Since the 06-24 testing update and switching to linux63 6.3.9 I have a problem with my notebooks internal display. Its resolution is 3840x2160 but I usually run it with 1920x1080 and 100% scaling, because my secondary display also runs with 100% scaling and so I can prevent scaling issues. When running 3840x2160 on the internal display I use 200% scaling.
linux63 6.3.10 still has the issue, so I downgraded to 6.3.8 for now.
My system specs:
inxi -v7azy
Kernel: 6.3.8-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.3-x86_64
root=UUID=b561ecdc-46e9-46aa-b927-c527ce0053c7 rw rootflags=subvol=@ quiet
cryptdevice=UUID=25185331-5a84-4561-ac17-badc6735198f:luks-25185331-5a84-4561-ac17-badc6735198f
root=/dev/mapper/luks-25185331-5a84-4561-ac17-badc6735198f splash
apparmor=1 security=apparmor udev.log_priority=3 amd_pstate=passive
Desktop: GNOME v: 44.2 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 44.1
Type: Laptop System: LENOVO product: 21A00004GE v: ThinkPad P14s Gen 2a
Mobo: LENOVO model: 21A00004GE v: SDK0J40697 WIN
serial: <superuser required> UEFI: LENOVO v: R1MET53W (1.23 )
date: 02/23/2023
ID-1: BAT0 charge: 47.5 Wh (100.0%) condition: 47.5/50.5 Wh (94.1%)
volts: 12.9 min: 11.5 model: SMP 5B10W51827 type: Li-poly serial: <filter>
status: full cycles: 52
Device-1: hidpp_battery_0 model: Logitech Wireless Gaming Mouse
serial: <filter> charge: 5% (should be ignored) rechargeable: yes
status: discharging
System RAM: available: 29.2 GiB used: 6.32 GiB (21.6%)
Info: model: AMD Ryzen 7 PRO 5850U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
microcode: 0xA50000D
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB
desc: 1x16 MiB
Speed (MHz): avg: 1742 high: 4507 min/max: 400/4507 boost: enabled scaling:
driver: amd-pstate governor: schedutil cores: 1: 4507 2: 1113 3: 1113 4: 1113
5: 1113 6: 1113 7: 1113 8: 1113 9: 1113 10: 1113 11: 1547 12: 1113 13: 3530
14: 4507 15: 1546 16: 1113 bogomips: 60712
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Cezanne [Radeon Vega Series / Radeon Mobile Series]
vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5 code: Vega
process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s ports: active: DP-2,eDP-1
empty: DP-1,HDMI-A-1 bus-ID: 07:00.0 chip-ID: 1002:1638 class-ID: 0300
temp: 47.0 C
Device-2: IMC Networks Integrated Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:2 chip-ID: 13d3:5406
Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.2
compositor: gnome-shell driver: X: loaded: amdgpu
gpu: amdgpu display-ID: 0
Monitor-1: DP-2 model: LG (GoldStar) Ultra HD serial: <filter> built: 2018
res: 3840x2160 dpi: 163 gamma: 1.2 size: 600x340mm (23.62x13.39")
diag: 690mm (27.2") ratio: 16:9 modes: max: 3840x2160 min: 640x480
Monitor-2: eDP-1 model-id: CSO 0x1407 built: 2020 res: 3840x2160 dpi: 316
gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14") ratio: 16:9 modes:
API: OpenGL v: 4.6 Mesa 23.1.3 renderer: AMD Radeon Graphics (renoir LLVM
15.0.7 DRM 3.52 6.3.8-1-MANJARO) direct-render: Yes
Device-1: AMD Renoir Radeon High Definition Audio vendor: Lenovo
link-max: gen: 4 speed: 16 GT/s bus-ID: 07:00.1 chip-ID: 1002:1637
class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x, snd_pci_acp5x,
snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
snd_sof_amd_renoir, snd_sof_amd_rembrandt pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 07:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 07:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: Generalplus USB Audio Device
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 5-2.4.3:9 chip-ID: 1b3f:2008 class-ID: 0300
API: ALSA v: k6.3.8-1-MANJARO status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.71 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 4000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp2s0f0 state: down mac: <filter>
Device-2: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter
vendor: Lenovo driver: rtw89_8852ae v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8852 class-ID: 0280
IP v6: <filter> type: noprefixroute scope: global
Device-3: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
port: 2000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Message: Output throttled. IPs: 3; Limit: 10; Override: --limit [1-x;-1
all]
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-4:7 chip-ID: 0bda:4852
Report: bt-adapter ID: hci0 rfk-id: 1 state: up address: <filter>
Device-1: luks-25185331-5a84-4561-ac17-badc6735198f maj-min: 254:0
type: LUKS dm: dm-0 size: 854.65 GiB
Components:
p-1: nvme0n1p5 maj-min: 259:5 size: 854.65 GiB
Local Storage: total: 1013.62 GiB used: 492.92 GiB (48.6%)
ID-1: /dev/mmcblk0 maj-min: 179:0 model: N/A size: 59.75 GiB block-size:
physical: 512 B logical: 512 B tech: SSD serial: <filter> scheme: MBR
ID-2: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFS001TDE9X081N
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 41730C20 temp: 49.9 C
scheme: GPT
ID-1: / raw-size: 854.65 GiB size: 854.65 GiB (100.00%)
used: 433.75 GiB (50.8%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-25185331-5a84-4561-ac17-badc6735198f label: N/A
uuid: b561ecdc-46e9-46aa-b927-c527ce0053c7
ID-2: /boot/efi raw-size: 1000 MiB size: 998 MiB (99.80%)
used: 33.4 MiB (3.3%) fs: vfat dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
uuid: 9012-51C1
ID-3: /home raw-size: 854.65 GiB size: 854.65 GiB (100.00%)
ID-4: /run/media/timo/4A91-64AA raw-size: 59.73 GiB
size: 59.73 GiB (99.99%) used: 59.14 GiB (99.0%) fs: exfat
dev: /dev/mmcblk0p1 maj-min: 179:1 label: N/A uuid: 4A91-64AA
ID-5: /var/cache raw-size: 854.65 GiB size: 854.65 GiB (100.00%)
ID-6: /var/log raw-size: 854.65 GiB size: 854.65 GiB (100.00%)
Kernel: swappiness: 1 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: zram size: 467.2 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram0
ID-2: swap-2 type: zram size: 467.2 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram1
ID-3: swap-3 type: zram size: 467.2 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram2
ID-4: swap-4 type: zram size: 467.2 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram3
ID-5: swap-5 type: zram size: 467.2 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram4
ID-6: swap-6 type: zram size: 467.2 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram5
ID-7: swap-7 type: zram size: 467.2 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram6
ID-8: swap-8 type: zram size: 467.2 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram7
ID-9: swap-9 type: zram size: 467.2 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram8
ID-10: swap-10 type: zram size: 467.2 MiB used: 0 KiB (0.0%)
priority: 32767 dev: /dev/zram9
ID-11: swap-11 type: zram size: 467.2 MiB used: 0 KiB (0.0%)
priority: 32767 dev: /dev/zram10
ID-12: swap-12 type: zram size: 467.2 MiB used: 0 KiB (0.0%)
priority: 32767 dev: /dev/zram11
ID-13: swap-13 type: zram size: 467.2 MiB used: 0 KiB (0.0%)
priority: 32767 dev: /dev/zram12
ID-14: swap-14 type: zram size: 467.2 MiB used: 0 KiB (0.0%)
priority: 32767 dev: /dev/zram13
ID-15: swap-15 type: zram size: 467.2 MiB used: 0 KiB (0.0%)
priority: 32767 dev: /dev/zram14
ID-16: swap-16 type: zram size: 467.2 MiB used: 0 KiB (0.0%)
priority: 32767 dev: /dev/zram15
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 260 MiB fs: vfat label: SYSTEM
uuid: 80F5-AAEB
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 97 GiB fs: ntfs label: Windows
uuid: DE8AF85B8AF8321F
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 1000 MiB fs: ntfs
label: WinRE_DRV uuid: 3E06F91A06F8D43D
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 1-2:2 info: IMC Networks Integrated Camera type: video
driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 13d3:5406 class-ID: fe01 serial: <filter>
Hub-2: 2-0:1 info: super-speed hub ports: 2 rev: 3.0
Device-1: 3-3:2 info: Alcor Micro AU9540 Smartcard Reader type: smart card
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 50mA chip-ID: 058f:9540 class-ID: 0b00
Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Hub-6: 5-1:2 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5411
Device-1: 5-1.1:4 info: Realtek BillBoard Device type: billboard
mode: 1.1 chip-ID: 0bda:5400 class-ID: 1100 serial: <filter>
Hub-7: 5-2:3 info: Realtek RTS5411 Hub ports: 5 rev: 2.1
Device-1: 5-2.3:6 info: Logitech Cordless Mouse Receiver type: mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0
chip-ID: 046d:c537 class-ID: 0300
Hub-8: 5-2.4:8 info: Terminus USB 2.0 Hub ports: 4 rev: 2.0
chip-ID: 1a40:0801 class-ID: 0900
Device-1: 5-2.4.3:9 info: Generalplus USB Audio Device type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
Device-2: 5-2.4.4:10 info: Logitech G213 Prodigy Gaming Keyboard
type: keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
chip-ID: 046d:c336 class-ID: 0300 serial: <filter>
Device-3: 5-3:5 info: Synaptics Prometheus MIS Touch Fingerprint Reader
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0
chip-ID: 06cb:00bd class-ID: ff00 serial: <filter>
Device-4: 5-4:7 info: Realtek Bluetooth Radio type: bluetooth driver: btusb
interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 500mA chip-ID: 0bda:4852 class-ID: e001 serial: <filter>
Hub-9: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
System Temperatures: cpu: 59.0 C mobo: N/A gpu: amdgpu temp: 48.0 C
Fan Speeds (RPM): fan-1: 3300 fan-2: 3300
Processes: 475 Uptime: 3m wakeups: 4 Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: 1658
pm: pacman pkgs: 1650 libs: 388 tools: gnome-software,pamac,yay pm: flatpak
pkgs: 8 Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.27
I suspect this commit to be responsible:
commit edcfed8671ee57bb599184f2e12a1b3e11b32306
Author: Hersen Wu <hersenxs.wu@amd.com>
Date: Thu May 25 08:37:40 2023 -0400
drm/amd/display: edp do not add non-edid timings
commit e749dd10e5f292061ad63d2b030194bf7d7d452c upstream.
[Why] most edp support only timings from edid. applying
non-edid timings, especially those timings out of edp
bandwidth, may damage edp.
[How] do not add non-edid timings for edp.
Cc: Mario Limonciello <mario.limonciello@amd.com>
Cc: Alex Deucher <alexander.deucher@amd.com>
Cc: stable@vger.kernel.org
Acked-by: Stylon Wang <stylon.wang@amd.com>
Signed-off-by: Hersen Wu <hersenxs.wu@amd.com>
Reviewed-by: Roman Li <roman.li@amd.com>
Tested-by: Daniel Wheeler <daniel.wheeler@amd.com>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
