Hola , tengo problemas con sonido luego de una nueva y limpia instalación, algún consejo de como solucionarlo. Muchas gracias
Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=0fb091fc-3271-483e-818a-5dc21ccbd08d rw quiet apparmor=1
security=apparmor resume=UUID=e4ab7b14-ec9e-4155-b5eb-28717df67c17
udev.log_priority=3
Desktop: KDE Plasma 5.23.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Dell product: Latitude 3420 v: N/A
serial: Chassis: type: 10 serial:
Mobo: Dell model: 0KMD3M v: A00 serial: UEFI: Dell
v: 1.3.1 date: 04/23/2021
ID-1: BAT0 charge: 23.7 Wh (58.1%) condition: 40.8/40.8 Wh (100.0%)
volts: 11.6 min: 11.2 model: SMP DELL MGCM514 type: Li-poly serial:
status: Discharging
Device-1: hidpp_battery_0 model: Logitech M350 Wireless Mouse
serial: charge: 100% (should be ignored) rechargeable: yes
status: Discharging
RAM: total: 3.59 GiB used: 1.96 GiB (54.5%)
Info: Quad Core model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
arch: Tiger Lake family: 6 model-id: 8C (140) stepping: 1 microcode: 88
cache: L1: 320 KiB L2: 5 MiB L3: 8 MiB bogomips: 22120
Speed: 979 MHz min/max: 400/4200 MHz Core speeds (MHz): 1: 1200 2: 1132
3: 894 4: 1214 5: 1172 6: 879 7: 838 8: 1267
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2 avx512_vnni
avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f
avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2 cdp_l2 clflush
clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl
dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma
fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp hwp_notify
hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt invpcid invpcid_single
lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b movdiri msr mtrr
nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge
pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdt_a rdtscp rep_good
sdbg sep sha_ni smap smep split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
tsc_known_freq umip vaes vme vmx vnmi vpclmulqdq vpid x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Dell
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:9a49 class-ID: 0300
Device-2: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 3-6:3 chip-ID: 0c45:6d1a class-ID: 0e02
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver:
loaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP-1 res: 1366x768 hz: 60 dpi: 112 size: 309x173mm (12.2x6.8")
diag: 354mm (13.9")
OpenGL: renderer: Mesa Intel Xe Graphics (TGL GT2) v: 4.6 Mesa 21.2.5
direct render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Dell
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:a0c8 class-ID: 0401
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: yes
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:a0f0 class-ID: 0280
IF: wlp0s20f3 state: up mac:
IP v4: type: dynamic noprefixroute scope: global
broadcast:
IP v6: type: noprefixroute scope: link
vendor: Dell driver: r8169 v: kernel port: 3000 bus-ID: 2c:00.0
IF: enp44s0 state: down mac:
WAN IP:
bus-ID: 3-10:4 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 1.36 TiB used: 12.46 GiB (0.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNVS500G
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: rev: EDFK0N01 temp: 36.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
type: HDD rpm: 5400 serial: rev: 01 scheme: GPT
ID-1: / raw-size: 78.12 GiB size: 76.35 GiB (97.73%) used: 11.54 GiB (15.1%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 0fb091fc-3271-483e-818a-5dc21ccbd08d
ID-2: /boot/efi raw-size: 301 MiB size: 300.4 MiB (99.79%)
label: NO_LABEL uuid: 1C6D-8153
ID-3: /home raw-size: 381.48 GiB size: 374.43 GiB (98.15%)
used: 944.9 MiB (0.2%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
label: N/A uuid: ae4fdda7-02c7-4b07-847d-0ca5d01636a3
ID-1: swap-1 type: partition size: 5.86 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: e4ab7b14-ec9e-4155-b5eb-28717df67c17
ID-1: /dev/sda1 maj-min: 8:1 size: 775 MiB fs: vfat label: ESP
uuid: C4B6-760E
ID-2: /dev/sda2 maj-min: 8:2 size: 8 GiB fs: vfat label: OS uuid: 4EC5-305C
ID-3: /dev/sda3 maj-min: 8:3 size: 922.75 GiB fs: ext4 label: UBUNTU
uuid: 4d206231-9394-4aa9-a6be-d286aeb59da5
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-4:2 info: Logitech Unifying Receiver type: Mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 98mA chip-ID: 046d:c52f class-ID: 0300
Device-2: 3-6:3 info: Microdia Integrated_Webcam_HD type: Video
Device-3: 3-10:4 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
class-ID: e001
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 32.0 C mobo: N/A
Processes: 258 Uptime: 30m wakeups: 1153 Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1256 lib: 336
flatpak: 0 Shell: Zsh v: 5.8 default: Bash v: 5.1.8 running-in: konsole
inxi: 3.3.09
