EDIT: To be clear I’m just asking for help regarding that error and not how to create and enable swap.
I tried to follow this guide initially but I was running into issues.
https://wiki.manjaro.org/index.php/Swap#How_Much_Swap_do_I_Need
So I watched a couple youtube videos and kinda mixed and matched. I think the youtube videos were kinda dated on how you go about it, since I even copied the commands and made sure they match the video with no typos. Ultimately I went back to the above link and realised that I missed a step, which is why it initially wasn’t working. I managed to get it working just fine, but I’m thinking some of the stuff I tried doing before that is what may be causing the errors.
After sitting at that initial error on startup, then it shows a few more errors and then boots up. The following errors are:
[ TIME ] Timed out waiting for device /dev/disk/by-uuid/long serial
[DEPEND] Dependency failed for /dev/disk/by-uuid/same serial
[DEPEND] Dependency failed for Swap.
[ TIME ] Timed out waiting for device /dev/disk/by-uuid.
[DEPEND] Dependency failed for /dev/disk/by-uuid.
Once the computer finally boots up things seem to be running just fine, but obviously I’d like to fix this issue, because the bootup so much slower now, and even though I’m not noticing issues when I’m back on, I’m sure there’ll be some sort of problem in the background affecting the system. Also I haven’t actually done anything but using the internet since the issue, so it’s very probable that I will eventually run into issues.
I don’t know how great this command really is, but when I type sudo systemctl --failed in the terminal it says there are no errors found.
UNIT LOAD ACTIVE SUB DESCRIPTION
0 loaded units listed.
I’m still new to linux, so if you need more information that requires terminal commands, just let me know what they are. I know basic commands but need to look things up very often.
