Slow booting manjaro kde plasma 20.2
i have a problem with my linux it boot very slow and at the start it feel very slow too
and sometimes it take a lot of time to open programs
systemd-analyze
the output
Startup finished in 5.338s (firmware) + 14.668s (loader) + 3.591s (kernel) + 34.009s (userspace) = 57.608s
graphical.target reached after 32.997s in userspace
systemd-analyze blame
the output
13.896s snapd.service
11.486s systemd-journal-flush.service
 7.573s lvm2-monitor.service
 5.846s polkit.service
 5.559s systemd-modules-load.service
 5.485s ModemManager.service
 4.767s dev-sda2.device
 3.597s avahi-daemon.service
 3.595s bluetooth.service
 3.592s NetworkManager.service
 3.182s cups.service
 3.130s systemd-tmpfiles-setup.service
 1.925s wpa_supplicant.service
 1.859s systemd-logind.service
 1.753s systemd-udevd.service
 1.733s linux-module-cleanup.service
 1.625s apparmor.service
 1.487s var-lib-snapd-snap-eclipse-48.mount
 1.358s var-lib-snapd-snap-core18-1944.mount
 1.322s systemd-fsck-root.service
 1.189s var-lib-snapd-snap-gedit-605.mount
 1.148s systemd-random-seed.service
 1.087s dev-loop8.device
 1.050s var-lib-snapd-snap-gnome\x2d3\x2d28\x2d1804-145.mount
 1.032s dev-loop0.device
 1.012s tlp.service
  959ms var-lib-snapd-snap-gtk\x2dcommon\x2dthemes-1514.mount
  899ms dev-loop7.device
  882ms snapd.apparmor.service
  870ms var-lib-snapd-snap-notepad\x2dplus\x2dplus-253.mount
  852ms var-lib-snapd-snap-snapd-10707.mount
  810ms systemd-backlight@backlight:intel_backlight.service
  766ms dev-loop2.device
  690ms systemd-tmpfiles-setup-dev.service
  639ms upower.service
  629ms user@1000.service
  584ms systemd-fsck@dev-disk-by\x2duuid-3CD1\x2d2C82.service
  573ms systemd-udev-trigger.service
  536ms udisks2.service
  515ms boot-efi.mount
  491ms systemd-update-utmp.service
  420ms systemd-journald.service
  408ms dev-loop6.device
  364ms modprobe@configfs.service
  351ms var-lib-snapd-snap-wine\x2dplatform\x2druntime-206.mount
  324ms systemd-sysctl.service
  313ms systemd-binfmt.service
  281ms rtkit-daemon.service
  256ms var-lib-snapd-snap-wine\x2dplatform\x2d5\x2dstable-16.mount
  233ms systemd-tmpfiles-clean.service
  182ms modprobe@drm.service
  156ms modprobe@fuse.service
  125ms dev-hugepages.mount
  124ms dev-mqueue.mount
  123ms sys-kernel-debug.mount
  122ms sys-kernel-tracing.mount
  118ms systemd-rfkill.service
  111ms systemd-remount-fs.service
   80ms tmp.mount
   76ms kmod-static-nodes.service
   75ms dev-loop1.device
   14ms proc-sys-fs-binfmt_misc.mount
   12ms user-runtime-dir@1000.service
    6ms systemd-user-sessions.service
    6ms dev-loop4.device
    5ms sys-kernel-config.mount
    5ms dev-loop3.device
    3ms dev-loop5.device
    3ms sys-fs-fuse-connections.mount
  859us snapd.socket
systemd-analyze critical-chain<br>the output
The time when unit became active or started is printed after the "@" character.
The time the unit took to start is printed after the "+" character.
graphical.target @34.811s
└─multi-user.target @34.810s
  └─snapd.service @20.912s +13.896s
    └─basic.target @20.574s
      └─sockets.target @20.574s
        └─snapd.socket @20.573s +859us
          └─sysinit.target @20.554s
            └─systemd-update-utmp.service @20.063s +491ms
              └─systemd-tmpfiles-setup.service @16.929s +3.130s
                └─systemd-journal-flush.service @5.439s +11.486s
                  └─systemd-remount-fs.service @5.264s +111ms
                    └─systemd-fsck-root.service @3.939s +1.322s
                      └─systemd-journald.socket @3.842s
                        └─system.slice @3.574s
                          └─-.slice @3.574s
inxi -Fzy
  Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 Desktop: KDE Plasma 5.20.5
  Distro: Manjaro Linux
  Type: Laptop System: HP product: HP Pavilion Laptop 14-bf1xx
  v: Type1ProductConfigId serial: <filter>
  Mobo: HP model: 83CE v: 59.40 serial: <filter> UEFI: Insyde v: F.35
  date: 02/23/2018
  ID-1: BAT1 charge: 9.5 Wh condition: 10.1/42.1 Wh (24%)
  Info: Quad Core model: Intel Core i7-8550U bits: 64 type: MT MCP
  L2 cache: 8 MiB
  Speed: 600 MHz min/max: 400/4000 MHz Core speeds (MHz): 1: 600 2: 600 3: 600
  4: 600 5: 600 6: 600 7: 600 8: 600
  Device-1: Intel UHD Graphics 620 driver: i915 v: kernel
  Device-2: NVIDIA GM108M [GeForce 940MX] driver: nvidia v: 460.32.03
  Device-3: Cheng Uei Precision Industry (Foxlink) HP Wide Vision HD Camera
  type: USB driver: uvcvideo
  Display: x11 server: X.Org 1.20.10 driver: loaded: modesetting,nvidia
  unloaded: intel,nouveau resolution: 1280x720
  OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.3.3
  Device-1: Intel Sunrise Point-LP HD Audio driver: snd_hda_intel
  Sound Server: ALSA v: k5.9.16-1-MANJARO
  driver: r8169
  Device-2: Intel Wireless 7265 driver: iwlwifi
  Local Storage: total: 1.03 TiB used: 29.44 GiB (2.8%)
  ID-1: /dev/sda vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB
  ID-2: /dev/sdb vendor: SanDisk model: SD9SN8W-128G-1006 size: 119.24 GiB
  ID-1: / size: 105.33 GiB used: 29.37 GiB (27.9%) fs: ext4 dev: /dev/sda2
  ID-2: /boot/efi size: 256 MiB used: 73.1 MiB (28.6%) fs: vfat dev: /dev/sdb1
  System Temperatures: cpu: 32.0 C mobo: 29.8 C
  Processes: 233 Uptime: 24m Memory: 11.62 GiB used: 2.34 GiB (20.1%)
  Shell: Bash inxi: 3.2.02
Hi, nothing triggers me but, snap seems to take a long time to load. Do you use it? if not you can opt to to disable it.
some swap might be usefull, even if it almost never used. Swap - Manjaro
Depending on how long you are running with this install, do some maintenance?
https://wiki.manjaro.org/index.php/System_Maintenance
