Hi everyone,
I installed Manjaro about 3 month ago and am really happy using it, however my boot times dropped heavily after I didn’t use my computer for one month.
Manjaro is installed on a M.2 PCI-E 3.0 SSD with initial boot times of around 10 seconds. Now it takes at least 2 Minutes, sometimes even longer.
I’m quite new to Linux but from what I think it’s not a problem of the OS, the problem seems to be more on the GRUB or BIOS side.
I already reset the BIOS and updated it but the issue persists.
systemd-analyze says
Startup finished in 1min 23.194s (firmware) + 1min 27.223s (loader) + 2.985s (kernel) + 5.804s (userspace) = 2min 59.207s
graphical.target reached after 5.803s in userspace.
all the services in systemd-analyze blame are below 3s so no issue there, I guess.
My GRUB config looks like this
# GRUB boot loader configuration
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash udev.log_priority=3"
journalctl --boot --priority=3 gives me
Okt 05 11:03:53 PJM kernel: x86/cpu: VMX (outside TXT) disabled by BIOS
Okt 05 11:03:53 PJM kernel: x86/cpu: SGX disabled by BIOS.
Okt 05 11:03:55 PJM kernel: usb usb1-port9: connect-debounce failed
Okt 05 11:03:58 PJM kernel: usb 1-9: device descriptor read/64, error -71
Okt 05 11:03:59 PJM kernel: usb 1-9: device descriptor read/64, error -71
Okt 05 11:04:00 PJM kernel: usb 1-9: device descriptor read/64, error -71
Okt 05 11:04:01 PJM kernel: usb 1-9: device not accepting address 7, error -71
Okt 05 11:04:02 PJM kernel: usb 1-9: device not accepting address 8, error -71
Okt 05 11:04:02 PJM kernel: usb usb1-port9: unable to enumerate USB device
Okt 05 11:04:03 PJM kernel: usb 1-9: device descriptor read/64, error -71
Okt 05 11:04:04 PJM kernel: usb 1-9: device not accepting address 11, error -71
Okt 05 11:04:06 PJM kernel: usb usb1-port9: Cannot enable. Maybe the USB cable is bad?
Okt 05 11:04:06 PJM kernel: usb usb1-port9: unable to enumerate USB device
Okt 05 11:04:06 PJM kernel: usb 1-5: 1:1: cannot get freq at ep 0x81
Okt 05 11:04:06 PJM kernel: usb 1-5: 2:1: cannot get freq at ep 0x2
Okt 05 11:04:08 PJM kernel: usb 1-5: 2:1: cannot get freq at ep 0x2
Okt 05 11:04:31 PJM pulseaudio[929]: GetManagedObjects() failed: org.freedesktop.DBus.Error.TimedOut: Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)
Okt 05 11:08:15 PJM pulseaudio[929]: ALSA weckte uns auf, um neue Daten auf das Gerät zu schreiben, doch es gab nichts zum Schreiben!
Okt 05 11:08:15 PJM pulseaudio[929]: Dies ist höchstwahrscheinlich ein Fehler im ALSA-Treiber »snd_usb_audio«. Bitte melden Sie diesen Fehler den ALSA-Entwicklern.
Okt 05 11:08:15 PJM pulseaudio[929]: Wir wurden durch das POLLOUT-Set geweckt, allerdings lieferte ein anschließender snd_pcm_avail() den Wert 0 oder einen anderen Wert < min_avail.
(sorry for the German pulseaudio output)
There’s my inxi -Fza just for reference
Kernel: 6.5.5-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64
root=UUID=d7653467-1ce3-4b5a-9a98-8081e3a2d1c2 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2
Type: Desktop Mobo: ASUSTeK model: Z170 PRO GAMING v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 3805
date: 05/16/2018
Info: model: Intel Core i7-6700K bits: 64 type: MT MCP arch: Skylake-S
gen: core 6 level: v3 note: check built: 2015 process: Intel 14nm family: 6
model-id: 0x5E (94) stepping: 3 microcode: 0xF0
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 828 high: 1026 min/max: 800/4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 1026
5: 800 6: 800 7: 800 8: 800 bogomips: 64026
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Type: gather_data_sampling status: Vulnerable: No microcode
Type: itlb_multihit status: KVM: VMX unsupported
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GA104 [GeForce RTX 3060] vendor: Micro-Star MSI
driver: nvidia v: 535.113.01 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-09) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-23 pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.0 chip-ID: 10de:2487
class-ID: 0300
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.2.1
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 92 s-size: 530x301mm (20.87x11.85")
s-diag: 610mm (24")
Monitor-1: Unknown-1 mapped: DP-1 res: 1920x1080 hz: 60 dpi: 93
size: 527x296mm (20.75x11.65") modes: 1920x1080
API: EGL v: 1.5 hw: drv: nvidia platforms: gbm: drv: nvidia
API: OpenGL v: 4.6.0 vendor: nvidia v: 535.113.01 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce RTX 3060/PCIe/SSE2
memory: 11.72 GiB
API: Vulkan v: 1.3.264 layers: 5 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 driver: nvidia v: 535.113.01
device-ID: 10de:2487 surfaces: xcb,xlib
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3
chip-ID: 8086:a170 class-ID: 0403
Device-2: NVIDIA GA104 High Definition Audio vendor: Micro-Star MSI
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:228b
class-ID: 0403
Device-3: RODE Microphones RØDE NT-USB Mini
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-5:4 chip-ID: 19f7:0015 class-ID: 0300
serial: <filter>
API: ALSA v: k6.5.5-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.80 status: off with: wireplumber status: active
tools: pw-cli,wpctl
Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 1.71 TiB used: 264.45 GiB (15.1%)
model: WD Blue SN570 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 234110WD temp: 33.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 840 PRO Series
size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 6B0Q scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD5000AZRX-00L4HB0 size: 465.76 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 5400 serial: <filter>
fw-rev: 1A01 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 750 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 1B6Q scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
used: 264.45 GiB (28.9%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
used: 292 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: file size: 14.9 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 32.0 C mobo: N/A gpu: nvidia temp: 43 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
Processes: 230 Uptime: 44m wakeups: 0 Memory: total: 16 GiB
available: 15.57 GiB used: 4.76 GiB (30.6%) Init: systemd v: 254
Packages: 1353 pm: pacman pkgs: 1347 libs: 456 tools: pamac pm: flatpak
pkgs: 6 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.30
