Reyyan
September 24, 2022, 9:44am
1
Any sort of screen recorder wont work as of last month. I was working fine but now its just stuck at 2 still frames but the cursor is being recorded properly. i dont know the reason for this happening so i came here to find a solution. I am kinda new to linux
Heres a gif of the video recording:
(I am trying to move the simplescreen recorder window here and minimizing dolphin)
Just a guess, you are on Wayland Session. Try X11 instead.
Anyway, more information about your system is required, share it as described in [HowTo] Receive better support
Reyyan
September 24, 2022, 9:59am
3
I am using X11. Here is the info about my system:
Kernel: 5.18.16-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-linux-zen
root=UUID=d5f62ce4-c66c-4d67-b50e-44daba642345 rw
i915.enable_dpcd_backlight=0 quiet
resume=UUID=cb4185d1-f25c-458e-81e6-6d14df23566b udev.log_priority=3
Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5 info: latte-dock
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Portable System: Dell product: Inspiron N5010 v: A02
serial: <superuser required>
Mobo: Dell model: 0WXY9J v: A02 serial: <superuser required>
UEFI-[Legacy]: Dell v: A02 date: 04/09/2010
ID-1: BAT0 charge: 1.3 Wh (100.0%) condition: 1.3/48.8 Wh (2.6%) volts: 11.1
min: 11.1 model: Samsung DELL 7XFJJ05 type: Li-ion serial: <filter>
status: full
RAM: total: 3.64 GiB used: 2.8 GiB (76.9%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: Intel Core i3 M 350 bits: 64 type: MT MCP arch: Westmere
gen: core 1 level: v2 built: 2010-11 process: Intel 32nm family: 6
model-id: 0x25 (37) stepping: 2 microcode: 0x11
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1151 high: 1290 min/max: 931/2261 scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 1199 2: 1045 3: 1290
4: 1070 bogomips: 18087
Flags: acpi aperfmperf apic arat arch_perfmon bts clflush cmov
constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts ept est
flexpriority flush_l1d fpu fxsr ht ibpb ibrs lahf_lm lm mca mce mmx
monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pdcm pebs pge pni popcnt
pse pse36 pti rdtscp rep_good sep ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
syscall tm tm2 tpr_shadow tsc vme vmx vnmi vpid xtopology xtpr
vulnerable
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
SMT vulnerable
Device-1: Intel Core Processor Integrated Graphics vendor: Dell driver: i915
v: kernel arch: Gen-5.75 process: Intel 45nm built: 2010 ports:
active: LVDS-1 empty: DP-1,HDMI-A-1,VGA-1 bus-ID: 00:02.0
chip-ID: 8086:0046 class-ID: 0300
Device-2: Microdia Laptop_Integrated_Webcam_1.3M type: USB
driver: uvcvideo bus-ID: 1-1.6:4 chip-ID: 0c45:6461 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.3
compositor: kwin_x11 driver: X: loaded: intel gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: LVDS-1 mapped: LVDS1 model: Seiko Epson 0x5441 built: 2009
res: 1366x768 hz: 60 dpi: 102 gamma: 1.2 size: 340x190mm (13.39x7.48")
diag: 395mm (15.5") ratio: 16:9 modes: 1366x768
OpenGL: renderer: Mesa Intel HD Graphics (ILK) v: 2.1 Mesa 22.1.6
direct render: Yes
Device-1: Intel 5 Series/3400 Series High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:3b56
class-ID: 0403
Sound Server-1: ALSA v: k5.18.16-zen1-1-zen running: yes
Sound Server-2: PulseAudio v: 16.1 running: no
Sound Server-3: PipeWire v: 0.3.56 running: yes
Device-1: Broadcom BCM4313 802.11bgn Wireless Network Adapter vendor: Dell
Inspiron M5010 / XPS 8300 driver: bcma-pci-bridge v: N/A modules: bcma
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 12:00.0 chip-ID: 14e4:4727
class-ID: 0280
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000
bus-ID: 13:00.0 chip-ID: 10ec:8136 class-ID: 0200
IF: enp19s0 state: down mac: <filter>
IF-ID-1: wlp18s0b1 state: up mac: <filter>
Local Storage: total: 298.09 GiB used: 164.02 GiB (55.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: HN-M320MBB
size: 298.09 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 5400 serial: <filter> rev: 0001 scheme: MBR
Optical-1: /dev/sr0 vendor: PLDS model: DVD+-RW DS-8A4S rev: JD12
dev-links: cdrom
ID-1: / raw-size: 48.57 GiB size: 47.5 GiB (97.81%) used: 29.28 GiB (61.6%)
fs: ext4 dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: d5f62ce4-c66c-4d67-b50e-44daba642345
ID-2: /run/media/reyyan/A8E0256AE0254044 raw-size: 63 MiB size: 63 MiB
(99.99%) used: 23 MiB (36.4%) fs: ntfs dev: /dev/sda1 maj-min: 8:1
label: N/A uuid: A8E0256AE0254044
ID-3: /run/media/reyyan/APP&DOWNLOADS raw-size: 35.17 GiB size: 35.17 GiB
(100.00%) used: 22.1 GiB (62.8%) fs: ntfs dev: /dev/sda3 maj-min: 8:3
label: APP&DOWNLOADS uuid: 01D8A764F0621E80
ID-4: /run/media/reyyan/General raw-size: 87.74 GiB size: 87.74 GiB
(100.00%) used: 47.44 GiB (54.1%) fs: ntfs dev: /dev/sda6 maj-min: 8:6
label: General uuid: 01D88EC83BE9A180
ID-5: /run/media/reyyan/Media raw-size: 30 GiB size: 30 GiB (100.00%)
used: 12.6 GiB (42.0%) fs: ntfs dev: /dev/sda7 maj-min: 8:7 label: Media
uuid: 01D88EC27942F320
ID-6: /run/media/reyyan/Windows raw-size: 92.56 GiB size: 92.56 GiB
(100.00%) used: 52.41 GiB (56.6%) fs: ntfs dev: /dev/sda2 maj-min: 8:2
label: Windows uuid: 01D88ECDED7705F0
ID-1: swap-1 type: file size: 512 MiB used: 511.8 MiB (100.0%)
priority: -2 file: /swapfile
ID-2: swap-2 type: partition size: 4 GiB used: 187.7 MiB (4.6%)
priority: -3 dev: /dev/sda8 maj-min: 8:8 label: N/A
uuid: cb4185d1-f25c-458e-81e6-6d14df23566b
ID-1: /dev/sda4 maj-min: 8:4 size: 1 KiB fs: <superuser required> label: N/A
uuid: N/A
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
speed: 480 Mb/s chip-ID: 8087:0020 class-ID: 0900
Device-1: 1-1.1:3 info: USB OPTICAL MOUSE type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
power: 100mA chip-ID: 30fa:0400 class-ID: 0301
Device-2: 1-1.6:4 info: Microdia Laptop_Integrated_Webcam_1.3M type: Video
Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Hub-5: 2-1.6:3 info: Broadcom BCM2046B1 USB 2.0 Hub (part of BCM2046
Bluetooth) ports: 3 rev: 2.0 speed: 12 Mb/s power: 94mA chip-ID: 0a5c:4500
Device-1: 2-1.6.1:4 info: Dell Integrated Keyboard type: Keyboard
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 2mA
chip-ID: 413c:8161 class-ID: 0301
Device-2: 2-1.6.2:5 info: Dell Integrated Touchpad [Synaptics] type: Mouse
chip-ID: 413c:8162 class-ID: 0301
System Temperatures: cpu: 56.0 C mobo: N/A
Fan Speeds (RPM): fan-1: 3320
Processes: 210 Uptime: 47m wakeups: 1 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.1 clang: 14.0.6
Packages: 1518 pm: pacman pkgs: 1516 libs: 440 tools: pamac,yay pm: flatpak
pkgs: 0 pm: snap pkgs: 2 Shell: Zsh v: 5.9 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.21
Reyyan:
But you managed to install the zen kernel …
Reyyan:
5.18.16-zen1-1-zen
Any reason why not using Manjaro kernels, or did you try them?
Reyyan
September 24, 2022, 11:52am
5
Well i did say kinda. I just followed a youtube tutorial
i was using the manjaro kernal but i heard that the zen kernal is faster so i tried it out and now im using it.
I switched to the manjaro kernal and the problem still persists
