Hello everyone. I am attempting to get SLI/MultiGpu working on my PC using the arch wiki NVIDIA. But for some reason it claims it is not turned on even though I think it might be?
nvidia-settings -q all | grep MultiGPU
nvidia-settings -q all | grep SLIMode
Return nothing.
Next I went in to xorg.conf and added “MultiGPU” “Auto” option “SLI” “Auto” under the monitor device. When I pulled up the nvidia settings the 2nd card changed it now showed Used Dedicated Memory and GPU utilization going from 0% to 1% occasionally. When the option is removed the GPU utilization and Used dedicated memory stays at 0MBs. I hope I am understanding this correctly.
Still a return of nothing for the above nividia-settings.
I well also note that both my monitors are plugged into the same GPU and function properly.
Is there a way to confirm its working? Did I do the steps wrong? I am really just looking for general suggestions or if I missed something. If any more information is needed please let me know.
Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-nvidia 2020.11.30 false PCI
