Narsil
1
Hi,
I’m out of my competence here and need help …
My Lenovo E580, running Manjaro/XFCE, dosen’t sleep nor hibernate, nor react to lid close …
I don’t really know hot to investigate this, could someone help me please ?
Diego
Here is my inxi and journalctl --system after a systemctl suspend
Kernel: 5.19.7-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.19-x86_64
root=UUID=cab735ee-bedb-4253-9e43-7acb19317468 rw quiet apparmor=1
security=apparmor resume=UUID=33f1aa84-43df-4efc-8276-52bdb5e2001f
udev.log_priority=3
Desktop: Xfce v: 4.16.1 tk: Gtk v: 3.24.34 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 20KS006EMZ v: ThinkPad E580
Mobo: LENOVO model: 20KS006EMZ v: SDK0J40697 WIN
serial: <superuser required> UEFI: LENOVO v: R0PET71W (1.48 )
date: 07/12/2022
ID-1: BAT0 charge: 38.1 Wh (92.7%) condition: 41.1/45.7 Wh (89.9%)
volts: 12.3 min: 11.1 model: Celxpert 01AV448 type: Li-poly serial: <filter>
status: charging cycles: 90
Device-1: hidpp_battery_0 model: Logitech K520 serial: <filter> charge: 70%
(should be ignored) rechargeable: yes status: discharging
Device-2: hidpp_battery_1 model: Logitech MX Vertical Advanced Ergonomic
Mouse serial: <filter> charge: 55% (should be ignored) rechargeable: yes
status: discharging
RAM: total: 15.4 GiB used: 3.77 GiB (24.5%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: Intel Core i7-8550U bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 level: v3 built: 2017 process: Intel 14nm family: 6
model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xF0
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1518 high: 2000 min/max: 400/4000 scaling:
driver: intel_pstate governor: powersave cores: 1: 700 2: 2000 3: 709 4: 737
5: 2000 6: 2000 7: 2000 8: 2000 bogomips: 32012
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sdbg sep sgx smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
active: DP-3,DP-4,eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
Device-2: AMD Lexa PRO [Radeon 540/540X/550/550X / RX 540X/550/550X]
vendor: Lenovo driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands
process: GF 14nm built: 2016-20 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
link-max: gen: 3 speed: 8 GT/s lanes: 8 bus-ID: 02:00.0 chip-ID: 1002:699f
class-ID: 0380
Device-3: Chicony Integrated Camera (1280x720@30) type: USB
driver: uvcvideo bus-ID: 1-6:4 chip-ID: 04f2:b604 class-ID: 0e02
serial: <filter>
Display: x11 server: X.Org v: 21.1.4 compositor: xfwm v: 4.16.1 driver: X:
loaded: modesetting unloaded: amdgpu alternate: fbdev,vesa gpu: i915
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 5760x1080 s-dpi: 96 s-size: 1524x285mm (60.00x11.22")
s-diag: 1550mm (61.04")
Monitor-1: DP-3 mapped: DP-1-2 pos: center model: LG (GoldStar) E2750
built: 2009 res: 1920x1080 hz: 60 dpi: 96 gamma: 1.2
size: 510x290mm (20.08x11.42") diag: 690mm (27.2") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
Monitor-2: DP-4 mapped: DP-1-3 pos: right model: LG (GoldStar) E2750
Monitor-3: eDP-1 pos: primary,left model: Lenovo 0x40ba built: 2018
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: 1920x1080
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo
driver: snd_hda_intel bus-ID: 1-2.3.3.2:12 v: kernel chip-ID: 17ef:30d1
alternate: snd_soc_skl,snd_soc_avs bus-ID: 00:1f.3 class-ID: 0300
serial: <filter> chip-ID: 8086:9d71 class-ID: 0403
Device-2: Lenovo ThinkPad USB-C Dock Gen2 USB Audio type: USB
driver: hid-generic,snd-usb-audio,usbhid
Sound Server-1: ALSA v: k5.19.7-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.57 running: yes
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: c000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Intel Dual Band Wireless-AC 3165 Plus Bluetooth driver: iwlwifi
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 05:00.0
chip-ID: 8086:3166 class-ID: 0280
IF: wlp5s0 state: up mac: <filter>
Device-3: Lenovo USB-C Dock Ethernet type: USB driver: r8152
bus-ID: 2-2.1:4 chip-ID: 17ef:a387 class-ID: 0000 serial: <filter>
IF: enp0s20f0u2u1 state: up speed: 1000 Mbps duplex: full mac: <filter>
bus-ID: 1-5:9 chip-ID: 8087:0a2a class-ID: e001
Local Storage: total: 1.14 TiB used: 955.11 GiB (81.6%)
model: MZVLB256HAHQ-000L7 size: 238.47 GiB block-size: physical: 512 B
rev: 1L2QEXD7 temp: 34.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS721010A9E630
type: HDD rpm: 7200 serial: <filter> rev: A3J0 scheme: GPT
ID-1: / raw-size: 122.5 GiB size: 120.02 GiB (97.97%) used: 60.37 GiB
(50.3%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7 label: N/A
uuid: cab735ee-bedb-4253-9e43-7acb19317468
ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%) used: 316 KiB
(0.1%) fs: vfat dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
uuid: 8B72-B51E
ID-3: /home raw-size: 833.86 GiB size: 819.69 GiB (98.30%) used: 425.21
GiB (51.9%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 674e9fea-3c1e-4294-89fc-58577a4a5158
ID-4: /home/<filter>/pCloudDrive raw-size: N/A size: 2 TiB used: 469.53
GiB (22.9%) fs: fuse source: ERR-102
ID-1: swap-1 type: partition size: 2 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
uuid: 33f1aa84-43df-4efc-8276-52bdb5e2001f
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 260 MiB fs: vfat label: SYSTEM
uuid: 98B4-F143
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 112.23 GiB fs: bitlocker
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 1000 MiB fs: ntfs
label: WinRE_DRV uuid: 10D6B773D6B75824
ID-5: /dev/sda1 maj-min: 8:1 size: 97.66 GiB fs: ntfs label: Donnees
uuid: 26A5B53F301FFA93
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Hub-2: 1-2:2 info: Lenovo USB2.0 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 17ef:a392 class-ID: 0900
Hub-3: 1-2.2:5 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Hub-4: 1-2.2.4:8 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Hub-5: 1-2.3:7 info: Lenovo USB2.0 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 17ef:a394 class-ID: 0900
Hub-6: 1-2.3.3:10 info: Lenovo USB2.0 Hub ports: 4 rev: 2.0
speed: 480 Mb/s power: 100mA chip-ID: 17ef:a395 class-ID: 0900
Device-1: 1-2.3.3.1:16 info: Lenovo 40AS type: Billboard,HID
power: 100mA chip-ID: 17ef:a38f class-ID: 0300 serial: <filter>
Device-2: 1-2.3.3.2:12 info: Lenovo ThinkPad USB-C Dock Gen2 USB Audio
type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
rev: 2.0 speed: 12 Mb/s power: 30mA chip-ID: 17ef:30d1 class-ID: 0300
serial: <filter>
Device-3: 1-2.3.3.4:13 info: Logitech Unifying Receiver
type: Keyboard,Mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-4: 1-5:9 info: Intel Bluetooth wireless interface type: Bluetooth
Device-5: 1-6:4 info: Chicony Integrated Camera (1280x720@30) type: Video
chip-ID: 04f2:b604 class-ID: 0e02 serial: <filter>
Device-6: 1-8:6 info: Synaptics Metallica MOH Touch Fingerprint Reader
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 06cb:00a2 class-ID: ff00 serial: <filter>
Hub-7: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
Hub-8: 2-2:2 info: Lenovo USB3.1 Hub ports: 4 rev: 3.1 speed: 5 Gb/s
chip-ID: 17ef:a391 class-ID: 0900
Device-1: 2-2.1:4 info: Lenovo USB-C Dock Ethernet type: Network
driver: r8152 interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 288mA
Hub-9: 2-2.3:3 info: Lenovo USB3.1 Hub ports: 4 rev: 3.1 speed: 5 Gb/s
chip-ID: 17ef:a393 class-ID: 0900
System Temperatures: cpu: 56.0 C pch: 48.0 C mobo: N/A gpu: amdgpu
temp: 47.0 C
Fan Speeds (RPM): fan-1: 0 fan-2: 0
Processes: 284 Uptime: 9m wakeups: 23 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.2.0 alt: 11
clang: 14.0.6 Packages: 1986 pm: pacman pkgs: 1976 libs: 515
tools: pamac,yaourt pm: flatpak pkgs: 0 pm: snap pkgs: 10 Shell: Bash
v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.21
sep 14 17:41:33 LAPTOP-Diego bluetoothd[1699]: src/adv_monitor.c:btd_adv_monitor_power_down() Unexpected NULL btd_adv_monitor_manager object upon power down
sep 14 17:41:33 LAPTOP-Diego bluetoothd[1699]: src/device.c:set_wake_allowed_complete() Set device flags return status: Invalid Parameters
sep 14 17:41:33 LAPTOP-Diego bluetoothd[1699]: src/adapter.c:set_device_privacy_complete() Set device flags return status: Invalid Parameters
sep 14 17:41:41 LAPTOP-Diego lightdm[11255]: gkr-pam: unable to locate daemon control file
Hello @Narsil
Please ensure that the lid switch button correctly report close and open:
sudo libinput list-devices
Example (choose another device if needed):
sudo libinput debug-events /dev/input/event0
Close the lid and open it.
Look for “lid switch” or “SWITCH_TOGGLE”
If it is not there. then it is a problem with firmware/UEFI, which is not compatible with the kernel.
Otherwise read this post:
Narsil
3
It does, I go read the suggested post.
[diego@LAPTOP-Diego ~]$ sudo libinput debug-events /dev/input/event1
-event1 DEVICE_ADDED Lid Switch seat0 default group1 cap:S
event1 SWITCH_TOGGLE +0.000s switch lid state 1
event1 SWITCH_TOGGLE +4.882s switch lid state 0
Oh well, then the lid switch should work.
Did you try a suspend or hibernate recently? Go check the logs:
journalctl --list-boots
and chose one by the first number:
Filter for Suspend:
journalctl --boot -1 | sed -n -r "/Starting.+Suspend/,/Finished.+Suspend/p"
Filter for Hibernate:
journalctl --boot -1 | sed -n -r "/Starting.+Hibernate/,/Finished.+Hibernate/p"
Narsil
5
I’don’t understand what I’m doing, but …
journalctl --list-boots (last) :
0 76e09fa79bae44e5a8e94d5492d86a7c Wed 2022-09-14 17:22:59 CEST Thu 2022-09-15 17:42:29 CEST
journalctl --boot -1 | sed -n -r “/Starting.+Suspend/,/Finished.+Suspend/p” (last) :
sep 14 17:22:27 LAPTOP-Diego kernel: Freezing user space processes ... (elapsed 0.003 seconds) done.
sep 14 17:22:27 LAPTOP-Diego kernel: OOM killer disabled.
sep 14 17:22:27 LAPTOP-Diego kernel: Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
sep 14 17:22:27 LAPTOP-Diego kernel: printk: Suspending console(s) (use no_console_suspend to debug)
sep 14 17:22:27 LAPTOP-Diego kernel: sd 0:0:0:0: [sda] Synchronizing SCSI cache
sep 14 17:22:27 LAPTOP-Diego kernel: sd 0:0:0:0: [sda] Stopping disk
sep 14 17:22:27 LAPTOP-Diego kernel: ACPI: EC: interrupt blocked
sep 14 17:22:27 LAPTOP-Diego kernel: amdgpu 0000:02:00.0: amdgpu: PCI CONFIG reset
sep 14 17:22:27 LAPTOP-Diego kernel: ACPI: PM: Preparing to enter system sleep state S3
sep 14 17:22:27 LAPTOP-Diego kernel: ACPI: EC: event blocked
sep 14 17:22:27 LAPTOP-Diego kernel: ACPI: EC: EC stopped
sep 14 17:22:27 LAPTOP-Diego kernel: ACPI: PM: Saving platform NVS memory
sep 14 17:22:27 LAPTOP-Diego kernel: Disabling non-boot CPUs ...
sep 14 17:22:27 LAPTOP-Diego kernel: smpboot: CPU 1 is now offline
sep 14 17:22:27 LAPTOP-Diego kernel: smpboot: CPU 2 is now offline
sep 14 17:22:27 LAPTOP-Diego kernel: smpboot: CPU 3 is now offline
sep 14 17:22:27 LAPTOP-Diego kernel: smpboot: CPU 4 is now offline
sep 14 17:22:27 LAPTOP-Diego kernel: smpboot: CPU 5 is now offline
sep 14 17:22:27 LAPTOP-Diego kernel: smpboot: CPU 6 is now offline
sep 14 17:22:27 LAPTOP-Diego kernel: smpboot: CPU 7 is now offline
sep 14 17:22:27 LAPTOP-Diego kernel: ACPI: PM: Low-level resume complete
sep 14 17:22:27 LAPTOP-Diego kernel: ACPI: EC: EC started
sep 14 17:22:27 LAPTOP-Diego kernel: ACPI: PM: Restoring platform NVS memory
sep 14 17:22:27 LAPTOP-Diego kernel: Enabling non-boot CPUs ...
sep 14 17:22:27 LAPTOP-Diego kernel: x86: Booting SMP configuration:
sep 14 17:22:27 LAPTOP-Diego kernel: smpboot: Booting Node 0 Processor 1 APIC 0x2
sep 14 17:22:27 LAPTOP-Diego kernel: CPU1 is up
sep 14 17:22:27 LAPTOP-Diego kernel: smpboot: Booting Node 0 Processor 2 APIC 0x4
sep 14 17:22:27 LAPTOP-Diego kernel: CPU2 is up
sep 14 17:22:27 LAPTOP-Diego kernel: smpboot: Booting Node 0 Processor 3 APIC 0x6
sep 14 17:22:27 LAPTOP-Diego kernel: CPU3 is up
sep 14 17:22:27 LAPTOP-Diego kernel: smpboot: Booting Node 0 Processor 4 APIC 0x1
sep 14 17:22:27 LAPTOP-Diego kernel: CPU4 is up
sep 14 17:22:27 LAPTOP-Diego kernel: smpboot: Booting Node 0 Processor 5 APIC 0x3
sep 14 17:22:27 LAPTOP-Diego kernel: CPU5 is up
sep 14 17:22:27 LAPTOP-Diego kernel: smpboot: Booting Node 0 Processor 6 APIC 0x5
sep 14 17:22:27 LAPTOP-Diego kernel: CPU6 is up
sep 14 17:22:27 LAPTOP-Diego kernel: smpboot: Booting Node 0 Processor 7 APIC 0x7
sep 14 17:22:27 LAPTOP-Diego kernel: CPU7 is up
sep 14 17:22:27 LAPTOP-Diego kernel: ACPI: PM: Waking up from system sleep state S3
sep 14 17:22:27 LAPTOP-Diego kernel: ACPI: EC: interrupt unblocked
sep 14 17:22:27 LAPTOP-Diego kernel: ACPI: EC: event unblocked
sep 14 17:22:27 LAPTOP-Diego kernel: sd 0:0:0:0: [sda] Starting disk
sep 14 17:22:27 LAPTOP-Diego kernel: iwlwifi 0000:05:00.0: RF_KILL bit toggled to enable radio.
sep 14 17:22:27 LAPTOP-Diego kernel: nvme nvme0: Shutdown timeout set to 8 seconds
sep 14 17:22:27 LAPTOP-Diego kernel: iwlwifi 0000:05:00.0: Applying debug destination EXTERNAL_DRAM
sep 14 17:22:27 LAPTOP-Diego kernel: nvme nvme0: 8/0/0 default/read/poll queues
sep 14 17:22:27 LAPTOP-Diego kernel: [drm] PCIE GART of 256M enabled (table at 0x000000F400000000).
sep 14 17:22:27 LAPTOP-Diego kernel: iwlwifi 0000:05:00.0: FW already configured (0) - re-configuring
sep 14 17:22:27 LAPTOP-Diego kernel: i915 0000:00:02.0: [drm] [ENCODER:94:DDI A/PHY A] is disabled/in DSI mode with an ungated DDI clock, gate it
sep 14 17:22:27 LAPTOP-Diego kernel: i915 0000:00:02.0: [drm] [ENCODER:102:DDI B/PHY B] is disabled/in DSI mode with an ungated DDI clock, gate it
sep 14 17:22:27 LAPTOP-Diego kernel: i915 0000:00:02.0: [drm] [ENCODER:111:DDI C/PHY C] is disabled/in DSI mode with an ungated DDI clock, gate it
sep 14 17:22:27 LAPTOP-Diego kernel: [drm] UVD and UVD ENC initialized successfully.
sep 14 17:22:27 LAPTOP-Diego kernel: usb 2-2: reset SuperSpeed USB device number 2 using xhci_hcd
sep 14 17:22:27 LAPTOP-Diego kernel: [drm] VCE initialized successfully.
sep 14 17:22:27 LAPTOP-Diego kernel: usb 1-5: reset full-speed USB device number 10 using xhci_hcd
sep 14 17:22:27 LAPTOP-Diego kernel: usb 1-6: reset high-speed USB device number 5 using xhci_hcd
sep 14 17:22:27 LAPTOP-Diego kernel: usb 1-2: reset high-speed USB device number 3 using xhci_hcd
sep 14 17:22:27 LAPTOP-Diego kernel: usb 2-2.1: reset SuperSpeed USB device number 4 using xhci_hcd
sep 14 17:22:27 LAPTOP-Diego kernel: r8152 2-2.1:1.0 enp0s20f0u2u1: Invalid header when reading pass-thru MAC addr
sep 14 17:22:27 LAPTOP-Diego kernel: r8152 2-2.1:1.0: skip request firmware
sep 14 17:22:27 LAPTOP-Diego kernel: r8152 2-2.1:1.0: load rtl8153b-2 v1 10/23/19 successfully
sep 14 17:22:27 LAPTOP-Diego kernel: usb 2-2.3: reset SuperSpeed USB device number 3 using xhci_hcd
sep 14 17:22:27 LAPTOP-Diego kernel: usb 1-2.3: reset high-speed USB device number 8 using xhci_hcd
sep 14 17:22:27 LAPTOP-Diego kernel: ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
sep 14 17:22:27 LAPTOP-Diego kernel: ata1.00: ACPI cmd f5/00:00:00:00:00:a0(SECURITY FREEZE LOCK) filtered out
sep 14 17:22:27 LAPTOP-Diego kernel: ata1.00: ACPI cmd ef/10:03:00:00:00:a0(SET FEATURES) filtered out
sep 14 17:22:27 LAPTOP-Diego kernel: ata1.00: configured for UDMA/133
sep 14 17:22:27 LAPTOP-Diego kernel: usb 1-2.2: reset high-speed USB device number 6 using xhci_hcd
sep 14 17:22:27 LAPTOP-Diego kernel: usb 1-2.2.4: reset high-speed USB device number 9 using xhci_hcd
sep 14 17:22:27 LAPTOP-Diego kernel: usb 1-2.3.3: reset high-speed USB device number 11 using xhci_hcd
sep 14 17:22:27 LAPTOP-Diego kernel: usb 1-2.3.3.1: reset full-speed USB device number 44 using xhci_hcd
sep 14 17:22:27 LAPTOP-Diego kernel: usb 1-2.3.3.2: reset full-speed USB device number 13 using xhci_hcd
sep 14 17:22:27 LAPTOP-Diego kernel: usb 1-2.3.3.4: reset full-speed USB device number 14 using xhci_hcd
sep 14 17:22:27 LAPTOP-Diego kernel: OOM killer enabled.
sep 14 17:22:27 LAPTOP-Diego kernel: Restarting tasks ...
sep 14 17:22:27 LAPTOP-Diego kernel: mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
sep 14 17:22:27 LAPTOP-Diego kernel: done.
sep 14 17:22:27 LAPTOP-Diego kernel: audit: type=1334 audit(1663168947.586:965): prog-id=163 op=LOAD
sep 14 17:22:27 LAPTOP-Diego kernel: audit: type=1130 audit(1663168947.590:966): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=shadow comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
sep 14 17:22:27 LAPTOP-Diego kernel: audit: type=1131 audit(1663168947.593:967): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
sep 14 17:22:27 LAPTOP-Diego audit: BPF prog-id=163 op=LOAD
sep 14 17:22:27 LAPTOP-Diego audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=shadow comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
sep 14 17:22:27 LAPTOP-Diego audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
sep 14 17:22:27 LAPTOP-Diego bluetoothd[2368]: Endpoint unregistered: sender=:1.63 path=/MediaEndpoint/A2DPSource/ldac_hq
sep 14 17:22:27 LAPTOP-Diego systemd[1]: Starting Load/Save RF Kill Switch Status...
sep 14 17:22:27 LAPTOP-Diego bluetoothd[2368]: Endpoint unregistered: sender=:1.63 path=/MediaEndpoint/A2DPSource/ldac_sq
sep 14 17:22:27 LAPTOP-Diego systemd[1]: Starting Rotate log files...
sep 14 17:22:27 LAPTOP-Diego bluetoothd[2368]: Endpoint unregistered: sender=:1.63 path=/MediaEndpoint/A2DPSource/ldac_mq
sep 14 17:22:27 LAPTOP-Diego systemd[1]: Started Verify integrity of password and group files.
sep 14 17:22:27 LAPTOP-Diego bluetoothd[2368]: Endpoint unregistered: sender=:1.63 path=/MediaEndpoint/A2DPSink/aptx_hd
sep 14 17:22:27 LAPTOP-Diego systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
sep 14 17:22:27 LAPTOP-Diego bluetoothd[2368]: Endpoint unregistered: sender=:1.63 path=/MediaEndpoint/A2DPSource/aptx_hd
sep 14 17:22:27 LAPTOP-Diego bluetoothd[2368]: Endpoint unregistered: sender=:1.63 path=/MediaEndpoint/A2DPSink/sbc
sep 14 17:22:27 LAPTOP-Diego bluetoothd[2368]: Endpoint unregistered: sender=:1.63 path=/MediaEndpoint/A2DPSource/sbc
sep 14 17:22:27 LAPTOP-Diego bluetoothd[2368]: Endpoint unregistered: sender=:1.63 path=/MediaEndpoint/A2DPSink/sbc_xq_453
sep 14 17:22:27 LAPTOP-Diego bluetoothd[2368]: Endpoint unregistered: sender=:1.63 path=/MediaEndpoint/A2DPSource/sbc_xq_453
sep 14 17:22:27 LAPTOP-Diego bluetoothd[2368]: Endpoint unregistered: sender=:1.63 path=/MediaEndpoint/A2DPSink/sbc_xq_512
sep 14 17:22:27 LAPTOP-Diego bluetoothd[2368]: Endpoint unregistered: sender=:1.63 path=/MediaEndpoint/A2DPSource/sbc_xq_512
sep 14 17:22:27 LAPTOP-Diego bluetoothd[2368]: Endpoint unregistered: sender=:1.63 path=/MediaEndpoint/A2DPSink/sbc_xq_552
sep 14 17:22:27 LAPTOP-Diego bluetoothd[2368]: Endpoint unregistered: sender=:1.63 path=/MediaEndpoint/A2DPSource/sbc_xq_552
sep 14 17:22:27 LAPTOP-Diego systemd[1]: shadow.service: Deactivated successfully.
sep 14 17:22:27 LAPTOP-Diego audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=shadow comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
sep 14 17:22:27 LAPTOP-Diego kernel: audit: type=1131 audit(1663168947.643:968): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=shadow comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
sep 14 17:22:27 LAPTOP-Diego systemd[1]: logrotate.service: Deactivated successfully.
sep 14 17:22:27 LAPTOP-Diego systemd[1]: Finished Rotate log files.
sep 14 17:22:27 LAPTOP-Diego audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=logrotate comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
sep 14 17:22:27 LAPTOP-Diego audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=logrotate comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
sep 14 17:22:27 LAPTOP-Diego systemd-sleep[171414]: System returned from sleep state.
sep 14 17:22:27 LAPTOP-Diego kernel: audit: type=1130 audit(1663168947.666:969): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=logrotate comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
sep 14 17:22:27 LAPTOP-Diego kernel: audit: type=1131 audit(1663168947.666:970): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=logrotate comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
sep 14 17:22:27 LAPTOP-Diego kernel: PM: suspend exit
sep 14 17:22:27 LAPTOP-Diego kernel: Bluetooth: hci0: Legacy ROM 2.5 revision 1.0 build 3 week 17 2014
sep 14 17:22:27 LAPTOP-Diego kernel: Bluetooth: hci0: Intel Bluetooth firmware file: intel/ibt-hw-37.8.10-fw-1.10.3.11.e.bseq
sep 14 17:22:27 LAPTOP-Diego audit: BPF prog-id=0 op=UNLOAD
sep 14 17:22:27 LAPTOP-Diego kernel: audit: type=1334 audit(1663168947.690:971): prog-id=0 op=UNLOAD
sep 14 17:22:27 LAPTOP-Diego tlp[171639]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
sep 14 17:22:27 LAPTOP-Diego tlp[171639]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
sep 14 17:22:27 LAPTOP-Diego kernel: usb 1-8: USB disconnect, device number 38
sep 14 17:22:27 LAPTOP-Diego tlp[171639]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
sep 14 17:22:27 LAPTOP-Diego tlp[171639]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
sep 14 17:22:27 LAPTOP-Diego kernel: usb 1-8: new full-speed USB device number 45 using xhci_hcd
sep 14 17:22:27 LAPTOP-Diego kernel: Bluetooth: hci0: Intel BT fw patch 0x32 completed & activated
sep 14 17:22:28 LAPTOP-Diego kernel: usb 1-8: New USB device found, idVendor=06cb, idProduct=00a2, bcdDevice= 1.64
sep 14 17:22:28 LAPTOP-Diego kernel: usb 1-8: New USB device strings: Mfr=0, Product=0, SerialNumber=1
sep 14 17:22:28 LAPTOP-Diego kernel: usb 1-8: SerialNumber: 7148b486765d
sep 14 17:22:28 LAPTOP-Diego bluetoothd[2368]: src/device.c:device_set_wake_support() Unable to set wake_support without RPA resolution
sep 14 17:22:28 LAPTOP-Diego mtp-probe[171788]: checking bus 1, device 45: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-8"
sep 14 17:22:28 LAPTOP-Diego mtp-probe[171788]: bus: 1, device: 45 was not an MTP device
sep 14 17:22:28 LAPTOP-Diego systemd[3981]: Stopped target Bluetooth.
sep 14 17:22:28 LAPTOP-Diego systemd[1]: Stopped target Bluetooth Support.
sep 14 17:22:28 LAPTOP-Diego bluetoothd[2368]: src/adv_monitor.c:btd_adv_monitor_power_down() Unexpected NULL btd_adv_monitor_manager object upon power down
sep 14 17:22:28 LAPTOP-Diego pulseaudio[4370]: Could not find org.bluez.BatteryProviderManager1.RegisterBatteryProvider(), is bluetoothd started with experimental features enabled (-E flag)?
sep 14 17:22:28 LAPTOP-Diego systemd[3981]: Reached target Bluetooth.
sep 14 17:22:28 LAPTOP-Diego NetworkManager[572]: <info> [1663168948.1143] manager: (A8:9C:ED:9F:AE:F3): new Bluetooth device (/org/freedesktop/NetworkManager/Devices/11)
sep 14 17:22:28 LAPTOP-Diego systemd[1]: Reached target Bluetooth Support.
sep 14 17:22:28 LAPTOP-Diego systemd[1]: Started Load/Save RF Kill Switch Status.
sep 14 17:22:28 LAPTOP-Diego audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
sep 14 17:22:28 LAPTOP-Diego kernel: audit: type=1130 audit(1663168948.120:972): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
sep 14 17:22:28 LAPTOP-Diego bluetoothd[2368]: Endpoint registered: sender=:1.63 path=/MediaEndpoint/A2DPSource/ldac_hq
sep 14 17:22:28 LAPTOP-Diego bluetoothd[2368]: Endpoint registered: sender=:1.63 path=/MediaEndpoint/A2DPSource/ldac_sq
sep 14 17:22:28 LAPTOP-Diego bluetoothd[2368]: Endpoint registered: sender=:1.63 path=/MediaEndpoint/A2DPSource/ldac_mq
sep 14 17:22:28 LAPTOP-Diego bluetoothd[2368]: Endpoint registered: sender=:1.63 path=/MediaEndpoint/A2DPSink/aptx_hd
sep 14 17:22:28 LAPTOP-Diego bluetoothd[2368]: Endpoint registered: sender=:1.63 path=/MediaEndpoint/A2DPSource/aptx_hd
sep 14 17:22:28 LAPTOP-Diego bluetoothd[2368]: Endpoint registered: sender=:1.63 path=/MediaEndpoint/A2DPSink/sbc
sep 14 17:22:28 LAPTOP-Diego bluetoothd[2368]: Endpoint registered: sender=:1.63 path=/MediaEndpoint/A2DPSource/sbc
sep 14 17:22:28 LAPTOP-Diego bluetoothd[2368]: Endpoint registered: sender=:1.63 path=/MediaEndpoint/A2DPSink/sbc_xq_453
sep 14 17:22:28 LAPTOP-Diego bluetoothd[2368]: Endpoint registered: sender=:1.63 path=/MediaEndpoint/A2DPSource/sbc_xq_453
sep 14 17:22:28 LAPTOP-Diego bluetoothd[2368]: Endpoint registered: sender=:1.63 path=/MediaEndpoint/A2DPSink/sbc_xq_512
sep 14 17:22:28 LAPTOP-Diego bluetoothd[2368]: Endpoint registered: sender=:1.63 path=/MediaEndpoint/A2DPSource/sbc_xq_512
sep 14 17:22:28 LAPTOP-Diego bluetoothd[2368]: Endpoint registered: sender=:1.63 path=/MediaEndpoint/A2DPSink/sbc_xq_552
sep 14 17:22:28 LAPTOP-Diego bluetoothd[2368]: Endpoint registered: sender=:1.63 path=/MediaEndpoint/A2DPSource/sbc_xq_552
sep 14 17:22:28 LAPTOP-Diego baloo_file_extractor[5578]: kf.baloo: "/home/diego/pCloudDrive/Documents/Job/Recherches/2000/Quark.doc" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
sep 14 17:22:28 LAPTOP-Diego dbus-daemon[558]: [system] Activating via systemd: service name='org.blueman.Mechanism' unit='blueman-mechanism.service' requested by ':1.76' (uid=1000 pid=4499 comm="/usr/bin/python /usr/bin/blueman-applet")
sep 14 17:22:28 LAPTOP-Diego systemd[1]: Starting Bluetooth management mechanism...
sep 14 17:22:28 LAPTOP-Diego bluetoothd[2368]: src/device.c:set_wake_allowed_complete() Set device flags return status: Invalid Parameters
sep 14 17:22:28 LAPTOP-Diego bluetoothd[2368]: src/adapter.c:set_device_privacy_complete() Set device flags return status: Invalid Parameters
sep 14 17:22:28 LAPTOP-Diego systemd[1]: systemd-suspend.service: Deactivated successfully.
sep 14 17:22:28 LAPTOP-Diego systemd[1]: Finished System Suspend.
@Narsil
That’s the problem:
It started suspending, but the ACPI, so your UEFI firmware says: “No” and it wakes up again.
So only way to solves this is the updating the firmware or toggle settings at the UEFI. I personally see no other way.
Maybe only set a custom OSI. Here is pretty good tutorial: https://discovery.endeavouros.com/acpi-kernel-parameters/acpi-kernel-parameters-and-how-to-choose-them/2021/03/
