Please teach me reason and where to fix the problem.
KDE Plasma desktop computer (kernel 5.4 & kernel 5.10), runs skype everytime when start up; even when i have shutdown skype before reboot!
This happened all the time.
Why it stuck at “must run skype” at start up even i already shutdown the skype before shutdown ? Which folder and file in it dictate that behaviour ?
You start your Desktop with the previous Windows / Prowgramms
System-Settings-> Startup and Shutdown-> Work Surface Session-> previews start with…
You can try to start with empty Desktop. Starting with empty Deskop enviromental also speed up your boot time.
You need to click “Save Session” (afterfully exiting Skype) before you logout, reboot, or shutdown, otherwise it will keep using your previous session’s settings.
UPDATE: Skype cannot even be in the tray nor background when you do the above steps.
Can you please show me where is the “save session” button ? i only saw “start with an empty session” dial button (under system settings> startup and shutdown> desktop session.
Your menu is different than mine. (You might be using the latest KDE default menu launcher.)
You can try with a different menu (such as Legacy Application Launcher), or simply choose and apply the option to “Start with an empty session” under your Desktop Session settings window (shown in your screenshot.)
