I’m having issue of extremely slow internet issue with my college wifi. It works fine with ethernet but on using wifi it’s highly unstable like disconnects automatically and also speed and latency is very poor. With ethernet I’m getting around 100 Mbps while with wifi it’s around 2-5 Mbps and sometime even less. The same wifi working perfect when I boots into windows on same laptop so it’s not a hardware issue. I tried searching on many forums with the same issue but nothing seems to work.
This issue is only with my college wifi. On using my mobile data hotspot as wifi it works fine. FYI My college wifi needs a login portal on intranet.
On running below command
> inxi -F | grep iwlwifi
Device-1: Intel Ice Lake-LP PCH CNVi WiFi driver: iwlwifi
System specs
> sudo inxi --admin --verbosity=7 --filter --no-host --width
[sudo] password for keshav:
Kernel: 6.1.31-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=e2066732-46b7-45c5-a6d4-27574c6bee49 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.5 tk: Qt v: 5.15.9 info: latte-dock
wm: kwin_wayland dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 81WL v: Lenovo IdeaPad S340-15IIL
serial: <filter> Chassis: type: 10 v: Lenovo IdeaPad S340-15IIL
serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40700 WIN serial: <filter>
UEFI: LENOVO v: CUCN73WW(V3.15) date: 05/04/2022
ID-1: BAT1 charge: 52.3 Wh (98.7%) condition: 53.0/52.5 Wh (101.0%)
volts: 12.7 min: 11.3 model: LGC L18L3PF3 type: Li-ion serial: <filter>
status: not charging cycles: 406
System RAM: available: 19.22 GiB used: 7.56 GiB (39.4%)
Array-1: capacity: 32 GiB slots: 2 EC: None max-module-size: 16 GiB
note: est.
Device-1: ChannelA-DRAM type: DDR4 detail: synchronous size: 16 GiB
speed: 2667 MT/s volts: curr: 1.2 min: 1.35 max: 1.5 width (bits): data: 64
total: 64 manufacturer: Crucial part-no: CT16G4SFRA266.M8FF
serial: <filter>
Device-2: ChannelB-DRAM type: DDR4 detail: synchronous size: 4 GiB
total: 64 manufacturer: Micron part-no: 4ATF51264HZ-3G2J1 serial: N/A
Info: model: Intel Core i5-1035G1 socket: U3E1 bits: 64 type: MT MCP
arch: Ice Lake gen: core 10 level: v4 note: check built: 2019-21
process: Intel 10nm family: 6 model-id: 0x7E (126) stepping: 5
microcode: 0xBA
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 2 MiB desc: 4x512 KiB L3: 6 MiB
desc: 1x6 MiB
Speed (MHz): avg: 1500 high: 3601 min/max: 400/3600 base/boost: 1000/8300
scaling: driver: intel_pstate governor: powersave volts: 0.6 V
ext-clock: 100 MHz cores: 1: 1200 2: 1200 3: 1200 4: 1200 5: 3601 6: 1200
7: 1200 8: 1200 bogomips: 19048
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f avx512ifma
avx512vbmi avx512vl bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
est f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp
hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
rdtscp rep_good sdbg sep sgx sgx_lc sha_ni smap smep split_lock_detect ss
ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: retbleed mitigation: Enhanced IBRS
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel Iris Plus Graphics G1 vendor: Lenovo driver: i915 v: kernel
arch: Gen-11 process: Intel 10nm built: 2019-21 ports: active: eDP-1
empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:8a56 class-ID: 0300
Device-2: NVIDIA GP108M [GeForce MX250] vendor: Lenovo driver: nvidia
v: 530.41.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-05) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 4 link-max: gen: 3
speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1d13 class-ID: 0302
Device-3: Syntek Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3 chip-ID: 174f:2426
Display: server: X.Org v: 23.1.1 with: Xwayland v: 23.1.1
compositor: kwin_wayland driver: X: loaded: modesetting,nvidia
alternate: fbdev,nouveau,nv,vesa dri: iris gpu: i915 display-ID: :1
screens: 1
s-diag: 582mm (22.93") monitors: <missing: xrandr>
Monitor-1: eDP-1 model: LG Display 0x05e5 built: 2018 res: 1920x1080
dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 23.0.4 renderer: Mesa Intel UHD Graphics (ICL GT1)
direct-render: Yes
Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Lenovo
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_icl
bus-ID: 00:1f.3 chip-ID: 8086:34c8 class-ID: 0403
API: ALSA v: k6.1.31-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.70 status: n/a (root, process) with: wireplumber
status: active tools: pw-cli,wpctl
Server-3: PulseAudio v: 16.1 status: active (root, process)
with: pulseaudio-alsa type: plugin tools: pacat,pactl
Device-1: Intel Ice Lake-LP PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:34f0 class-ID: 0280
Device-2: ICS Advent USB 10/100 LAN driver: cdc_ether type: USB rev: 2.1
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1:5 chip-ID: 0fe6:9900
class-ID: 0a00 serial: <filter>
IF: enp0s20f0u1c2 state: up speed: 100 Mbps duplex: half mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:4
Report: rfkill ID: hci0 rfk-id: 8 state: up address: see --recommends
Local Storage: total: 1.36 TiB used: 877.01 GiB (62.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 500GB
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B4QFXO7 temp: 36.9 C
scheme: GPT
SMART: yes health: PASSED on: 31d 2h cycles: 1,645
read-units: 11,502,735 [5.88 TB] written-units: 18,661,261 [9.55 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B sata: 3.3
speed: 6.0 Gb/s tech: HDD rpm: 5400 serial: <filter> fw-rev: 0E temp: 32 C
scheme: GPT
SMART: yes state: enabled health: PASSED on: 291d 22h cycles: 4762
ID-1: / raw-size: 249.02 GiB size: 244.06 GiB (98.00%)
used: 52.34 GiB (21.4%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p6
maj-min: 259:6 label: N/A uuid: e2066732-46b7-45c5-a6d4-27574c6bee49
used: 292 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p5
maj-min: 259:5 label: N/A uuid: 67DB-A2E2
ID-3: /run/media/keshav/C81A56B51A569FEC raw-size: 215.55 GiB
size: 215.55 GiB (100.00%) used: 171.2 GiB (79.4%) fs: ntfs
block-size: 4096 B dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: C81A56B51A569FEC
ID-4: /run/media/keshav/HDD raw-size: 931.5 GiB size: 931.5 GiB (100.00%)
used: 653.46 GiB (70.2%) fs: ntfs block-size: 4096 B dev: /dev/sda3
maj-min: 8:3 label: HDD uuid: 2072A69E72A67864
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
uuid: CE53-3133
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: N/A label: N/A
uuid: N/A
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 802 MiB fs: ntfs label: N/A
uuid: 5674552874550BDD
ID-4: /dev/sda1 maj-min: 8:1 size: 1024 KiB fs: N/A label: N/A uuid: N/A
ID-5: /dev/sda2 maj-min: 8:2 size: 15 MiB fs: N/A label: N/A uuid: N/A
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-1:5 info: ICS Advent USB 10/100 LAN
type: ethernet network,CDC-data driver: cdc_ether interfaces: 2 rev: 2.1
chip-ID: 0fe6:9900 class-ID: 0a00 serial: <filter>
Device-2: 1-2:6 info: HP HP 150 Wireless Mouse type: mouse
lanes: 1 mode: 1.1 power: 100mA chip-ID: 03f0:6241 class-ID: 0301
Device-3: 1-6:3 info: Syntek Integrated Camera type: video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 174f:2426 class-ID: 0e02 serial: <filter>
Device-4: 1-10:4 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.1
System Temperatures: cpu: 52.0 C mobo: N/A
Processes: 370 Uptime: 1d 4h 56m wakeups: 34 Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7
Packages: 1314 pm: pacman pkgs: 1286 libs: 371 tools: pamac,yay pm: flatpak
pkgs: 28 Shell: Zsh (sudo) v: 5.9 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.27
