Why SimpleScreenRecorder can’t record clearly when compositor
rendering backend : openGL 3.1/2.0
is enable? but it works fine on XRender
There are 1000s of applications in the Manjaro repository and we don’t manage all of the, we just pull them from “Upstream”.
You’d be better off going here to ask a question like that.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or or
if you agree)
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
