Hi,
A few weeks ago my system started slowing down significantly intermittently. When that happens, opening a new terminal takes a few seconds.
During these times htop shows either aur/teams-for-linux at 100% CPU or a browser at 100-200% CPU. Closing both “solves” the issue. I’ve tried several browsers (brave, firefox and chromium) and the behavior is the same. The browser can have a few tabs open or hundreds. The slow down occurs at intermittent intervals and isn’t reproduced reliably. But it happens numerous time a day.
My workflow hasn’t changed before the slow downs started. Other than the above GUI tools, I only use CLI tools. Although they don’t consume much CPU they are affected during slowdown. I’m using the Manjaro i3 flavor.
Other, similar, threads didn’t help. intel_gpu_top during slowdowns shows under 30% resource consumption. Below is as much information as I understood can be helpful to debug.
Using slices didn’t help, either.
cat ~/.config/systemd/user/teams.slice
[Slice]
CPUQuota=200%
MemoryHigh=6G
MemoryMax=8G
MemorySwapMax=4G
systemd-run --user --slice=teams.slice /usr/bin/teams-for-linux
Same for whatever browser didn’t limit the slowdown to the program.
Can anyone, please, help me debug why my system runs slow, at times, when using either teams or a browser?
inxi --admin --verbosity=7 --filter --width
Kernel: 5.17.15-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.17-x86_64
root=UUID=a5b66abc-94f1-47e6-aa54-dcf91a610fcb rw rootflags=subvol=@ quiet
resume=UUID=c8d919a1-4a4f-486b-8f79-07f3e5fa064f udev.log_priority=3
Desktop: i3 v: 4.20.1 info: i3bar dm: LightDM v: 1.32.0
Type: Laptop System: Dell product: Latitude 5420 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Dell model: 054CCV v: A00 serial: <filter> UEFI: Dell v: 1.11.2
date: 08/26/2021
ID-1: BAT0 charge: 17.2 Wh (35.8%) condition: 48.0/62.4 Wh (76.9%)
volts: 15.7 min: 15.2 model: SWD-ATL4.175 DELL 1K2CF12 type: Li-poly
serial: <filter> status: charging
RAM: total: 31.09 GiB used: 9.52 GiB (30.6%)
Array-1: capacity: 128 GiB slots: 2 EC: None max-module-size: 64 GiB
note: est.
Device-1: DIMM B type: DDR4 detail: synchronous size: 16 GiB
speed: 3200 MT/s volts: curr: 1.2 width (bits): data: 64 total: 64
manufacturer: 802C0000802C part-no: 8ATF2G64HZ-3G2E2 serial: <filter>
Device-2: DIMM A type: DDR4 detail: synchronous size: 16 GiB
Info: model: 11th Gen Intel Core i7-1185G7 socket: U3E1 bits: 64
type: MT MCP arch: Tiger Lake gen: core 11 built: 2020 process: Intel 10nm
family: 6 model-id: 0x8C (140) stepping: 1 microcode: 0xA4
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 3001 high: 4543 min/max: 400/4800 base/boost: 4300/4800
scaling: driver: intel_pstate governor: performance volts: 1.0 V
ext-clock: 100 MHz cores: 1: 1397 2: 3564 3: 2772 4: 4543 5: 2789 6: 2713
7: 3050 8: 3185 bogomips: 28888
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b
movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
rdt_a rdtscp rep_good sdbg sep sha_ni smap smep smx split_lock_detect ss
ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tme tpr_shadow tsc
tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Dell
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2, HDMI-A-3
bus-ID: 00:02.0 chip-ID: 8086:9a49 class-ID: 0300
Device-2: Sunplus Innovation Integrated_Webcam_FHD type: USB
driver: uvcvideo bus-ID: 3-6:3 chip-ID: 1bcf:2ba0 class-ID: 0e02
serial: <filter>
Display: x11 server: X.Org v: 21.1.4 compositor: Picom v: git-7e568
driver: X: loaded: modesetting alternate: fbdev,vesa gpu: i915
display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: AU Optronics 0x4a90 built: 2020 res: 1920x1080
dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel Xe Graphics (TGL GT2) v: 4.6 Mesa 22.1.6
direct render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Dell
driver: snd_hda_intel bus-ID: 3-3:37 v: kernel chip-ID: 1038:12aa
alternate: snd_sof_pci_intel_tgl class-ID: 0300 bus-ID: 00:1f.3
chip-ID: 8086:a0c8 serial: <filter> class-ID: 0403
Device-2: SteelSeries ApS Arctis 5 type: USB
driver: hid-generic,snd-usb-audio,usbhid
Sound Server-1: ALSA v: k5.17.15-1-MANJARO running: yes
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:a0f0 class-ID: 0280
Device-2: Intel Ethernet I219-LM vendor: Dell driver: N/A modules: e1000e
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15fb class-ID: 0200
IF-ID-1: br-193d47046db2 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IP v6: <filter> scope: link
IF-ID-2: br-e81ba5b6edb7 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
Message: Output throttled. IPs: 2; Limit: 10; Override: --limit [1-x;-1
all]
IF-ID-3: docker0 state: down mac: <filter>
all]
IF-ID-4: docker_gwbridge state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
all]
IF-ID-5: ppp0 state: unknown speed: N/A duplex: N/A mac: N/A
Message: Output throttled. IPs: 1; Limit: 10; Override: --limit [1-x;-1
all]
IF-ID-6: veth3486aee state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-7: veth4744e7b state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-8: veth734b147 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-9: veth83f8035 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-10: veth94d55a0 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-11: veth9d7a572 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-12: veth9de2d85 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-13: vethba9e7e0 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-14: vethcc3718d state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-15: vethdb30830 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-16: vetheb26833 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-17: virbr0 state: down mac: <filter>
all]
bus-ID: 3-10:5 chip-ID: 8087:0026 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: disabled
rfk-block: hardware: no software: no address: see --recommends
Device-1: luks-edd1b5eb-826e-42d7-aeb8-f3caa2048468 maj-min: 254:0
type: LUKS dm: dm-0 size: 825.17 GiB
Components:
p-1: nvme0n1p3 maj-min: 259:3 size: 825.17 GiB
Local Storage: total: 953.87 GiB used: 158.17 GiB (16.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2300 NVMe 1024GB
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 23000030 temp: 35.9 C scheme: GPT
SMART: yes health: PASSED on: 12d 0h cycles: 478 read-units: 7,257,189
[3.71 TB] written-units: 19,262,783 [9.86 TB]
ID-1: / raw-size: 94.2 GiB size: 94.2 GiB (100.00%) used: 56.13 GiB (59.6%)
fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: a5b66abc-94f1-47e6-aa54-dcf91a610fcb
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 580 KiB
(0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: 4791-2108
ID-3: /home raw-size: 825.17 GiB size: 825.17 GiB (100.00%) used: 102.02
GiB (12.4%) fs: btrfs block-size: 4096 B dev: /dev/dm-0 maj-min: 254:0
mapped: luks-edd1b5eb-826e-42d7-aeb8-f3caa2048468 label: N/A
uuid: bfc45a61-7d57-4d10-aa37-a78315bbdb3b
ID-4: /mnt/qa raw-size: N/A size: 1.5 TiB used: 1.43 TiB (95.2%) fs: cifs
dev: /dev/QA
ID-5: /mnt/versions raw-size: N/A size: 2.4 TiB used: 2.05 TiB (85.6%)
fs: cifs dev: /dev/Versions
ID-6: /var/cache raw-size: 94.2 GiB size: 94.2 GiB (100.00%) used: 56.13
GiB (59.6%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2 label: N/A uuid: a5b66abc-94f1-47e6-aa54-dcf91a610fcb
ID-7: /var/log raw-size: 94.2 GiB size: 94.2 GiB (100.00%) used: 56.13 GiB
(59.6%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: partition size: 34.21 GiB used: 21.8 MiB (0.1%)
priority: -2 dev: /dev/nvme0n1p4 maj-min: 259:4 label: N/A
uuid: c8d919a1-4a4f-486b-8f79-07f3e5fa064f
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-3:37 info: SteelSeries ApS Arctis 5 type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 6 rev: 2.0
speed: 12 Mb/s power: 250mA chip-ID: 1038:12aa class-ID: 0300
serial: <filter>
Device-2: 3-6:3 info: Sunplus Innovation Integrated_Webcam_FHD type: Video
driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA
chip-ID: 1bcf:2ba0 class-ID: 0e02 serial: <filter>
Device-3: 3-8:4 info: Broadcom 58200 type: Smart Card driver: N/A
interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 100mA chip-ID: 0a5c:5843
class-ID: 0b00 serial: <filter>
Device-4: 3-10:5 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
class-ID: e001
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 53.0 C mobo: N/A
Processes: 448 Uptime: 13d 19h 51m wakeups: 60554 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.1 Packages:
pacman: 1153 lib: 291 Shell: Zsh (sudo) v: 5.9 default: Bash v: 5.1.16
running-in: urxvt inxi: 3.3.20
[~] swapon
NAME TYPE SIZE USED PRIO
/dev/nvme0n1p4 partition 34.2G 21.8M -2
[~] journalctl --catalog --priority=3 --boot=-1
# Nothing from past 2 weeks
uname -a
Linux edd-dell 5.17.15-1-MANJARO #1 SMP PREEMPT Wed Jun 15 07:09:31 UTC 2022 x86_64 GNU/Linux
sudo smartctl -a /dev/nvme0n1p1
smartctl 7.3 2022-02-28 r5338 [x86_64-linux-5.17.15-1-MANJARO] (local build)
Copyright (C) 2002-22, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Number: Micron 2300 NVMe 1024GB
Serial Number: 21042C8E1B24
Firmware Version: 23000030
PCI Vendor/Subsystem ID: 0x1344
IEEE OUI Identifier: 0x00a075
Controller ID: 0
NVMe Version: 1.3
Number of Namespaces: 1
Namespace 1 Size/Capacity: 1,024,209,543,168 [1.02 TB]
Namespace 1 Formatted LBA Size: 512
Namespace 1 IEEE EUI-64: 00a075 012c8e1b24
Local Time is: Wed Aug 31 18:44:30 2022 IDT
Firmware Updates (0x14): 2 Slots, no Reset required
Optional Admin Commands (0x0017): Security Format Frmw_DL Self_Test
Optional NVM Commands (0x0057): Comp Wr_Unc DS_Mngmt Sav/Sel_Feat Timestmp
Log Page Attributes (0x1a): Cmd_Eff_Lg Telmtry_Lg Pers_Ev_Lg
Maximum Data Transfer Size: 512 Pages
Warning Comp. Temp. Threshold: 83 Celsius
Critical Comp. Temp. Threshold: 85 Celsius
Namespace 1 Features (0x08): No_ID_Reuse
Supported Power States
St Op Max Active Idle RL RT WL WT Ent_Lat Ex_Lat
0 + 8.25W - - 0 0 0 0 0 0
1 + 3.00W - - 1 1 1 1 0 0
2 + 1.90W - - 2 2 2 2 0 0
3 - 0.0800W - - 3 3 3 3 10000 2500
4 - 0.0050W - - 4 4 4 4 12000 35000
Supported LBA Sizes (NSID 0x1)
Id Fmt Data Metadt Rel_Perf
0 + 512 0 0
=== START OF SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
SMART/Health Information (NVMe Log 0x02)
Critical Warning: 0x00
Temperature: 33 Celsius
Available Spare: 100%
Available Spare Threshold: 50%
Percentage Used: 1%
Data Units Read: 7,257,154 [3.71 TB]
Data Units Written: 19,260,281 [9.86 TB]
Host Read Commands: 70,389,342
Host Write Commands: 186,969,935
Controller Busy Time: 2,635
Power Cycles: 478
Power On Hours: 288
Unsafe Shutdowns: 88
Media and Data Integrity Errors: 0
Error Information Log Entries: 667
Warning Comp. Temperature Time: 0
Critical Comp. Temperature Time: 0
Temperature Sensor 1: 33 Celsius
Temperature Sensor 2: 37 Celsius
Thermal Temp. 1 Transition Count: 1459
Thermal Temp. 1 Total Time: 69544
Error Information (NVMe Log 0x01, 16 of 256 entries)
Num ErrCount SQId CmdId Status PELoc LBA NSID VS
0 667 0 0x5003 0x8004 0x000 0 0 -
cat /etc/fstab
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=4791-2108 /boot/efi vfat umask=0077 0 2
UUID=a5b66abc-94f1-47e6-aa54-dcf91a610fcb / btrfs subvol=/@,defaults,noatime,space_cache 0 1
UUID=a5b66abc-94f1-47e6-aa54-dcf91a610fcb /var/cache btrfs subvol=/@cache,defaults,noatime,space_cache 0 2
UUID=a5b66abc-94f1-47e6-aa54-dcf91a610fcb /var/log btrfs subvol=/@log,defaults,noatime,space_cache 0 2
/dev/mapper/luks-edd1b5eb-826e-42d7-aeb8-f3caa2048468 /home btrfs defaults,noatime,space_cache 0 2
UUID=c8d919a1-4a4f-486b-8f79-07f3e5fa064f swap swap defaults,noatime 0 0
//ens-fs01.ensilo.local/Versions /mnt/versions/ cifs user,uid=edd,gid=edd,rw,credentials=/home/edd/.cifs_creds,vers=2.0 0 0
//ens-fs01.ensilo.local/QA /mnt/qa/ cifs user,uid=edd,gid=edd,rw,credentials=/home/edd/.cifs_creds,vers=2.0 0 0
sudo dmesg --level emerg,alert,crit,err,warn
[1175223.696427] kauditd_printk_skb: 43 callbacks suppressed
[1175229.757362] kauditd_printk_skb: 19 callbacks suppressed
[1175235.083475] kauditd_printk_skb: 86 callbacks suppressed
[1175240.405163] kauditd_printk_skb: 90 callbacks suppressed
[1175246.069010] kauditd_printk_skb: 36 callbacks suppressed
[1175251.169389] kauditd_printk_skb: 29 callbacks suppressed
[1175257.422168] kauditd_printk_skb: 16 callbacks suppressed
[1175266.634206] kauditd_printk_skb: 44 callbacks suppressed
[1175274.194770] kauditd_printk_skb: 43 callbacks suppressed
[1175283.753815] kauditd_printk_skb: 13 callbacks suppressed
[1175289.712557] kauditd_printk_skb: 15 callbacks suppressed
[1175296.442827] kauditd_printk_skb: 9 callbacks suppressed
[1175303.366454] kauditd_printk_skb: 43 callbacks suppressed
[1175332.676266] kauditd_printk_skb: 5 callbacks suppressed
[1175355.326011] kauditd_printk_skb: 7 callbacks suppressed
[1175360.412562] kauditd_printk_skb: 7 callbacks suppressed
[1175374.095874] kauditd_printk_skb: 15 callbacks suppressed
[1175379.215905] kauditd_printk_skb: 18 callbacks suppressed
[1175399.645941] kauditd_printk_skb: 12 callbacks suppressed
[1175406.472413] kauditd_printk_skb: 14 callbacks suppressed
[1175411.585769] kauditd_printk_skb: 7 callbacks suppressed
[1175437.165917] kauditd_printk_skb: 5 callbacks suppressed
[1175486.574908] kauditd_printk_skb: 14 callbacks suppressed
[1175519.738243] kauditd_printk_skb: 7 callbacks suppressed
[1175531.203595] kauditd_printk_skb: 9 callbacks suppressed
[1175541.261975] kauditd_printk_skb: 28 callbacks suppressed
[1175547.902874] kauditd_printk_skb: 33 callbacks suppressed
[1175564.625851] kauditd_printk_skb: 10 callbacks suppressed
[1175618.471994] kauditd_printk_skb: 15 callbacks suppressed
[1175628.521436] kauditd_printk_skb: 9 callbacks suppressed
[1175670.979189] kauditd_printk_skb: 13 callbacks suppressed
[1175744.813864] kauditd_printk_skb: 9 callbacks suppressed
[1175759.735575] kauditd_printk_skb: 14 callbacks suppressed
[1175857.464543] kauditd_printk_skb: 9 callbacks suppressed
[1175867.688143] kauditd_printk_skb: 14 callbacks suppressed
[1175877.539009] kauditd_printk_skb: 10 callbacks suppressed
[1175882.551479] kauditd_printk_skb: 10 callbacks suppressed
[1192773.060005] kauditd_printk_skb: 34 callbacks suppressed
