If my computer is turned on for some time, when I shutdown my computer it takes around 2 minutes to shutdown. I have attempted to see what is causing it by looking through my logs, however have failed to identify a potential cause. Any help or advice would be appreciated. If there is other information you need to help me, let me know and I can locate it.
Here is the output of inxi --admin --verbosity=7 --filter --no-host
System: Kernel: 5.10.60-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=ca01a140-0eb7-4727-9aee-0a0409208238 rw nowatchdog quiet
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 info: docker wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux
base: Arch Linux
Machine: Type: Desktop Mobo: Micro-Star model: B450 TOMAHAWK MAX (MS-7C02) v: 1.0 serial: <filter>
UEFI-[Legacy]: American Megatrends v: 3.70 date: 06/09/2020
Battery: Message: No system battery data found. Is one present?
Memory: RAM: total: 31.37 GiB used: 6.42 GiB (20.5%)
CPU: Info: 8-Core model: AMD Ryzen 7 3800X bits: 64 type: MT MCP arch: Zen 2 family: 17 (23) model-id: 71 (113)
stepping: 0 microcode: 8701021 cache: L2: 4 MiB bogomips: 124862
Speed: 2200 MHz min/max: 2200/3900 MHz boost: enabled Core speeds (MHz): 1: 2200 2: 2200 3: 2200 4: 2200 5: 2056
6: 2052 7: 2054 8: 3411 9: 2200 10: 2200 11: 2054 12: 1877 13: 1871 14: 3190 15: 2200 16: 2200
Flags: 3dnowprefetch abm adx aes aperfmperf apic arat avic avx avx2 bmi1 bmi2 bpext cat_l3 cdp_l3 clflush
clflushopt clwb clzero cmov cmp_legacy constant_tsc cpb cpuid cqm cqm_llc cqm_mbm_local cqm_mbm_total cqm_occup_llc
cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht
hw_pstate ibpb ibs irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sev
sev_es sha_ni skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall
tce topoext tsc tsc_scale umip v_vmsave_vmload vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec
xsaveerptr xsaveopt xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, STIBP: conditional, RSB filling
Graphics: Device-1: NVIDIA GP107 [GeForce GTX 1050] vendor: eVga.com. driver: nvidia v: 470.63.01
alternate: nouveau,nvidia_drm bus-ID: 26:00.0 chip-ID: 10de:1c81 class-ID: 0300
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 95 s-size: 513x292mm (20.2x11.5") s-diag: 590mm (23.2")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 96 size: 509x286mm (20.0x11.3") diag: 584mm (23")
OpenGL: renderer: NVIDIA GeForce GTX 1050/PCIe/SSE2 v: 4.6.0 NVIDIA 470.63.01 direct render: Yes
Audio: Device-1: NVIDIA GP107GL High Definition Audio vendor: eVga.com. driver: snd_hda_intel v: kernel bus-ID: 26:00.1
chip-ID: 10de:0fb9 class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Starship/Matisse HD Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel bus-ID: 28:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound Server-1: ALSA v: k5.10.60-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: no
Use of uninitialized value $args in concatenation (.) or string at /usr/bin/inxi line 2493.
Use of uninitialized value in concatenation (.) or string at /usr/bin/inxi line 2493.
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 14 100 14 0 0 187 0 --:--:-- --:--:-- --:--:-- 189
Network: Device-1: Realtek RTL8192CE PCIe Wireless Network Adapter vendor: ASUSTeK driver: rtl8192ce v: kernel port: e000
bus-ID: 21:00.0 chip-ID: 10ec:8178 class-ID: 0280
IF: wlo1 state: down mac: <filter>
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI driver: r8169 v: kernel
port: d000 bus-ID: 22:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp34s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
IF-ID-1: docker0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IP v6: <filter> scope: link
IF-ID-2: veth7e3676c state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-3: veth82f9de3 state: up speed: 10000 Mbps duplex: full mac: <filter>
Bluetooth: Message: No bluetooth data found.
Logical: Message: No logical block device data found.
RAID: Message: No RAID data found.
Drives: Local Storage: total: 3.18 TiB used: 664.65 GiB (20.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 500GB size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 3B6Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD20EZRZ-00Z5HB0 size: 1.82 TiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 0A80 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 870 EVO 1TB size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 1B6Q scheme: GPT
Partition: ID-1: / raw-size: 931.5 GiB size: 915.8 GiB (98.32%) used: 270.97 GiB (29.6%) fs: ext4 dev: /dev/sdc2 maj-min: 8:34
label: N/A uuid: ca01a140-0eb7-4727-9aee-0a0409208238
ID-2: /media/hdd1 raw-size: 1.81 TiB size: 1.81 TiB (100.00%) used: 393.68 GiB (21.2%) fs: ntfs dev: /dev/sdb1
maj-min: 8:17 label: Storage space uuid: DC2A5BEF2A5BC4E4
Swap: Alert: No swap data was found.
Unmounted: ID-1: /dev/sda1 maj-min: 8:1 size: 499 MiB fs: ntfs label: N/A uuid: F21681AE168173FF
ID-2: /dev/sda2 maj-min: 8:2 size: 99 MiB fs: vfat label: N/A uuid: 12B2-9DFE
ID-3: /dev/sda3 maj-min: 8:3 size: 16 MiB fs: <superuser required> label: N/A uuid: N/A
ID-4: /dev/sda4 maj-min: 8:4 size: 465.16 GiB fs: ntfs label: N/A uuid: 1080B45680B4444E
ID-5: /dev/sdc1 maj-min: 8:33 size: 16 MiB fs: <superuser required> label: N/A uuid: N/A
USB: Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 10 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
Device-1: 1-2:2 info: Corsair CORSAIR K70 RGB MK.2 LOW PROFILE Mechanical Gaming Keyboard type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 500mA chip-ID: 1b1c:1b55 class-ID: 0300
serial: <filter>
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
Device-1: 3-2:2 info: Razer USA Naga Chroma type: Mouse,Keyboard driver: razermouse,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 500mA chip-ID: 1532:0053 class-ID: 0300
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Sensors: System Temperatures: cpu: 49.4 C mobo: N/A gpu: nvidia temp: 35 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 30%
Info: Processes: 375 Uptime: 12m wakeups: 0 Init: systemd v: 248 tool: systemctl Compilers: gcc: 11.1.0 Packages:
pacman: 1403 lib: 416 flatpak: 0 Shell: Bash v: 5.1.8 running-in: yakuake inxi: 3.3.06
Here is the output of journalctl -b -1
https://aptget.xyz/qFL3Q/boot.log
Some things to note of the log, the time of the last line in the log seems to be the time it actually shuts down, but the line where it says System is powering down.
happens around 2 minutes after I start the shutdown.
From what I found online, I’m assuming the kwin_x11 errors seems likely to not be related, especially since I see that error at other times as well.
The sddm errors are what I am guessing might be the problem, but I wasn’t able to find any solutions online, only other people mentioning they had the problem and one person mentioning that they also had a slow shutdown issue here. While a person did mention a fix in that link, it appeared to be exclusively for an issue with logging on that also generated the same exit code.
sddm errors for people that don’t want to look at log:
Sep 03 16:25:56 TheRealComputer sddm[722]: Authentication error: "Process crashed"
Sep 03 16:25:56 TheRealComputer sddm[722]: Auth: sddm-helper crashed (exit code 15)
Sep 03 16:25:56 TheRealComputer sddm[722]: Auth: sddm-helper exited with 15
Any suggestions on how to resolve this would be appreciated.
