Hi all
I have recently installed a new hard disk (6 TB, WD Blue, SATA III) for storage. When accessing the disk on Manjaro it takes about 1 minute until the contents are shown. Same goes for opening folders on the disk, copying files and system shut down. The issue isn’t consistent, on some boots (rarely) it’s ok.
When accessing the disk with Windows 10 (dual boot) the device seems to work fine. I have formatted multiple times (ext4 - quick, NTFS - full), created new partition tables (GUID) and run S.M.A.R.T diagnostics all without resolving the issue. I am afraid I don’t know what else i can do. Does anybody understand what’s causing this problem? Maybe even know how to fix it?
Full system info here: paste. ubuntu. com /p/Jpgp5F8WXy (sorry can’t post links)
# inxi -Fazy
Kernel: 5.11.0-0-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64
root=UUID= <filter> ro quiet apparmor=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Desktop System: ASUS product: N/A v: N/A serial: N/A
Mobo: ASUSTeK model: PRIME B550-PLUS v: Rev X.0x serial: <filter>
UEFI: American Megatrends v: 1202 date: 10/22/2020
Info: 6-Core model: AMD Ryzen 5 5600X socket: AM4 bits: 64 type: MT MCP
arch: Zen 3 family: 19 (25) model-id: 21 (33) stepping: N/A
microcode: A201009 L1 cache: 384 KiB L2 cache: 3 MiB L3 cache: 31.2 MiB
bogomips: 88663
Speed: 2832 MHz min/max: 2200/5210 MHz base/boost: 3700/4650 boost: enabled
volts: 1.1 V ext-clock: 100 MHz Core speeds (MHz): 1: 2832 2: 2188 3: 2075
4: 2193 5: 2096 6: 2195 7: 2189 8: 2193 9: 2195 10: 2194 11: 2195 12: 2196
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
STIBP: always-on, RSB filling
Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT]
vendor: Sapphire Limited driver: amdgpu v: kernel bus ID: 09:00.0
chip ID: 1002:73bf class ID: 0300
Display: x11 server: X.Org 1.20.10 driver: loaded: amdgpu,ati
unloaded: modesetting,radeon alternate: fbdev,vesa display ID: :0.0
screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1016x571mm (40.0x22.5")
s-diag: 1165mm (45.9")
Monitor-1: DisplayPort-1 res: 3840x2160 hz: 60 dpi: 140
size: 698x393mm (27.5x15.5") diag: 801mm (31.5")
OpenGL:
renderer: AMD SIENNA_CICHLID (DRM 3.40.0 5.11.0-0-MANJARO LLVM 11.0.1)
v: 4.6 Mesa 21.1.0-devel (git-766538f83c) direct render: Yes
Device-1: AMD driver: snd_hda_intel v: kernel bus ID: 09:00.1
chip ID: 1002:ab28 class ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus ID: 0b:00.4 chip ID: 1022:1487
class ID: 0403
Sound Server: ALSA v: k5.11.0-0-MANJARO
vendor: ASUSTeK driver: r8169 v: kernel port: f000 bus ID: 06:00.0
chip ID: 10ec:8168 class ID: 0200
IF: enp6s0 state: down mac: <filter>
Device-2: Realtek 802.11ac NIC type: USB driver: usb-network bus ID: 3-3:2
chip ID: 0bda:c811 class ID: 0000 serial: <filter>
IF-ID-1: <filter>
IF-ID-2: <filter>
Local Storage: total: 6.37 TiB used: 44.5 GiB (0.7%)
model: WDS100T2B0C-00PXH0 size: 931.51 GiB block size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter>
rev: 211070WD temp: 46.9 C scheme: GPT
SMART: yes health: PASSED on: 54 hrs cycles: 21 read-units: 454,449 [232 GB]
written-units: 836,138 [428 GB]
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD60EZAZ-00ZGHB0
family: Blue (SMR) size: 5.46 TiB block size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter>
rev: 0A80 temp: 34 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 36 hrs cycles: 12
ID-1: / raw size: 672.85 GiB size: 661.29 GiB (98.28%)
used: 42.56 GiB (6.4%) fs: ext4 block size: 4096 B dev: /dev/nvme0n1p4
maj-min: 259:4
ID-2: /boot/efi raw size: 100 MiB size: 96 MiB (96.00%)
used: 31.8 MiB (33.1%) fs: vfat block size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
System Temperatures: cpu: 43.0 C mobo: N/A gpu: amdgpu temp: 60.0 C
mem: 66.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 874
Processes: 295 Uptime: 1h 00m wakeups: 0 Memory: 15.61 GiB
used: 3.34 GiB (21.4%) Init: systemd v: 247 Compilers: gcc: 10.2.0
clang: 11.0.1 Packages: pacman: 1211 lib: 379 flatpak: 0 Shell: Bash (su)
v: 5.1.0 running in: xfce4-terminal inxi: 3.3.01
# smartctl -a /dev/sda
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.11.0-0-MANJARO] (local build)
Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Western Digital Blue (SMR)
Device Model: WDC WD60EZAZ-00ZGHB0
Serial Number: WD- <filter>
LU WWN Device Id: 5 0014ee 2bdde1823
Firmware Version: 80.00A80
User Capacity: 6’001’175’126’016 bytes [6.00 TB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Rotation Rate: 5400 rpm
Form Factor: 3.5 inches
TRIM Command: Available
Device is: In smartctl database [for details use: -P show]
ATA Version is: ACS-3 T13/2161-D revision 5
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Tue Feb 16 08:16:42 2021 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 180) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 7) minutes.
Conveyance self-test routine
SCT capabilities: (0x3035) SCT Status supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 224 224 021 Pre-fail Always - 3766
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 13
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 35
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 12
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 1
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 235
194 Temperature_Celsius 0x0022 121 105 000 Old_age Always - 29
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 100 253 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Extended offline Aborted by host 90% 32 -
# 2 Short offline Completed without error 00% 31 -
# 3 Short offline Interrupted (host reset) 90% 17 -
# 4 Extended offline Aborted by host 90% 17 -
>>> extensive test cancelled after 1 hour stuck at 10%
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
# dmesg >>> excerpt from original output, just what seemed most relevant to me
[ 0.237514] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[ 0.239533] ACPI: Interpreter enabled
[ 0.239542] ACPI: (supports S0 S3 S4 S5)
[ 0.239543] ACPI: Using IOAPIC for interrupt routing
[ 0.239696] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.239696] ACPI: Enabled 4 GPEs in block 00 to 1F
[ 0.243754] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.243758] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.243894] acpi PNP0A08:00: _OSC: platform does not support [PCIeHotplug SHPCHotplug PME LTR DPC]
[ 0.244023] acpi PNP0A08:00: _OSC: OS now controls [AER PCIeCapability]
[ 0.244030] acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-7f] only partially covers this bridge
[ 0.244263] PCI host bridge to bus 0000:00
[ 3.162550] acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 3.162605] acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 3.162639] acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 3.162720] acpi PNP0C14:04: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 3.213892] sp5100_tco: SP5100/SB800 TCO WatchDog Timer Driver
[ 3.213948] sp5100-tco sp5100-tco: Using 0xfed80b00 for watchdog MMIO address
[ 3.213954] sp5100-tco sp5100-tco: Watchdog hardware is disabled
[ 1631.312328] ata6.00: exception Emask 0x0 SAct 0x20000 SErr 0x50000 action 0x6 frozen
[ 1631.312333] ata6: SError: { PHYRdyChg CommWake }
[ 1631.312336] ata6.00: failed command: READ FPDMA QUEUED
[ 1631.312337] ata6.00: cmd 60/02:88:02:08:00/00:00:00:00:00/40 tag 17 ncq dma 1024 in
res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
[ 1631.312340] ata6.00: status: { DRDY }
[ 1631.312342] ata6: hard resetting link
[ 1631.778725] ata6: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1631.779746] ata6.00: configured for UDMA/133
[ 1631.779791] ata6.00: device reported invalid CHS sector 0
[ 1631.779795] ata6: EH complete
[ 1632.718473] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
