Slow-Motion after Hibernation
I have a pretty new pc with this hardware setup:
KDE Plasma Version: 6.1.5
KDE Frameworks Version: 6.6.0
Qt Version: 6.7.2
Kernel Version: 6.6.54-2-MANJARO (64-bit)
Graphics Platform: X11
Processors: 20 × 13th Gen Intel® Core™ i5-13600K
Memory: 31.1 GiB of RAM
Graphics Processor: Mesa Intel® Graphics
Manufacturer: Micro-Star International Co., Ltd.
Product Name: MS-7D98
System Version: 3.0
sda = NVME Device
I’ve set energy saving settings to go to hibbernation (Disk & Memory) after 20 Minutes.
If system wake up again, the pain starts!!!
  • One of my screens (dual-screen setup) don’t wake up,
  • Everything is extremely slow-motion (like a 4Mhz XT PC from 1994).
  • If I made it to open the system-monitor (after a couple of minutes) there isn’t any huge peaks in the history… even if the system is still slow as hell
My Partition-Table looks like this (enough swap):
Log off & Re-Login (without reboot) fix this issue and anything work fast and smooth as before.
I didn’t found any obvious in the logs.
TL4: screenshots removed
I’d suggest launching htop in a Konsole window so you can watch what happens before and after Hibernate. (I think it’s installed by default? If not, sudo pacman -Syu htop).
Does the system stay slow if you leave it running for a while?
top
is roughly the same
and it is present
The forum is text based, searchable - I have removed your screenshots - please do not post screenshots.
I have a somewhat similar system based on i7-13700H.
Using hibernation does work, but loading the hibernated state takes too long.
Using the sleep state is better - it loads faster - no delay like hibernation - and a moderne system like yours should be able to hold power for days in that state.
Yes, stays slow all the time, till re-login
