Basicamente ayer tenia audio y hoy no, normalmente con cambiar el perfil de audio (perfiles que ya no me salen) o conectar y desconectar audifonos se soluciona pero hoy ni eso.
He leido por ahi que para ayudarme necesitan esta información que me lanza inxi -Fxxxzm
Kernel: 5.9.16-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 10.2.0
Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.6 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Dell product: Inspiron 5559 v: N/A
Mobo: Dell model: 06CMH7 v: A00 serial: <superuser required> UEFI: Dell
v: 1.3.0 date: 07/17/2017
RAM: total: 15.53 GiB used: 3.38 GiB (21.8%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: dual core model: Intel Core i5-6200U bits: 64 type: MT MCP
smt: enabled arch: Skylake rev: 3 cache: L1: 128 KiB L2: 512 KiB L3: 3 MiB
Speed (MHz): avg: 500 min/max: 400/2800 cores: 1: 500 2: 500 3: 500
4: 500 bogomips: 19204
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Dell driver: i915
v: kernel arch: Gen-9 ports: active: HDMI-A-1,eDP-1 empty: none
bus-ID: 00:02.0 chip-ID: 8086:1916 class-ID: 0300
Device-2: Suyin Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-5:6 chip-ID: 064e:920b class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915
display-ID: :0 screens: 1
Screen-1: 0 s-res: 3286x1128 s-dpi: 96 s-size: 867x297mm (34.13x11.69")
s-diag: 916mm (36.08")
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: primary,top-left model: HP 25xi
serial: <filter> res: 1920x1080 hz: 60 dpi: 88
size: 553x311mm (21.77x12.24") diag: 634mm (25") modes: max: 1920x1080
min: 720x400
Monitor-2: eDP-1 pos: bottom-r model: BOE Display 0x0615 res: 1366x768
hz: 60 dpi: 112 size: 309x173mm (12.17x6.81") diag: 389mm (15.3")
modes: 1366x768
OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 22.1.7
direct render: Yes
Message: No device data found.
Sound Server-3: PipeWire v: 0.3.58 running: yes
Device-1: Intel Wireless 3160 driver: iwlwifi v: kernel pcie:
speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:08b3 class-ID: 0280
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
driver: r8169 v: kernel pcie: speed: 2.5 GT/s lanes: 1 port: e000
bus-ID: 02:00.0 chip-ID: 10ec:8136 class-ID: 0200
bus-ID: 1-8:8 chip-ID: 8087:07dc class-ID: e001
Local Storage: total: 1.2 TiB used: 243.23 GiB (19.8%)
ID-1: /dev/sda vendor: Seagate model: ST9320423AS size: 298.09 GiB
speed: 3.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: SDM1 scheme: GPT
ID-2: /dev/sdb type: USB vendor: Toshiba model: MQ04ABF100
size: 931.51 GiB type: HDD rpm: 5400 serial: <filter> rev: 1101 scheme: MBR
ID-1: / size: 275.3 GiB used: 243.23 GiB (88.4%) fs: ext4 dev: /dev/sda2
ID-2: /boot/efi size: 299.4 MiB used: 328 KiB (0.1%) fs: vfat
dev: /dev/sda1
ID-1: swap-1 type: partition size: 17.09 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda3
System Temperatures: cpu: 51.0 C mobo: 41.0 C sodimm: SODIMM C
Fan Speeds (RPM): cpu: 0
Processes: 225 Uptime: 10m wakeups: 1 Init: systemd v: 251
default: graphical Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1516
pm: pacman pkgs: 1495 pm: flatpak pkgs: 11 pm: snap pkgs: 10 Shell: Zsh
v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.22
