000-0xea0fffff]
[ 1.031273] pci 0000:00:1d.0: bridge window [mem 0xb0000000-0xd1ffffff 64bit pref]
[ 1.031356] pci 0000:05:00.0: [8086:15c0] type 01 class 0x060400
[ 1.031434] pci 0000:05:00.0: enabling Extended Tags
[ 1.031528] pci 0000:05:00.0: supports D1 D2
[ 1.031530] pci 0000:05:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.031681] pci 0000:05:01.0: [8086:15c0] type 01 class 0x060400
[ 1.031758] pci 0000:05:01.0: enabling Extended Tags
[ 1.031856] pci 0000:05:01.0: supports D1 D2
[ 1.031857] pci 0000:05:01.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.032001] pci 0000:05:02.0: [8086:15c0] type 01 class 0x060400
[ 1.032079] pci 0000:05:02.0: enabling Extended Tags
[ 1.032173] pci 0000:05:02.0: supports D1 D2
[ 1.032175] pci 0000:05:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.032351] pci 0000:04:00.0: PCI bridge to [bus 05-3c]
[ 1.032361] pci 0000:04:00.0: bridge window [mem 0xd4000000-0xea0fffff]
[ 1.032368] pci 0000:04:00.0: bridge window [mem 0xb0000000-0xd1ffffff 64bit pref]
[ 1.032456] pci 0000:06:00.0: [8086:15bf] type 00 class 0x088000
[ 1.032494] pci 0000:06:00.0: reg 0x10: [mem 0xea000000-0xea03ffff]
[ 1.032507] pci 0000:06:00.0: reg 0x14: [mem 0xea040000-0xea040fff]
[ 1.032578] pci 0000:06:00.0: enabling Extended Tags
[ 1.032690] pci 0000:06:00.0: supports D1 D2
[ 1.032692] pci 0000:06:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.032866] pci 0000:05:00.0: PCI bridge to [bus 06]
[ 1.032877] pci 0000:05:00.0: bridge window [mem 0xea000000-0xea0fffff]
[ 1.032955] pci 0000:05:01.0: PCI bridge to [bus 07-3b]
[ 1.032966] pci 0000:05:01.0: bridge window [mem 0xd4000000-0xe9efffff]
[ 1.032973] pci 0000:05:01.0: bridge window [mem 0xb0000000-0xd1ffffff 64bit pref]
[ 1.033082] pci 0000:3c:00.0: [8086:15c1] type 00 class 0x0c0330
[ 1.033122] pci 0000:3c:00.0: reg 0x10: [mem 0xe9f00000-0xe9f0ffff]
[ 1.033211] pci 0000:3c:00.0: enabling Extended Tags
[ 1.033327] pci 0000:3c:00.0: supports D1 D2
[ 1.033328] pci 0000:3c:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.033385] pci 0000:3c:00.0: 8.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s x4 link at 0000:05:02.0 (capable of 31.504 Gb/s with 8 GT/s x4 link)
[ 1.033563] pci 0000:05:02.0: PCI bridge to [bus 3c]
[ 1.033573] pci 0000:05:02.0: bridge window [mem 0xe9f00000-0xe9ffffff]
[ 1.033933] pci 0000:3d:00.0: [17aa:0006] type 00 class 0x010802
[ 1.033968] pci 0000:3d:00.0: reg 0x10: [mem 0xec000000-0xec003fff 64bit]
[ 1.034134] pci 0000:3d:00.0: 15.752 Gb/s available PCIe bandwidth, limited by 8 GT/s x2 link at 0000:00:1d.2 (capable of 31.504 Gb/s with 8 GT/s x4 link)
[ 1.034379] pci 0000:00:1d.2: PCI bridge to [bus 3d]
[ 1.034385] pci 0000:00:1d.2: bridge window [mem 0xec000000-0xec0fffff]
[ 1.048098] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 1.048194] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 *10 11 12 14 15)
[ 1.048286] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 1.048377] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 1.048468] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 1.048559] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 1.048650] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 1.048741] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 1.050055] ACPI: EC: interrupt unblocked
[ 1.050077] ACPI: EC: event unblocked
[ 1.050093] ACPI: \_SB_.PCI0.LPCB.EC__: GPE=0x16, EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 1.050095] ACPI: \_SB_.PCI0.LPCB.EC__: Used as boot DSDT EC to handle transactions and events
[ 1.050319] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[ 1.050319] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 1.050319] pci 0000:00:02.0: vgaarb: bridge control possible
[ 1.050319] vgaarb: loaded
[ 1.050319] ACPI: bus type USB registered
[ 1.050319] usbcore: registered new interface driver usbfs
[ 1.050319] usbcore: registered new interface driver hub
[ 1.050319] usbcore: registered new device driver usb
[ 1.050319] pps_core: LinuxPPS API ver. 1 registered
[ 1.050319] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.050319] PTP clock support registered
[ 1.050319] EDAC MC: Ver: 3.0.0
[ 1.050319] Registered efivars operations
[ 1.050319] PCI: Using ACPI for IRQ routing
[ 1.050319] PCI: pci_cache_line_size set to 64 bytes
[ 1.050812] e820: reserve RAM buffer [mem 0x00058000-0x0005ffff]
[ 1.050814] e820: reserve RAM buffer [mem 0x0008c000-0x0008ffff]
[ 1.050815] e820: reserve RAM buffer [mem 0x7f259000-0x7fffffff]
[ 1.050817] e820: reserve RAM buffer [mem 0x7ff1d000-0x7fffffff]
[ 1.050818] e820: reserve RAM buffer [mem 0x83539000-0x83ffffff]
[ 1.050820] e820: reserve RAM buffer [mem 0x8e8f4000-0x8fffffff]
[ 1.050822] e820: reserve RAM buffer [mem 0x461800000-0x463ffffff]
[ 1.051061] NetLabel: Initializing
[ 1.051062] NetLabel: domain hash size = 128
[ 1.051063] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 1.051084] NetLabel: unlabeled traffic allowed by default
[ 1.051093] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 1.051093] hpet0: 8 comparators, 64-bit 24.000000 MHz counter
[ 1.056980] clocksource: Switched to clocksource tsc-early
[ 1.088983] VFS: Disk quotas dquot_6.6.0
[ 1.089049] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.089440] AppArmor: AppArmor Filesystem Enabled
[ 1.089473] pnp: PnP ACPI init
[ 1.089630] system 00:00: [mem 0x40000000-0x403fffff] has been reserved
[ 1.089638] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 1.089928] system 00:01: [mem 0xfd000000-0xfdabffff] has been reserved
[ 1.089930] system 00:01: [mem 0xfdad0000-0xfdadffff] has been reserved
[ 1.089932] system 00:01: [mem 0xfdb00000-0xfdffffff] has been reserved
[ 1.089935] system 00:01: [mem 0xfe000000-0xfe01ffff] could not be reserved
[ 1.089937] system 00:01: [mem 0xfe036000-0xfe03bfff] has been reserved
[ 1.089939] system 00:01: [mem 0xfe03d000-0xfe3fffff] has been reserved
[ 1.089941] system 00:01: [mem 0xfe410000-0xfe7fffff] has been reserved
[ 1.089946] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 1.090638] system 00:02: [io 0xff00-0xfffe] has been reserved
[ 1.090643] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 1.091911] system 00:03: [io 0x0680-0x069f] has been reserved
[ 1.091913] system 00:03: [io 0xffff] has been reserved
[ 1.091916] system 00:03: [io 0xffff] has been reserved
[ 1.091918] system 00:03: [io 0xffff] has been reserved
[ 1.091943] system 00:03: [io 0x1800-0x18fe] has been reserved
[ 1.091945] system 00:03: [io 0x164e-0x164f] has been reserved
[ 1.091951] system 00:03: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 1.092215] pnp 00:04: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 1.092309] system 00:05: [io 0x1854-0x1857] has been reserved
[ 1.092314] system 00:05: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[ 1.092368] pnp 00:06: Plug and Play ACPI device, IDs LEN0071 PNP0303 (active)
[ 1.092417] pnp 00:07: Plug and Play ACPI device, IDs LEN0093 PNP0f13 (active)
[ 1.092671] system 00:08: [io 0x1800-0x189f] could not be reserved
[ 1.092673] system 00:08: [io 0x0800-0x087f] has been reserved
[ 1.092675] system 00:08: [io 0x0880-0x08ff] has been reserved
[ 1.092678] system 00:08: [io 0x0900-0x097f] has been reserved
[ 1.092680] system 00:08: [io 0x0980-0x09ff] has been reserved
[ 1.092682] system 00:08: [io 0x0a00-0x0a7f] has been reserved
[ 1.092684] system 00:08: [io 0x0a80-0x0aff] has been reserved
[ 1.092686] system 00:08: [io 0x0b00-0x0b7f] has been reserved
[ 1.092688] system 00:08: [io 0x0b80-0x0bff] has been reserved
[ 1.092690] system 00:08: [io 0x15e0-0x15ef] has been reserved
[ 1.092692] system 00:08: [io 0x1600-0x167f] could not be reserved
[ 1.092694] system 00:08: [io 0x1640-0x165f] could not be reserved
[ 1.092697] system 00:08: [mem 0xf8000000-0xfbffffff] has been reserved
[ 1.092700] system 00:08: [mem 0xfed10000-0xfed13fff] has been reserved
[ 1.092702] system 00:08: [mem 0xfed18000-0xfed18fff] has been reserved
[ 1.092704] system 00:08: [mem 0xfed19000-0xfed19fff] has been reserved
[ 1.092706] system 00:08: [mem 0xfeb00000-0xfebfffff] has been reserved
[ 1.092708] system 00:08: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 1.092711] system 00:08: [mem 0xfed90000-0xfed93fff] could not be reserved
[ 1.092713] system 00:08: [mem 0xf7fe0000-0xf7ffffff] has been reserved
[ 1.092719] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 1.095483] system 00:09: [mem 0xfdaf0000-0xfdafffff] has been reserved
[ 1.095486] system 00:09: [mem 0xfdae0000-0xfdaeffff] has been reserved
[ 1.095488] system 00:09: [mem 0xfdac0000-0xfdacffff] has been reserved
[ 1.095493] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 1.096700] system 00:0a: [mem 0xfed10000-0xfed17fff] could not be reserved
[ 1.096702] system 00:0a: [mem 0xfed18000-0xfed18fff] has been reserved
[ 1.096705] system 00:0a: [mem 0xfed19000-0xfed19fff] has been reserved
[ 1.096707] system 00:0a: [mem 0xf8000000-0xfbffffff] has been reserved
[ 1.096709] system 00:0a: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 1.096712] system 00:0a: [mem 0xfed90000-0xfed93fff] could not be reserved
[ 1.096714] system 00:0a: [mem 0xfed45000-0xfed8ffff] has been reserved
[ 1.096716] system 00:0a: [mem 0xff000000-0xffffffff] has been reserved
[ 1.096718] system 00:0a: [mem 0xfee00000-0xfeefffff] has been reserved
[ 1.096721] system 00:0a: [mem 0xf7fe0000-0xf7ffffff] has been reserved
[ 1.096726] system 00:0a: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 1.097387] system 00:0b: [mem 0x00000000-0x0009ffff] could not be reserved
[ 1.097389] system 00:0b: [mem 0x000c0000-0x000c3fff] could not be reserved
[ 1.097391] system 00:0b: [mem 0x000c8000-0x000cbfff] could not be reserved
[ 1.097393] system 00:0b: [mem 0x000d0000-0x000d3fff] could not be reserved
[ 1.097395] system 00:0b: [mem 0x000d8000-0x000dbfff] could not be reserved
[ 1.097397] system 00:0b: [mem 0x000e0000-0x000e3fff] could not be reserved
[ 1.097399] system 00:0b: [mem 0x000e8000-0x000ebfff] could not be reserved
[ 1.097401] system 00:0b: [mem 0x000f0000-0x000fffff] could not be reserved
[ 1.097404] system 00:0b: [mem 0x00100000-0x9c7fffff] could not be reserved
[ 1.097406] system 00:0b: [mem 0xfec00000-0xfed3ffff] could not be reserved
[ 1.097409] system 00:0b: [mem 0xfed4c000-0xffffffff] could not be reserved
[ 1.097414] system 00:0b: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 1.097664] pnp: PnP ACPI: found 12 devices
[ 1.105411] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 1.105422] pci 0000:00:1c.0: bridge window [io 0x1000-0x0fff] to [bus 01] add_size 1000
[ 1.105426] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 01] add_size 200000 add_align 100000
[ 1.105428] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff] to [bus 01] add_size 200000 add_align 100000
[ 1.105433] pci 0000:05:01.0: bridge window [io 0x1000-0x0fff] to [bus 07-3b] add_size 1000
[ 1.105437] pci 0000:04:00.0: bridge window [io 0x1000-0x0fff] to [bus 05-3c] add_size 1000
[ 1.105439] pci 0000:00:1d.0: bridge window [io 0x1000-0x0fff] to [bus 04-3c] add_size 1000
[ 1.105449] pci 0000:00:1c.0: BAR 14: assigned [mem 0x9c800000-0x9c9fffff]
[ 1.105457] pci 0000:00:1c.0: BAR 15: assigned [mem 0x9ca00000-0x9cbfffff 64bit pref]
[ 1.105461] pci 0000:00:1c.0: BAR 13: assigned [io 0x2000-0x2fff]
[ 1.105464] pci 0000:00:1d.0: BAR 13: assigned [io 0x3000-0x3fff]
[ 1.105467] pci 0000:00:1c.0: PCI bridge to [bus 01]
[ 1.105472] pci 0000:00:1c.0: bridge window [io 0x2000-0x2fff]
[ 1.105477] pci 0000:00:1c.0: bridge window [mem 0x9c800000-0x9c9fffff]
[ 1.105481] pci 0000:00:1c.0: bridge window [mem 0x9ca00000-0x9cbfffff 64bit pref]
[ 1.105488] pci 0000:00:1c.6: PCI bridge to [bus 03]
[ 1.105495] pci 0000:00:1c.6: bridge window [mem 0xec100000-0xec1fffff]
[ 1.105504] pci 0000:04:00.0: BAR 13: assigned [io 0x3000-0x3fff]
[ 1.105507] pci 0000:05:01.0: BAR 13: assigned [io 0x3000-0x3fff]
[ 1.105509] pci 0000:05:00.0: PCI bridge to [bus 06]
[ 1.105516] pci 0000:05:00.0: bridge window [mem 0xea000000-0xea0fffff]
[ 1.105527] pci 0000:05:01.0: PCI bridge to [bus 07-3b]
[ 1.105530] pci 0000:05:01.0: bridge window [io 0x3000-0x3fff]
[ 1.105536] pci 0000:05:01.0: bridge window [mem 0xd4000000-0xe9efffff]
[ 1.105541] pci 0000:05:01.0: bridge window [mem 0xb0000000-0xd1ffffff 64bit pref]
[ 1.105549] pci 0000:05:02.0: PCI bridge to [bus 3c]
[ 1.105555] pci 0000:05:02.0: bridge window [mem 0xe9f00000-0xe9ffffff]
[ 1.105566] pci 0000:04:00.0: PCI bridge to [bus 05-3c]
[ 1.105569] pci 0000:04:00.0: bridge window [io 0x3000-0x3fff]
[ 1.105575] pci 0000:04:00.0: bridge window [mem 0xd4000000-0xea0fffff]
[ 1.105580] pci 0000:04:00.0: bridge window [mem 0xb0000000-0xd1ffffff 64bit pref]
[ 1.105587] pci 0000:00:1d.0: PCI bridge to [bus 04-3c]
[ 1.105590] pci 0000:00:1d.0: bridge window [io 0x3000-0x3fff]
[ 1.105594] pci 0000:00:1d.0: bridge window [mem 0xd4000000-0xea0fffff]
[ 1.105598] pci 0000:00:1d.0: bridge window [mem 0xb0000000-0xd1ffffff 64bit pref]
[ 1.105604] pci 0000:00:1d.2: PCI bridge to [bus 3d]
[ 1.105609] pci 0000:00:1d.2: bridge window [mem 0xec000000-0xec0fffff]
[ 1.105618] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 1.105620] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 1.105622] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 1.105624] pci_bus 0000:00: resource 7 [mem 0x9c800000-0xf7ffffff window]
[ 1.105626] pci_bus 0000:00: resource 8 [mem 0xfd000000-0xfe7fffff window]
[ 1.105629] pci_bus 0000:01: resource 0 [io 0x2000-0x2fff]
[ 1.105631] pci_bus 0000:01: resource 1 [mem 0x9c800000-0x9c9fffff]
[ 1.105632] pci_bus 0000:01: resource 2 [mem 0x9ca00000-0x9cbfffff 64bit pref]
[ 1.105634] pci_bus 0000:03: resource 1 [mem 0xec100000-0xec1fffff]
[ 1.105636] pci_bus 0000:04: resource 0 [io 0x3000-0x3fff]
[ 1.105638] pci_bus 0000:04: resource 1 [mem 0xd4000000-0xea0fffff]
[ 1.105640] pci_bus 0000:04: resource 2 [mem 0xb0000000-0xd1ffffff 64bit pref]
[ 1.105641] pci_bus 0000:05: resource 0 [io 0x3000-0x3fff]
[ 1.105643] pci_bus 0000:05: resource 1 [mem 0xd4000000-0xea0fffff]
[ 1.105645] pci_bus 0000:05: resource 2 [mem 0xb0000000-0xd1ffffff 64bit pref]
[ 1.105647] pci_bus 0000:06: resource 1 [mem 0xea000000-0xea0fffff]
[ 1.105649] pci_bus 0000:07: resource 0 [io 0x3000-0x3fff]
[ 1.105650] pci_bus 0000:07: resource 1 [mem 0xd4000000-0xe9efffff]
[ 1.105652] pci_bus 0000:07: resource 2 [mem 0xb0000000-0xd1ffffff 64bit pref]
[ 1.105654] pci_bus 0000:3c: resource 1 [mem 0xe9f00000-0xe9ffffff]
[ 1.105656] pci_bus 0000:3d: resource 1 [mem 0xec000000-0xec0fffff]
[ 1.106168] NET: Registered protocol family 2
[ 1.106681] IP idents hash table entries: 262144 (order: 9, 2097152 bytes)
[ 1.110711] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes)
[ 1.110793] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 1.111098] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 1.111275] TCP: Hash tables configured (established 131072 bind 65536)
[ 1.111396] UDP hash table entries: 8192 (order: 6, 262144 bytes)
[ 1.111463] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes)
[ 1.111774] NET: Registered protocol family 1
[ 1.111782] NET: Registered protocol family 44
[ 1.111799] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 1.114088] pci 0000:04:00.0: enabling device (0006 -> 0007)
[ 1.114718] PCI: CLS 128 bytes, default 64
[ 1.114792] Unpacking initramfs...
[ 1.451086] Freeing initrd memory: 17364K
[ 1.487037] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 1.487040] software IO TLB: mapped [mem 0x89b58000-0x8db58000] (64MB)
[ 1.487107] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x1e71785e5dd, max_idle_ns: 440795244814 ns
[ 1.487140] clocksource: Switched to clocksource tsc
[ 1.487444] Scanning for low memory corruption every 60 seconds
[ 1.489119] Initialise system trusted keyrings
[ 1.489196] Key type blacklist registered
[ 1.489330] workingset: timestamp_bits=41 max_order=22 bucket_order=0
[ 1.493862] zbud: loaded
[ 1.498345] Key type asymmetric registered
[ 1.498347] Asymmetric key parser 'x509' registered
[ 1.498363] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 1.498435] io scheduler noop registered
[ 1.498436] io scheduler deadline registered
[ 1.498560] io scheduler cfq registered
[ 1.498563] io scheduler mq-deadline registered
[ 1.498564] io scheduler kyber registered
[ 1.498673] io scheduler bfq registered
[ 1.498780] io scheduler bfq-sq registered (default)
[ 1.498782] BFQ I/O-scheduler: v10 (with cgroups support)
[ 1.498894] io scheduler bfq-mq registered
[ 1.498895] BFQ I/O-scheduler: v10 (with cgroups support)
[ 1.499978] pcieport 0000:00:1c.0: Signaling PME with IRQ 122
[ 1.500019] pciehp 0000:00:1c.0:pcie004: Slot #0 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ LLActRep+
[ 1.500574] pcieport 0000:00:1c.6: Signaling PME with IRQ 123
[ 1.501737] pcieport 0000:00:1d.0: Signaling PME with IRQ 124
[ 1.501803] pciehp 0000:00:1d.0:pcie004: Slot #8 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ LLActRep+
[ 1.502367] pcieport 0000:00:1d.2: Signaling PME with IRQ 125
[ 1.502722] pcieport 0000:05:01.0: enabling device (0006 -> 0007)
[ 1.502937] pciehp 0000:05:01.0:pcie204: Slot #1 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ LLActRep+
[ 1.503332] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 1.503589] efifb: probing for efifb
[ 1.503612] efifb: No BGRT, not showing boot graphics
[ 1.503614] efifb: framebuffer at 0xa0000000, using 8128k, total 8128k
[ 1.503616] efifb: mode is 1920x1080x32, linelength=7680, pages=1
[ 1.503617] efifb: scrolling: redraw
[ 1.503619] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 1.503761] fbcon: Deferring console take-over
[ 1.503763] fb0: EFI VGA frame buffer device
[ 1.503777] intel_idle: MWAIT substates: 0x11142120
[ 1.503778] intel_idle: v0.4.1 model 0x8E
[ 1.505196] intel_idle: lapic_timer_reliable_states 0xffffffff
[ 1.505351] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0
[ 1.505378] ACPI: Sleep Button [SLPB]
[ 1.505497] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input1
[ 1.505516] ACPI: Lid Switch [LID]
[ 1.505627] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 1.505645] ACPI: Power Button [PWRF]
[ 1.512376] thermal LNXTHERM:00: registered as thermal_zone0
[ 1.512378] ACPI: Thermal Zone [THM0] (45 C)
[ 1.512918] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.513964] AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[ 1.513965] AMD IOMMUv2 functionality not available on this system
[ 1.516532] nvme nvme0: pci function 0000:3d:00.0
[ 1.516586] usbcore: registered new interface driver usbserial_generic
[ 1.516592] usbserial: USB Serial support registered for generic
[ 1.516886] rtc_cmos 00:04: RTC can wake from S4
[ 1.517930] rtc_cmos 00:04: registered as rtc0
[ 1.517960] rtc_cmos 00:04: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[ 1.518083] intel_pstate: Intel P-state driver initializing
[ 1.519276] intel_pstate: HWP enabled
[ 1.519459] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.519549] intel_pmc_core: initialized
[ 1.520439] NET: Registered protocol family 10
[ 1.533511] Segment Routing with IPv6
[ 1.533570] NET: Registered protocol family 17
[ 1.534738] mce: Using 10 MCE banks
[ 1.534785] RAS: Correctable Errors collector initialized.
[ 1.534918] microcode: sig=0x806ea, pf=0x80, revision=0xf4
[ 1.535250] microcode: Microcode Update Driver: v2.2.
[ 1.535299] sched_clock: Marking stable (1544264839, -9021973)->(1561653803, -26410937)
[ 1.535879] registered taskstats version 1
[ 1.535918] Loading compiled-in X.509 certificates
[ 1.543218] Loaded X.509 cert 'Build time autogenerated kernel key: 8e8b3dca863cff7ca0c6eaacbf9b54568cce9347'
[ 1.543279] zswap: loaded using pool lzo/zbud
[ 1.554273] Key type big_key registered
[ 1.554278] AppArmor: AppArmor sha1 policy hashing enabled
[ 1.556346] Magic number: 8:649:991
[ 1.556350] machinecheck machinecheck4: hash matches
[ 1.556410] memory memory34: hash matches
[ 1.556555] rtc_cmos 00:04: setting system clock to 2024-05-23 14:59:13 UTC (1716476353)
[ 1.762968] nvme0n1: p1 p2
[ 1.813635] CPU3: Core temperature above threshold, cpu clock throttled (total events = 1)
[ 1.813636] CPU7: Core temperature above threshold, cpu clock throttled (total events = 1)
[ 1.813637] CPU7: Package temperature above threshold, cpu clock throttled (total events = 1)
[ 1.813637] CPU3: Package temperature above threshold, cpu clock throttled (total events = 1)
[ 1.813686] CPU4: Package temperature above threshold, cpu clock throttled (total events = 1)
[ 1.813686] CPU0: Package temperature above threshold, cpu clock throttled (total events = 1)
[ 1.813687] CPU5: Package temperature above threshold, cpu clock throttled (total events = 1)
[ 1.813688] CPU6: Package temperature above threshold, cpu clock throttled (total events = 1)
[ 1.813689] CPU2: Package temperature above threshold, cpu clock throttled (total events = 1)
[ 1.813690] CPU1: Package temperature above threshold, cpu clock throttled (total events = 1)
[ 2.034427] Freeing unused decrypted memory: 2040K
[ 2.230653] CPU3: Core temperature/speed normal
[ 2.230654] CPU3: Package temperature/speed normal
[ 2.230655] CPU7: Core temperature/speed normal
[ 2.230655] CPU7: Package temperature/speed normal
[ 2.230697] CPU0: Package temperature/speed normal
[ 2.230698] CPU4: Package temperature/speed normal
[ 2.230699] CPU6: Package temperature/speed normal
[ 2.230699] CPU5: Package temperature/speed normal
[ 2.230700] CPU1: Package temperature/speed normal
[ 2.230701] CPU2: Package temperature/speed normal
[ 2.262842] Freeing unused kernel image memory: 1628K
[ 2.277384] Write protecting the kernel read-only data: 18432k
[ 2.278369] Freeing unused kernel image memory: 2008K
[ 2.278541] Freeing unused kernel image memory: 468K
[ 2.284770] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 2.284770] x86/mm: Checking user space page tables
[ 2.290978] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 2.290979] Run /init as init process
[ 2.497192] i8042: PNP: PS/2 Controller [PNP0303:KBD,PNP0f13:MOU] at 0x60,0x64 irq 1,12
[ 2.499026] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 2.499029] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 2.511264] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 2.511273] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[ 2.512360] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x0000000081109810
[ 2.512625] xhci_hcd 0000:00:14.0: cache line size of 128 is not supported
[ 2.512911] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 2.512913] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.512914] usb usb1: Product: xHCI Host Controller
[ 2.512916] usb usb1: Manufacturer: Linux 4.19.313-1-MANJARO xhci-hcd
[ 2.512917] usb usb1: SerialNumber: 0000:00:14.0
[ 2.513147] hub 1-0:1.0: USB hub found
[ 2.513173] hub 1-0:1.0: 12 ports detected
[ 2.514878] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 2.514881] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[ 2.514885] xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed
[ 2.514978] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[ 2.514979] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.514980] usb usb2: Product: xHCI Host Controller
[ 2.514982] usb usb2: Manufacturer: Linux 4.19.313-1-MANJARO xhci-hcd
[ 2.514983] usb usb2: SerialNumber: 0000:00:14.0
[ 2.515170] hub 2-0:1.0: USB hub found
[ 2.515189] hub 2-0:1.0: 6 ports detected
[ 2.516149] xhci_hcd 0000:3c:00.0: xHCI Host Controller
[ 2.516152] xhci_hcd 0000:3c:00.0: new USB bus registered, assigned bus number 3
[ 2.517293] xhci_hcd 0000:3c:00.0: hcc params 0x200077c1 hci version 0x110 quirks 0x0000000000009810
[ 2.517610] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 2.517612] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.517613] usb usb3: Product: xHCI Host Controller
[ 2.517614] usb usb3: Manufacturer: Linux 4.19.313-1-MANJARO xhci-hcd
[ 2.517615] usb usb3: SerialNumber: 0000:3c:00.0
[ 2.517751] hub 3-0:1.0: USB hub found
[ 2.517763] hub 3-0:1.0: 2 ports detected
[ 2.518548] xhci_hcd 0000:3c:00.0: xHCI Host Controller
[ 2.518551] xhci_hcd 0000:3c:00.0: new USB bus registered, assigned bus number 4
[ 2.518553] xhci_hcd 0000:3c:00.0: Host supports USB 3.1 Enhanced SuperSpeed
[ 2.518690] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[ 2.518691] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.518692] usb usb4: Product: xHCI Host Controller
[ 2.518693] usb usb4: Manufacturer: Linux 4.19.313-1-MANJARO xhci-hcd
[ 2.518693] usb usb4: SerialNumber: 0000:3c:00.0
[ 2.518865] hub 4-0:1.0: USB hub found
[ 2.518879] hub 4-0:1.0: 2 ports detected
[ 2.532677] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3
[ 2.561706] fbcon: Taking over console
[ 2.561822] Console: switching to colour frame buffer device 240x67
[ 2.594793] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.701354] systemd[1]: systemd 255.5-3-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
[ 2.701366] systemd[1]: Detected architecture x86-64.
[ 2.702486] systemd[1]: Hostname set to <HandSoup>.
[ 2.715658] systemd[1]: bpf-lsm: BPF LSM hook not enabled in the kernel, BPF LSM not supported
[ 2.827021] usb 1-7: new full-speed USB device number 2 using xhci_hcd
[ 3.007980] usb 1-7: New USB device found, idVendor=8087, idProduct=0a2b, bcdDevice= 0.10
[ 3.007981] usb 1-7: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.012504] systemd[1]: Queued start job for default target Graphical Interface.
[ 3.018519] systemd[1]: Created slice Slice /system/dirmngr.
[ 3.018785] systemd[1]: Created slice Slice /system/getty.
[ 3.019065] systemd[1]: Created slice Slice /system/gpg-agent.
[ 3.019350] systemd[1]: Created slice Slice /system/gpg-agent-browser.
[ 3.019551] systemd[1]: Created slice Slice /system/gpg-agent-extra.
[ 3.019764] systemd[1]: Created slice Slice /system/gpg-agent-ssh.
[ 3.019956] systemd[1]: Created slice Slice /system/keyboxd.
[ 3.020179] systemd[1]: Created slice Slice /system/maia-console.
[ 3.020486] systemd[1]: Created slice Slice /system/modprobe.
[ 3.020693] systemd[1]: Created slice Slice /system/systemd-fsck.
[ 3.020869] systemd[1]: Created slice User and Session Slice.
[ 3.020951] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 3.020994] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 3.021250] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 3.021276] systemd[1]: Expecting device /dev/disk/by-uuid/86CA-BD85...
[ 3.021293] systemd[1]: Reached target Local Encrypted Volumes.
[ 3.021311] systemd[1]: Reached target Login Prompts.
[ 3.021327] systemd[1]: Reached target Local Integrity Protected Volumes.
[ 3.021348] systemd[1]: Reached target Remote File Systems.
[ 3.021364] systemd[1]: Reached target Slice Units.
[ 3.021380] systemd[1]: Reached target Mounting snaps.
[ 3.021396] systemd[1]: Reached target Mounted snaps.
[ 3.021414] systemd[1]: Reached target Swaps.
[ 3.021432] systemd[1]: Reached target System Time Set.
[ 3.021469] systemd[1]: Reached target Local Verity Protected Volumes.
[ 3.021558] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 3.021796] systemd[1]: Listening on LVM2 poll daemon socket.
[ 3.022912] systemd[1]: Listening on Process Core Dump Socket.
[ 3.023015] systemd[1]: Listening on Journal Socket (/dev/log).
[ 3.023114] systemd[1]: Listening on Journal Socket.
[ 3.023134] systemd[1]: TPM2 PCR Extension (Varlink) was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[ 3.023329] systemd[1]: Listening on udev Control Socket.
[ 3.023407] systemd[1]: Listening on udev Kernel Socket.
[ 3.024340] systemd[1]: Mounting Huge Pages File System...
[ 3.025010] systemd[1]: Mounting POSIX Message Queue File System...
[ 3.025680] systemd[1]: Mounting Kernel Debug File System...
[ 3.026335] systemd[1]: Mounting Kernel Trace File System...
[ 3.027407] systemd[1]: Starting Load AppArmor profiles...
[ 3.028405] systemd[1]: Starting Create List of Static Device Nodes...
[ 3.030208] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 3.031810] systemd[1]: Starting Load Kernel Module configfs...
[ 3.033394] systemd[1]: Starting Load Kernel Module dm_mod...
[ 3.035400] systemd[1]: Starting Load Kernel Module drm...
[ 3.036459] systemd[1]: Starting Load Kernel Module fuse...
[ 3.037503] systemd[1]: Starting Load Kernel Module loop...
[ 3.037594] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
[ 3.040536] systemd[1]: Starting Load Kernel Modules...
[ 3.040576] systemd[1]: TPM2 PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[ 3.043419] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 3.043510] systemd[1]: TPM2 SRK Setup (Early) was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[ 3.046503] systemd[1]: Starting Coldplug All udev Devices...
[ 3.046704] Linux agpgart interface v0.103
[ 3.048297] systemd[1]: Mounted Huge Pages File System.
[ 3.048453] systemd[1]: Mounted POSIX Message Queue File System.
[ 3.048612] systemd[1]: Mounted Kernel Debug File System.
[ 3.048729] systemd[1]: Mounted Kernel Trace File System.
[ 3.048992] systemd[1]: Finished Create List of Static Device Nodes.
[ 3.049309] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 3.049457] systemd[1]: Finished Load Kernel Module configfs.
[ 3.052248] random: lvm: uninitialized urandom read (4 bytes read)
[ 3.052314] device-mapper: uevent: version 1.0.3
[ 3.053011] fuse init (API version 7.27)
[ 3.054561] systemd[1]: Mounting Kernel Configuration File System...
[ 3.054868] device-mapper: ioctl: 4.39.0-ioctl (2018-04-03) initialised: dm-devel@redhat.com
[ 3.056215] EXT4-fs (nvme0n1p2): re-mounted. Opts: (null)
[ 3.056242] loop: module loaded
[ 3.057003] systemd[1]: Starting Create Static Device Nodes in /dev gracefully...
[ 3.057910] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
[ 3.058077] systemd[1]: Finished Load Kernel Module dm_mod.
[ 3.058418] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 3.058551] systemd[1]: Finished Load Kernel Module fuse.
[ 3.058859] systemd[1]: modprobe@loop.service: Deactivated successfully.
[ 3.058978] systemd[1]: Finished Load Kernel Module loop.
[ 3.059144] systemd[1]: Finished Load Kernel Modules.
[ 3.059300] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 3.060254] systemd[1]: Mounting FUSE Control File System...
[ 3.061075] systemd[1]: Rebuild Hardware Database was skipped because no trigger condition checks were met.
[ 3.062128] systemd[1]: Starting Load/Save OS Random Seed...
[ 3.062280] systemd[1]: Repartition Root Disk was skipped because no trigger condition checks were met.
[ 3.063234] systemd[1]: Starting Apply Kernel Variables...
[ 3.063266] systemd[1]: TPM2 SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[ 3.064009] systemd[1]: Mounted Kernel Configuration File System.
[ 3.069735] systemd[1]: Mounted FUSE Control File System.
[ 3.077385] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 3.077540] systemd[1]: Finished Load Kernel Module drm.
[ 3.111854] audit: type=1400 audit(1716476355.050:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=270 comm="apparmor_parser"
[ 3.115293] audit: type=1400 audit(1716476355.050:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=271 comm="apparmor_parser"
[ 3.115622] audit: type=1400 audit(1716476355.050:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=271 comm="apparmor_parser"
[ 3.131912] audit: type=1400 audit(1716476355.070:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="samba-bgqd" pid=273 comm="apparmor_parser"
[ 3.135674] audit: type=1400 audit(1716476355.070:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="php-fpm" pid=272 comm="apparmor_parser"
[ 3.137053] audit: type=1400 audit(1716476355.080:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="samba-rpcd" pid=275 comm="apparmor_parser"
[ 3.153981] audit: type=1400 audit(1716476355.090:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="ping" pid=268 comm="apparmor_parser"
[ 3.157133] usb 2-3: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[ 3.172134] audit: type=1400 audit(1716476355.110:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="samba-dcerpcd" pid=274 comm="apparmor_parser"
[ 3.182161] audit: type=1400 audit(1716476355.120:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="samba-rpcd-spoolss" pid=279 comm="apparmor_parser"
[ 3.197859] usb 2-3: New USB device found, idVendor=0bda, idProduct=0316, bcdDevice= 2.04
[ 3.197861] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.197863] usb 2-3: Product: USB3.0-CRW
[ 3.197865] usb 2-3: Manufacturer: Generic
[ 3.197866] usb 2-3: SerialNumber: 20120501030900000
[ 3.220090] systemd[1]: Finished Coldplug All udev Devices.
[ 3.308587] systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
[ 3.316421] systemd[1]: Finished Apply Kernel Variables.
[ 3.324079] systemd[1]: Starting CLI Netfilter Manager...
[ 3.336999] usb 1-8: new high-speed USB device number 3 using xhci_hcd
[ 3.340531] systemd[1]: Finished CLI Netfilter Manager.
[ 3.353107] systemd[1]: Finished Create Static Device Nodes in /dev gracefully.
[ 3.354386] systemd[1]: Starting Create System Users...
[ 3.528286] usb 1-8: New USB device found, idVendor=5986, idProduct=2113, bcdDevice=54.22
[ 3.528288] usb 1-8: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.528290] usb 1-8: Product: Integrated Camera
[ 3.528292] usb 1-8: Manufacturer: SunplusIT Inc
[ 3.604712] systemd[1]: Finished Create System Users.
[ 3.606017] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 3.681081] systemd[1]: Finished Load AppArmor profiles.
[ 3.681986] systemd[1]: Starting Load AppArmor profiles managed internally by snapd...
[ 3.687021] usb 1-9: new full-speed USB device number 4 using xhci_hcd
[ 3.692113] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 331 (snapd-apparmor)
[ 3.692838] systemd[1]: Mounting Arbitrary Executable File Formats File System...
[ 3.699885] systemd[1]: Mounted Arbitrary Executable File Formats File System.
[ 3.703705] systemd[1]: Finished Load AppArmor profiles managed internally by snapd.
[ 3.773311] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 3.773413] systemd[1]: Reached target Preparation for Local File Systems.
[ 3.774367] systemd[1]: Mounting /tmp...
[ 3.774389] systemd[1]: Virtual Machine and Container Storage (Compatibility) was skipped because of an unmet condition check (ConditionPathExists=/var/lib/machines.raw).
[ 3.775886] systemd[1]: Started Entropy Daemon based on the HAVEGE algorithm.
[ 3.777734] systemd[1]: Starting Journal Service...
[ 3.778920] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[ 3.780333] systemd[1]: Mounted /tmp.
[ 3.795553] systemd-journald[341]: Collecting audit messages is disabled.
[ 3.846598] systemd[1]: Started Journal Service.
[ 3.856174] systemd-journald[341]: Received client request to flush runtime journal.
[ 3.862681] systemd-journald[341]: /var/log/journal/d7912df23b194504a7ed53bd0a0f15eb/system.journal: Journal file uses a different sequence number ID, rotating.
[ 3.862685] systemd-journald[341]: Rotating system journal.
[ 3.868225] usb 1-9: New USB device found, idVendor=06cb, idProduct=009a, bcdDevice= 1.64
[ 3.868227] usb 1-9: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[ 3.868229] usb 1-9: SerialNumber: a6fd98866605
[ 3.993624] SCSI subsystem initialized
[ 4.001609] usb-storage 2-3:1.0: USB Mass Storage device detected
[ 4.010102] scsi host0: usb-storage 2-3:1.0
[ 4.010348] usbcore: registered new interface driver usb-storage
[ 4.013924] usbcore: registered new interface driver uas
[ 4.080079] ACPI: AC Adapter [AC] (off-line)
[ 4.099379] battery: ACPI: Battery Slot [BAT0] (battery present)
[ 4.127272] battery: ACPI: Battery Slot [BAT1] (battery present)
[ 4.248509] i801_smbus 0000:00:1f.4: enabling device (0000 -> 0003)
[ 4.248656] i801_smbus 0000:00:1f.4: SPD Write Disable is set
[ 4.248709] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[ 4.251994] mei_me 0000:00:16.0: enabling device (0004 -> 0006)
[ 4.252668] RAPL PMU: API unit is 2^-32 Joules, 5 fixed counters, 655360 ms ovfl timer
[ 4.252670] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[ 4.252671] RAPL PMU: hw unit of domain package 2^-14 Joules
[ 4.252671] RAPL PMU: hw unit of domain dram 2^-14 Joules
[ 4.252672] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[ 4.252673] RAPL PMU: hw unit of domain psys 2^-14 Joules
[ 4.266564] resource sanity check: requesting [mem 0xfed10000-0xfed15fff], which spans more than pnp 00:08 [mem 0xfed10000-0xfed13fff]
[ 4.266573] caller snb_uncore_imc_init_box+0x6c/0xb0 [intel_uncore] mapping multiple BARs
[ 4.276156] proc_thermal 0000:00:04.0: enabling device (0000 -> 0002)
[ 4.284248] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 4.284249] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 4.284495] e1000e 0000:00:1f.6: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[ 4.287623] thunderbolt 0000:06:00.0: NHI initialized, starting thunderbolt
[ 4.287627] thunderbolt 0000:06:00.0: allocating TX ring 0 of size 10
[ 4.287645] thunderbolt 0000:06:00.0: allocating RX ring 0 of size 10
[ 4.287674] thunderbolt 0000:06:00.0: control channel created
[ 4.287675] thunderbolt 0000:06:00.0: control channel starting...
[ 4.287677] thunderbolt 0000:06:00.0: starting TX ring 0
[ 4.287684] thunderbolt 0000:06:00.0: enabling interrupt at register 0x38200 bit 0 (0x0 -> 0x1)
[ 4.287686] thunderbolt 0000:06:00.0: starting RX ring 0
[ 4.287693] thunderbolt 0000:06:00.0: enabling interrupt at register 0x38200 bit 12 (0x1 -> 0x1001)
[ 4.295517] Non-volatile memory driver v1.3
[ 4.310288] cryptd: max_cpu_qlen set to 1000
[ 4.334207] Bluetooth: Core ver 2.22
[ 4.334226] NET: Registered protocol family 31
[ 4.334227] Bluetooth: HCI device and connection manager initialized
[ 4.334230] Bluetooth: HCI socket layer initialized
[ 4.334232] Bluetooth: L2CAP socket layer initialized
[ 4.334239] Bluetooth: SCO socket layer initialized
[ 4.335730] thinkpad_acpi: ThinkPad ACPI Extras v0.26
[ 4.335731] thinkpad_acpi: http://ibm-acpi.sf.net/
[ 4.335732] thinkpad_acpi: ThinkPad BIOS N24ET76W (1.51 ), EC unknown
[ 4.335733] thinkpad_acpi: Lenovo ThinkPad T480, model 20L50018US
[ 4.341252] AVX2 version of gcm_enc/dec engaged.
[ 4.341253] AES CTR mode by8 optimization enabled
[ 4.359356] thinkpad_acpi: radio switch found; radios are enabled
[ 4.359651] thinkpad_acpi: This ThinkPad has standard ACPI backlight brightness control, supported by the ACPI video driver
[ 4.359652] thinkpad_acpi: Disabling thinkpad-acpi brightness events by default...
[ 4.366153] usbcore: registered new interface driver btusb
[ 4.381371] Bluetooth: hci0: Firmware revision 0.1 build 19 week 44 2021
[ 4.390143] thunderbolt 0000:06:00.0: current switch config:
[ 4.390147] thunderbolt 0000:06:00.0: Switch: 8086:15c0 (Revision: 1, TB Version: 2)
[ 4.390149] thunderbolt 0000:06:00.0: Max Port Number: 5
[ 4.390150] thunderbolt 0000:06:00.0: Config:
[ 4.390153] thunderbolt 0000:06:00.0: Upstream Port Number: 3 Depth: 0 Route String: 0x0 Enabled: 1, PlugEventsDelay: 254ms
[ 4.390154] thunderbolt 0000:06:00.0: unknown1: 0x0 unknown4: 0x0
[ 4.401046] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 4.425181] proc_thermal 0000:00:04.0: Creating sysfs group for PROC_THERMAL_PCI
[ 4.427760] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 4.428088] cfg80211: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[ 4.428573] thinkpad_acpi: rfkill switch tpacpi_bluetooth_sw: radio is unblocked
[ 4.444502] thinkpad_acpi: battery 2 registered (start 0, stop 100)
[ 4.448101] thinkpad_acpi: battery 1 registered (start 0, stop 100)
[ 4.448106] battery: new extension: ThinkPad Battery Extension
[ 4.448161] input: ThinkPad Extra Buttons as /devices/platform/thinkpad_acpi/input/input6
[ 4.450548] media: Linux media interface: v0.10
[ 4.518890] thunderbolt 0000:06:00.0: 0: uid: 0x1094270bdd14e00
[ 4.519017] thunderbolt 0000:06:00.0: Port 0: 8086:15c0 (Revision: 1, TB Version: 1, Type: Port (0x1))
[ 4.519019] thunderbolt 0000:06:00.0: Max hop id (in/out): 7/7
[ 4.519020] thunderbolt 0000:06:00.0: Max counters: 8
[ 4.519022] thunderbolt 0000:06:00.0: NFC Credits: 0x800000
[ 4.520121] thunderbolt 0000:06:00.0: Port 1: 8086:15c0 (Revision: 1, TB Version: 1, Type: Port (0x1))
[ 4.520123] thunderbolt 0000:06:00.0: Max hop id (in/out): 15/15
[ 4.520125] thunderbolt 0000:06:00.0: Max counters: 16
[ 4.520126] thunderbolt 0000:06:00.0: NFC Credits: 0x3c00000
[ 4.520632] thunderbolt 0000:06:00.0: Port 2: 8086:15c0 (Revision: 1, TB Version: 1, Type: Port (0x1))
[ 4.520635] thunderbolt 0000:06:00.0: Max hop id (in/out): 15/15
[ 4.520636] thunderbolt 0000:06:00.0: Max counters: 16
[ 4.520638] thunderbolt 0000:06:00.0: NFC Credits: 0x3c00000
[ 4.520759] thunderbolt 0000:06:00.0: Port 3: 8086:15c0 (Revision: 1, TB Version: 1, Type: NHI (0x2))
[ 4.520761] thunderbolt 0000:06:00.0: Max hop id (in/out): 11/11
[ 4.520762] thunderbolt 0000:06:00.0: Max counters: 16
[ 4.520764] thunderbolt 0000:06:00.0: NFC Credits: 0x1000000
[ 4.520889] thunderbolt 0000:06:00.0: Port 4: 8086:15c0 (Revision: 1, TB Version: 1, Type: PCIe (0x100101))
[ 4.520891] thunderbolt 0000:06:00.0: Max hop id (in/out): 8/8
[ 4.520892] thunderbolt 0000:06:00.0: Max counters: 2
[ 4.520894] thunderbolt 0000:06:00.0: NFC Credits: 0x800000
[ 4.521014] thunderbolt 0000:06:00.0: Port 5: 8086:15c0 (Revision: 1, TB Version: 1, Type: DP/HDMI (0xe0101))
[ 4.521015] thunderbolt 0000:06:00.0: Max hop id (in/out): 9/9
[ 4.521016] thunderbolt 0000:06:00.0: Max counters: 2
[ 4.521018] thunderbolt 0000:06:00.0: NFC Credits: 0x1000000
[ 4.539557] e1000e 0000:00:1f.6 0000:00:1f.6 (uninitialized): registered PHC clock
[ 4.562300] videodev: Linux video capture interface: v2.00
[ 4.573959] iTCO_vendor_support: vendor-support=0
[ 4.576203] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[ 4.576267] iTCO_wdt: Found a Intel PCH TCO device (Version=4, TCOBASE=0x0400)
[ 4.576390] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 4.611441] VFIO - User Level meta-driver version: 0.3
[ 4.611601] random: crng init done
[ 4.637554] Intel(R) Wireless WiFi driver for Linux
[ 4.637556] Copyright(c) 2003- 2015 Intel Corporation
[ 4.640179] e1000e 0000:00:1f.6 eth0: (PCI Express:2.5GT/s:Width x1) e8:6a:64:32:ef:e3
[ 4.640182] e1000e 0000:00:1f.6 eth0: Intel(R) PRO/1000 Network Connection
[ 4.640461] e1000e 0000:00:1f.6 eth0: MAC: 12, PHY: 12, PBA No: 1000FF-0FF
[ 4.681886] iwlwifi 0000:03:00.0: loaded firmware version 36.ca7b901d.0 op_mode iwlmvm
[ 4.712698] e1000e 0000:00:1f.6 enp0s31f6: renamed from eth0
[ 4.713787] uvcvideo: Found UVC 1.00 device Integrated Camera (5986:2113)
[ 4.737943] intel_rapl: Found RAPL domain package
[ 4.737944] intel_rapl: Found RAPL domain core
[ 4.737945] intel_rapl: Found RAPL domain uncore
[ 4.737946] intel_rapl: Found RAPL domain dram
[ 4.739168] input: Integrated Camera: Integrated C as /devices/pci0000:00/0000:00:14.0/usb1/1-8/1-8:1.0/input/input7
[ 4.739233] usbcore: registered new interface driver uvcvideo
[ 4.739234] USB Video Class driver (1.1.1)
[ 4.790385] checking generic (a0000000 7f0000) vs hw (a0000000 10000000)
[ 4.790386] fb: switching to inteldrmfb from EFI VGA
[ 4.790400] Console: switching to colour dummy device 80x25
[ 4.790490] [drm] Replacing VGA console driver
[ 4.793546] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 4.793546] [drm] Driver supports precise vblank timestamp query.
[ 4.793914] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 4.795415] [drm] Finished loading DMC firmware i915/kbl_dmc_ver1_04.bin (v1.4)
[ 4.880985] iwlwifi 0000:03:00.0: Detected Intel(R) Dual Band Wireless AC 8265, REV=0x230
[ 4.946807] iwlwifi 0000:03:00.0: base HW address: 18:56:80:01:02:20
[ 5.025299] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
[ 5.025489] thermal thermal_zone6: failed to read out thermal zone (-61)
[ 5.027613] iwlwifi 0000:03:00.0 wlp3s0: renamed from wlan0
[ 5.090461] scsi 0:0:0:0: Direct-Access Generic- SD/MMC 1.00 PQ: 0 ANSI: 6
[ 5.105647] psmouse serio1: synaptics: queried max coordinates: x [..5676], y [..4690]
[ 5.106463] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 5.136478] psmouse serio1: synaptics: queried min coordinates: x [1266..], y [1162..]
[ 5.136482] psmouse serio1: synaptics: Trying to set up SMBus access
[ 5.187535] rmi4_smbus 0-002c: registering SMbus-connected sensor
[ 5.285546] rmi4_f01 rmi4-00.fn01: found RMI device, manufacturer: Synaptics, product: TM3276-022, fw id: 2700066
[ 5.353266] input: Synaptics TM3276-022 as /devices/rmi4-00/input/input8
[ 5.356080] mousedev: PS/2 mouse device common for all mice
[ 5.358933] serio: RMI4 PS/2 pass-through port at rmi4-00.fn03
[ 5.382220] [drm] Initialized i915 1.6.0 20180719 for 0000:00:02.0 on minor 0
[ 5.433090] ACPI: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ 5.433600] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input10
[ 5.433892] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 5.550394] fbcon: inteldrmfb (fb0) is primary device
[ 5.583296] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 5.731823] psmouse serio2: trackpoint: IBM TrackPoint firmware: 0x0e, buttons: 3/3
[ 5.778390] input: TPPS/2 IBM TrackPoint as /devices/rmi4-00/rmi4-00.fn03/serio2/input/input9
[ 5.793434] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 5.793436] Bluetooth: BNEP filters: protocol multicast
[ 5.793442] Bluetooth: BNEP socket layer initialized
[ 6.753372] Console: switching to colour frame buffer device 240x67
[ 6.776727] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
[ 6.823871] NET: Registered protocol family 38
[ 6.855024] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC257: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[ 6.855027] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 6.855028] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[ 6.855029] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 6.855030] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 6.855032] snd_hda_codec_realtek hdaudioC0D0: Mic=0x19
[ 6.855033] snd_hda_codec_realtek hdaudioC0D0: Internal Mic=0x12
[ 6.860718] IPv6: ADDRCONF(NETDEV_UP): enp0s31f6: link is not ready
[ 6.932354] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1f.3/sound/card0/input11
[ 6.936085] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input12
[ 6.936254] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input13
[ 6.937025] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input14
[ 6.937096] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input15
[ 6.937134] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input16
[ 6.937162] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input17
[ 6.937209] input: HDA Intel PCH HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input18
[ 7.030503] kauditd_printk_skb: 55 callbacks suppressed
[ 7.030503] audit: type=1400 audit(1716476358.970:66): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/lib/snapd/snap-confine" pid=669 comm="apparmor_parser"
[ 7.097441] IPv6: ADDRCONF(NETDEV_UP): enp0s31f6: link is not ready
[ 7.098045] audit: type=1400 audit(1716476359.040:67): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=669 comm="apparmor_parser"
[ 7.108977] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready
[ 7.344352] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready
[ 7.599726] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready
[ 7.792279] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready
[ 11.130989] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready
[ 11.305482] wlp3s0: authenticate with c0:94:35:6d:6a:3d
[ 11.318513] wlp3s0: send auth to c0:94:35:6d:6a:3d (try 1/3)
[ 11.326106] wlp3s0: authenticated
[ 11.329749] wlp3s0: associate with c0:94:35:6d:6a:3d (try 1/3)
[ 11.337105] wlp3s0: RX AssocResp from c0:94:35:6d:6a:3d (capab=0x1011 status=0 aid=5)
[ 11.339086] wlp3s0: associated
[ 11.385333] IPv6: ADDRCONF(NETDEV_CHANGE): wlp3s0: link becomes ready
[ 11.420845] wlp3s0: Limiting TX power to 30 (30 - 0) dBm as advertised by c0:94:35:6d:6a:3d
[ 18.113850] systemd-journald[341]: /var/log/journal/d7912df23b194504a7ed53bd0a0f15eb/user-1000.journal: Journal file uses a different sequence number ID, rotating.
[ 19.579064] thunderbolt 0000:06:00.0: stopping RX ring 0
[ 19.579078] thunderbolt 0000:06:00.0: disabling interrupt at register 0x38200 bit 12 (0x1001 -> 0x1)
[ 19.579104] thunderbolt 0000:06:00.0: stopping TX ring 0
[ 19.579116] thunderbolt 0000:06:00.0: disabling interrupt at register 0x38200 bit 0 (0x1 -> 0x0)
[ 19.579131] thunderbolt 0000:06:00.0: control channel stopped
[ 25.035767] wlp3s0: deauthenticating from c0:94:35:6d:6a:3d by local choice (Reason: 3=DEAUTH_LEAVING)
[ 25.051196] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready
[ 25.061443] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready
[ 25.167050] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready
[ 25.199975] PM: suspend entry (deep)
[ 25.199977] PM: Syncing filesystems ... done.
[ 25.211465] Freezing user space processes ... (elapsed 0.015 seconds) done.
[ 25.227025] OOM killer disabled.
[ 25.227026] Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
[ 25.228185] Suspending console(s) (use no_console_suspend to debug)
[ 25.298507] e1000e: EEE TX LPI TIMER: 00000011
[ 25.658213] ACPI: EC: interrupt blocked
[ 25.978217] ACPI: Preparing to enter system sleep state S3
[ 25.987411] ACPI: EC: event blocked
[ 25.987412] ACPI: EC: EC stopped
[ 25.987414] PM: Saving platform NVS memory
[ 25.987425] Disabling non-boot CPUs ...
[ 26.049978] smpboot: CPU 1 is now offline
[ 26.108769] smpboot: CPU 2 is now offline
[ 26.148758] smpboot: CPU 3 is now offline
[ 26.199328] smpboot: CPU 4 is now offline
[ 26.248664] smpboot: CPU 5 is now offline
[ 26.298572] smpboot: CPU 6 is now offline
[ 26.338554] smpboot: CPU 7 is now offline
[ 26.344504] ACPI: Low-level resume complete
[ 26.344549] ACPI: EC: EC started
[ 26.344549] PM: Restoring platform NVS memory
[ 26.345153] Enabling non-boot CPUs ...
[ 26.345186] x86: Booting SMP configuration:
[ 26.345187] smpboot: Booting Node 0 Processor 1 APIC 0x2
[ 26.345597] cache: parent cpu1 should not be sleeping
[ 26.345732] CPU1 is up
[ 26.345753] smpboot: Booting Node 0 Processor 2 APIC 0x4
[ 26.346158] cache: parent cpu2 should not be sleeping
[ 26.346301] CPU2 is up
[ 26.346319] smpboot: Booting Node 0 Processor 3 APIC 0x6
[ 26.346725] cache: parent cpu3 should not be sleeping
[ 26.346876] CPU3 is up
[ 26.346892] smpboot: Booting Node 0 Processor 4 APIC 0x1
[ 26.347372] cache: parent cpu4 should not be sleeping
[ 26.347703] CPU4 is up
[ 26.347721] smpboot: Booting Node 0 Processor 5 APIC 0x3
[ 26.348122] cache: parent cpu5 should not be sleeping
[ 26.348284] CPU5 is up
[ 26.348300] smpboot: Booting Node 0 Processor 6 APIC 0x5
[ 26.348701] cache: parent cpu6 should not be sleeping
[ 26.348874] CPU6 is up
[ 26.348892] smpboot: Booting Node 0 Processor 7 APIC 0x7
[ 26.349301] cache: parent cpu7 should not be sleeping
[ 26.349484] CPU7 is up
[ 26.355288] ACPI: Waking up from system sleep state S3
[ 26.464754] ACPI: EC: interrupt unblocked
[ 26.772491] ACPI: EC: event unblocked
[ 26.776012] xhci_hcd 0000:3c:00.0: xHC error in resume, USBSTS 0x401, Reinit
[ 26.776017] usb usb3: root hub lost power or was reset
[ 26.776020] usb usb4: root hub lost power or was reset
[ 26.887080] usb 2-3: Disable of device-initiated U1 failed.
[ 26.890543] usb 2-3: Disable of device-initiated U2 failed.
[ 27.120539] usb 2-3: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[ 27.300351] usb 1-8: reset high-speed USB device number 3 using xhci_hcd
[ 27.630465] usb 1-7: reset full-speed USB device number 2 using xhci_hcd
[ 27.879683] thunderbolt 0000:06:00.0: control channel starting...
[ 27.879687] thunderbolt 0000:06:00.0: starting TX ring 0
[ 27.879698] thunderbolt 0000:06:00.0: enabling interrupt at register 0x38200 bit 0 (0x0 -> 0x1)
[ 27.879700] thunderbolt 0000:06:00.0: starting RX ring 0
[ 27.879710] thunderbolt 0000:06:00.0: enabling interrupt at register 0x38200 bit 12 (0x1 -> 0x1001)
[ 27.890328] acpi LNXPOWER:01: Turning OFF
[ 27.890978] OOM killer enabled.
[ 27.890979] Restarting tasks ...
[ 27.893134] Bluetooth: hci0: Bootloader revision 0.0 build 26 week 38 2015
[ 27.893338] done.
[ 27.894097] Bluetooth: hci0: Device revision is 16
[ 27.894100] Bluetooth: hci0: Secure boot is enabled
[ 27.894102] Bluetooth: hci0: OTP lock is enabled
[ 27.894104] Bluetooth: hci0: API lock is enabled
[ 27.894106] Bluetooth: hci0: Debug lock is disabled
[ 27.894109] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[ 27.900638] Bluetooth: hci0: Found device firmware: intel/ibt-12-16.sfi
[ 27.920033] usb 1-9: USB disconnect, device number 4
[ 27.945916] PM: suspend exit
[ 27.950199] pci_bus 0000:06: Allocating resources
[ 27.950212] pci_bus 0000:3c: Allocating resources
[ 27.950272] pci_bus 0000:06: Allocating resources
[ 27.950283] pci_bus 0000:3c: Allocating resources
[ 28.070261] e1000e: enp0s31f6 NIC Link is Down
[ 28.071191] IPv6: ADDRCONF(NETDEV_UP): enp0s31f6: link is not ready
[ 28.080035] usb 1-9: new full-speed USB device number 5 using xhci_hcd
[ 28.272090] usb 1-9: New USB device found, idVendor=06cb, idProduct=009a, bcdDevice= 1.64
[ 28.272092] usb 1-9: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[ 28.272093] usb 1-9: SerialNumber: a6fd98866605
[ 28.310330] IPv6: ADDRCONF(NETDEV_UP): enp0s31f6: link is not ready
[ 28.316653] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready
[ 28.878752] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready
[ 29.483585] Bluetooth: hci0: Waiting for firmware download to complete
[ 29.484145] Bluetooth: hci0: Firmware loaded in 1554709 usecs
[ 29.484352] Bluetooth: hci0: Waiting for device to boot
[ 29.497187] Bluetooth: hci0: Device booted in 12658 usecs
[ 29.502049] Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-12-16.ddc
[ 29.505154] Bluetooth: hci0: Applying Intel DDC parameters completed
[ 32.201938] wlp3s0: authenticate with c0:94:35:6d:6a:3d
[ 32.214944] wlp3s0: send auth to c0:94:35:6d:6a:3d (try 1/3)
[ 32.221749] wlp3s0: authenticated
[ 32.230138] wlp3s0: associate with c0:94:35:6d:6a:3d (try 1/3)
[ 32.237118] wlp3s0: RX AssocResp from c0:94:35:6d:6a:3d (capab=0x1011 status=0 aid=5)
[ 32.240499] wlp3s0: associated
[ 32.256591] IPv6: ADDRCONF(NETDEV_CHANGE): wlp3s0: link becomes ready
[ 32.299390] wlp3s0: Limiting TX power to 30 (30 - 0) dBm as advertised by c0:94:35:6d:6a:3d
[ 34.663994] wlp3s0: deauthenticating from c0:94:35:6d:6a:3d by local choice (Reason: 3=DEAUTH_LEAVING)
[ 34.674516] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready
[ 34.752343] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready
[ 35.038069] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready
[ 35.055246] PM: suspend entry (deep)
[ 35.055248] PM: Syncing filesystems ... done.
[ 35.060696] Freezing user space processes ... (elapsed 0.099 seconds) done.
[ 35.160230] OOM killer disabled.
[ 35.160232] Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
[ 35.161692] Suspending console(s) (use no_console_suspend to debug)
[ 35.231674] e1000e: EEE TX LPI TIMER: 00000011
[ 35.610995] thunderbolt 0000:06:00.0: stopping RX ring 0
[ 35.611153] ACPI: EC: interrupt blocked
[ 35.611199] thunderbolt 0000:06:00.0: disabling interrupt at register 0x38200 bit 12 (0x1001 -> 0x1)
[ 35.611229] thunderbolt 0000:06:00.0: stopping TX ring 0
[ 35.611241] thunderbolt 0000:06:00.0: disabling interrupt at register 0x38200 bit 0 (0x1 -> 0x0)
[ 35.611260] thunderbolt 0000:06:00.0: control channel stopped
[ 35.921307] ACPI: Preparing to enter system sleep state S3
[ 35.930400] ACPI: EC: event blocked
[ 35.930402] ACPI: EC: EC stopped
[ 35.930403] PM: Saving platform NVS memory
[ 35.930414] Disabling non-boot CPUs ...
[ 35.972984] smpboot: CPU 1 is now offline
[ 36.011817] smpboot: CPU 2 is now offline
[ 36.051806] smpboot: CPU 3 is now offline
[ 36.112379] smpboot: CPU 4 is now offline
[ 36.151683] smpboot: CPU 5 is now offline
[ 36.191609] smpboot: CPU 6 is now offline
[ 36.231579] smpboot: CPU 7 is now offline
[ 36.236721] ACPI: Low-level resume complete
[ 36.236768] ACPI: EC: EC started
[ 36.236768] PM: Restoring platform NVS memory
[ 36.237372] Enabling non-boot CPUs ...
[ 36.237405] x86: Booting SMP configuration:
[ 36.237406] smpboot: Booting Node 0 Processor 1 APIC 0x2
[ 36.237824] cache: parent cpu1 should not be sleeping
[ 36.237949] CPU1 is up
[ 36.237971] smpboot: Booting Node 0 Processor 2 APIC 0x4
[ 36.238391] cache: parent cpu2 should not be sleeping
[ 36.238525] CPU2 is up
[ 36.238541] smpboot: Booting Node 0 Processor 3 APIC 0x6
[ 36.238961] cache: parent cpu3 should not be sleeping
[ 36.239105] CPU3 is up
[ 36.239121] smpboot: Booting Node 0 Processor 4 APIC 0x1
[ 36.239611] cache: parent cpu4 should not be sleeping
[ 36.239938] CPU4 is up
[ 36.239957] smpboot: Booting Node 0 Processor 5 APIC 0x3
[ 36.240374] cache: parent cpu5 should not be sleeping
[ 36.240528] CPU5 is up
[ 36.240544] smpboot: Booting Node 0 Processor 6 APIC 0x5
[ 36.240960] cache: parent cpu6 should not be sleeping
[ 36.241124] CPU6 is up
[ 36.241141] smpboot: Booting Node 0 Processor 7 APIC 0x7
[ 36.241558] cache: parent cpu7 should not be sleeping
[ 36.241735] CPU7 is up
[ 36.247529] ACPI: Waking up from system sleep state S3
[ 36.349311] ACPI: EC: interrupt unblocked
[ 36.463991] thunderbolt 0000:06:00.0: control channel starting...
[ 36.463995] thunderbolt 0000:06:00.0: starting TX ring 0
[ 36.464006] thunderbolt 0000:06:00.0: enabling interrupt at register 0x38200 bit 0 (0x0 -> 0x1)
[ 36.464009] thunderbolt 0000:06:00.0: starting RX ring 0
[ 36.464019] thunderbolt 0000:06:00.0: enabling interrupt at register 0x38200 bit 12 (0x1 -> 0x1001)
[ 36.656268] ACPI: EC: event unblocked
[ 36.659091] xhci_hcd 0000:3c:00.0: xHC error in resume, USBSTS 0x401, Reinit
[ 36.659095] usb usb3: root hub lost power or was reset
[ 36.659098] usb usb4: root hub lost power or was reset
[ 36.770867] usb 2-3: Disable of device-initiated U1 failed.
[ 36.774331] usb 2-3: Disable of device-initiated U2 failed.
[ 37.004366] usb 2-3: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[ 37.184210] usb 1-7: reset full-speed USB device number 2 using xhci_hcd
[ 37.514121] usb 1-8: reset high-speed USB device number 3 using xhci_hcd
[ 37.774220] acpi LNXPOWER:01: Turning OFF
[ 37.774784] OOM killer enabled.
[ 37.774786] Restarting tasks ...
[ 37.775699] Bluetooth: hci0: Bootloader revision 0.0 build 26 week 38 2015
[ 37.776710] Bluetooth: hci0: Device revision is 16
[ 37.776713] Bluetooth: hci0: Secure boot is enabled
[ 37.776716] Bluetooth: hci0: OTP lock is enabled
[ 37.776718] Bluetooth: hci0: API lock is enabled
[ 37.776723] Bluetooth: hci0: Debug lock is disabled
[ 37.776727] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[ 37.776734] Bluetooth: hci0: Found device firmware: intel/ibt-12-16.sfi
[ 37.776804] done.
[ 37.803802] usb 1-9: USB disconnect, device number 5
[ 37.829406] PM: suspend exit
[ 37.853910] pci_bus 0000:06: Allocating resources
[ 37.853923] pci_bus 0000:3c: Allocating resources
[ 37.854197] pci_bus 0000:06: Allocating resources
[ 37.854208] pci_bus 0000:3c: Allocating resources
[ 37.953833] usb 1-9: new full-speed USB device number 6 using xhci_hcd
[ 38.092776] e1000e: enp0s31f6 NIC Link is Down
[ 38.094743] IPv6: ADDRCONF(NETDEV_UP): enp0s31f6: link is not ready
[ 38.145754] usb 1-9: New USB device found, idVendor=06cb, idProduct=009a, bcdDevice= 1.64
[ 38.145756] usb 1-9: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[ 38.145756] usb 1-9: SerialNumber: a6fd98866605
[ 38.333990] IPv6: ADDRCONF(NETDEV_UP): enp0s31f6: link is not ready
[ 38.335981] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready
[ 38.510203] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready
[ 39.332971] Bluetooth: hci0: Waiting for firmware download to complete
[ 39.333735] Bluetooth: hci0: Firmware loaded in 1522458 usecs
[ 39.333809] Bluetooth: hci0: Waiting for device to boot
[ 39.346759] Bluetooth: hci0: Device booted in 12711 usecs
[ 39.346765] Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-12-16.ddc
[ 39.349823] Bluetooth: hci0: Applying Intel DDC parameters completed
[ 41.857347] wlp3s0: authenticate with c0:94:35:6d:6a:3d
[ 41.868866] wlp3s0: send auth to c0:94:35:6d:6a:3d (try 1/3)
[ 41.876428] wlp3s0: authenticated
[ 41.883787] wlp3s0: associate with c0:94:35:6d:6a:3d (try 1/3)
[ 41.890964] wlp3s0: RX AssocResp from c0:94:35:6d:6a:3d (capab=0x1011 status=0 aid=4)
[ 41.893228] wlp3s0: associated
[ 41.910601] IPv6: ADDRCONF(NETDEV_CHANGE): wlp3s0: link becomes ready
[ 41.976189] wlp3s0: Limiting TX power to 30 (30 - 0) dBm as advertised by c0:94:35:6d:6a:3d
[ 43.895863] thunderbolt 0000:06:00.0: stopping RX ring 0
[ 43.895874] thunderbolt 0000:06:00.0: disabling interrupt at register 0x38200 bit 12 (0x1001 -> 0x1)
[ 43.895893] thunderbolt 0000:06:00.0: stopping TX ring 0
[ 43.895902] thunderbolt 0000:06:00.0: disabling interrupt at register 0x38200 bit 0 (0x1 -> 0x0)
[ 43.895911] thunderbolt 0000:06:00.0: control channel stopped
[trentdalton@HandSoup ~]$
