hi, thx for the replies.
I once configured samba to create shared folders, but that was a while ago. I don’t use nor configure samba lately.
Teo:
That said, it could be unrelated. The kernel log from previous boot might provide insight
journalctl -b -1 -k --no-pager
I don’t really understand how to inspect the results. What should I look for?
here’s the journalctl output:
Nov 02 18:03:06 03v67 kernel: microcode: updated early: 0x8a -> 0xb8, date = 2024-02-15
Nov 02 18:03:06 03v67 kernel: Linux version 6.5.13-7-MANJARO (builduser@fv-az1207-429) (gcc (GCC) 13.2.1 20230801, GNU ld (GNU Binutils) 2.41.0) #1 SMP PREEMPT_DYNAMIC Wed Dec 20 07:15:58 UTC 2023
Nov 02 18:03:06 03v67 kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64 root=UUID=b54d7936-bc36-4be3-af80-0925eaad5c46 rw quiet splash apparmor=1 security=apparmor udev.log_priority=3
Nov 02 18:03:06 03v67 kernel: x86/split lock detection: #AC: crashing the kernel on kernel split_locks and warning on user-space split_locks
Nov 02 18:03:06 03v67 kernel: BIOS-provided physical RAM map:
Nov 02 18:03:06 03v67 kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009efff] usable
Nov 02 18:03:06 03v67 kernel: BIOS-e820: [mem 0x000000000009f000-0x00000000000fffff] reserved
Nov 02 18:03:06 03v67 kernel: BIOS-e820: [mem 0x0000000000100000-0x000000003fd98fff] usable
Nov 02 18:03:06 03v67 kernel: BIOS-e820: [mem 0x000000003fd99000-0x0000000040698fff] reserved
Nov 02 18:03:06 03v67 kernel: BIOS-e820: [mem 0x0000000040699000-0x00000000424aefff] usable
Nov 02 18:03:06 03v67 kernel: BIOS-e820: [mem 0x00000000424af000-0x00000000442fefff] reserved
Nov 02 18:03:06 03v67 kernel: BIOS-e820: [mem 0x00000000442ff000-0x0000000044b2efff] ACPI NVS
Nov 02 18:03:06 03v67 kernel: BIOS-e820: [mem 0x0000000044b2f000-0x0000000044bfefff] ACPI data
Nov 02 18:03:06 03v67 kernel: BIOS-e820: [mem 0x0000000044bff000-0x0000000044bfffff] usable
Nov 02 18:03:06 03v67 kernel: BIOS-e820: [mem 0x0000000044c00000-0x0000000048ffffff] reserved
Nov 02 18:03:06 03v67 kernel: BIOS-e820: [mem 0x0000000049e00000-0x000000004f7fffff] reserved
Nov 02 18:03:06 03v67 kernel: BIOS-e820: [mem 0x00000000c0000000-0x00000000cfffffff] reserved
Nov 02 18:03:06 03v67 kernel: BIOS-e820: [mem 0x00000000fe010000-0x00000000fe010fff] reserved
Nov 02 18:03:06 03v67 kernel: BIOS-e820: [mem 0x00000000fed20000-0x00000000fed7ffff] reserved
Nov 02 18:03:06 03v67 kernel: BIOS-e820: [mem 0x00000000ff500000-0x00000000ffffffff] reserved
Nov 02 18:03:06 03v67 kernel: BIOS-e820: [mem 0x0000000100000000-0x00000006b07fffff] usable
Nov 02 18:03:06 03v67 kernel: NX (Execute Disable) protection: active
Nov 02 18:03:06 03v67 kernel: e820: update [mem 0x37e3d018-0x37e66857] usable ==> usable
Nov 02 18:03:06 03v67 kernel: extended physical RAM map:
Nov 02 18:03:06 03v67 kernel: reserve setup_data: [mem 0x0000000000000000-0x000000000009efff] usable
Nov 02 18:03:06 03v67 kernel: reserve setup_data: [mem 0x000000000009f000-0x00000000000fffff] reserved
Nov 02 18:03:06 03v67 kernel: reserve setup_data: [mem 0x0000000000100000-0x0000000037e3d017] usable
Nov 02 18:03:06 03v67 kernel: reserve setup_data: [mem 0x0000000037e3d018-0x0000000037e66857] usable
Nov 02 18:03:06 03v67 kernel: reserve setup_data: [mem 0x0000000037e66858-0x000000003fd98fff] usable
Nov 02 18:03:06 03v67 kernel: reserve setup_data: [mem 0x000000003fd99000-0x0000000040698fff] reserved
Nov 02 18:03:06 03v67 kernel: reserve setup_data: [mem 0x0000000040699000-0x00000000424aefff] usable
Nov 02 18:03:06 03v67 kernel: reserve setup_data: [mem 0x00000000424af000-0x00000000442fefff] reserved
Nov 02 18:03:06 03v67 kernel: reserve setup_data: [mem 0x00000000442ff000-0x0000000044b2efff] ACPI NVS
Nov 02 18:03:06 03v67 kernel: reserve setup_data: [mem 0x0000000044b2f000-0x0000000044bfefff] ACPI data
Nov 02 18:03:06 03v67 kernel: reserve setup_data: [mem 0x0000000044bff000-0x0000000044bfffff] usable
Nov 02 18:03:06 03v67 kernel: reserve setup_data: [mem 0x0000000044c00000-0x0000000048ffffff] reserved
Nov 02 18:03:06 03v67 kernel: reserve setup_data: [mem 0x0000000049e00000-0x000000004f7fffff] reserved
Nov 02 18:03:06 03v67 kernel: reserve setup_data: [mem 0x00000000c0000000-0x00000000cfffffff] reserved
Nov 02 18:03:06 03v67 kernel: reserve setup_data: [mem 0x00000000fe010000-0x00000000fe010fff] reserved
Nov 02 18:03:06 03v67 kernel: reserve setup_data: [mem 0x00000000fed20000-0x00000000fed7ffff] reserved
Nov 02 18:03:06 03v67 kernel: reserve setup_data: [mem 0x00000000ff500000-0x00000000ffffffff] reserved
Nov 02 18:03:06 03v67 kernel: reserve setup_data: [mem 0x0000000100000000-0x00000006b07fffff] usable
Nov 02 18:03:06 03v67 kernel: efi: EFI v2.7 by INSYDE Corp.
Nov 02 18:03:06 03v67 kernel: efi: ACPI=0x44bfe000 ACPI 2.0=0x44bfe014 TPMFinalLog=0x44ac5000 SMBIOS=0x429de000 SMBIOS 3.0=0x429dc000 ESRT=0x3bf60a98 INITRD=0x3bee1a98 RNG=0x44b75018 TPMEventLog=0x3bed2018
Nov 02 18:03:06 03v67 kernel: random: crng init done
Nov 02 18:03:06 03v67 kernel: efi: Remove mem71: MMIO range=[0xc0000000-0xcfffffff] (256MB) from e820 map
Nov 02 18:03:06 03v67 kernel: e820: remove [mem 0xc0000000-0xcfffffff] reserved
Nov 02 18:03:06 03v67 kernel: efi: Not removing mem72: MMIO range=[0xfe010000-0xfe010fff] (4KB) from e820 map
Nov 02 18:03:06 03v67 kernel: efi: Remove mem74: MMIO range=[0xff500000-0xffffffff] (11MB) from e820 map
Nov 02 18:03:06 03v67 kernel: e820: remove [mem 0xff500000-0xffffffff] reserved
Nov 02 18:03:06 03v67 kernel: SMBIOS 3.3.0 present.
Nov 02 18:03:06 03v67 kernel: DMI: Acer Aspire A514-54G/Lily_TL, BIOS V1.26 03/14/2022
Nov 02 18:03:06 03v67 kernel: tsc: Detected 2400.000 MHz processor
Nov 02 18:03:06 03v67 kernel: tsc: Detected 2419.200 MHz TSC
Nov 02 18:03:06 03v67 kernel: e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
Nov 02 18:03:06 03v67 kernel: e820: remove [mem 0x000a0000-0x000fffff] usable
Nov 02 18:03:06 03v67 kernel: last_pfn = 0x6b0800 max_arch_pfn = 0x400000000
Nov 02 18:03:06 03v67 kernel: MTRR map: 5 entries (3 fixed + 2 variable; max 23), built from 10 variable MTRRs
Nov 02 18:03:06 03v67 kernel: x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
Nov 02 18:03:06 03v67 kernel: last_pfn = 0x44c00 max_arch_pfn = 0x400000000
Nov 02 18:03:06 03v67 kernel: esrt: Reserving ESRT space from 0x000000003bf60a98 to 0x000000003bf60ad0.
Nov 02 18:03:06 03v67 kernel: e820: update [mem 0x3bf60000-0x3bf60fff] usable ==> reserved
Nov 02 18:03:06 03v67 kernel: Using GB pages for direct mapping
Nov 02 18:03:06 03v67 kernel: Secure boot disabled
Nov 02 18:03:06 03v67 kernel: RAMDISK: [mem 0x37e67000-0x39b56fff]
Nov 02 18:03:06 03v67 kernel: ACPI: Early table checksum verification disabled
Nov 02 18:03:06 03v67 kernel: ACPI: RSDP 0x0000000044BFE014 000024 (v02 ACRSYS)
Nov 02 18:03:06 03v67 kernel: ACPI: XSDT 0x0000000044BDB188 000124 (v01 ACRSYS ACRPRDCT 00000002 01000013)
Nov 02 18:03:06 03v67 kernel: ACPI: FACP 0x0000000044BDE000 000114 (v06 ACRSYS ACRPRDCT 00000002 1025 00040000)
Nov 02 18:03:06 03v67 kernel: ACPI: DSDT 0x0000000044B81000 059948 (v02 ACRSYS ACRPRDCT 00000002 1025 00040000)
Nov 02 18:03:06 03v67 kernel: ACPI: FACS 0x0000000044AA2000 000040
Nov 02 18:03:06 03v67 kernel: ACPI: UEFI 0x0000000044B2E000 000236 (v01 ACRSYS ACRPRDCT 00000001 1025 00040000)
Nov 02 18:03:06 03v67 kernel: ACPI: SSDT 0x0000000044BFA000 00255C (v02 ACRSYS ACRPRDCT 00003000 1025 00040000)
Nov 02 18:03:06 03v67 kernel: ACPI: SSDT 0x0000000044BF9000 000105 (v02 ACRSYS ACRPRDCT 00003000 1025 00040000)
Nov 02 18:03:06 03v67 kernel: ACPI: SSDT 0x0000000044BF6000 002137 (v02 ACRSYS ACRPRDCT 00003000 1025 00040000)
Nov 02 18:03:06 03v67 kernel: ACPI: SSDT 0x0000000044BF2000 003300 (v02 ACRSYS ACRPRDCT 00003000 1025 00040000)
Nov 02 18:03:06 03v67 kernel: ACPI: SSDT 0x0000000044BF1000 00077B (v02 ACRSYS ACRPRDCT 00001000 1025 00040000)
Nov 02 18:03:06 03v67 kernel: ACPI: TPM2 0x0000000044BF0000 00004C (v04 ACRSYS ACRPRDCT 00000002 1025 00040000)
Nov 02 18:03:06 03v67 kernel: ACPI: MSDM 0x0000000044BEF000 000055 (v03 ACRSYS ACRPRDCT 00000001 1025 00040000)
Nov 02 18:03:06 03v67 kernel: ACPI: SSDT 0x0000000044BEE000 000D02 (v02 ACRSYS ACRPRDCT 00000000 1025 00040000)
Nov 02 18:03:06 03v67 kernel: ACPI: NHLT 0x0000000044BEC000 001B54 (v00 ACRSYS ACRPRDCT 00000002 1025 00040000)
Nov 02 18:03:06 03v67 kernel: ACPI: LPIT 0x0000000044BEB000 0000CC (v01 ACRSYS ACRPRDCT 00000002 1025 00040000)
Nov 02 18:03:06 03v67 kernel: ACPI: WSMT 0x0000000044BEA000 000028 (v01 ACRSYS ACRPRDCT 00000002 1025 00040000)
Nov 02 18:03:06 03v67 kernel: ACPI: SSDT 0x0000000044BE9000 000B70 (v02 ACRSYS ACRPRDCT 00001000 1025 00040000)
Nov 02 18:03:06 03v67 kernel: ACPI: SSDT 0x0000000044BE8000 00012A (v02 ACRSYS ACRPRDCT 00000000 1025 00040000)
Nov 02 18:03:06 03v67 kernel: ACPI: DBGP 0x0000000044BE7000 000034 (v01 ACRSYS ACRPRDCT 00000002 1025 00040000)
Nov 02 18:03:06 03v67 kernel: ACPI: DBG2 0x0000000044BE6000 000054 (v00 ACRSYS ACRPRDCT 00000002 1025 00040000)
Nov 02 18:03:06 03v67 kernel: ACPI: SSDT 0x0000000044BDF000 006BA9 (v01 ACRSYS ACRPRDCT 00001000 1025 00040000)
Nov 02 18:03:06 03v67 kernel: ACPI: HPET 0x0000000044BDD000 000038 (v01 ACRSYS ACRPRDCT 00000002 1025 00040000)
Nov 02 18:03:06 03v67 kernel: ACPI: APIC 0x0000000044BDC000 00012C (v04 ACRSYS ACRPRDCT 00000002 1025 00040000)
Nov 02 18:03:06 03v67 kernel: ACPI: MCFG 0x0000000044BFD000 00003C (v01 ACRSYS ACRPRDCT 00000002 1025 00040000)
Nov 02 18:03:06 03v67 kernel: ACPI: SSDT 0x0000000044B80000 000C78 (v02 ACRSYS ACRPRDCT 00000002 1025 00040000)
Nov 02 18:03:06 03v67 kernel: ACPI: DMAR 0x0000000044B7F000 000088 (v02 ACRSYS ACRPRDCT 00000002 1025 00040000)
Nov 02 18:03:06 03v67 kernel: ACPI: SSDT 0x0000000044B7C000 002D73 (v01 ACRSYS ACRPRDCT 00001000 1025 00040000)
Nov 02 18:03:06 03v67 kernel: ACPI: UEFI 0x0000000044A5B000 00063A (v01 ACRSYS ACRPRDCT 00000000 1025 00040000)
Nov 02 18:03:06 03v67 kernel: ACPI: UEFI 0x0000000044A5A000 00005C (v01 ACRSYS ACRPRDCT 00000000 1025 00040000)
Nov 02 18:03:06 03v67 kernel: ACPI: SSDT 0x0000000044B7B000 000985 (v02 ACRSYS ACRPRDCT 00001000 1025 00040000)
Nov 02 18:03:06 03v67 kernel: ACPI: SSDT 0x0000000044B7A000 0000F8 (v01 ACRSYS ACRPRDCT 00001000 1025 00040000)
Nov 02 18:03:06 03v67 kernel: ACPI: SSDT 0x0000000044B79000 000835 (v02 ACRSYS ACRPRDCT 00003000 1025 00040000)
Nov 02 18:03:06 03v67 kernel: ACPI: FPDT 0x0000000044B78000 000044 (v01 ACRSYS ACRPRDCT 00000002 1025 00040000)
Nov 02 18:03:06 03v67 kernel: ACPI: PTDT 0x0000000044B76000 000CFE (v00 ACRSYS ACRPRDCT 00000005 1025 00040000)
Nov 02 18:03:06 03v67 kernel: ACPI: BGRT 0x0000000044B77000 000038 (v01 ACRSYS ACRPRDCT 00000001 1025 00040000)
Nov 02 18:03:06 03v67 kernel: ACPI: Reserving FACP table memory at [mem 0x44bde000-0x44bde113]
Nov 02 18:03:06 03v67 kernel: ACPI: Reserving DSDT table memory at [mem 0x44b81000-0x44bda947]
Nov 02 18:03:06 03v67 kernel: ACPI: Reserving FACS table memory at [mem 0x44aa2000-0x44aa203f]
Nov 02 18:03:06 03v67 kernel: ACPI: Reserving UEFI table memory at [mem 0x44b2e000-0x44b2e235]
Nov 02 18:03:06 03v67 kernel: ACPI: Reserving SSDT table memory at [mem 0x44bfa000-0x44bfc55b]
Nov 02 18:03:06 03v67 kernel: ACPI: Reserving SSDT table memory at [mem 0x44bf9000-0x44bf9104]
Nov 02 18:03:06 03v67 kernel: ACPI: Reserving SSDT table memory at [mem 0x44bf6000-0x44bf8136]
Nov 02 18:03:06 03v67 kernel: ACPI: Reserving SSDT table memory at [mem 0x44bf2000-0x44bf52ff]
Nov 02 18:03:06 03v67 kernel: ACPI: Reserving SSDT table memory at [mem 0x44bf1000-0x44bf177a]
Nov 02 18:03:06 03v67 kernel: ACPI: Reserving TPM2 table memory at [mem 0x44bf0000-0x44bf004b]
Nov 02 18:03:06 03v67 kernel: ACPI: Reserving MSDM table memory at [mem 0x44bef000-0x44bef054]
Nov 02 18:03:06 03v67 kernel: ACPI: Reserving SSDT table memory at [mem 0x44bee000-0x44beed01]
Nov 02 18:03:06 03v67 kernel: ACPI: Reserving NHLT table memory at [mem 0x44bec000-0x44bedb53]
Nov 02 18:03:06 03v67 kernel: ACPI: Reserving LPIT table memory at [mem 0x44beb000-0x44beb0cb]
Nov 02 18:03:06 03v67 kernel: ACPI: Reserving WSMT table memory at [mem 0x44bea000-0x44bea027]
Nov 02 18:03:06 03v67 kernel: ACPI: Reserving SSDT table memory at [mem 0x44be9000-0x44be9b6f]
Nov 02 18:03:06 03v67 kernel: ACPI: Reserving SSDT table memory at [mem 0x44be8000-0x44be8129]
Nov 02 18:03:06 03v67 kernel: ACPI: Reserving DBGP table memory at [mem 0x44be7000-0x44be7033]
Nov 02 18:03:06 03v67 kernel: ACPI: Reserving DBG2 table memory at [mem 0x44be6000-0x44be6053]
Nov 02 18:03:06 03v67 kernel: ACPI: Reserving SSDT table memory at [mem 0x44bdf000-0x44be5ba8]
Nov 02 18:03:06 03v67 kernel: ACPI: Reserving HPET table memory at [mem 0x44bdd000-0x44bdd037]
Nov 02 18:03:06 03v67 kernel: ACPI: Reserving APIC table memory at [mem 0x44bdc000-0x44bdc12b]
Nov 02 18:03:06 03v67 kernel: ACPI: Reserving MCFG table memory at [mem 0x44bfd000-0x44bfd03b]
Nov 02 18:03:06 03v67 kernel: ACPI: Reserving SSDT table memory at [mem 0x44b80000-0x44b80c77]
Nov 02 18:03:06 03v67 kernel: ACPI: Reserving DMAR table memory at [mem 0x44b7f000-0x44b7f087]
Nov 02 18:03:06 03v67 kernel: ACPI: Reserving SSDT table memory at [mem 0x44b7c000-0x44b7ed72]
Nov 02 18:03:06 03v67 kernel: ACPI: Reserving UEFI table memory at [mem 0x44a5b000-0x44a5b639]
Nov 02 18:03:06 03v67 kernel: ACPI: Reserving UEFI table memory at [mem 0x44a5a000-0x44a5a05b]
Nov 02 18:03:06 03v67 kernel: ACPI: Reserving SSDT table memory at [mem 0x44b7b000-0x44b7b984]
Nov 02 18:03:06 03v67 kernel: ACPI: Reserving SSDT table memory at [mem 0x44b7a000-0x44b7a0f7]
Nov 02 18:03:06 03v67 kernel: ACPI: Reserving SSDT table memory at [mem 0x44b79000-0x44b79834]
Nov 02 18:03:06 03v67 kernel: ACPI: Reserving FPDT table memory at [mem 0x44b78000-0x44b78043]
Nov 02 18:03:06 03v67 kernel: ACPI: Reserving PTDT table memory at [mem 0x44b76000-0x44b76cfd]
Nov 02 18:03:06 03v67 kernel: ACPI: Reserving BGRT table memory at [mem 0x44b77000-0x44b77037]
Nov 02 18:03:06 03v67 kernel: No NUMA configuration found
Nov 02 18:03:06 03v67 kernel: Faking a node at [mem 0x0000000000000000-0x00000006b07fffff]
Nov 02 18:03:06 03v67 kernel: NODE_DATA(0) allocated [mem 0x6b07fb000-0x6b07fffff]
Nov 02 18:03:06 03v67 kernel: Zone ranges:
Nov 02 18:03:06 03v67 kernel: DMA [mem 0x0000000000001000-0x0000000000ffffff]
Nov 02 18:03:06 03v67 kernel: DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
Nov 02 18:03:06 03v67 kernel: Normal [mem 0x0000000100000000-0x00000006b07fffff]
Nov 02 18:03:06 03v67 kernel: Device empty
Nov 02 18:03:06 03v67 kernel: Movable zone start for each node
Nov 02 18:03:06 03v67 kernel: Early memory node ranges
Nov 02 18:03:06 03v67 kernel: node 0: [mem 0x0000000000001000-0x000000000009efff]
Nov 02 18:03:06 03v67 kernel: node 0: [mem 0x0000000000100000-0x000000003fd98fff]
Nov 02 18:03:06 03v67 kernel: node 0: [mem 0x0000000040699000-0x00000000424aefff]
Nov 02 18:03:06 03v67 kernel: node 0: [mem 0x0000000044bff000-0x0000000044bfffff]
Nov 02 18:03:06 03v67 kernel: node 0: [mem 0x0000000100000000-0x00000006b07fffff]
Nov 02 18:03:06 03v67 kernel: Initmem setup node 0 [mem 0x0000000000001000-0x00000006b07fffff]
Nov 02 18:03:06 03v67 kernel: On node 0, zone DMA: 1 pages in unavailable ranges
Nov 02 18:03:06 03v67 kernel: On node 0, zone DMA: 97 pages in unavailable ranges
Nov 02 18:03:06 03v67 kernel: On node 0, zone DMA32: 2304 pages in unavailable ranges
Nov 02 18:03:06 03v67 kernel: On node 0, zone DMA32: 10064 pages in unavailable ranges
Nov 02 18:03:06 03v67 kernel: On node 0, zone Normal: 13312 pages in unavailable ranges
Nov 02 18:03:06 03v67 kernel: On node 0, zone Normal: 30720 pages in unavailable ranges
Nov 02 18:03:06 03v67 kernel: Reserving Intel graphics memory at [mem 0x4b800000-0x4f7fffff]
Nov 02 18:03:06 03v67 kernel: ACPI: PM-Timer IO Port: 0x1808
Nov 02 18:03:06 03v67 kernel: ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
Nov 02 18:03:06 03v67 kernel: ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
Nov 02 18:03:06 03v67 kernel: ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
Nov 02 18:03:06 03v67 kernel: ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
Nov 02 18:03:06 03v67 kernel: ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
Nov 02 18:03:06 03v67 kernel: ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
Nov 02 18:03:06 03v67 kernel: ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
Nov 02 18:03:06 03v67 kernel: ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
Nov 02 18:03:06 03v67 kernel: ACPI: LAPIC_NMI (acpi_id[0x09] high edge lint[0x1])
Nov 02 18:03:06 03v67 kernel: ACPI: LAPIC_NMI (acpi_id[0x0a] high edge lint[0x1])
Nov 02 18:03:06 03v67 kernel: ACPI: LAPIC_NMI (acpi_id[0x0b] high edge lint[0x1])
Nov 02 18:03:06 03v67 kernel: ACPI: LAPIC_NMI (acpi_id[0x0c] high edge lint[0x1])
Nov 02 18:03:06 03v67 kernel: ACPI: LAPIC_NMI (acpi_id[0x0d] high edge lint[0x1])
Nov 02 18:03:06 03v67 kernel: ACPI: LAPIC_NMI (acpi_id[0x0e] high edge lint[0x1])
Nov 02 18:03:06 03v67 kernel: ACPI: LAPIC_NMI (acpi_id[0x0f] high edge lint[0x1])
Nov 02 18:03:06 03v67 kernel: ACPI: LAPIC_NMI (acpi_id[0x10] high edge lint[0x1])
Nov 02 18:03:06 03v67 kernel: IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
Nov 02 18:03:06 03v67 kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
Nov 02 18:03:06 03v67 kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
Nov 02 18:03:06 03v67 kernel: ACPI: Using ACPI (MADT) for SMP configuration information
Nov 02 18:03:06 03v67 kernel: ACPI: HPET id: 0x8086a201 base: 0xfed00000
Nov 02 18:03:06 03v67 kernel: e820: update [mem 0x3a931000-0x3aa24fff] usable ==> reserved
Nov 02 18:03:06 03v67 kernel: TSC deadline timer available
Nov 02 18:03:06 03v67 kernel: smpboot: Allowing 8 CPUs, 0 hotplug CPUs
Nov 02 18:03:06 03v67 kernel: PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
Nov 02 18:03:06 03v67 kernel: PM: hibernation: Registered nosave memory: [mem 0x0009f000-0x000fffff]
Nov 02 18:03:06 03v67 kernel: PM: hibernation: Registered nosave memory: [mem 0x37e3d000-0x37e3dfff]
Nov 02 18:03:06 03v67 kernel: PM: hibernation: Registered nosave memory: [mem 0x37e66000-0x37e66fff]
Nov 02 18:03:06 03v67 kernel: PM: hibernation: Registered nosave memory: [mem 0x3a931000-0x3aa24fff]
Nov 02 18:03:06 03v67 kernel: PM: hibernation: Registered nosave memory: [mem 0x3bf60000-0x3bf60fff]
Nov 02 18:03:06 03v67 kernel: PM: hibernation: Registered nosave memory: [mem 0x3fd99000-0x40698fff]
Nov 02 18:03:06 03v67 kernel: PM: hibernation: Registered nosave memory: [mem 0x424af000-0x442fefff]
Nov 02 18:03:06 03v67 kernel: PM: hibernation: Registered nosave memory: [mem 0x442ff000-0x44b2efff]
Nov 02 18:03:06 03v67 kernel: PM: hibernation: Registered nosave memory: [mem 0x44b2f000-0x44bfefff]
Nov 02 18:03:06 03v67 kernel: PM: hibernation: Registered nosave memory: [mem 0x44c00000-0x48ffffff]
Nov 02 18:03:06 03v67 kernel: PM: hibernation: Registered nosave memory: [mem 0x49000000-0x49dfffff]
Nov 02 18:03:06 03v67 kernel: PM: hibernation: Registered nosave memory: [mem 0x49e00000-0x4f7fffff]
Nov 02 18:03:06 03v67 kernel: PM: hibernation: Registered nosave memory: [mem 0x4f800000-0xfe00ffff]
Nov 02 18:03:06 03v67 kernel: PM: hibernation: Registered nosave memory: [mem 0xfe010000-0xfe010fff]
Nov 02 18:03:06 03v67 kernel: PM: hibernation: Registered nosave memory: [mem 0xfe011000-0xfed1ffff]
Nov 02 18:03:06 03v67 kernel: PM: hibernation: Registered nosave memory: [mem 0xfed20000-0xfed7ffff]
Nov 02 18:03:06 03v67 kernel: PM: hibernation: Registered nosave memory: [mem 0xfed80000-0xffffffff]
Nov 02 18:03:06 03v67 kernel: [mem 0x4f800000-0xfe00ffff] available for PCI devices
Nov 02 18:03:06 03v67 kernel: Booting paravirtualized kernel on bare hardware
Nov 02 18:03:06 03v67 kernel: clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
Nov 02 18:03:06 03v67 kernel: setup_percpu: NR_CPUS:320 nr_cpumask_bits:8 nr_cpu_ids:8 nr_node_ids:1
Nov 02 18:03:06 03v67 kernel: percpu: Embedded 64 pages/cpu s225280 r8192 d28672 u262144
Nov 02 18:03:06 03v67 kernel: pcpu-alloc: s225280 r8192 d28672 u262144 alloc=1*2097152
Nov 02 18:03:06 03v67 kernel: pcpu-alloc: [0] 0 1 2 3 4 5 6 7
Nov 02 18:03:06 03v67 kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64 root=UUID=b54d7936-bc36-4be3-af80-0925eaad5c46 rw quiet splash apparmor=1 security=apparmor udev.log_priority=3
Nov 02 18:03:06 03v67 kernel: Unknown kernel command line parameters "splash BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64", will be passed to user space.
Nov 02 18:03:06 03v67 kernel: Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
Nov 02 18:03:06 03v67 kernel: Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
Nov 02 18:03:06 03v67 kernel: Fallback order for Node 0: 0
Nov 02 18:03:06 03v67 kernel: Built 1 zonelists, mobility grouping on. Total pages: 6137377
Nov 02 18:03:06 03v67 kernel: Policy zone: Normal
Nov 02 18:03:06 03v67 kernel: mem auto-init: stack:all(zero), heap alloc:on, heap free:off
Nov 02 18:03:06 03v67 kernel: software IO TLB: area num 8.
Nov 02 18:03:06 03v67 kernel: Memory: 24252412K/24939832K available (16384K kernel code, 2142K rwdata, 13044K rodata, 3400K init, 3852K bss, 687160K reserved, 0K cma-reserved)
Nov 02 18:03:06 03v67 kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
Nov 02 18:03:06 03v67 kernel: ftrace: allocating 48678 entries in 191 pages
Nov 02 18:03:06 03v67 kernel: ftrace: allocated 191 pages with 7 groups
Nov 02 18:03:06 03v67 kernel: Dynamic Preempt: full
Nov 02 18:03:06 03v67 kernel: rcu: Preemptible hierarchical RCU implementation.
Nov 02 18:03:06 03v67 kernel: rcu: RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=8.
Nov 02 18:03:06 03v67 kernel: rcu: RCU priority boosting: priority 1 delay 500 ms.
Nov 02 18:03:06 03v67 kernel: Trampoline variant of Tasks RCU enabled.
Nov 02 18:03:06 03v67 kernel: Rude variant of Tasks RCU enabled.
Nov 02 18:03:06 03v67 kernel: Tracing variant of Tasks RCU enabled.
Nov 02 18:03:06 03v67 kernel: rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
Nov 02 18:03:06 03v67 kernel: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
Nov 02 18:03:06 03v67 kernel: NR_IRQS: 20736, nr_irqs: 2048, preallocated irqs: 16
Nov 02 18:03:06 03v67 kernel: rcu: srcu_init: Setting srcu_struct sizes based on contention.
Nov 02 18:03:06 03v67 kernel: kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
Nov 02 18:03:06 03v67 kernel: Console: colour dummy device 80x25
Nov 02 18:03:06 03v67 kernel: printk: console [tty0] enabled
Nov 02 18:03:06 03v67 kernel: ACPI: Core revision 20230331
Nov 02 18:03:06 03v67 kernel: hpet: HPET dysfunctional in PC10. Force disabled.
Nov 02 18:03:06 03v67 kernel: APIC: Switch to symmetric I/O mode setup
Nov 02 18:03:06 03v67 kernel: DMAR: Host address width 39
Nov 02 18:03:06 03v67 kernel: DMAR: DRHD base: 0x000000fed90000 flags: 0x0
Nov 02 18:03:06 03v67 kernel: DMAR: dmar0: reg_base_addr fed90000 ver 4:0 cap 1c0000c40660462 ecap 29a00f0505e
Nov 02 18:03:06 03v67 kernel: DMAR: DRHD base: 0x000000fed91000 flags: 0x1
Nov 02 18:03:06 03v67 kernel: DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
Nov 02 18:03:06 03v67 kernel: DMAR: RMRR base: 0x0000004b000000 end: 0x0000004f7fffff
Nov 02 18:03:06 03v67 kernel: DMAR-IR: IOAPIC id 2 under DRHD base 0xfed91000 IOMMU 1
Nov 02 18:03:06 03v67 kernel: DMAR-IR: HPET id 0 under DRHD base 0xfed91000
Nov 02 18:03:06 03v67 kernel: DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
Nov 02 18:03:06 03v67 kernel: DMAR-IR: Enabled IRQ remapping in x2apic mode
Nov 02 18:03:06 03v67 kernel: x2apic enabled
Nov 02 18:03:06 03v67 kernel: Switched APIC routing to cluster x2apic.
Nov 02 18:03:06 03v67 kernel: clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x22df1149949, max_idle_ns: 440795312789 ns
Nov 02 18:03:06 03v67 kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 4840.00 BogoMIPS (lpj=8064000)
Nov 02 18:03:06 03v67 kernel: CPU0: Thermal monitoring enabled (TM1)
Nov 02 18:03:06 03v67 kernel: x86/cpu: User Mode Instruction Prevention (UMIP) activated
Nov 02 18:03:06 03v67 kernel: process: using mwait in idle threads
Nov 02 18:03:06 03v67 kernel: CET detected: Indirect Branch Tracking enabled
Nov 02 18:03:06 03v67 kernel: Last level iTLB entries: 4KB 0, 2MB 0, 4MB 0
Nov 02 18:03:06 03v67 kernel: Last level dTLB entries: 4KB 0, 2MB 0, 4MB 0, 1GB 0
Nov 02 18:03:06 03v67 kernel: Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
Nov 02 18:03:06 03v67 kernel: Spectre V2 : Mitigation: Enhanced / Automatic IBRS
Nov 02 18:03:06 03v67 kernel: Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
Nov 02 18:03:06 03v67 kernel: Spectre V2 : Spectre v2 / PBRSB-eIBRS: Retire a single CALL on VMEXIT
Nov 02 18:03:06 03v67 kernel: Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
Nov 02 18:03:06 03v67 kernel: Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
Nov 02 18:03:06 03v67 kernel: GDS: Mitigation: Microcode
Nov 02 18:03:06 03v67 kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
Nov 02 18:03:06 03v67 kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
Nov 02 18:03:06 03v67 kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
Nov 02 18:03:06 03v67 kernel: x86/fpu: Supporting XSAVE feature 0x020: 'AVX-512 opmask'
Nov 02 18:03:06 03v67 kernel: x86/fpu: Supporting XSAVE feature 0x040: 'AVX-512 Hi256'
Nov 02 18:03:06 03v67 kernel: x86/fpu: Supporting XSAVE feature 0x080: 'AVX-512 ZMM_Hi256'
Nov 02 18:03:06 03v67 kernel: x86/fpu: Supporting XSAVE feature 0x200: 'Protection Keys User registers'
Nov 02 18:03:06 03v67 kernel: x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
Nov 02 18:03:06 03v67 kernel: x86/fpu: xstate_offset[5]: 832, xstate_sizes[5]: 64
Nov 02 18:03:06 03v67 kernel: x86/fpu: xstate_offset[6]: 896, xstate_sizes[6]: 512
Nov 02 18:03:06 03v67 kernel: x86/fpu: xstate_offset[7]: 1408, xstate_sizes[7]: 1024
Nov 02 18:03:06 03v67 kernel: x86/fpu: xstate_offset[9]: 2432, xstate_sizes[9]: 8
Nov 02 18:03:06 03v67 kernel: x86/fpu: Enabled xstate features 0x2e7, context size is 2440 bytes, using 'compacted' format.
Nov 02 18:03:06 03v67 kernel: Freeing SMP alternatives memory: 40K
Nov 02 18:03:06 03v67 kernel: pid_max: default: 32768 minimum: 301
Nov 02 18:03:06 03v67 kernel: LSM: initializing lsm=capability,landlock,lockdown,yama,bpf,apparmor,integrity
Nov 02 18:03:06 03v67 kernel: landlock: Up and running.
Nov 02 18:03:06 03v67 kernel: Yama: becoming mindful.
Nov 02 18:03:06 03v67 kernel: LSM support for eBPF active
Nov 02 18:03:06 03v67 kernel: AppArmor: AppArmor initialized
Nov 02 18:03:06 03v67 kernel: Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
Nov 02 18:03:06 03v67 kernel: Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
Nov 02 18:03:06 03v67 kernel: smpboot: CPU0: 11th Gen Intel(R) Core(TM) i5-1135G7 @ 2.40GHz (family: 0x6, model: 0x8c, stepping: 0x1)
Nov 02 18:03:06 03v67 kernel: RCU Tasks: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1.
Nov 02 18:03:06 03v67 kernel: RCU Tasks Rude: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1.
Nov 02 18:03:06 03v67 kernel: RCU Tasks Trace: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1.
Nov 02 18:03:06 03v67 kernel: Performance Events: PEBS fmt4+-baseline, AnyThread deprecated, Icelake events, 32-deep LBR, full-width counters, Intel PMU driver.
Nov 02 18:03:06 03v67 kernel: ... version: 5
Nov 02 18:03:06 03v67 kernel: ... bit width: 48
Nov 02 18:03:06 03v67 kernel: ... generic registers: 8
Nov 02 18:03:06 03v67 kernel: ... value mask: 0000ffffffffffff
Nov 02 18:03:06 03v67 kernel: ... max period: 00007fffffffffff
Nov 02 18:03:06 03v67 kernel: ... fixed-purpose events: 4
Nov 02 18:03:06 03v67 kernel: ... event mask: 0001000f000000ff
Nov 02 18:03:06 03v67 kernel: signal: max sigframe size: 3632
Nov 02 18:03:06 03v67 kernel: Estimated ratio of average max frequency by base frequency (times 1024): 1621
Nov 02 18:03:06 03v67 kernel: rcu: Hierarchical SRCU implementation.
Nov 02 18:03:06 03v67 kernel: rcu: Max phase no-delay instances is 1000.
Nov 02 18:03:06 03v67 kernel: NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
Nov 02 18:03:06 03v67 kernel: smp: Bringing up secondary CPUs ...
Nov 02 18:03:06 03v67 kernel: smpboot: x86: Booting SMP configuration:
Nov 02 18:03:06 03v67 kernel: .... node #0, CPUs: #1 #2 #3 #4 #5 #6 #7
Nov 02 18:03:06 03v67 kernel: smp: Brought up 1 node, 8 CPUs
Nov 02 18:03:06 03v67 kernel: smpboot: Max logical packages: 1
Nov 02 18:03:06 03v67 kernel: smpboot: Total of 8 processors activated (38722.00 BogoMIPS)
Nov 02 18:03:06 03v67 kernel: devtmpfs: initialized
Nov 02 18:03:06 03v67 kernel: x86/mm: Memory block size: 128MB
Nov 02 18:03:06 03v67 kernel: ACPI: PM: Registering ACPI NVS region [mem 0x442ff000-0x44b2efff] (8585216 bytes)
Nov 02 18:03:06 03v67 kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
Nov 02 18:03:06 03v67 kernel: futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
Nov 02 18:03:06 03v67 kernel: pinctrl core: initialized pinctrl subsystem
Nov 02 18:03:06 03v67 kernel: PM: RTC time: 11:03:02, date: 2024-11-02
Nov 02 18:03:06 03v67 kernel: NET: Registered PF_NETLINK/PF_ROUTE protocol family
Nov 02 18:03:06 03v67 kernel: DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
Nov 02 18:03:06 03v67 kernel: DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
Nov 02 18:03:06 03v67 kernel: DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
Nov 02 18:03:06 03v67 kernel: audit: initializing netlink subsys (disabled)
Nov 02 18:03:06 03v67 kernel: audit: type=2000 audit(1730545382.009:1): state=initialized audit_enabled=0 res=1
Nov 02 18:03:06 03v67 kernel: thermal_sys: Registered thermal governor 'fair_share'
Nov 02 18:03:06 03v67 kernel: thermal_sys: Registered thermal governor 'bang_bang'
Nov 02 18:03:06 03v67 kernel: thermal_sys: Registered thermal governor 'step_wise'
Nov 02 18:03:06 03v67 kernel: thermal_sys: Registered thermal governor 'user_space'
Nov 02 18:03:06 03v67 kernel: thermal_sys: Registered thermal governor 'power_allocator'
Nov 02 18:03:06 03v67 kernel: cpuidle: using governor ladder
Nov 02 18:03:06 03v67 kernel: cpuidle: using governor menu
Nov 02 18:03:06 03v67 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
Nov 02 18:03:06 03v67 kernel: PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xc0000000-0xcfffffff] (base 0xc0000000)
Nov 02 18:03:06 03v67 kernel: PCI: not using MMCONFIG
Nov 02 18:03:06 03v67 kernel: PCI: Using configuration type 1 for base access
Nov 02 18:03:06 03v67 kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Nov 02 18:03:06 03v67 kernel: kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
Nov 02 18:03:06 03v67 kernel: HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
Nov 02 18:03:06 03v67 kernel: HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
Nov 02 18:03:06 03v67 kernel: HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
Nov 02 18:03:06 03v67 kernel: HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
Nov 02 18:03:06 03v67 kernel: ACPI: Added _OSI(Module Device)
Nov 02 18:03:06 03v67 kernel: ACPI: Added _OSI(Processor Device)
Nov 02 18:03:06 03v67 kernel: ACPI: Added _OSI(3.0 _SCP Extensions)
Nov 02 18:03:06 03v67 kernel: ACPI: Added _OSI(Processor Aggregator Device)
Nov 02 18:03:06 03v67 kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS01._UPC], AE_ALREADY_EXISTS (20230331/dswload2-326)
Nov 02 18:03:06 03v67 kernel: ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20230331/psobject-220)
Nov 02 18:03:06 03v67 kernel: ACPI: Skipping parse of AML opcode: Method (0x0014)
Nov 02 18:03:06 03v67 kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS01._PLD], AE_ALREADY_EXISTS (20230331/dswload2-326)
Nov 02 18:03:06 03v67 kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS02._UPC], AE_ALREADY_EXISTS (20230331/dswload2-326)
Nov 02 18:03:06 03v67 kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS02._PLD], AE_ALREADY_EXISTS (20230331/dswload2-326)
Nov 02 18:03:06 03v67 kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS03._UPC], AE_ALREADY_EXISTS (20230331/dswload2-326)
Nov 02 18:03:06 03v67 kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS03._PLD], AE_ALREADY_EXISTS (20230331/dswload2-326)
Nov 02 18:03:06 03v67 kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS04._UPC], AE_ALREADY_EXISTS (20230331/dswload2-326)
Nov 02 18:03:06 03v67 kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS04._PLD], AE_ALREADY_EXISTS (20230331/dswload2-326)
Nov 02 18:03:06 03v67 kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS05._UPC], AE_ALREADY_EXISTS (20230331/dswload2-326)
Nov 02 18:03:06 03v67 kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS05._PLD], AE_ALREADY_EXISTS (20230331/dswload2-326)
Nov 02 18:03:06 03v67 kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS06._UPC], AE_ALREADY_EXISTS (20230331/dswload2-326)
Nov 02 18:03:06 03v67 kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS06._PLD], AE_ALREADY_EXISTS (20230331/dswload2-326)
Nov 02 18:03:06 03v67 kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS07._UPC], AE_ALREADY_EXISTS (20230331/dswload2-326)
Nov 02 18:03:06 03v67 kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS07._PLD], AE_ALREADY_EXISTS (20230331/dswload2-326)
Nov 02 18:03:06 03v67 kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS08._UPC], AE_ALREADY_EXISTS (20230331/dswload2-326)
Nov 02 18:03:06 03v67 kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS08._PLD], AE_ALREADY_EXISTS (20230331/dswload2-326)
Nov 02 18:03:06 03v67 kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS09._UPC], AE_ALREADY_EXISTS (20230331/dswload2-326)
Nov 02 18:03:06 03v67 kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS09._PLD], AE_ALREADY_EXISTS (20230331/dswload2-326)
Nov 02 18:03:06 03v67 kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS10._UPC], AE_ALREADY_EXISTS (20230331/dswload2-326)
Nov 02 18:03:06 03v67 kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS10._PLD], AE_ALREADY_EXISTS (20230331/dswload2-326)
Nov 02 18:03:06 03v67 kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.SS01._UPC], AE_ALREADY_EXISTS (20230331/dswload2-326)
Nov 02 18:03:06 03v67 kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.SS01._PLD], AE_ALREADY_EXISTS (20230331/dswload2-326)
Nov 02 18:03:06 03v67 kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.SS02._UPC], AE_ALREADY_EXISTS (20230331/dswload2-326)
Nov 02 18:03:06 03v67 kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.SS02._PLD], AE_ALREADY_EXISTS (20230331/dswload2-326)
Nov 02 18:03:06 03v67 kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.SS03._UPC], AE_ALREADY_EXISTS (20230331/dswload2-326)
Nov 02 18:03:06 03v67 kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.SS03._PLD], AE_ALREADY_EXISTS (20230331/dswload2-326)
Nov 02 18:03:06 03v67 kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.SS04._UPC], AE_ALREADY_EXISTS (20230331/dswload2-326)
Nov 02 18:03:06 03v67 kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.SS04._PLD], AE_ALREADY_EXISTS (20230331/dswload2-326)
Nov 02 18:03:06 03v67 kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.SS05._UPC], AE_ALREADY_EXISTS (20230331/dswload2-326)
Nov 02 18:03:06 03v67 kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.SS05._PLD], AE_ALREADY_EXISTS (20230331/dswload2-326)
Nov 02 18:03:06 03v67 kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.SS06._UPC], AE_ALREADY_EXISTS (20230331/dswload2-326)
Nov 02 18:03:06 03v67 kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.SS06._PLD], AE_ALREADY_EXISTS (20230331/dswload2-326)
Nov 02 18:03:06 03v67 kernel: ACPI: 15 ACPI AML tables successfully acquired and loaded
Nov 02 18:03:06 03v67 kernel: ACPI: Dynamic OEM Table Load:
Nov 02 18:03:06 03v67 kernel: ACPI: SSDT 0xFFFF948101C2DA00 0001C6 (v02 PmRef Cpu0Psd 00003000 INTL 20160422)
Nov 02 18:03:06 03v67 kernel: ACPI: \_SB_.PR00: _OSC native thermal LVT Acked
Nov 02 18:03:06 03v67 kernel: ACPI: SSDT 0xFFFF948100EF7000 000386 (v02 PmRef Cpu0Cst 00003001 INTL 20160422)
Nov 02 18:03:06 03v67 kernel: ACPI: SSDT 0xFFFF948100EEB800 0005C3 (v02 PmRef Cpu0Ist 00003000 INTL 20160422)
Nov 02 18:03:06 03v67 kernel: ACPI: SSDT 0xFFFF948100EF6800 00028B (v02 PmRef Cpu0Hwp 00003000 INTL 20160422)
Nov 02 18:03:06 03v67 kernel: ACPI: SSDT 0xFFFF948100EE2000 0008E7 (v02 PmRef ApIst 00003000 INTL 20160422)
Nov 02 18:03:06 03v67 kernel: ACPI: SSDT 0xFFFF948100EEC800 00048A (v02 PmRef ApHwp 00003000 INTL 20160422)
Nov 02 18:03:06 03v67 kernel: ACPI: SSDT 0xFFFF948100EEF000 0004D4 (v02 PmRef ApPsd 00003000 INTL 20160422)
Nov 02 18:03:06 03v67 kernel: ACPI: SSDT 0xFFFF948100EEB000 00048A (v02 PmRef ApCst 00003000 INTL 20160422)
Nov 02 18:03:06 03v67 kernel: ACPI: EC: EC started
Nov 02 18:03:06 03v67 kernel: ACPI: EC: interrupt blocked
Nov 02 18:03:06 03v67 kernel: ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
Nov 02 18:03:06 03v67 kernel: ACPI: \_SB_.PC00.LPCB.EC0_: Boot DSDT EC used to handle transactions
Nov 02 18:03:06 03v67 kernel: ACPI: Interpreter enabled
Nov 02 18:03:06 03v67 kernel: ACPI: PM: (supports S0 S3 S4 S5)
Nov 02 18:03:06 03v67 kernel: ACPI: Using IOAPIC for interrupt routing
Nov 02 18:03:06 03v67 kernel: PCI: MMCONFIG at [mem 0xc0000000-0xcfffffff] reserved as ACPI motherboard resource
Nov 02 18:03:06 03v67 kernel: PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
Nov 02 18:03:06 03v67 kernel: PCI: Using E820 reservations for host bridge windows
Nov 02 18:03:06 03v67 kernel: ACPI: Enabled 7 GPEs in block 00 to 7F
Nov 02 18:03:06 03v67 kernel: ACPI: \_SB_.PC00.PEG0.PCRP: New power resource
Nov 02 18:03:06 03v67 kernel: ACPI: \_SB_.PC00.SAT0.VOL0.V0PR: New power resource
Nov 02 18:03:06 03v67 kernel: ACPI: \_SB_.PC00.SAT0.VOL1.V1PR: New power resource
Nov 02 18:03:06 03v67 kernel: ACPI: \_SB_.PC00.SAT0.VOL2.V2PR: New power resource
Nov 02 18:03:06 03v67 kernel: ACPI: \_SB_.PC00.CNVW.WRST: New power resource
Nov 02 18:03:06 03v67 kernel: ACPI: \_SB_.PC00.VMD0.VOL0.V0PR: New power resource
Nov 02 18:03:06 03v67 kernel: ACPI: \_SB_.PC00.VMD0.VOL1.V1PR: New power resource
Nov 02 18:03:06 03v67 kernel: ACPI: \_SB_.PC00.VMD0.VOL2.V2PR: New power resource
Nov 02 18:03:06 03v67 kernel: ACPI: \_SB_.PC00.VMD0.VOL3.V3PR: New power resource
Nov 02 18:03:06 03v67 kernel: ACPI: \_TZ_.FN00: New power resource
Nov 02 18:03:06 03v67 kernel: ACPI: \_TZ_.FN01: New power resource
Nov 02 18:03:06 03v67 kernel: ACPI: \_TZ_.FN02: New power resource
Nov 02 18:03:06 03v67 kernel: ACPI: \_TZ_.FN03: New power resource
Nov 02 18:03:06 03v67 kernel: ACPI: \_TZ_.FN04: New power resource
Nov 02 18:03:06 03v67 kernel: ACPI: \PIN_: New power resource
Nov 02 18:03:06 03v67 kernel: ACPI: PCI Root Bridge [PC00] (domain 0000 [bus 00-e0])
Nov 02 18:03:06 03v67 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
Nov 02 18:03:06 03v67 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR DPC]
Nov 02 18:03:06 03v67 kernel: PCI host bridge to bus 0000:00
Nov 02 18:03:06 03v67 kernel: pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
Nov 02 18:03:06 03v67 kernel: pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
Nov 02 18:03:06 03v67 kernel: pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
Nov 02 18:03:06 03v67 kernel: pci_bus 0000:00: root bus resource [mem 0x4f800000-0xbfffffff window]
Nov 02 18:03:06 03v67 kernel: pci_bus 0000:00: root bus resource [mem 0x4000000000-0x7fffffffff window]
Nov 02 18:03:06 03v67 kernel: pci_bus 0000:00: root bus resource [bus 00-e0]
Nov 02 18:03:06 03v67 kernel: pci 0000:00:00.0: [8086:9a14] type 00 class 0x060000
Nov 02 18:03:06 03v67 kernel: pci 0000:00:02.0: [8086:9a49] type 00 class 0x030000
Nov 02 18:03:06 03v67 kernel: pci 0000:00:02.0: reg 0x10: [mem 0x6014000000-0x6014ffffff 64bit]
Nov 02 18:03:06 03v67 kernel: pci 0000:00:02.0: reg 0x18: [mem 0x4000000000-0x400fffffff 64bit pref]
Nov 02 18:03:06 03v67 kernel: pci 0000:00:02.0: reg 0x20: [io 0x5000-0x503f]
Nov 02 18:03:06 03v67 kernel: pci 0000:00:02.0: BAR 2: assigned to efifb
Nov 02 18:03:06 03v67 kernel: pci 0000:00:02.0: DMAR: Skip IOMMU disabling for graphics
Nov 02 18:03:06 03v67 kernel: pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
Nov 02 18:03:06 03v67 kernel: pci 0000:00:02.0: reg 0x344: [mem 0x00000000-0x00ffffff 64bit]
Nov 02 18:03:06 03v67 kernel: pci 0000:00:02.0: VF(n) BAR0 space: [mem 0x00000000-0x06ffffff 64bit] (contains BAR0 for 7 VFs)
Nov 02 18:03:06 03v67 kernel: pci 0000:00:02.0: reg 0x34c: [mem 0x00000000-0x1fffffff 64bit pref]
Nov 02 18:03:06 03v67 kernel: pci 0000:00:02.0: VF(n) BAR2 space: [mem 0x00000000-0xdfffffff 64bit pref] (contains BAR2 for 7 VFs)
Nov 02 18:03:06 03v67 kernel: pci 0000:00:06.0: [8086:9a09] type 01 class 0x060400
Nov 02 18:03:06 03v67 kernel: pci 0000:00:06.0: PME# supported from D0 D3hot D3cold
Nov 02 18:03:06 03v67 kernel: pci 0000:00:06.0: PTM enabled (root), 4ns granularity
Nov 02 18:03:06 03v67 kernel: pci 0000:00:08.0: [8086:9a11] type 00 class 0x088000
Nov 02 18:03:06 03v67 kernel: pci 0000:00:08.0: reg 0x10: [mem 0x601540f000-0x601540ffff 64bit]
Nov 02 18:03:06 03v67 kernel: pci 0000:00:0e.0: [8086:9a0b] type 00 class 0x010400
Nov 02 18:03:06 03v67 kernel: pci 0000:00:0e.0: reg 0x10: [mem 0x6012000000-0x6013ffffff 64bit]
Nov 02 18:03:06 03v67 kernel: pci 0000:00:0e.0: reg 0x18: [mem 0x50000000-0x51ffffff]
Nov 02 18:03:06 03v67 kernel: pci 0000:00:0e.0: reg 0x20: [mem 0x6015300000-0x60153fffff 64bit]
Nov 02 18:03:06 03v67 kernel: pci 0000:00:14.0: [8086:a0ed] type 00 class 0x0c0330
Nov 02 18:03:06 03v67 kernel: pci 0000:00:14.0: reg 0x10: [mem 0x53180000-0x5318ffff 64bit]
Nov 02 18:03:06 03v67 kernel: pci 0000:00:14.0: PME# supported from D3hot D3cold
Nov 02 18:03:06 03v67 kernel: pci 0000:00:14.2: [8086:a0ef] type 00 class 0x050000
Nov 02 18:03:06 03v67 kernel: pci 0000:00:14.2: reg 0x10: [mem 0x6015404000-0x6015407fff 64bit]
Nov 02 18:03:06 03v67 kernel: pci 0000:00:14.2: reg 0x18: [mem 0x601540e000-0x601540efff 64bit]
Nov 02 18:03:06 03v67 kernel: pci 0000:00:15.0: [8086:a0e8] type 00 class 0x0c8000
Nov 02 18:03:06 03v67 kernel: pci 0000:00:15.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
Nov 02 18:03:06 03v67 kernel: pci 0000:00:15.3: [8086:a0eb] type 00 class 0x0c8000
Nov 02 18:03:06 03v67 kernel: pci 0000:00:15.3: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
Nov 02 18:03:06 03v67 kernel: pci 0000:00:16.0: [8086:a0e0] type 00 class 0x078000
Nov 02 18:03:06 03v67 kernel: pci 0000:00:16.0: reg 0x10: [mem 0x601540b000-0x601540bfff 64bit]
Nov 02 18:03:06 03v67 kernel: pci 0000:00:16.0: PME# supported from D3hot
Nov 02 18:03:06 03v67 kernel: pci 0000:00:17.0: [8086:09ab] type 00 class 0x088000
Nov 02 18:03:06 03v67 kernel: pci 0000:00:19.0: [8086:a0c5] type 00 class 0x0c8000
Nov 02 18:03:06 03v67 kernel: pci 0000:00:19.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
Nov 02 18:03:06 03v67 kernel: pci 0000:00:19.1: [8086:a0c6] type 00 class 0x0c8000
Nov 02 18:03:06 03v67 kernel: pci 0000:00:19.1: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
Nov 02 18:03:06 03v67 kernel: pci 0000:00:1d.0: [8086:a0b0] type 01 class 0x060400
Nov 02 18:03:06 03v67 kernel: pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
Nov 02 18:03:06 03v67 kernel: pci 0000:00:1d.0: PTM enabled (root), 4ns granularity
Nov 02 18:03:06 03v67 kernel: pci 0000:00:1d.1: [8086:a0b1] type 01 class 0x060400
Nov 02 18:03:06 03v67 kernel: pci 0000:00:1d.1: PME# supported from D0 D3hot D3cold
Nov 02 18:03:06 03v67 kernel: pci 0000:00:1d.1: PTM enabled (root), 4ns granularity
Nov 02 18:03:06 03v67 kernel: pci 0000:00:1f.0: [8086:a082] type 00 class 0x060100
Nov 02 18:03:06 03v67 kernel: pci 0000:00:1f.3: [8086:a0c8] type 00 class 0x040100
Nov 02 18:03:06 03v67 kernel: pci 0000:00:1f.3: reg 0x10: [mem 0x6015400000-0x6015403fff 64bit]
Nov 02 18:03:06 03v67 kernel: pci 0000:00:1f.3: reg 0x20: [mem 0x6015200000-0x60152fffff 64bit]
Nov 02 18:03:06 03v67 kernel: pci 0000:00:1f.3: PME# supported from D3hot D3cold
Nov 02 18:03:06 03v67 kernel: pci 0000:00:1f.4: [8086:a0a3] type 00 class 0x0c0500
Nov 02 18:03:06 03v67 kernel: pci 0000:00:1f.4: reg 0x10: [mem 0x6015408000-0x60154080ff 64bit]
Nov 02 18:03:06 03v67 kernel: pci 0000:00:1f.4: reg 0x20: [io 0xefa0-0xefbf]
Nov 02 18:03:06 03v67 kernel: pci 0000:00:1f.5: [8086:a0a4] type 00 class 0x0c8000
Nov 02 18:03:06 03v67 kernel: pci 0000:00:1f.5: reg 0x10: [mem 0xfe010000-0xfe010fff]
Nov 02 18:03:06 03v67 kernel: pci 0000:01:00.0: [10de:1c94] type 00 class 0x030200
Nov 02 18:03:06 03v67 kernel: pci 0000:01:00.0: reg 0x10: [mem 0x52000000-0x52ffffff]
Nov 02 18:03:06 03v67 kernel: pci 0000:01:00.0: reg 0x14: [mem 0x6000000000-0x600fffffff 64bit pref]
Nov 02 18:03:06 03v67 kernel: pci 0000:01:00.0: reg 0x1c: [mem 0x6010000000-0x6011ffffff 64bit pref]
Nov 02 18:03:06 03v67 kernel: pci 0000:01:00.0: reg 0x24: [io 0x4000-0x407f]
Nov 02 18:03:06 03v67 kernel: pci 0000:01:00.0: reg 0x30: [mem 0xfff80000-0xffffffff pref]
Nov 02 18:03:06 03v67 kernel: pci 0000:01:00.0: Enabling HDA controller
Nov 02 18:03:06 03v67 kernel: pci 0000:01:00.0: 31.504 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x4 link at 0000:00:06.0 (capable of 126.016 Gb/s with 8.0 GT/s PCIe x16 link)
Nov 02 18:03:06 03v67 kernel: pci 0000:00:06.0: PCI bridge to [bus 01]
Nov 02 18:03:06 03v67 kernel: pci 0000:00:06.0: bridge window [io 0x4000-0x4fff]
Nov 02 18:03:06 03v67 kernel: pci 0000:00:06.0: bridge window [mem 0x52000000-0x52ffffff]
Nov 02 18:03:06 03v67 kernel: pci 0000:00:06.0: bridge window [mem 0x6000000000-0x6011ffffff 64bit pref]
Nov 02 18:03:06 03v67 kernel: pci 0000:02:00.0: [10ec:8168] type 00 class 0x020000
Nov 02 18:03:06 03v67 kernel: pci 0000:02:00.0: reg 0x10: [io 0x3000-0x30ff]
Nov 02 18:03:06 03v67 kernel: pci 0000:02:00.0: reg 0x18: [mem 0x53004000-0x53004fff 64bit]
Nov 02 18:03:06 03v67 kernel: pci 0000:02:00.0: reg 0x20: [mem 0x53000000-0x53003fff 64bit]
Nov 02 18:03:06 03v67 kernel: pci 0000:02:00.0: supports D1 D2
Nov 02 18:03:06 03v67 kernel: pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
Nov 02 18:03:06 03v67 kernel: pci 0000:00:1d.0: PCI bridge to [bus 02]
Nov 02 18:03:06 03v67 kernel: pci 0000:00:1d.0: bridge window [io 0x3000-0x3fff]
Nov 02 18:03:06 03v67 kernel: pci 0000:00:1d.0: bridge window [mem 0x53000000-0x530fffff]
Nov 02 18:03:06 03v67 kernel: pci 0000:03:00.0: [14c3:7961] type 00 class 0x028000
Nov 02 18:03:06 03v67 kernel: pci 0000:03:00.0: reg 0x10: [mem 0x6015000000-0x60150fffff 64bit pref]
Nov 02 18:03:06 03v67 kernel: pci 0000:03:00.0: reg 0x18: [mem 0x6015100000-0x6015103fff 64bit pref]
Nov 02 18:03:06 03v67 kernel: pci 0000:03:00.0: reg 0x20: [mem 0x6015104000-0x6015104fff 64bit pref]
Nov 02 18:03:06 03v67 kernel: pci 0000:03:00.0: supports D1 D2
Nov 02 18:03:06 03v67 kernel: pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
Nov 02 18:03:06 03v67 kernel: pci 0000:00:1d.1: PCI bridge to [bus 03]
Nov 02 18:03:06 03v67 kernel: pci 0000:00:1d.1: bridge window [mem 0x6015000000-0x60151fffff 64bit pref]
Nov 02 18:03:06 03v67 kernel: Low-power S0 idle used by default for system suspend
Nov 02 18:03:06 03v67 kernel: ACPI: EC: interrupt unblocked
Nov 02 18:03:06 03v67 kernel: ACPI: EC: event unblocked
Nov 02 18:03:06 03v67 kernel: ACPI: EC: GPE=0x6e
Nov 02 18:03:06 03v67 kernel: ACPI: \_SB_.PC00.LPCB.EC0_: Boot DSDT EC initialization complete
Nov 02 18:03:06 03v67 kernel: ACPI: \_SB_.PC00.LPCB.EC0_: EC: Used to handle transactions and events
Nov 02 18:03:06 03v67 kernel: iommu: Default domain type: Translated
Nov 02 18:03:06 03v67 kernel: iommu: DMA domain TLB invalidation policy: lazy mode
Nov 02 18:03:06 03v67 kernel: SCSI subsystem initialized
Nov 02 18:03:06 03v67 kernel: libata version 3.00 loaded.
Nov 02 18:03:06 03v67 kernel: ACPI: bus type USB registered
Nov 02 18:03:06 03v67 kernel: usbcore: registered new interface driver usbfs
Nov 02 18:03:06 03v67 kernel: usbcore: registered new interface driver hub
Nov 02 18:03:06 03v67 kernel: usbcore: registered new device driver usb
Nov 02 18:03:06 03v67 kernel: pps_core: LinuxPPS API ver. 1 registered
Nov 02 18:03:06 03v67 kernel: pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
Nov 02 18:03:06 03v67 kernel: PTP clock support registered
Nov 02 18:03:06 03v67 kernel: EDAC MC: Ver: 3.0.0
Nov 02 18:03:06 03v67 kernel: efivars: Registered efivars operations
Nov 02 18:03:06 03v67 kernel: NetLabel: Initializing
Nov 02 18:03:06 03v67 kernel: NetLabel: domain hash size = 128
Nov 02 18:03:06 03v67 kernel: NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
Nov 02 18:03:06 03v67 kernel: NetLabel: unlabeled traffic allowed by default
Nov 02 18:03:06 03v67 kernel: mctp: management component transport protocol core
Nov 02 18:03:06 03v67 kernel: NET: Registered PF_MCTP protocol family
Nov 02 18:03:06 03v67 kernel: PCI: Using ACPI for IRQ routing
Nov 02 18:03:06 03v67 kernel: PCI: pci_cache_line_size set to 64 bytes
Nov 02 18:03:06 03v67 kernel: pci 0000:00:1f.5: can't claim BAR 0 [mem 0xfe010000-0xfe010fff]: no compatible bridge window
Nov 02 18:03:06 03v67 kernel: e820: reserve RAM buffer [mem 0x0009f000-0x0009ffff]
Nov 02 18:03:06 03v67 kernel: e820: reserve RAM buffer [mem 0x37e3d018-0x37ffffff]
Nov 02 18:03:06 03v67 kernel: e820: reserve RAM buffer [mem 0x3a931000-0x3bffffff]
Nov 02 18:03:06 03v67 kernel: e820: reserve RAM buffer [mem 0x3bf60000-0x3bffffff]
Nov 02 18:03:06 03v67 kernel: e820: reserve RAM buffer [mem 0x3fd99000-0x3fffffff]
Nov 02 18:03:06 03v67 kernel: e820: reserve RAM buffer [mem 0x424af000-0x43ffffff]
Nov 02 18:03:06 03v67 kernel: e820: reserve RAM buffer [mem 0x44c00000-0x47ffffff]
Nov 02 18:03:06 03v67 kernel: e820: reserve RAM buffer [mem 0x6b0800000-0x6b3ffffff]
Nov 02 18:03:06 03v67 kernel: pci 0000:00:02.0: vgaarb: setting as boot VGA device
Nov 02 18:03:06 03v67 kernel: pci 0000:00:02.0: vgaarb: bridge control possible
Nov 02 18:03:06 03v67 kernel: pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
Nov 02 18:03:06 03v67 kernel: vgaarb: loaded
Nov 02 18:03:06 03v67 kernel: clocksource: Switched to clocksource tsc-early
Nov 02 18:03:06 03v67 kernel: VFS: Disk quotas dquot_6.6.0
Nov 02 18:03:06 03v67 kernel: VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
Nov 02 18:03:06 03v67 kernel: AppArmor: AppArmor Filesystem Enabled
Nov 02 18:03:06 03v67 kernel: pnp: PnP ACPI init
Nov 02 18:03:06 03v67 kernel: system 00:00: [io 0x0680-0x069f] has been reserved
Nov 02 18:03:06 03v67 kernel: system 00:00: [io 0x164e-0x164f] has been reserved
Nov 02 18:03:06 03v67 kernel: system 00:00: [io 0xfd60-0xfd63] has been reserved
Nov 02 18:03:06 03v67 kernel: system 00:02: [io 0x1854-0x1857] has been reserved
Nov 02 18:03:06 03v67 kernel: pnp 00:04: disabling [mem 0xc0000000-0xcfffffff] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
Nov 02 18:03:06 03v67 kernel: system 00:04: [mem 0xfedc0000-0xfedc7fff] has been reserved
Nov 02 18:03:06 03v67 kernel: system 00:04: [mem 0xfeda0000-0xfeda0fff] has been reserved
Nov 02 18:03:06 03v67 kernel: system 00:04: [mem 0xfeda1000-0xfeda1fff] has been reserved
Nov 02 18:03:06 03v67 kernel: system 00:04: [mem 0xfed20000-0xfed7ffff] could not be reserved
Nov 02 18:03:06 03v67 kernel: system 00:04: [mem 0xfed90000-0xfed93fff] could not be reserved
Nov 02 18:03:06 03v67 kernel: system 00:04: [mem 0xfed45000-0xfed8ffff] could not be reserved
Nov 02 18:03:06 03v67 kernel: system 00:04: [mem 0xfee00000-0xfeefffff] has been reserved
Nov 02 18:03:06 03v67 kernel: system 00:05: [io 0x1800-0x18fe] could not be reserved
Nov 02 18:03:06 03v67 kernel: system 00:05: [mem 0xfe000000-0xfe01ffff] could not be reserved
Nov 02 18:03:06 03v67 kernel: system 00:05: [mem 0xfe04c000-0xfe04ffff] has been reserved
Nov 02 18:03:06 03v67 kernel: system 00:05: [mem 0xfe050000-0xfe0affff] has been reserved
Nov 02 18:03:06 03v67 kernel: system 00:05: [mem 0xfe0d0000-0xfe0fffff] has been reserved
Nov 02 18:03:06 03v67 kernel: system 00:05: [mem 0xfe200000-0xfe7fffff] has been reserved
Nov 02 18:03:06 03v67 kernel: system 00:05: [mem 0xff000000-0xffffffff] has been reserved
Nov 02 18:03:06 03v67 kernel: system 00:05: [mem 0xfd000000-0xfd68ffff] has been reserved
Nov 02 18:03:06 03v67 kernel: system 00:05: [mem 0xfd6b0000-0xfd6cffff] has been reserved
Nov 02 18:03:06 03v67 kernel: system 00:05: [mem 0xfd6f0000-0xfdffffff] has been reserved
Nov 02 18:03:06 03v67 kernel: system 00:06: [io 0x2000-0x20fe] has been reserved
Nov 02 18:03:06 03v67 kernel: pnp: PnP ACPI: found 8 devices
Nov 02 18:03:06 03v67 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
Nov 02 18:03:06 03v67 kernel: NET: Registered PF_INET protocol family
Nov 02 18:03:06 03v67 kernel: IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
Nov 02 18:03:06 03v67 kernel: tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
Nov 02 18:03:06 03v67 kernel: Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
Nov 02 18:03:06 03v67 kernel: TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
Nov 02 18:03:06 03v67 kernel: TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
Nov 02 18:03:06 03v67 kernel: TCP: Hash tables configured (established 262144 bind 65536)
Nov 02 18:03:06 03v67 kernel: MPTCP token hash table entries: 32768 (order: 7, 786432 bytes, linear)
Nov 02 18:03:06 03v67 kernel: UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
Nov 02 18:03:06 03v67 kernel: UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
Nov 02 18:03:06 03v67 kernel: NET: Registered PF_UNIX/PF_LOCAL protocol family
Nov 02 18:03:06 03v67 kernel: NET: Registered PF_XDP protocol family
Nov 02 18:03:06 03v67 kernel: pci 0000:01:00.0: can't claim BAR 6 [mem 0xfff80000-0xffffffff pref]: no compatible bridge window
Nov 02 18:03:06 03v67 kernel: pci 0000:00:02.0: BAR 9: assigned [mem 0x4020000000-0x40ffffffff 64bit pref]
Nov 02 18:03:06 03v67 kernel: pci 0000:00:02.0: BAR 7: assigned [mem 0x4010000000-0x4016ffffff 64bit]
Nov 02 18:03:06 03v67 kernel: pci 0000:00:15.0: BAR 0: assigned [mem 0x4017000000-0x4017000fff 64bit]
Nov 02 18:03:06 03v67 kernel: pci 0000:00:15.3: BAR 0: assigned [mem 0x4017001000-0x4017001fff 64bit]
Nov 02 18:03:06 03v67 kernel: pci 0000:00:19.0: BAR 0: assigned [mem 0x4017002000-0x4017002fff 64bit]
Nov 02 18:03:06 03v67 kernel: pci 0000:00:19.1: BAR 0: assigned [mem 0x4017003000-0x4017003fff 64bit]
Nov 02 18:03:06 03v67 kernel: resource: avoiding allocation from e820 entry [mem 0x0009f000-0x000fffff]
Nov 02 18:03:06 03v67 kernel: pci 0000:00:1f.5: BAR 0: assigned [mem 0x4f800000-0x4f800fff]
Nov 02 18:03:06 03v67 kernel: pci 0000:01:00.0: BAR 6: no space for [mem size 0x00080000 pref]
Nov 02 18:03:06 03v67 kernel: pci 0000:01:00.0: BAR 6: failed to assign [mem size 0x00080000 pref]
Nov 02 18:03:06 03v67 kernel: pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
Nov 02 18:03:06 03v67 kernel: pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
Nov 02 18:03:06 03v67 kernel: pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
Nov 02 18:03:06 03v67 kernel: pci_bus 0000:00: resource 7 [mem 0x4f800000-0xbfffffff window]
Nov 02 18:03:06 03v67 kernel: pci_bus 0000:00: resource 8 [mem 0x4000000000-0x7fffffffff window]
Nov 02 18:03:06 03v67 kernel: pci_bus 0000:01: resource 0 [io 0x4000-0x4fff]
Nov 02 18:03:06 03v67 kernel: pci_bus 0000:01: resource 1 [mem 0x52000000-0x52ffffff]
Nov 02 18:03:06 03v67 kernel: pci_bus 0000:01: resource 2 [mem 0x6000000000-0x6011ffffff 64bit pref]
Nov 02 18:03:06 03v67 kernel: pci_bus 0000:02: resource 0 [io 0x3000-0x3fff]
Nov 02 18:03:06 03v67 kernel: pci_bus 0000:02: resource 1 [mem 0x53000000-0x530fffff]
Nov 02 18:03:06 03v67 kernel: pci_bus 0000:03: resource 2 [mem 0x6015000000-0x60151fffff 64bit pref]
Nov 02 18:03:06 03v67 kernel: PCI: CLS 64 bytes, default 64
Nov 02 18:03:06 03v67 kernel: PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
Nov 02 18:03:06 03v67 kernel: software IO TLB: mapped [mem 0x0000000033e3d000-0x0000000037e3d000] (64MB)
Nov 02 18:03:06 03v67 kernel: Trying to unpack rootfs image as initramfs...
Nov 02 18:03:06 03v67 kernel: clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x22df1149949, max_idle_ns: 440795312789 ns
Nov 02 18:03:06 03v67 kernel: Initialise system trusted keyrings
Nov 02 18:03:06 03v67 kernel: Key type blacklist registered
Nov 02 18:03:06 03v67 kernel: workingset: timestamp_bits=41 max_order=23 bucket_order=0
Nov 02 18:03:06 03v67 kernel: zbud: loaded
Nov 02 18:03:06 03v67 kernel: integrity: Platform Keyring initialized
Nov 02 18:03:06 03v67 kernel: integrity: Machine keyring initialized
Nov 02 18:03:06 03v67 kernel: Key type asymmetric registered
Nov 02 18:03:06 03v67 kernel: Asymmetric key parser 'x509' registered
Nov 02 18:03:06 03v67 kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
Nov 02 18:03:06 03v67 kernel: io scheduler mq-deadline registered
Nov 02 18:03:06 03v67 kernel: io scheduler kyber registered
Nov 02 18:03:06 03v67 kernel: io scheduler bfq registered
Nov 02 18:03:06 03v67 kernel: pcieport 0000:00:06.0: PME: Signaling with IRQ 122
Nov 02 18:03:06 03v67 kernel: pcieport 0000:00:06.0: AER: enabled with IRQ 122
Nov 02 18:03:06 03v67 kernel: pcieport 0000:00:06.0: DPC: enabled with IRQ 122
Nov 02 18:03:06 03v67 kernel: pcieport 0000:00:06.0: DPC: error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
Nov 02 18:03:06 03v67 kernel: pcieport 0000:00:1d.0: PME: Signaling with IRQ 123
Nov 02 18:03:06 03v67 kernel: pcieport 0000:00:1d.0: AER: enabled with IRQ 123
Nov 02 18:03:06 03v67 kernel: pcieport 0000:00:1d.0: DPC: enabled with IRQ 123
Nov 02 18:03:06 03v67 kernel: pcieport 0000:00:1d.0: DPC: error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
Nov 02 18:03:06 03v67 kernel: pcieport 0000:00:1d.1: PME: Signaling with IRQ 124
Nov 02 18:03:06 03v67 kernel: pcieport 0000:00:1d.1: AER: enabled with IRQ 124
Nov 02 18:03:06 03v67 kernel: pcieport 0000:00:1d.1: DPC: enabled with IRQ 124
Nov 02 18:03:06 03v67 kernel: pcieport 0000:00:1d.1: DPC: error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
Nov 02 18:03:06 03v67 kernel: shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
Nov 02 18:03:06 03v67 kernel: Monitor-Mwait will be used to enter C-1 state
Nov 02 18:03:06 03v67 kernel: Monitor-Mwait will be used to enter C-2 state
Nov 02 18:03:06 03v67 kernel: Monitor-Mwait will be used to enter C-3 state
Nov 02 18:03:06 03v67 kernel: ACPI: \_SB_.PR00: Found 3 idle states
Nov 02 18:03:06 03v67 kernel: ACPI: AC: AC Adapter [ACAD] (on-line)
Nov 02 18:03:06 03v67 kernel: input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:19/PNP0C0D:00/input/input0
Nov 02 18:03:06 03v67 kernel: ACPI: button: Lid Switch [LID0]
Nov 02 18:03:06 03v67 kernel: input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1
Nov 02 18:03:06 03v67 kernel: ACPI: button: Sleep Button [SLPB]
Nov 02 18:03:06 03v67 kernel: input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2
Nov 02 18:03:06 03v67 kernel: ACPI: button: Power Button [PWRB]
Nov 02 18:03:06 03v67 kernel: thermal LNXTHERM:00: registered as thermal_zone0
Nov 02 18:03:06 03v67 kernel: ACPI: thermal: Thermal Zone [TZ00] (28 C)
Nov 02 18:03:06 03v67 kernel: Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
Nov 02 18:03:06 03v67 kernel: ACPI: battery: Slot [BAT1] (battery present)
Nov 02 18:03:06 03v67 kernel: hpet_acpi_add: no address or irqs in _CRS
Nov 02 18:03:06 03v67 kernel: Non-volatile memory driver v1.3
Nov 02 18:03:06 03v67 kernel: Linux agpgart interface v0.103
Nov 02 18:03:06 03v67 kernel: tpm tpm0: tpm_read_log_acpi: Failed to map ACPI memory
Nov 02 18:03:06 03v67 kernel: AMD-Vi: AMD IOMMUv2 functionality not available on this system - This is not a bug.
Nov 02 18:03:06 03v67 kernel: ACPI: bus type drm_connector registered
Nov 02 18:03:06 03v67 kernel: [drm] Initialized simpledrm 1.0.0 20200625 for simple-framebuffer.0 on minor 0
Nov 02 18:03:06 03v67 kernel: fbcon: Deferring console take-over
Nov 02 18:03:06 03v67 kernel: simple-framebuffer simple-framebuffer.0: [drm] fb0: simpledrmdrmfb frame buffer device
Nov 02 18:03:06 03v67 kernel: usbcore: registered new interface driver usbserial_generic
Nov 02 18:03:06 03v67 kernel: usbserial: USB Serial support registered for generic
Nov 02 18:03:06 03v67 kernel: rtc_cmos 00:01: RTC can wake from S4
Nov 02 18:03:06 03v67 kernel: rtc_cmos 00:01: registered as rtc0
Nov 02 18:03:06 03v67 kernel: rtc_cmos 00:01: setting system clock to 2024-11-02T11:03:02 UTC (1730545382)
Nov 02 18:03:06 03v67 kernel: rtc_cmos 00:01: alarms up to one month, y3k, 242 bytes nvram
Nov 02 18:03:06 03v67 kernel: intel_pstate: Intel P-state driver initializing
Nov 02 18:03:06 03v67 kernel: intel_pstate: HWP enabled
Nov 02 18:03:06 03v67 kernel: ledtrig-cpu: registered to indicate activity on CPUs
Nov 02 18:03:06 03v67 kernel: hid: raw HID events driver (C) Jiri Kosina
Nov 02 18:03:06 03v67 kernel: intel_pmc_core INT33A1:00: initialized
Nov 02 18:03:06 03v67 kernel: drop_monitor: Initializing network drop monitor service
Nov 02 18:03:06 03v67 kernel: Initializing XFRM netlink socket
Nov 02 18:03:06 03v67 kernel: NET: Registered PF_INET6 protocol family
Nov 02 18:03:06 03v67 kernel: Freeing initrd memory: 29632K
Nov 02 18:03:06 03v67 kernel: Segment Routing with IPv6
Nov 02 18:03:06 03v67 kernel: RPL Segment Routing with IPv6
Nov 02 18:03:06 03v67 kernel: In-situ OAM (IOAM) with IPv6
Nov 02 18:03:06 03v67 kernel: NET: Registered PF_PACKET protocol family
Nov 02 18:03:06 03v67 kernel: microcode: Microcode Update Driver: v2.2.
Nov 02 18:03:06 03v67 kernel: resctrl: L2 allocation detected
Nov 02 18:03:06 03v67 kernel: IPI shorthand broadcast: enabled
Nov 02 18:03:06 03v67 kernel: sched_clock: Marking stable (356798476, 6619575)->(389242877, -25824826)
Nov 02 18:03:06 03v67 kernel: registered taskstats version 1
Nov 02 18:03:06 03v67 kernel: Loading compiled-in X.509 certificates
Nov 02 18:03:06 03v67 kernel: Loaded X.509 cert 'Build time autogenerated kernel key: 9521b6295932e2fe6379b30a95ae33b21553aa15'
Nov 02 18:03:06 03v67 kernel: zswap: loaded using pool zstd/zsmalloc
Nov 02 18:03:06 03v67 kernel: Key type .fscrypt registered
Nov 02 18:03:06 03v67 kernel: Key type fscrypt-provisioning registered
Nov 02 18:03:06 03v67 kernel: AppArmor: AppArmor sha1 policy hashing enabled
Nov 02 18:03:06 03v67 kernel: integrity: Loading X.509 certificate: UEFI:db
Nov 02 18:03:06 03v67 kernel: integrity: Loaded X.509 cert 'Acer Database: 84f00f5841571abd2cc11a8c26d5c9c8d2b6b0b5'
Nov 02 18:03:06 03v67 kernel: integrity: Loaded X.509 cert 'Microsoft Windows Production PCA 2011: a92902398e16c49778cd90f99e4f9ae17c55af53'
Nov 02 18:03:06 03v67 kernel: integrity: Loaded X.509 cert 'Microsoft Corporation UEFI CA 2011: 13adbf4309bd82709c8cd54f316ed522988a1bd4'
Nov 02 18:03:06 03v67 kernel: integrity: Problem loading X.509 certificate -65
Nov 02 18:03:06 03v67 kernel: integrity: Error adding keys to platform keyring UEFI:db
Nov 02 18:03:06 03v67 kernel: integrity: Loaded X.509 cert 'Linpus: linpus.com: 2e092cab5e97a89f94a6e272ec7267c267cf4483'
Nov 02 18:03:06 03v67 kernel: PM: Magic number: 0:858:73
Nov 02 18:03:06 03v67 kernel: RAS: Correctable Errors collector initialized.
Nov 02 18:03:06 03v67 kernel: clk: Disabling unused clocks
Nov 02 18:03:06 03v67 kernel: Freeing unused decrypted memory: 2036K
Nov 02 18:03:06 03v67 kernel: Freeing unused kernel image (initmem) memory: 3400K
Nov 02 18:03:06 03v67 kernel: Write protecting the kernel read-only data: 30720k
Nov 02 18:03:06 03v67 kernel: Freeing unused kernel image (rodata/data gap) memory: 1292K
Nov 02 18:03:06 03v67 kernel: x86/mm: Checked W+X mappings: passed, no W+X pages found.
Nov 02 18:03:06 03v67 kernel: rodata_test: all tests were successful
Nov 02 18:03:06 03v67 kernel: Run /init as init process
Nov 02 18:03:06 03v67 kernel: with arguments:
Nov 02 18:03:06 03v67 kernel: /init
Nov 02 18:03:06 03v67 kernel: splash
Nov 02 18:03:06 03v67 kernel: with environment:
Nov 02 18:03:06 03v67 kernel: HOME=/
Nov 02 18:03:06 03v67 kernel: TERM=linux
Nov 02 18:03:06 03v67 kernel: BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64
Nov 02 18:03:06 03v67 kernel: wmi_bus wmi_bus-PNP0C14:02: WQ data block query control method not found
Nov 02 18:03:06 03v67 kernel: i8042: PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
Nov 02 18:03:06 03v67 kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
Nov 02 18:03:06 03v67 kernel: serio: i8042 KBD port at 0x60,0x64 irq 1
Nov 02 18:03:06 03v67 kernel: vmd 0000:00:0e.0: PCI host bridge to bus 10000:e0
Nov 02 18:03:06 03v67 kernel: pci_bus 10000:e0: root bus resource [bus e0-ff]
Nov 02 18:03:06 03v67 kernel: pci_bus 10000:e0: root bus resource [mem 0x50000000-0x51ffffff]
Nov 02 18:03:06 03v67 kernel: pci_bus 10000:e0: root bus resource [mem 0x6015302000-0x60153fffff 64bit]
Nov 02 18:03:06 03v67 kernel: pci 10000:e0:17.0: [8086:a0d3] type 00 class 0x010601
Nov 02 18:03:06 03v67 kernel: pci 10000:e0:17.0: reg 0x10: [mem 0x00000000-0x00001fff]
Nov 02 18:03:06 03v67 kernel: pci 10000:e0:17.0: reg 0x14: [mem 0x00000000-0x000000ff]
Nov 02 18:03:06 03v67 kernel: pci 10000:e0:17.0: reg 0x18: [io 0x0000-0x0007]
Nov 02 18:03:06 03v67 kernel: pci 10000:e0:17.0: reg 0x1c: [io 0x0000-0x0003]
Nov 02 18:03:06 03v67 kernel: pci 10000:e0:17.0: reg 0x20: [io 0x0000-0x001f]
Nov 02 18:03:06 03v67 kernel: pci 10000:e0:17.0: reg 0x24: [mem 0x50000000-0x500007ff]
Nov 02 18:03:06 03v67 kernel: pci 10000:e0:17.0: PME# supported from D3hot
Nov 02 18:03:06 03v67 kernel: pci 10000:e0:1c.0: [8086:09ab] type 00 class 0x088000
Nov 02 18:03:06 03v67 kernel: pci 10000:e0:1c.4: [8086:a0bc] type 01 class 0x060400
Nov 02 18:03:06 03v67 kernel: pci 10000:e0:1c.4: PME# supported from D0 D3hot D3cold
Nov 02 18:03:06 03v67 kernel: pci 10000:e0:1c.4: PTM enabled (root), 4ns granularity
Nov 02 18:03:06 03v67 kernel: pci 10000:e0:1c.4: Primary bus is hard wired to 0
Nov 02 18:03:06 03v67 kernel: pci 10000:e1:00.0: [2646:500c] type 00 class 0x010802
Nov 02 18:03:06 03v67 kernel: pci 10000:e1:00.0: reg 0x10: [mem 0x50100000-0x50103fff 64bit]
Nov 02 18:03:06 03v67 kernel: xhci_hcd 0000:00:14.0: xHCI Host Controller
Nov 02 18:03:06 03v67 kernel: xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
Nov 02 18:03:06 03v67 kernel: pci 10000:e0:1c.4: PCI bridge to [bus e1]
Nov 02 18:03:06 03v67 kernel: pci 10000:e0:1c.4: bridge window [io 0x0000-0x0fff]
Nov 02 18:03:06 03v67 kernel: pci 10000:e0:1c.4: bridge window [mem 0x50100000-0x501fffff]
Nov 02 18:03:06 03v67 kernel: xhci_hcd 0000:00:14.0: hcc params 0x20007fc1 hci version 0x120 quirks 0x0000000200009810
Nov 02 18:03:06 03v67 kernel: xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
Nov 02 18:03:06 03v67 kernel: xhci_hcd 0000:00:14.0: Host supports USB 3.1 Enhanced SuperSpeed
Nov 02 18:03:06 03v67 kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.05
Nov 02 18:03:06 03v67 kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Nov 02 18:03:06 03v67 kernel: usb usb1: Product: xHCI Host Controller
Nov 02 18:03:06 03v67 kernel: usb usb1: Manufacturer: Linux 6.5.13-7-MANJARO xhci-hcd
Nov 02 18:03:06 03v67 kernel: usb usb1: SerialNumber: 0000:00:14.0
Nov 02 18:03:06 03v67 kernel: hub 1-0:1.0: USB hub found
Nov 02 18:03:06 03v67 kernel: hub 1-0:1.0: 12 ports detected
Nov 02 18:03:06 03v67 kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.05
Nov 02 18:03:06 03v67 kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Nov 02 18:03:06 03v67 kernel: usb usb2: Product: xHCI Host Controller
Nov 02 18:03:06 03v67 kernel: usb usb2: Manufacturer: Linux 6.5.13-7-MANJARO xhci-hcd
Nov 02 18:03:06 03v67 kernel: usb usb2: SerialNumber: 0000:00:14.0
Nov 02 18:03:06 03v67 kernel: hub 2-0:1.0: USB hub found
Nov 02 18:03:06 03v67 kernel: hub 2-0:1.0: 4 ports detected
Nov 02 18:03:06 03v67 kernel: input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3
Nov 02 18:03:06 03v67 kernel: pci 10000:e0:1c.4: BAR 14: assigned [mem 0x50000000-0x500fffff]
Nov 02 18:03:06 03v67 kernel: pci 10000:e0:17.0: BAR 0: assigned [mem 0x50100000-0x50101fff]
Nov 02 18:03:06 03v67 kernel: pci 10000:e0:1c.4: BAR 13: no space for [io size 0x1000]
Nov 02 18:03:06 03v67 kernel: pci 10000:e0:1c.4: BAR 13: failed to assign [io size 0x1000]
Nov 02 18:03:06 03v67 kernel: pci 10000:e0:17.0: BAR 5: assigned [mem 0x50102000-0x501027ff]
Nov 02 18:03:06 03v67 kernel: pci 10000:e0:17.0: BAR 1: assigned [mem 0x50102800-0x501028ff]
Nov 02 18:03:06 03v67 kernel: pci 10000:e0:17.0: BAR 4: no space for [io size 0x0020]
Nov 02 18:03:06 03v67 kernel: pci 10000:e0:17.0: BAR 4: failed to assign [io size 0x0020]
Nov 02 18:03:06 03v67 kernel: pci 10000:e0:17.0: BAR 2: no space for [io size 0x0008]
Nov 02 18:03:06 03v67 kernel: pci 10000:e0:17.0: BAR 2: failed to assign [io size 0x0008]
Nov 02 18:03:06 03v67 kernel: pci 10000:e0:17.0: BAR 3: no space for [io size 0x0004]
Nov 02 18:03:06 03v67 kernel: pci 10000:e0:17.0: BAR 3: failed to assign [io size 0x0004]
Nov 02 18:03:06 03v67 kernel: pci 10000:e1:00.0: BAR 0: assigned [mem 0x50000000-0x50003fff 64bit]
Nov 02 18:03:06 03v67 kernel: pci 10000:e0:1c.4: bridge window [mem 0x50000000-0x500fffff]
Nov 02 18:03:06 03v67 kernel: pci 10000:e1:00.0: VMD: Default LTR value set by driver
Nov 02 18:03:06 03v67 kernel: ahci 10000:e0:17.0: version 3.0
Nov 02 18:03:06 03v67 kernel: ahci 10000:e0:17.0: can't derive routing for PCI INT A
Nov 02 18:03:06 03v67 kernel: ahci 10000:e0:17.0: PCI INT A: no GSI
Nov 02 18:03:06 03v67 kernel: ahci 10000:e0:17.0: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
Nov 02 18:03:06 03v67 kernel: ahci 10000:e0:17.0: flags: 64bit ncq sntf pm clo only pio slum part deso sadm sds
Nov 02 18:03:06 03v67 kernel: scsi host0: ahci
Nov 02 18:03:06 03v67 kernel: scsi host1: ahci
Nov 02 18:03:06 03v67 kernel: ata1: SATA max UDMA/133 abar m2048@0x50102000 port 0x50102100 irq 145
Nov 02 18:03:06 03v67 kernel: ata2: SATA max UDMA/133 abar m2048@0x50102000 port 0x50102180 irq 145
Nov 02 18:03:06 03v67 kernel: pcieport 10000:e0:1c.4: can't derive routing for PCI INT A
Nov 02 18:03:06 03v67 kernel: pcieport 10000:e0:1c.4: PCI INT A: no GSI
Nov 02 18:03:06 03v67 kernel: pcieport 10000:e0:1c.4: PME: Signaling with IRQ 146
Nov 02 18:03:06 03v67 kernel: pcieport 10000:e0:1c.4: AER: enabled with IRQ 146
Nov 02 18:03:06 03v67 kernel: pcieport 10000:e0:1c.4: DPC: enabled with IRQ 146
Nov 02 18:03:06 03v67 kernel: pcieport 10000:e0:1c.4: DPC: error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
Nov 02 18:03:06 03v67 kernel: vmd 0000:00:0e.0: Bound to PCI domain 10000
Nov 02 18:03:06 03v67 kernel: ACPI Warning: \_SB.PC00.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20230331/nsarguments-61)
Nov 02 18:03:06 03v67 kernel: pci 0000:01:00.0: optimus capabilities: enabled, status dynamic power, hda bios codec supported
Nov 02 18:03:06 03v67 kernel: VGA switcheroo: detected Optimus DSM method \_SB_.PC00.PEG0.PEGP handle
Nov 02 18:03:06 03v67 kernel: nouveau: detected PR support, will not use DSM
Nov 02 18:03:06 03v67 kernel: nouveau 0000:01:00.0: enabling device (0006 -> 0007)
Nov 02 18:03:06 03v67 kernel: nouveau 0000:01:00.0: NVIDIA GP107 (137000a1)
Nov 02 18:03:06 03v67 kernel: usb 1-5: new full-speed USB device number 2 using xhci_hcd
Nov 02 18:03:06 03v67 kernel: nouveau 0000:01:00.0: bios: version 86.07.96.00.34
Nov 02 18:03:06 03v67 kernel: nouveau 0000:01:00.0: pmu: firmware unavailable
Nov 02 18:03:06 03v67 kernel: nouveau 0000:01:00.0: fb: 2048 MiB GDDR5
Nov 02 18:03:06 03v67 kernel: nouveau 0000:01:00.0: DRM: VRAM: 2048 MiB
Nov 02 18:03:06 03v67 kernel: nouveau 0000:01:00.0: DRM: GART: 536870912 MiB
Nov 02 18:03:06 03v67 kernel: nouveau 0000:01:00.0: DRM: BIT table 'A' not found
Nov 02 18:03:06 03v67 kernel: nouveau 0000:01:00.0: DRM: BIT table 'L' not found
Nov 02 18:03:06 03v67 kernel: nouveau 0000:01:00.0: DRM: Pointer to TMDS table not found
Nov 02 18:03:06 03v67 kernel: nouveau 0000:01:00.0: DRM: DCB version 4.1
Nov 02 18:03:06 03v67 kernel: nouveau 0000:01:00.0: DRM: MM: using COPY for buffer copies
Nov 02 18:03:06 03v67 kernel: [drm] Initialized nouveau 1.3.1 20120801 for 0000:01:00.0 on minor 1
Nov 02 18:03:06 03v67 kernel: nouveau 0000:01:00.0: [drm] No compatible format found
Nov 02 18:03:06 03v67 kernel: nouveau 0000:01:00.0: [drm] Cannot find any crtc or sizes
Nov 02 18:03:06 03v67 kernel: usb 1-5: New USB device found, idVendor=3938, idProduct=1031, bcdDevice= 1.08
Nov 02 18:03:06 03v67 kernel: usb 1-5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Nov 02 18:03:06 03v67 kernel: usb 1-5: Product: 2.4G Wireless Mouse
Nov 02 18:03:06 03v67 kernel: usb 1-5: Manufacturer: MOSART Semi.
Nov 02 18:03:06 03v67 kernel: input: MOSART Semi. 2.4G Wireless Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.0/0003:3938:1031.0001/input/input4
Nov 02 18:03:06 03v67 kernel: input: MOSART Semi. 2.4G Wireless Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.0/0003:3938:1031.0001/input/input5
Nov 02 18:03:06 03v67 kernel: hid-generic 0003:3938:1031.0001: input,hiddev96,hidraw0: USB HID v1.10 Mouse [MOSART Semi. 2.4G Wireless Mouse] on usb-0000:00:14.0-5/input0
Nov 02 18:03:06 03v67 kernel: usbcore: registered new interface driver usbhid
Nov 02 18:03:06 03v67 kernel: usbhid: USB HID core driver
Nov 02 18:03:06 03v67 kernel: ata2: SATA link down (SStatus 0 SControl 300)
Nov 02 18:03:06 03v67 kernel: ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Nov 02 18:03:06 03v67 kernel: usb 1-8: new high-speed USB device number 3 using xhci_hcd
Nov 02 18:03:06 03v67 kernel: ata1.00: ATA-10: ST2000LM015-2E8174, 0001, max UDMA/133
Nov 02 18:03:06 03v67 kernel: i915 0000:00:02.0: vgaarb: deactivate vga console
Nov 02 18:03:06 03v67 kernel: i915 0000:00:02.0: [drm] Using Transparent Hugepages
Nov 02 18:03:06 03v67 kernel: i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
Nov 02 18:03:06 03v67 kernel: i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/tgl_dmc_ver2_12.bin (v2.12)
Nov 02 18:03:06 03v67 kernel: i915 0000:00:02.0: [drm] Protected Xe Path (PXP) protected content support initialized
Nov 02 18:03:06 03v67 kernel: ata1.00: 3907029168 sectors, multi 16: LBA48 NCQ (depth 32), AA
Nov 02 18:03:06 03v67 kernel: ata1.00: configured for UDMA/133
Nov 02 18:03:06 03v67 kernel: scsi 0:0:0:0: Direct-Access ATA ST2000LM015-2E81 0001 PQ: 0 ANSI: 5
Nov 02 18:03:06 03v67 kernel: sd 0:0:0:0: [sda] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
Nov 02 18:03:06 03v67 kernel: sd 0:0:0:0: [sda] 4096-byte physical blocks
Nov 02 18:03:06 03v67 kernel: sd 0:0:0:0: [sda] Write Protect is off
Nov 02 18:03:06 03v67 kernel: sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
Nov 02 18:03:06 03v67 kernel: sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Nov 02 18:03:06 03v67 kernel: sd 0:0:0:0: [sda] Preferred minimum I/O size 4096 bytes
Nov 02 18:03:06 03v67 kernel: usb 1-8: New USB device found, idVendor=04f2, idProduct=b72b, bcdDevice=27.46
Nov 02 18:03:06 03v67 kernel: usb 1-8: New USB device strings: Mfr=3, Product=1, SerialNumber=2
Nov 02 18:03:06 03v67 kernel: usb 1-8: Product: HD User Facing
Nov 02 18:03:06 03v67 kernel: usb 1-8: Manufacturer: Chicony Electronics Co.,Ltd.
Nov 02 18:03:06 03v67 kernel: usb 1-8: SerialNumber: 200901010001
Nov 02 18:03:06 03v67 kernel: sda: sda1 sda2 sda3 sda4
Nov 02 18:03:06 03v67 kernel: sd 0:0:0:0: [sda] Attached SCSI disk
Nov 02 18:03:06 03v67 kernel: nvme nvme0: pci function 10000:e1:00.0
Nov 02 18:03:06 03v67 kernel: nvme 10000:e1:00.0: PCI INT A: no GSI
Nov 02 18:03:06 03v67 kernel: nvme nvme0: missing or invalid SUBNQN field.
Nov 02 18:03:06 03v67 kernel: nvme nvme0: Shutdown timeout set to 10 seconds
Nov 02 18:03:06 03v67 kernel: nvme nvme0: 8/0/0 default/read/poll queues
Nov 02 18:03:06 03v67 kernel: nvme0n1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10
Nov 02 18:03:06 03v67 kernel: usb 1-10: new high-speed USB device number 4 using xhci_hcd
Nov 02 18:03:06 03v67 kernel: usb 1-10: New USB device found, idVendor=04ca, idProduct=3802, bcdDevice= 1.00
Nov 02 18:03:06 03v67 kernel: usb 1-10: New USB device strings: Mfr=5, Product=6, SerialNumber=7
Nov 02 18:03:06 03v67 kernel: usb 1-10: Product: Wireless_Device
Nov 02 18:03:06 03v67 kernel: usb 1-10: Manufacturer: MediaTek Inc.
Nov 02 18:03:06 03v67 kernel: usb 1-10: SerialNumber: 000000000
Nov 02 18:03:06 03v67 kernel: [drm] Initialized i915 1.6.0 20201103 for 0000:00:02.0 on minor 2
Nov 02 18:03:06 03v67 kernel: ACPI: video: [Firmware Bug]: ACPI(PEGP) defines _DOD but not _DOS
Nov 02 18:03:06 03v67 kernel: ACPI: video: Video Device [PEGP] (multi-head: yes rom: yes post: no)
Nov 02 18:03:06 03v67 kernel: input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:00/LNXVIDEO:00/input/input6
Nov 02 18:03:06 03v67 kernel: ACPI: video: Video Device [GFX0] (multi-head: yes rom: no post: no)
Nov 02 18:03:06 03v67 kernel: input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input7
Nov 02 18:03:06 03v67 kernel: vga_switcheroo: enabled
Nov 02 18:03:06 03v67 kernel: fbcon: i915drmfb (fb0) is primary device
Nov 02 18:03:06 03v67 kernel: i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
Nov 02 18:03:06 03v67 kernel: EXT4-fs (nvme0n1p6): mounted filesystem b54d7936-bc36-4be3-af80-0925eaad5c46 r/w with ordered data mode. Quota mode: none.
Nov 02 18:03:06 03v67 systemd[1]: systemd 256.5-1-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +XKBCOMMON +UTMP -SYSVINIT +LIBARCHIVE)
Nov 02 18:03:06 03v67 systemd[1]: Detected architecture x86-64.
Nov 02 18:03:06 03v67 systemd[1]: Hostname set to <03v67>.
Nov 02 18:03:06 03v67 kernel: systemd[1]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
Nov 02 18:03:06 03v67 systemd[1]: bpf-restrict-fs: LSM BPF program attached
Nov 02 18:03:06 03v67 systemd[1]: Queued start job for default target Graphical Interface.
Nov 02 18:03:06 03v67 systemd[1]: Created slice Virtual Machine and Container Slice.
Nov 02 18:03:06 03v67 systemd[1]: Created slice Slice /system/dirmngr.
Nov 02 18:03:06 03v67 systemd[1]: Created slice Slice /system/getty.
Nov 02 18:03:06 03v67 systemd[1]: Created slice Slice /system/gpg-agent.
Nov 02 18:03:06 03v67 systemd[1]: Created slice Slice /system/gpg-agent-browser.
Nov 02 18:03:06 03v67 systemd[1]: Created slice Slice /system/gpg-agent-extra.
Nov 02 18:03:06 03v67 systemd[1]: Created slice Slice /system/gpg-agent-ssh.
Nov 02 18:03:06 03v67 systemd[1]: Created slice Slice /system/keyboxd.
Nov 02 18:03:06 03v67 systemd[1]: Created slice Slice /system/modprobe.
Nov 02 18:03:06 03v67 systemd[1]: Created slice Slice /system/systemd-fsck.
Nov 02 18:03:06 03v67 systemd[1]: Created slice User and Session Slice.
Nov 02 18:03:06 03v67 systemd[1]: Started Forward Password Requests to Wall Directory Watch.
Nov 02 18:03:06 03v67 systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
Nov 02 18:03:06 03v67 systemd[1]: Expecting device /dev/disk/by-uuid/10d1234f-6b2f-441f-8ce1-26ec69f6b694...
Nov 02 18:03:06 03v67 systemd[1]: Expecting device /dev/disk/by-uuid/D6FB-4934...
Nov 02 18:03:06 03v67 systemd[1]: Expecting device /dev/disk/by-uuid/f1adcdb5-29aa-4751-aa03-8752550310a2...
Nov 02 18:03:06 03v67 systemd[1]: Expecting device /dev/disk/by-uuid/fb9f30c6-88d1-47a6-aba5-99034be6d52a...
Nov 02 18:03:06 03v67 systemd[1]: Reached target Login Prompts.
Nov 02 18:03:06 03v67 systemd[1]: Reached target Local Integrity Protected Volumes.
Nov 02 18:03:06 03v67 systemd[1]: Reached target Remote File Systems.
Nov 02 18:03:06 03v67 systemd[1]: Reached target Slice Units.
Nov 02 18:03:06 03v67 systemd[1]: Reached target Local Verity Protected Volumes.
Nov 02 18:03:06 03v67 systemd[1]: Listening on Device-mapper event daemon FIFOs.
Nov 02 18:03:06 03v67 systemd[1]: Listening on LVM2 poll daemon socket.
Nov 02 18:03:06 03v67 systemd[1]: Listening on Process Core Dump Socket.
Nov 02 18:03:06 03v67 systemd[1]: Listening on Credential Encryption/Decryption.
Nov 02 18:03:06 03v67 systemd[1]: Listening on Journal Socket (/dev/log).
Nov 02 18:03:06 03v67 systemd[1]: Listening on Journal Sockets.
Nov 02 18:03:06 03v67 systemd[1]: TPM PCR Measurements was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
Nov 02 18:03:06 03v67 systemd[1]: Make TPM PCR Policy was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
Nov 02 18:03:06 03v67 systemd[1]: Listening on udev Control Socket.
Nov 02 18:03:06 03v67 systemd[1]: Listening on udev Kernel Socket.
Nov 02 18:03:06 03v67 systemd[1]: Mounting Huge Pages File System...
Nov 02 18:03:06 03v67 systemd[1]: Mounting POSIX Message Queue File System...
Nov 02 18:03:06 03v67 systemd[1]: Mounting Kernel Debug File System...
Nov 02 18:03:06 03v67 systemd[1]: Mounting Kernel Trace File System...
Nov 02 18:03:06 03v67 systemd[1]: Starting Load AppArmor profiles...
Nov 02 18:03:06 03v67 systemd[1]: Starting Create List of Static Device Nodes...
Nov 02 18:03:06 03v67 systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
Nov 02 18:03:06 03v67 systemd[1]: Starting Load Kernel Module configfs...
Nov 02 18:03:06 03v67 systemd[1]: Starting Load Kernel Module dm_mod...
Nov 02 18:03:06 03v67 systemd[1]: Starting Load Kernel Module drm...
Nov 02 18:03:06 03v67 systemd[1]: Starting Load Kernel Module fuse...
Nov 02 18:03:06 03v67 systemd[1]: Starting Load Kernel Module loop...
Nov 02 18:03:06 03v67 systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
Nov 02 18:03:06 03v67 systemd[1]: Clear Stale Hibernate Storage Info was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67).
Nov 02 18:03:06 03v67 systemd[1]: Starting Load Kernel Modules...
Nov 02 18:03:06 03v67 systemd[1]: TPM PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
Nov 02 18:03:06 03v67 systemd[1]: Starting Remount Root and Kernel File Systems...
Nov 02 18:03:06 03v67 systemd[1]: Early TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
Nov 02 18:03:06 03v67 systemd[1]: Starting Load udev Rules from Credentials...
Nov 02 18:03:06 03v67 systemd[1]: Starting Coldplug All udev Devices...
Nov 02 18:03:06 03v67 systemd[1]: Starting Virtual Console Setup...
Nov 02 18:03:06 03v67 systemd[1]: Mounted Huge Pages File System.
Nov 02 18:03:06 03v67 systemd[1]: Mounted POSIX Message Queue File System.
Nov 02 18:03:06 03v67 systemd[1]: Mounted Kernel Debug File System.
Nov 02 18:03:06 03v67 systemd[1]: Mounted Kernel Trace File System.
Nov 02 18:03:06 03v67 kernel: loop: module loaded
Nov 02 18:03:06 03v67 kernel: device-mapper: uevent: version 1.0.3
Nov 02 18:03:06 03v67 kernel: device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-devel@redhat.com
Nov 02 18:03:06 03v67 kernel: fuse: init (API version 7.38)
Nov 02 18:03:06 03v67 systemd[1]: Finished Create List of Static Device Nodes.
Nov 02 18:03:06 03v67 systemd[1]: modprobe@configfs.service: Deactivated successfully.
Nov 02 18:03:06 03v67 kernel: EXT4-fs (nvme0n1p6): re-mounted b54d7936-bc36-4be3-af80-0925eaad5c46 r/w. Quota mode: none.
Nov 02 18:03:06 03v67 kernel: audit: type=1400 audit(1730545385.416:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=335 comm="apparmor_parser"
Nov 02 18:03:06 03v67 kernel: audit: type=1400 audit(1730545385.416:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=336 comm="apparmor_parser"
Nov 02 18:03:06 03v67 kernel: audit: type=1400 audit(1730545385.416:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=336 comm="apparmor_parser"
Nov 02 18:03:06 03v67 kernel: audit: type=1400 audit(1730545385.426:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="ping" pid=334 comm="apparmor_parser"
Nov 02 18:03:06 03v67 kernel: audit: type=1400 audit(1730545385.430:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="samba-bgqd" pid=338 comm="apparmor_parser"
Nov 02 18:03:06 03v67 kernel: audit: type=1400 audit(1730545385.430:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="samba-dcerpcd" pid=339 comm="apparmor_parser"
Nov 02 18:03:06 03v67 kernel: audit: type=1400 audit(1730545385.433:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="php-fpm" pid=337 comm="apparmor_parser"
Nov 02 18:03:06 03v67 kernel: audit: type=1400 audit(1730545385.440:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="klogd" pid=343 comm="apparmor_parser"
Nov 02 18:03:06 03v67 kernel: audit: type=1400 audit(1730545385.443:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="samba-rpcd" pid=340 comm="apparmor_parser"
Nov 02 18:03:06 03v67 systemd[1]: Finished Load Kernel Module configfs.
Nov 02 18:03:06 03v67 systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
Nov 02 18:03:06 03v67 systemd[1]: Finished Load Kernel Module dm_mod.
Nov 02 18:03:06 03v67 systemd[1]: modprobe@drm.service: Deactivated successfully.
Nov 02 18:03:06 03v67 systemd[1]: Finished Load Kernel Module drm.
Nov 02 18:03:06 03v67 systemd[1]: modprobe@fuse.service: Deactivated successfully.
Nov 02 18:03:06 03v67 systemd[1]: Finished Load Kernel Module fuse.
Nov 02 18:03:06 03v67 kernel: fbcon: Taking over console
Nov 02 18:03:06 03v67 kernel: Console: switching to colour frame buffer device 240x67
Nov 02 18:03:06 03v67 systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
Nov 02 18:03:06 03v67 systemd[1]: modprobe@loop.service: Deactivated successfully.
Nov 02 18:03:06 03v67 systemd[1]: Finished Load Kernel Module loop.
Nov 02 18:03:06 03v67 systemd[1]: Finished Load Kernel Modules.
Nov 02 18:03:06 03v67 systemd[1]: Finished Load AppArmor profiles.
Nov 02 18:03:06 03v67 systemd[1]: Finished Remount Root and Kernel File Systems.
Nov 02 18:03:06 03v67 systemd[1]: Finished Load udev Rules from Credentials.
Nov 02 18:03:06 03v67 systemd[1]: Finished Coldplug All udev Devices.
Nov 02 18:03:06 03v67 systemd[1]: Finished Virtual Console Setup.
Nov 02 18:03:06 03v67 systemd[1]: Mounting FUSE Control File System...
Nov 02 18:03:06 03v67 systemd[1]: Mounting Kernel Configuration File System...
Nov 02 18:03:06 03v67 systemd[1]: Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc).
Nov 02 18:03:06 03v67 systemd[1]: Starting Load/Save OS Random Seed...
Nov 02 18:03:06 03v67 systemd[1]: Repartition Root Disk was skipped because no trigger condition checks were met.
Nov 02 18:03:06 03v67 systemd[1]: Starting Apply Kernel Variables...
Nov 02 18:03:06 03v67 systemd[1]: Starting Create Static Device Nodes in /dev gracefully...
Nov 02 18:03:06 03v67 systemd[1]: TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
Nov 02 18:03:06 03v67 systemd[1]: Mounted FUSE Control File System.
Nov 02 18:03:06 03v67 systemd[1]: Mounted Kernel Configuration File System.
Nov 02 18:03:06 03v67 systemd[1]: Finished Load/Save OS Random Seed.
Nov 02 18:03:06 03v67 systemd[1]: Finished Apply Kernel Variables.
Nov 02 18:03:06 03v67 systemd[1]: Starting CLI Netfilter Manager...
Nov 02 18:03:06 03v67 systemd[1]: Finished Create Static Device Nodes in /dev gracefully.
Nov 02 18:03:06 03v67 systemd[1]: Finished CLI Netfilter Manager.
Nov 02 18:03:06 03v67 systemd[1]: Create System Users was skipped because no trigger condition checks were met.
Nov 02 18:03:06 03v67 systemd[1]: Starting Create Static Device Nodes in /dev...
Nov 02 18:03:06 03v67 systemd[1]: Finished Create Static Device Nodes in /dev.
Nov 02 18:03:06 03v67 systemd[1]: Reached target Preparation for Local File Systems.
Nov 02 18:03:06 03v67 systemd[1]: Entropy Daemon based on the HAVEGE algorithm was skipped because of an unmet condition check (ConditionKernelVersion=<5.6).
Nov 02 18:03:06 03v67 systemd[1]: Starting Journal Service...
Nov 02 18:03:06 03v67 systemd[1]: Starting Rule-based Manager for Device Events and Files...
Nov 02 18:03:06 03v67 systemd-journald[399]: Collecting audit messages is disabled.
Nov 02 18:03:06 03v67 systemd[1]: Started Journal Service.
Nov 02 18:03:06 03v67 systemd-journald[399]: Received client request to flush runtime journal.
Nov 02 18:03:06 03v67 kernel: input: Acer Wireless Radio Control as /devices/LNXSYSTM:00/10251229:00/input/input8
Nov 02 18:03:06 03v67 kernel: input: Intel HID events as /devices/platform/INTC1051:00/input/input9
Nov 02 18:03:06 03v67 kernel: intel-hid INTC1051:00: platform supports 5 button array
Nov 02 18:03:06 03v67 kernel: input: Intel HID 5 button array as /devices/platform/INTC1051:00/input/input10
Nov 02 18:03:06 03v67 kernel: mousedev: PS/2 mouse device common for all mice
Nov 02 18:03:06 03v67 kernel: EDAC igen6: v2.5.1
Nov 02 18:03:06 03v67 kernel: mc: Linux media interface: v0.10
Nov 02 18:03:06 03v67 kernel: mei_me 0000:00:16.0: enabling device (0000 -> 0002)
Nov 02 18:03:06 03v67 kernel: i801_smbus 0000:00:1f.4: SPD Write Disable is set
Nov 02 18:03:06 03v67 kernel: i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
Nov 02 18:03:06 03v67 kernel: i2c i2c-16: 2/2 memory slots populated (from DMI)
Nov 02 18:03:06 03v67 kernel: i2c i2c-16: Successfully instantiated SPD at 0x50
Nov 02 18:03:06 03v67 kernel: intel-lpss 0000:00:15.0: enabling device (0004 -> 0006)
Nov 02 18:03:06 03v67 kernel: idma64 idma64.0: Found Intel integrated DMA 64-bit
Nov 02 18:03:06 03v67 kernel: spi-nor spi0.0: XM25QH128A (16384 Kbytes)
Nov 02 18:03:06 03v67 kernel: acer_wmi: Acer Laptop ACPI-WMI Extras
Nov 02 18:03:06 03v67 kernel: acer_wmi: Function bitmap for Communication Button: 0x801
Nov 02 18:03:06 03v67 kernel: Creating 1 MTD partitions on "0000:00:1f.5":
Nov 02 18:03:06 03v67 kernel: 0x000000000000-0x000001000000 : "BIOS"
Nov 02 18:03:06 03v67 kernel: input: PC Speaker as /devices/platform/pcspkr/input/input11
Nov 02 18:03:06 03v67 kernel: input: Acer WMI hotkeys as /devices/virtual/input/input12
Nov 02 18:03:06 03v67 kernel: videodev: Linux video capture interface: v2.00
Nov 02 18:03:06 03v67 kernel: intel-lpss 0000:00:15.3: enabling device (0004 -> 0006)
Nov 02 18:03:06 03v67 kernel: idma64 idma64.1: Found Intel integrated DMA 64-bit
Nov 02 18:03:06 03v67 kernel: resource: resource sanity check: requesting [mem 0x00000000fedc0000-0x00000000fedcdfff], which spans more than pnp 00:04 [mem 0xfedc0000-0xfedc7fff]
Nov 02 18:03:06 03v67 kernel: caller __uncore_imc_init_box+0xfa/0x150 [intel_uncore] mapping multiple BARs
Nov 02 18:03:06 03v67 kernel: r8169 0000:02:00.0 eth0: RTL8168h/8111h, 08:8f:c3:0a:14:81, XID 541, IRQ 160
Nov 02 18:03:06 03v67 kernel: r8169 0000:02:00.0 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko]
Nov 02 18:03:06 03v67 kernel: intel-lpss 0000:00:19.0: enabling device (0004 -> 0006)
Nov 02 18:03:06 03v67 kernel: idma64 idma64.2: Found Intel integrated DMA 64-bit
Nov 02 18:03:06 03v67 kernel: intel-lpss 0000:00:19.1: enabling device (0004 -> 0006)
Nov 02 18:03:06 03v67 kernel: idma64 idma64.3: Found Intel integrated DMA 64-bit
Nov 02 18:03:06 03v67 kernel: Bluetooth: Core ver 2.22
Nov 02 18:03:06 03v67 kernel: NET: Registered PF_BLUETOOTH protocol family
Nov 02 18:03:06 03v67 kernel: Bluetooth: HCI device and connection manager initialized
Nov 02 18:03:06 03v67 kernel: Bluetooth: HCI socket layer initialized
Nov 02 18:03:06 03v67 kernel: Bluetooth: L2CAP socket layer initialized
Nov 02 18:03:06 03v67 kernel: Bluetooth: SCO socket layer initialized
Nov 02 18:03:06 03v67 kernel: input: ELAN050B:01 04F3:312B Mouse as /devices/pci0000:00/0000:00:15.3/i2c_designware.1/i2c-18/i2c-ELAN050B:01/0018:04F3:312B.0002/input/input13
Nov 02 18:03:06 03v67 kernel: input: ELAN050B:01 04F3:312B Touchpad as /devices/pci0000:00/0000:00:15.3/i2c_designware.1/i2c-18/i2c-ELAN050B:01/0018:04F3:312B.0002/input/input15
Nov 02 18:03:06 03v67 kernel: hid-generic 0018:04F3:312B.0002: input,hidraw1: I2C HID v1.00 Mouse [ELAN050B:01 04F3:312B] on i2c-ELAN050B:01
Nov 02 18:03:06 03v67 kernel: mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_ops [i915])
Nov 02 18:03:06 03v67 kernel: mei_pxp 0000:00:16.0-fbf6fcf1-96cf-4e2e-a6a6-1bab8cbe36b1: bound 0000:00:02.0 (ops i915_pxp_tee_component_ops [i915])
Nov 02 18:03:06 03v67 kernel: ee1004 16-0050: 512 byte EE1004-compliant SPD EEPROM, read-only
Nov 02 18:03:06 03v67 kernel: cfg80211: Loading compiled-in X.509 certificates for regulatory database
Nov 02 18:03:06 03v67 kernel: iTCO_vendor_support: vendor-support=0
Nov 02 18:03:06 03v67 kernel: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
Nov 02 18:03:06 03v67 kernel: cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
Nov 02 18:03:06 03v67 kernel: RAPL PMU: API unit is 2^-32 Joules, 3 fixed counters, 655360 ms ovfl timer
Nov 02 18:03:06 03v67 kernel: RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
Nov 02 18:03:06 03v67 kernel: RAPL PMU: hw unit of domain package 2^-14 Joules
Nov 02 18:03:06 03v67 kernel: RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
Nov 02 18:03:06 03v67 kernel: r8169 0000:02:00.0 enp2s0: renamed from eth0
Nov 02 18:03:06 03v67 kernel: iTCO_wdt iTCO_wdt: Found a Intel PCH TCO device (Version=6, TCOBASE=0x0400)
Nov 02 18:03:06 03v67 kernel: cryptd: max_cpu_qlen set to 1000
Nov 02 18:03:06 03v67 kernel: iTCO_wdt iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
Nov 02 18:03:06 03v67 kernel: usbcore: registered new interface driver btusb
Nov 02 18:03:06 03v67 kernel: usb 1-8: Found UVC 1.10 device HD User Facing (04f2:b72b)
Nov 02 18:03:06 03v67 kernel: AVX2 version of gcm_enc/dec engaged.
Nov 02 18:03:06 03v67 kernel: AES CTR mode by8 optimization enabled
Nov 02 18:03:06 03v67 kernel: usbcore: registered new interface driver uvcvideo
Nov 02 18:03:06 03v67 kernel: snd_hda_intel 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040100
Nov 02 18:03:06 03v67 kernel: snd_hda_intel 0000:00:1f.3: Digital mics found on Skylake+ platform, using SOF driver
Nov 02 18:03:06 03v67 kernel: Bluetooth: hci0: Device setup in 137754 usecs
Nov 02 18:03:06 03v67 kernel: Bluetooth: hci0: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported.
Nov 02 18:03:06 03v67 kernel: intel_tcc_cooling: TCC Offset locked
Nov 02 18:03:06 03v67 kernel: Bluetooth: hci0: AOSP extensions version v0.96
Nov 02 18:03:06 03v67 kernel: Bluetooth: hci0: AOSP quality report is not supported
Nov 02 18:03:06 03v67 kernel: sof-audio-pci-intel-tgl 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040100
Nov 02 18:03:06 03v67 kernel: sof-audio-pci-intel-tgl 0000:00:1f.3: Digital mics found on Skylake+ platform, using SOF driver
Nov 02 18:03:06 03v67 kernel: sof-audio-pci-intel-tgl 0000:00:1f.3: enabling device (0000 -> 0002)
Nov 02 18:03:06 03v67 kernel: sof-audio-pci-intel-tgl 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if 0x040100
Nov 02 18:03:06 03v67 kernel: sof-audio-pci-intel-tgl 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
Nov 02 18:03:06 03v67 kernel: sof-audio-pci-intel-tgl 0000:00:1f.3: use msi interrupt mode
Nov 02 18:03:06 03v67 kernel: mt7921e 0000:03:00.0: enabling device (0000 -> 0002)
Nov 02 18:03:06 03v67 kernel: input: ELAN050B:01 04F3:312B Mouse as /devices/pci0000:00/0000:00:15.3/i2c_designware.1/i2c-18/i2c-ELAN050B:01/0018:04F3:312B.0002/input/input16
Nov 02 18:03:06 03v67 kernel: input: ELAN050B:01 04F3:312B Touchpad as /devices/pci0000:00/0000:00:15.3/i2c_designware.1/i2c-18/i2c-ELAN050B:01/0018:04F3:312B.0002/input/input18
Nov 02 18:03:06 03v67 kernel: hid-multitouch 0018:04F3:312B.0002: input,hidraw1: I2C HID v1.00 Mouse [ELAN050B:01 04F3:312B] on i2c-ELAN050B:01
Nov 02 18:03:06 03v67 kernel: EXT4-fs (nvme0n1p7): mounted filesystem 10d1234f-6b2f-441f-8ce1-26ec69f6b694 r/w with ordered data mode. Quota mode: none.
Nov 02 18:03:06 03v67 kernel: mt7921e 0000:03:00.0: ASIC revision: 79610010
Nov 02 18:03:06 03v67 kernel: intel_rapl_msr: PL4 support detected.
Nov 02 18:03:06 03v67 kernel: intel_rapl_common: Found RAPL domain package
Nov 02 18:03:06 03v67 kernel: intel_rapl_common: Found RAPL domain core
Nov 02 18:03:06 03v67 kernel: intel_rapl_common: Found RAPL domain uncore
Nov 02 18:03:06 03v67 kernel: sof-audio-pci-intel-tgl 0000:00:1f.3: hda codecs found, mask 5
Nov 02 18:03:06 03v67 kernel: sof-audio-pci-intel-tgl 0000:00:1f.3: using HDA machine driver skl_hda_dsp_generic now
Nov 02 18:03:06 03v67 kernel: sof-audio-pci-intel-tgl 0000:00:1f.3: DMICs detected in NHLT tables: 2
Nov 02 18:03:06 03v67 kernel: EXT4-fs (sda4): mounted filesystem f1adcdb5-29aa-4751-aa03-8752550310a2 r/w with ordered data mode. Quota mode: none.
Nov 02 18:03:06 03v67 kernel: sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware info: version 2:2:0-57864
Nov 02 18:03:06 03v67 kernel: sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware: ABI 3:22:1 Kernel ABI 3:23:0
Nov 02 18:03:06 03v67 kernel: sof-audio-pci-intel-tgl 0000:00:1f.3: unknown sof_ext_man header type 3 size 0x30
Nov 02 18:03:06 03v67 kernel: mt7921e 0000:03:00.0: HW/SW Version: 0x8a108a10, Build Time: 20240716150944a
Nov 02 18:03:06 03v67 kernel: mt7921e 0000:03:00.0: WM Firmware Version: ____010000, Build Time: 20240716151027
Nov 02 18:03:07 03v67 kernel: sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware info: version 2:2:0-57864
Nov 02 18:03:07 03v67 kernel: sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware: ABI 3:22:1 Kernel ABI 3:23:0
Nov 02 18:03:07 03v67 kernel: sof-audio-pci-intel-tgl 0000:00:1f.3: Topology: ABI 3:22:1 Kernel ABI 3:23:0
Nov 02 18:03:07 03v67 kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: Parent card not yet available, widget card binding deferred
Nov 02 18:03:07 03v67 kernel: snd_hda_codec_realtek ehdaudio0D0: autoconfig for ALC255: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
Nov 02 18:03:07 03v67 kernel: snd_hda_codec_realtek ehdaudio0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
Nov 02 18:03:07 03v67 kernel: snd_hda_codec_realtek ehdaudio0D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
Nov 02 18:03:07 03v67 kernel: snd_hda_codec_realtek ehdaudio0D0: mono: mono_out=0x0
Nov 02 18:03:07 03v67 kernel: snd_hda_codec_realtek ehdaudio0D0: inputs:
Nov 02 18:03:07 03v67 kernel: snd_hda_codec_realtek ehdaudio0D0: ASoC: sink widget AIF1TX overwritten
Nov 02 18:03:07 03v67 kernel: snd_hda_codec_realtek ehdaudio0D0: ASoC: source widget AIF1RX overwritten
Nov 02 18:03:07 03v67 kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget hifi3 overwritten
Nov 02 18:03:07 03v67 kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget hifi2 overwritten
Nov 02 18:03:07 03v67 kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget hifi1 overwritten
Nov 02 18:03:07 03v67 kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Codec Output Pin1 overwritten
Nov 02 18:03:07 03v67 kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Codec Input Pin1 overwritten
Nov 02 18:03:07 03v67 kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Analog Codec Playback overwritten
Nov 02 18:03:07 03v67 kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Digital Codec Playback overwritten
Nov 02 18:03:07 03v67 kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Alt Analog Codec Playback overwritten
Nov 02 18:03:07 03v67 kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Analog Codec Capture overwritten
Nov 02 18:03:07 03v67 kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Digital Codec Capture overwritten
Nov 02 18:03:07 03v67 kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Alt Analog Codec Capture overwritten
Nov 02 18:03:07 03v67 kernel: skl_hda_dsp_generic skl_hda_dsp_generic: hda_dsp_hdmi_build_controls: no PCM in topology for HDMI converter 3
Nov 02 18:03:07 03v67 kernel: input: sof-hda-dsp Front Headphone as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input19
Nov 02 18:03:07 03v67 kernel: input: sof-hda-dsp HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input20
Nov 02 18:03:07 03v67 kernel: input: sof-hda-dsp HDMI/DP,pcm=4 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input21
Nov 02 18:03:07 03v67 kernel: input: sof-hda-dsp HDMI/DP,pcm=5 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input22
Nov 02 18:03:07 03v67 kernel: mt7921e 0000:03:00.0 wlp3s0: renamed from wlan0
Nov 02 18:04:35 03v67 kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Nov 02 18:04:35 03v67 kernel: Bluetooth: BNEP filters: protocol multicast
Nov 02 18:04:35 03v67 kernel: Bluetooth: BNEP socket layer initialized
Nov 02 18:04:35 03v67 kernel: Bluetooth: MGMT ver 1.22
Nov 02 18:04:35 03v67 kernel: NET: Registered PF_ALG protocol family
Nov 02 18:04:36 03v67 kernel: NET: Registered PF_QIPCRTR protocol family
Nov 02 18:04:36 03v67 kernel: Generic FE-GE Realtek PHY r8169-0-200:00: attached PHY driver (mii_bus:phy_addr=r8169-0-200:00, irq=MAC)
Nov 02 18:04:36 03v67 kernel: Bluetooth: hci0: Device setup in 143159 usecs
Nov 02 18:04:36 03v67 kernel: Bluetooth: hci0: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported.
Nov 02 18:04:36 03v67 kernel: Bluetooth: hci0: AOSP extensions version v0.96
Nov 02 18:04:36 03v67 kernel: Bluetooth: hci0: AOSP quality report is not supported
Nov 02 18:04:36 03v67 kernel: r8169 0000:02:00.0 enp2s0: Link is Down
Nov 02 18:04:37 03v67 kernel: bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
Nov 02 18:04:37 03v67 kernel: kauditd_printk_skb: 51 callbacks suppressed
Nov 02 18:04:37 03v67 kernel: audit: type=1400 audit(1730545477.550:62): apparmor="DENIED" operation="open" class="file" profile="dnsmasq//libvirt_leaseshelper" name="/etc/gnutls/config" pid=877 comm="libvirt_leasesh" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Nov 02 18:04:38 03v67 kernel: nouveau 0000:01:00.0: Enabling HDA controller
Nov 02 18:04:38 03v67 kernel: nouveau 0000:01:00.0: bus: MMIO read of 00000000 FAULT at 6013d4 [ PRIVRING ]
Nov 02 18:04:39 03v67 kernel: wlp3s0: authenticate with f8:3e:95:02:d0:f4
Nov 02 18:04:39 03v67 kernel: wlp3s0: send auth to f8:3e:95:02:d0:f4 (try 1/3)
Nov 02 18:04:39 03v67 kernel: wlp3s0: authenticated
Nov 02 18:04:39 03v67 kernel: wlp3s0: associate with f8:3e:95:02:d0:f4 (try 1/3)
Nov 02 18:04:39 03v67 kernel: wlp3s0: RX AssocResp from f8:3e:95:02:d0:f4 (capab=0x1431 status=0 aid=37)
Nov 02 18:04:39 03v67 kernel: wlp3s0: associated
Nov 02 18:04:39 03v67 kernel: wlp3s0: Limiting TX power to 27 (27 - 0) dBm as advertised by f8:3e:95:02:d0:f4
Nov 02 18:04:39 03v67 kernel: rfkill: input handler disabled
Nov 02 18:04:42 03v67 kernel: audit: type=1400 audit(1730545482.520:63): apparmor="DENIED" operation="open" class="file" profile="nmbd" name="/etc/gnutls/config" pid=1381 comm="nmbd" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Nov 02 18:04:42 03v67 kernel: audit: type=1400 audit(1730545482.623:64): apparmor="DENIED" operation="open" class="file" profile="smbd" name="/etc/gnutls/config" pid=1389 comm="smbd" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Nov 02 18:04:42 03v67 kernel: audit: type=1400 audit(1730545482.706:65): apparmor="STATUS" operation="profile_load" profile="unconfined" name="docker-default" pid=1414 comm="apparmor_parser"
Nov 02 18:04:42 03v67 kernel: Bridge firewalling registered
Nov 02 11:05:06 03v67 systemd-journald[399]: Time jumped backwards, rotating.
Nov 02 11:08:45 03v67 kernel: rfkill: input handler enabled
Nov 02 11:08:46 03v67 kernel: nouveau 0000:01:00.0: Enabling HDA controller
Nov 02 11:08:46 03v67 kernel: nouveau 0000:01:00.0: bus: MMIO read of 00000000 FAULT at 6013d4 [ PRIVRING ]
Nov 02 11:08:50 03v67 kernel: rfkill: input handler disabled
Nov 02 11:08:51 03v67 kernel: warning: `pool-gnome-shel' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
Nov 02 11:08:51 03v67 kernel: Bluetooth: RFCOMM TTY layer initialized
Nov 02 11:08:51 03v67 kernel: Bluetooth: RFCOMM socket layer initialized
Nov 02 11:08:51 03v67 kernel: Bluetooth: RFCOMM ver 1.11
Nov 02 11:08:53 03v67 kernel: nouveau 0000:01:00.0: Enabling HDA controller
Nov 02 11:08:53 03v67 kernel: nouveau 0000:01:00.0: bus: MMIO read of 00000000 FAULT at 6013d4 [ PRIVRING ]
Nov 02 11:10:52 03v67 kernel: acer_wmi: Unknown function number - 4 - 0
Nov 02 11:10:53 03v67 kernel: acer_wmi: Unknown function number - 4 - 0
Nov 02 12:36:59 03v67 kernel: rfkill: input handler enabled
Nov 02 12:37:00 03v67 kernel: nouveau 0000:01:00.0: Enabling HDA controller
Nov 02 12:37:01 03v67 kernel: wlp3s0: deauthenticating from f8:3e:95:02:d0:f4 by local choice (Reason: 3=DEAUTH_LEAVING)
Nov 02 12:37:02 03v67 kernel: EXT4-fs (nvme0n1p7): unmounting filesystem 10d1234f-6b2f-441f-8ce1-26ec69f6b694.
Nov 02 12:37:02 03v67 kernel: EXT4-fs (sda4): unmounting filesystem f1adcdb5-29aa-4751-aa03-8752550310a2.
Nov 02 12:37:02 03v67 systemd-shutdown[1]: Syncing filesystems and block devices.
Nov 02 12:37:02 03v67 systemd-shutdown[1]: Sending SIGTERM to remaining processes...
Nov 02 12:37:02 03v67 systemd-journald[399]: Received SIGTERM from PID 1 (systemd-shutdow).
looks like fstab is ok. no devices are misconfigured
/etc/fstab:
UUID=D6FB-4934 /boot/efi vfat umask=0077 0 2
UUID=b54d7936-bc36-4be3-af80-0925eaad5c46 / ext4 defaults,noatime 0 1
UUID=10d1234f-6b2f-441f-8ce1-26ec69f6b694 /opt ext4 defaults,noatime 0 2
UUID=f1adcdb5-29aa-4751-aa03-8752550310a2 /home ext4 defaults,noatime 0 2
UUID=fb9f30c6-88d1-47a6-aba5-99034be6d52a none swap defaults 0 0
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0
blkid:
/dev/nvme0n1p9: LABEL="root" UUID="b2619041-b5f3-4e39-ba28-6046c18d64c8" BLOCK_SIZE="4096" TYPE="ext4" PARTLABEL="root" PARTUUID="3054772e-e1b9-47f2-a331-bbb13693fa47"
/dev/nvme0n1p7: UUID="10d1234f-6b2f-441f-8ce1-26ec69f6b694" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="75f3d846-f502-46dc-88cc-4825c70f3b9b"
/dev/nvme0n1p5: LABEL_FATBOOT="EFI" LABEL="EFI" UUID="D6FB-4934" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="7b0cb9ed-cbd6-414b-a7eb-3911e6070c98"
/dev/nvme0n1p3: LABEL="Acer" BLOCK_SIZE="512" UUID="467C30F57C30E17B" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="99a33a3d-5678-4810-8632-7c7b11da0f58"
/dev/nvme0n1p1: LABEL_FATBOOT="ESP" LABEL="ESP" UUID="B230-78EE" BLOCK_SIZE="512" TYPE="vfat" PARTLABEL="EFI system partition" PARTUUID="8bb13c56-a27b-42c8-84d8-86bfb6451c45"
/dev/nvme0n1p8: LABEL_FATBOOT="EFI" LABEL="EFI" UUID="3E98-B294" BLOCK_SIZE="512" TYPE="vfat" PARTLABEL="EFI system partition" PARTUUID="83a7c588-7af5-467d-9faa-bcf9ce72983b"
/dev/nvme0n1p10: BLOCK_SIZE="512" UUID="EAC67459C67427C9" TYPE="ntfs" PARTUUID="f1f470ca-b805-4f72-b249-f30489cae9b3"
/dev/nvme0n1p6: UUID="b54d7936-bc36-4be3-af80-0925eaad5c46" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="69b42405-2544-4306-96de-b3268992ca82"
/dev/nvme0n1p4: UUID="0C03-5AA2" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="ea213500-2ba5-4461-a815-39a966114ca0"
/dev/sda4: UUID="f1adcdb5-29aa-4751-aa03-8752550310a2" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="042205fb-8336-114d-b14c-38d88103260d"
/dev/sda2: LABEL="HDD" BLOCK_SIZE="512" UUID="F85E957F5E95377A" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="7748e7ac-6635-404e-9566-eaeebd5d2b26"
/dev/sda3: UUID="1751e4a4-7c37-4cf0-bb75-44b9a67cf679" TYPE="swap" PARTUUID="8d5743a4-c120-c548-9469-db7ec11f792c"
/dev/nvme0n1p2: PARTLABEL="Microsoft reserved partition" PARTUUID="20615dbb-4cbc-41be-b5a7-8c0e94433adb"
/dev/sda1: PARTLABEL="Microsoft reserved partition" PARTUUID="ece2cc96-cf7a-41de-bc5c-4dee9a6aef35"
