Slow to resume from suspend
I have a problem where my computer is quite slow to resume from suspend to idle, taking on the order of a minute. It feels faster to use suspend to disk! I have an Asus ROG Zephyrus G15 GA503QS. Here is some journald that I hope will shed some light on the problem when viewed by someone more knowledgeable than I.
Jan 13 14:26:23 Kaya-G15 systemd-logind[839]: Suspend key pressed short.
Jan 13 14:26:23 Kaya-G15 systemd-logind[839]: The system will suspend now!
Jan 13 14:26:23 Kaya-G15 ModemManager[864]: <info>  [sleep-monitor-systemd] system is about to suspend
Jan 13 14:26:23 Kaya-G15 NetworkManager[853]: <info>  [1673637983.4812] manager: sleep: sleep requested (sleeping: no  enabled: yes)
Jan 13 14:26:23 Kaya-G15 kscreenlocker_greet[46782]: Qt: Session management error: networkIdsList argument is NULL
Jan 13 14:26:23 Kaya-G15 kscreenlocker_greet[46782]: kscreenlocker_greet: Lockscreen QML outdated, falling back to default
Jan 13 14:26:23 Kaya-G15 NetworkManager[853]: <info>  [1673637983.7042] device (enp3s0): state change: unavailable -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Jan 13 14:26:23 Kaya-G15 kernel: r8169 0000:03:00.0 enp3s0: Link is Down
Jan 13 14:26:23 Kaya-G15 NetworkManager[853]: <info>  [1673637983.7133] manager: NetworkManager state is now ASLEEP
Jan 13 14:26:23 Kaya-G15 NetworkManager[853]: <info>  [1673637983.7134] device (wlp4s0): state change: activated -> deactivating (reason 'sleeping', sys-iface-state: 'managed')
Jan 13 14:26:23 Kaya-G15 kded5[1258]: org.kde.plasma.nm.kded: Unhandled active connection state change:  3
Jan 13 14:26:23 Kaya-G15 dbus-daemon[837]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.4' (uid=0 pid=853 comm="/usr/bin/NetworkManager --no-daemon")
Jan 13 14:26:23 Kaya-G15 systemd[1]: Starting Network Manager Script Dispatcher Service...
░░ Subject: A start job for unit NetworkManager-dispatcher.service has begun execution
░░ Defined-By: systemd
░░ A start job for unit NetworkManager-dispatcher.service has begun execution.
░░ The job identifier is 3530.
Jan 13 14:26:23 Kaya-G15 dbus-daemon[837]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jan 13 14:26:23 Kaya-G15 systemd[1]: Started Network Manager Script Dispatcher Service.
░░ Subject: A start job for unit NetworkManager-dispatcher.service has finished successfully
░░ A start job for unit NetworkManager-dispatcher.service has finished successfully.
Jan 13 14:26:23 Kaya-G15 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 13 14:26:23 Kaya-G15 kernel: audit: type=1130 audit(1673637983.743:221): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 13 14:26:23 Kaya-G15 kernel: wlp4s0: deauthenticating from 68:ff:7b:01:88:b0 by local choice (Reason: 3=DEAUTH_LEAVING)
Jan 13 14:26:23 Kaya-G15 kscreenlocker_greet[46782]: kf.kirigami: Failed to find a Kirigami platform plugin
Jan 13 14:26:23 Kaya-G15 kscreenlocker_greet[46782]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "en_US" . Search paths ("/usr/share/qt/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
Jan 13 14:26:24 Kaya-G15 wpa_supplicant[918]: wlp4s0: CTRL-EVENT-DISCONNECTED bssid=68:ff:7b:01:88:b0 reason=3 locally_generated=1
Jan 13 14:26:24 Kaya-G15 wpa_supplicant[918]: wlp4s0: CTRL-EVENT-DSCP-POLICY clear_all
Jan 13 14:26:24 Kaya-G15 wpa_supplicant[918]: wlp4s0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
Jan 13 14:26:24 Kaya-G15 NetworkManager[853]: <info>  [1673637984.0887] device (wlp4s0): supplicant interface state: completed -> disconnected
Jan 13 14:26:24 Kaya-G15 NetworkManager[853]: <info>  [1673637984.0889] device (wlp4s0): state change: deactivating -> disconnected (reason 'sleeping', sys-iface-state: 'managed')
Jan 13 14:26:24 Kaya-G15 NetworkManager[853]: <info>  [1673637984.0891] dhcp4 (wlp4s0): canceled DHCP transaction
Jan 13 14:26:24 Kaya-G15 NetworkManager[853]: <info>  [1673637984.0892] dhcp4 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Jan 13 14:26:24 Kaya-G15 NetworkManager[853]: <info>  [1673637984.0892] dhcp4 (wlp4s0): state changed no lease
Jan 13 14:26:24 Kaya-G15 NetworkManager[853]: <info>  [1673637984.1348] device (wlp4s0): set-hw-addr: set MAC address to B6:2B:5F:E4:FA:BE (scanning)
Jan 13 14:26:24 Kaya-G15 NetworkManager[853]: <info>  [1673637984.2285] device (wlp4s0): supplicant interface state: disconnected -> interface_disabled
Jan 13 14:26:24 Kaya-G15 NetworkManager[853]: <info>  [1673637984.2288] device (wlp4s0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Jan 13 14:26:24 Kaya-G15 NetworkManager[853]: <info>  [1673637984.3032] device (wlp4s0): set-hw-addr: reset MAC address to 34:6F:24:B5:13:41 (unmanage)
Jan 13 14:26:24 Kaya-G15 systemd[1]: Reached target Sleep.
░░ Subject: A start job for unit sleep.target has finished successfully
░░ A start job for unit sleep.target has finished successfully.
░░ The job identifier is 3635.
Jan 13 14:26:24 Kaya-G15 systemd[1]: Starting System Suspend...
░░ Subject: A start job for unit systemd-suspend.service has begun execution
░░ A start job for unit systemd-suspend.service has begun execution.
░░ The job identifier is 3632.
Jan 13 14:26:24 Kaya-G15 systemd-sleep[46841]: Entering sleep state 'suspend'...
░░ Subject: System sleep state suspend entered
░░ The system has now entered the suspend sleep state.
Jan 13 14:26:24 Kaya-G15 kernel: PM: suspend entry (s2idle)
Jan 13 14:26:24 Kaya-G15 wpa_supplicant[918]: nl80211: deinit ifname=wlp4s0 disabled_11b_rates=0
Jan 13 14:26:24 Kaya-G15 kernel: Filesystems sync: 0.006 seconds
Jan 13 14:27:39 Kaya-G15 kernel: Freezing user space processes ... (elapsed 0.232 seconds) done.
Jan 13 14:27:39 Kaya-G15 kernel: OOM killer disabled.
Jan 13 14:27:39 Kaya-G15 kernel: Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
Jan 13 14:27:39 Kaya-G15 kernel: printk: Suspending console(s) (use no_console_suspend to debug)
Jan 13 14:27:39 Kaya-G15 kernel: queueing ieee80211 work while going to suspend
Jan 13 14:27:39 Kaya-G15 kernel: ACPI: EC: interrupt blocked
Jan 13 14:27:39 Kaya-G15 kernel: ccp 0000:07:00.2: Refused to change power state from D0 to D3hot
Jan 13 14:27:39 Kaya-G15 kernel: ACPI: EC: interrupt unblocked
Jan 13 14:27:39 Kaya-G15 kernel: [drm] PCIE GART of 1024M enabled.
Jan 13 14:27:39 Kaya-G15 kernel: [drm] PTB located at 0x000000F41FC00000
Jan 13 14:27:39 Kaya-G15 kernel: amdgpu 0000:07:00.0: amdgpu: SMU is resuming...
Jan 13 14:27:39 Kaya-G15 kernel: amdgpu 0000:07:00.0: amdgpu: dpm has been disabled
Jan 13 14:27:39 Kaya-G15 kernel: amdgpu 0000:07:00.0: amdgpu: SMU is resumed successfully!
Jan 13 14:27:39 Kaya-G15 kernel: [drm] VCN decode and encode initialized successfully(under DPG Mode).
Jan 13 14:27:39 Kaya-G15 kernel: [drm] JPEG decode initialized successfully.
Jan 13 14:27:39 Kaya-G15 kernel: amdgpu 0000:07:00.0: amdgpu: ring gfx uses VM inv eng 0 on hub 0
Jan 13 14:27:39 Kaya-G15 kernel: amdgpu 0000:07:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
Jan 13 14:27:39 Kaya-G15 kernel: amdgpu 0000:07:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
Jan 13 14:27:39 Kaya-G15 kernel: amdgpu 0000:07:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 5 on hub 0
Jan 13 14:27:39 Kaya-G15 kernel: amdgpu 0000:07:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 6 on hub 0
Jan 13 14:27:39 Kaya-G15 kernel: amdgpu 0000:07:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 7 on hub 0
Jan 13 14:27:39 Kaya-G15 kernel: amdgpu 0000:07:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 8 on hub 0
Jan 13 14:27:39 Kaya-G15 kernel: amdgpu 0000:07:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 9 on hub 0
Jan 13 14:27:39 Kaya-G15 kernel: amdgpu 0000:07:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 10 on hub 0
Jan 13 14:27:39 Kaya-G15 kernel: amdgpu 0000:07:00.0: amdgpu: ring kiq_2.1.0 uses VM inv eng 11 on hub 0
Jan 13 14:27:39 Kaya-G15 kernel: amdgpu 0000:07:00.0: amdgpu: ring sdma0 uses VM inv eng 0 on hub 1
Jan 13 14:27:39 Kaya-G15 kernel: amdgpu 0000:07:00.0: amdgpu: ring vcn_dec uses VM inv eng 1 on hub 1
Jan 13 14:27:39 Kaya-G15 kernel: amdgpu 0000:07:00.0: amdgpu: ring vcn_enc0 uses VM inv eng 4 on hub 1
Jan 13 14:27:39 Kaya-G15 kernel: amdgpu 0000:07:00.0: amdgpu: ring vcn_enc1 uses VM inv eng 5 on hub 1
Jan 13 14:27:39 Kaya-G15 kernel: amdgpu 0000:07:00.0: amdgpu: ring jpeg_dec uses VM inv eng 6 on hub 1
Jan 13 14:27:39 Kaya-G15 kernel: nvme nvme1: 16/0/0 default/read/poll queues
Jan 13 14:27:39 Kaya-G15 kernel: nvme nvme1: Ignoring bogus Namespace Identifiers
Jan 13 14:27:39 Kaya-G15 kernel: nvme nvme0: I/O 8 QID 0 timeout, reset controller
Jan 13 14:27:39 Kaya-G15 kernel: nvme 0000:05:00.0: PM: dpm_run_callback(): pci_pm_resume+0x0/0xf0 returns -16
Jan 13 14:27:39 Kaya-G15 kernel: nvme 0000:05:00.0: PM: failed to resume async: error -16
Jan 13 14:27:39 Kaya-G15 kernel: OOM killer enabled.
Jan 13 14:27:39 Kaya-G15 kernel: Restarting tasks ... done.
Jan 13 14:27:39 Kaya-G15 kernel: random: crng reseeded on system resumption
Jan 13 14:27:39 Kaya-G15 kernel: PM: suspend exit
Jan 13 14:27:39 Kaya-G15 kernel: audit: type=1131 audit(1673638059.256:222): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 13 14:27:39 Kaya-G15 kernel: nvme nvme0: 16/0/0 default/read/poll queues
Jan 13 14:27:39 Kaya-G15 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 13 14:27:39 Kaya-G15 systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
░░ Subject: Unit succeeded
░░ The unit NetworkManager-dispatcher.service has successfully entered the 'dead' state.
Jan 13 14:27:39 Kaya-G15 touchegg[840]: libinput error: client bug: timer event11 keyboard: scheduled expiry is in the past (-46994ms), your system is too slow
Jan 13 14:27:39 Kaya-G15 touchegg[840]: libinput error: client bug: timer event11 keyboard: scheduled expiry is in the past (-46210ms), your system is too slow
Jan 13 14:27:39 Kaya-G15 rtkit-daemon[1236]: The canary thread is apparently starving. Taking action.
Jan 13 14:27:39 Kaya-G15 systemd-sleep[46841]: System returned from sleep state.
░░ Subject: System sleep state suspend left
░░ The system has now left the suspend sleep state.
Jan 13 14:27:39 Kaya-G15 rtkit-daemon[1236]: Demoting known real-time threads.
Jan 13 14:27:39 Kaya-G15 rtkit-daemon[1236]: Successfully demoted thread 43234 of process 43082.
Jan 13 14:27:39 Kaya-G15 rtkit-daemon[1236]: Successfully demoted thread 34387 of process 34252.
Jan 13 14:27:39 Kaya-G15 rtkit-daemon[1236]: Successfully demoted thread 1591 of process 1573.
Jan 13 14:27:39 Kaya-G15 rtkit-daemon[1236]: Successfully demoted thread 1589 of process 1573.
Jan 13 14:27:39 Kaya-G15 rtkit-daemon[1236]: Successfully demoted thread 1573 of process 1573.
Jan 13 14:27:39 Kaya-G15 rtkit-daemon[1236]: Successfully demoted thread 1433 of process 1430.
Jan 13 14:27:39 Kaya-G15 rtkit-daemon[1236]: Successfully demoted thread 1437 of process 1429.
Jan 13 14:27:39 Kaya-G15 rtkit-daemon[1236]: Successfully demoted thread 1429 of process 1429.
Jan 13 14:27:39 Kaya-G15 rtkit-daemon[1236]: Demoted 8 threads.
Jan 13 14:27:39 Kaya-G15 bluetoothd[835]: Controller resume with wake event 0x0
Jan 13 14:27:39 Kaya-G15 systemd[1]: systemd-suspend.service: Deactivated successfully.
░░ The unit systemd-suspend.service has successfully entered the 'dead' state.
Jan 13 14:27:39 Kaya-G15 systemd[1]: Finished System Suspend.
░░ Subject: A start job for unit systemd-suspend.service has finished successfully
░░ A start job for unit systemd-suspend.service has finished successfully.
Jan 13 14:27:39 Kaya-G15 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 13 14:27:39 Kaya-G15 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 13 14:27:39 Kaya-G15 systemd[1]: Stopped target Sleep.
░░ Subject: A stop job for unit sleep.target has finished
░░ A stop job for unit sleep.target has finished.
░░ The job identifier is 3636 and the job result is done.
Jan 13 14:27:39 Kaya-G15 systemd[1]: Reached target Suspend.
░░ Subject: A start job for unit suspend.target has finished successfully
░░ A start job for unit suspend.target has finished successfully.
░░ The job identifier is 3631.
Jan 13 14:27:39 Kaya-G15 systemd[1]: Stopped target Suspend.
░░ Subject: A stop job for unit suspend.target has finished
░░ A stop job for unit suspend.target has finished.
░░ The job identifier is 3639 and the job result is done.
Jan 13 14:27:39 Kaya-G15 systemd-logind[839]: Operation 'sleep' finished.
Jan 13 14:27:39 Kaya-G15 kernel: audit: type=1130 audit(1673638059.436:223): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 13 14:27:39 Kaya-G15 kernel: audit: type=1131 audit(1673638059.436:224): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 13 14:27:39 Kaya-G15 NetworkManager[853]: <info>  [1673638059.4442] manager: sleep: wake requested (sleeping: yes  enabled: yes)
Jan 13 14:27:39 Kaya-G15 NetworkManager[853]: <info>  [1673638059.4447] device (enp3s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Jan 13 14:27:39 Kaya-G15 ModemManager[864]: <info>  [sleep-monitor-systemd] system is resuming
Jan 13 14:27:39 Kaya-G15 kernel: RTL8226B_RTL8221B 2.5Gbps PHY r8169-0-300:00: attached PHY driver (mii_bus:phy_addr=r8169-0-300:00, irq=MAC)
Jan 13 14:27:39 Kaya-G15 dbus-daemon[837]: [system] Activating service name='org.kde.powerdevil.backlighthelper' requested by ':1.31' (uid=1000 pid=1361 comm="/usr/lib/org_kde_powerdevil") (using servicehelper)
Jan 13 14:27:39 Kaya-G15 dbus-daemon[837]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
Jan 13 14:27:39 Kaya-G15 NetworkManager[853]: <info>  [1673638059.6678] device (wlp4s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Jan 13 14:27:39 Kaya-G15 NetworkManager[853]: <info>  [1673638059.6686] manager: NetworkManager state is now DISCONNECTED
Jan 13 14:27:39 Kaya-G15 kernel: r8169 0000:03:00.0 enp3s0: Link is Down
Jan 13 14:27:39 Kaya-G15 wpa_supplicant[918]: dbus: fill_dict_with_properties dbus_interface=fi.w1.wpa_supplicant1.Interface.P2PDevice dbus_property=P2PDeviceConfig getter failed
Jan 13 14:27:39 Kaya-G15 NetworkManager[853]: <info>  [1673638059.7156] device (wlp4s0): supplicant interface state: internal-starting -> disconnected
Jan 13 14:27:39 Kaya-G15 NetworkManager[853]: <info>  [1673638059.7158] device (wlp4s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Jan 13 14:27:40 Kaya-G15 kcminit[47123]: Initializing  "/usr/lib/qt/plugins/plasma/kcms/systemsettings/kcm_mouse.so"
Jan 13 14:27:41 Kaya-G15 wpa_supplicant[918]: wlp4s0: CTRL-EVENT-REGDOM-CHANGE init=BEACON_HINT type=UNKNOWN
Jan 13 14:27:41 Kaya-G15 ModemManager[864]: <info>  [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:02.1/0000:03:00.0': not supported by any plugin
Jan 13 14:27:41 Kaya-G15 ModemManager[864]: <info>  [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:02.2/0000:04:00.0': not supported by any plugin
Jan 13 14:27:41 Kaya-G15 dbus-daemon[837]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.736' (uid=1000 pid=46782 comm="/usr/lib/kscreenlocker_greet --immediateLock --gra")
Jan 13 14:27:41 Kaya-G15 dbus-daemon[837]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Jan 13 14:27:41 Kaya-G15 kscreenlocker_greet[46782]: pam_systemd_home(kde:auth): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Jan 13 14:27:43 Kaya-G15 wpa_supplicant[918]: wlp4s0: CTRL-EVENT-REGDOM-CHANGE init=BEACON_HINT type=UNKNOWN
Jan 13 14:27:43 Kaya-G15 NetworkManager[853]: <info>  [1673638063.4574] policy: auto-activating connection 'JBKF2.4' (577cebad-b782-4bfb-9f82-f1096fa5df3c)
Jan 13 14:27:43 Kaya-G15 NetworkManager[853]: <info>  [1673638063.4579] device (wlp4s0): Activation: starting connection 'JBKF2.4' (577cebad-b782-4bfb-9f82-f1096fa5df3c)
Jan 13 14:27:43 Kaya-G15 NetworkManager[853]: <info>  [1673638063.4580] device (wlp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Jan 13 14:27:43 Kaya-G15 NetworkManager[853]: <info>  [1673638063.4581] manager: NetworkManager state is now CONNECTING
Jan 13 14:27:43 Kaya-G15 NetworkManager[853]: <info>  [1673638063.4583] device (wlp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Jan 13 14:27:43 Kaya-G15 NetworkManager[853]: <info>  [1673638063.4585] device (wlp4s0): Activation: (wifi) access point 'JBKF2.4' has security, but secrets are required.
Jan 13 14:27:43 Kaya-G15 NetworkManager[853]: <info>  [1673638063.4585] device (wlp4s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Jan 13 14:27:43 Kaya-G15 NetworkManager[853]: <info>  [1673638063.4586] sup-iface[d9bb09fe77e7a084,2,wlp4s0]: wps: type pbc start...
Jan 13 14:27:43 Kaya-G15 NetworkManager[853]: <info>  [1673638063.4594] device (wlp4s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Jan 13 14:27:43 Kaya-G15 NetworkManager[853]: <info>  [1673638063.4595] device (wlp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Jan 13 14:27:43 Kaya-G15 NetworkManager[853]: <info>  [1673638063.4596] device (wlp4s0): Activation: (wifi) connection 'JBKF2.4' has security, and secrets exist.  No new secrets needed.
Jan 13 14:27:43 Kaya-G15 NetworkManager[853]: <info>  [1673638063.4596] Config: added 'ssid' value 'JBKF2.4'
Jan 13 14:27:43 Kaya-G15 NetworkManager[853]: <info>  [1673638063.4596] Config: added 'scan_ssid' value '1'
Jan 13 14:27:43 Kaya-G15 NetworkManager[853]: <info>  [1673638063.4596] Config: added 'bgscan' value 'simple:30:-70:86400'
Jan 13 14:27:43 Kaya-G15 NetworkManager[853]: <info>  [1673638063.4596] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK SAE FT-SAE'
Jan 13 14:27:43 Kaya-G15 NetworkManager[853]: <info>  [1673638063.4597] Config: added 'auth_alg' value 'OPEN'
Jan 13 14:27:43 Kaya-G15 NetworkManager[853]: <info>  [1673638063.4597] Config: added 'psk' value '<hidden>'
Jan 13 14:27:43 Kaya-G15 wpa_supplicant[918]: wlp4s0: WPS-CANCEL
Jan 13 14:27:43 Kaya-G15 kdeconnectd[1500]: "Object does not exist at path “/org/freedesktop/NetworkManager/ActiveConnection/1”"
Jan 13 14:27:43 Kaya-G15 kded5[1258]: "Object does not exist at path “/org/freedesktop/NetworkManager/ActiveConnection/1”"
Jan 13 14:27:43 Kaya-G15 wpa_supplicant[918]: wlp4s0: SME: Trying to authenticate with 68:ff:7b:01:88:b0 (SSID='JBKF2.4' freq=2427 MHz)
Jan 13 14:27:43 Kaya-G15 kernel: wlp4s0: authenticate with 68:ff:7b:01:88:b0
Jan 13 14:27:43 Kaya-G15 kernel: wlp4s0: send auth to 68:ff:7b:01:88:b0 (try 1/3)
Jan 13 14:27:43 Kaya-G15 NetworkManager[853]: <info>  [1673638063.4995] device (wlp4s0): supplicant interface state: disconnected -> authenticating
Jan 13 14:27:43 Kaya-G15 wpa_supplicant[918]: wlp4s0: Trying to associate with 68:ff:7b:01:88:b0 (SSID='JBKF2.4' freq=2427 MHz)
Jan 13 14:27:43 Kaya-G15 NetworkManager[853]: <info>  [1673638063.5042] device (wlp4s0): supplicant interface state: authenticating -> associating
Jan 13 14:27:43 Kaya-G15 kernel: wlp4s0: authenticated
Jan 13 14:27:43 Kaya-G15 kernel: wlp4s0: associate with 68:ff:7b:01:88:b0 (try 1/3)
Jan 13 14:27:43 Kaya-G15 kernel: wlp4s0: RX AssocResp from 68:ff:7b:01:88:b0 (capab=0xc11 status=0 aid=1)
Jan 13 14:27:43 Kaya-G15 kernel: wlp4s0: associated
Jan 13 14:27:43 Kaya-G15 wpa_supplicant[918]: wlp4s0: Associated with 68:ff:7b:01:88:b0
Jan 13 14:27:43 Kaya-G15 wpa_supplicant[918]: wlp4s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Jan 13 14:27:43 Kaya-G15 wpa_supplicant[918]: wlp4s0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=US
Jan 13 14:27:43 Kaya-G15 NetworkManager[853]: <info>  [1673638063.5522] device (wlp4s0): supplicant interface state: associating -> associated
Jan 13 14:27:43 Kaya-G15 NetworkManager[853]: <info>  [1673638063.6214] device (wlp4s0): supplicant interface state: associated -> 4way_handshake
Jan 13 14:27:43 Kaya-G15 wpa_supplicant[918]: wlp4s0: WPA: Key negotiation completed with 68:ff:7b:01:88:b0 [PTK=CCMP GTK=CCMP]
Jan 13 14:27:43 Kaya-G15 wpa_supplicant[918]: wlp4s0: CTRL-EVENT-CONNECTED - Connection to 68:ff:7b:01:88:b0 completed [id=0 id_str=]
Jan 13 14:27:43 Kaya-G15 wpa_supplicant[918]: bgscan simple: Failed to enable signal strength monitoring
Jan 13 14:27:43 Kaya-G15 kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlp4s0: link becomes ready
Jan 13 14:27:43 Kaya-G15 NetworkManager[853]: <info>  [1673638063.7197] device (wlp4s0): supplicant interface state: 4way_handshake -> completed
Jan 13 14:27:43 Kaya-G15 NetworkManager[853]: <info>  [1673638063.7198] device (wlp4s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "JBKF2.4"
Jan 13 14:27:43 Kaya-G15 NetworkManager[853]: <info>  [1673638063.7226] device (wlp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Jan 13 14:27:43 Kaya-G15 NetworkManager[853]: <info>  [1673638063.7230] dhcp4 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Jan 13 14:27:43 Kaya-G15 NetworkManager[853]: <info>  [1673638063.7517] dhcp4 (wlp4s0): state changed new lease, address=192.168.0.104
Jan 13 14:27:43 Kaya-G15 NetworkManager[853]: <info>  [1673638063.7528] policy: set 'JBKF2.4' (wlp4s0) as default for IPv4 routing and DNS
Jan 13 14:27:43 Kaya-G15 NetworkManager[853]: <info>  [1673638063.7695] device (wlp4s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Jan 13 14:27:43 Kaya-G15 dbus-daemon[837]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.4' (uid=0 pid=853 comm="/usr/bin/NetworkManager --no-daemon")
Jan 13 14:27:43 Kaya-G15 systemd[1]: Starting Network Manager Script Dispatcher Service...
░░ The job identifier is 3640.
Jan 13 14:27:43 Kaya-G15 dbus-daemon[837]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jan 13 14:27:43 Kaya-G15 systemd[1]: Started Network Manager Script Dispatcher Service.
Jan 13 14:27:43 Kaya-G15 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 13 14:27:43 Kaya-G15 kernel: audit: type=1130 audit(1673638063.806:225): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 13 14:27:43 Kaya-G15 NetworkManager[853]: <info>  [1673638063.8130] device (wlp4s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Jan 13 14:27:43 Kaya-G15 NetworkManager[853]: <info>  [1673638063.8133] device (wlp4s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Jan 13 14:27:43 Kaya-G15 NetworkManager[853]: <info>  [1673638063.8136] manager: NetworkManager state is now CONNECTED_SITE
Jan 13 14:27:43 Kaya-G15 NetworkManager[853]: <info>  [1673638063.8141] device (wlp4s0): Activation: successful, device activated.
Jan 13 14:27:44 Kaya-G15 audit[47136]: USER_AUTH pid=47136 uid=1000 auid=1000 ses=3 msg='op=PAM:unix_chkpwd acct="kaya" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
Jan 13 14:27:44 Kaya-G15 kernel: audit: type=1100 audit(1673638064.199:226): pid=47136 uid=1000 auid=1000 ses=3 msg='op=PAM:unix_chkpwd acct="kaya" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
Jan 13 14:27:44 Kaya-G15 NetworkManager[853]: <info>  [1673638064.2186] manager: NetworkManager state is now CONNECTED_GLOBAL
Jan 13 14:27:44 Kaya-G15 kwin_x11[1259]: kwin_core: XCB error: 3 (BadWindow), sequence: 48366, resource id: 14680092, major code: 129 (SHAPE), minor code: 6 (Input)
Notice the gap between 14:26:24 and 14:27:39. Some of this time was the period between me telling the computer to go to sleep and me attempting to wake it. But I attempted to wake it at some point before 14:27:39. Yet there was still a sizable delay between me pressing a key to wake the machine and the first journald entry after that.
And as you can see, the computer does not appear to actually finish the suspend process until after it’s been told to resume. It is as though the suspend process itself gets suspended. Then when the computer is waking up, the suspend process has to finish before the computer can actually wake!
I also notice that userspace processes are not frozen until after the gap, when the computer is already starting to wake up. I haven’t done any tests, but I worry that this suggests that even s2idle’s more limited powersaving features are not working properly.
Does anyone have any ideas about what can be done to correct this behavior?
By the way, the output of cat /sys/power/mem_sleep is [s2idle], so I don’t seem to have suspend to memory available to me, although naturally I’d greatly prefer if I did. Perhaps there is a way to enable it on this computer; I haven’t looked into it. I should probably try – if I could get suspend to memory working properly, I would just use that and wouldn’t be concerned about pathological s2idle at all.
I have another Asus laptop on which s2idle is the only suspend option, and it always crashes after suspend – much worse than the behavior exhibited by this laptop. Are these suspend issues a common Asus problem or an s2idle problem? What a shame that s2idle is so ubiquitous these days.
doesnt the cat /sys/power/mem_sleep output deep?
check your bios/uefi settings, and see if there is some option/setting related to this…
also check if you are on RAID, instead of AHCI, that could also cause issues with suspend/resume… - if you are on raid and you are using windows, you will not be able to boot into it, if you switch
Hi and welcome to the forum :+1:
Check these threads: Search results for 's2idle ACPI' - Manjaro Linux Forum :wink:
Most probably it’s a BIOS setting that you need to change…
Thanks for the tips! I hope my slowness to respond here is not mistaken for ingratitude; it’s just been a busy few days.
Nope! Which does confused me, since hibernate seems to work fine.
I haven’t been able to find anything but I’ll look more closely.
I’m on NVMe
Check these threads: Search results for ‘s2idle ACPI’ - Manjaro Linux Forum :wink:
Thanks! I’ll work through these and see if anything looks like it might be useful. I tried to do some searching before making a forum post of my own, but that doesn’t mean there won’t be something useful in one of these threads.
provide also system info:
inxi -zav7
