Hi Everyone,
I was a little hesitant at first to post this, because this is based off of somebody else’s work, and for the life of me, I forgot from what website I got it ─ it was one of the hundreds if not thousands of wallpaper sites on the internet ─ not to mention that I don’t even know the name of the artist who created the original.
I am not going to post the original ─ I don’t know whether I have the permission to do so ─ but I’ll just say that the original was in turquoise colors, with a dark grey textured area. And it looked nice ─ quite Manjaro-like, even ─ but I was thinking that it would look better if it were blue, and so I started modifying it in GIMP , and this is the result.
Below are a couple of screenshots of how it looks against a Konsole window and a Dolphin window on my Plasma desktop…
And here’s the wallpaper itself ─ it is 1920 by 1080 pixels. Hope you like it.
I’ve just seen that the embedded image is only 960 x 540 pixels, so here’s the link to the 1920 x 1080 version.
Lunix
26 October 2020 11:39
2
It’s a nice clean wallpaper. And I like it.
I can only take credit for the colors, though. The design was someone else’s.
Ah, I found the site with the original ─ here it is.
Lunix
26 October 2020 14:01
4
“I can only take credit for the colors”
The colors are the only thing that matters
it’s a a shame to not offer it in svg
I’ve uploaded it to Telegram in a PM with you as an .svg ─ it’s 1.5 MiB in size.
My test is : 5ko !
only a speed test with bad colors
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<svg
xmlns:dc="http://purl.org/dc/elements/1.1/"
xmlns:cc="http://creativecommons.org/ns#"
xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"
xmlns:svg="http://www.w3.org/2000/svg"
xmlns="http://www.w3.org/2000/svg"
xmlns:sodipodi="http://sodipodi.sourceforge.net/DTD/sodipodi-0.dtd"
xmlns:inkscape="http://www.inkscape.org/namespaces/inkscape"
version="1.1"
id="svg2"
width="1920"
height="1080"
viewBox="0 0 1920 1080"
sodipodi:docname="geometry-1603729647794-2827.svg"
inkscape:version="1.0.1 (3bc2e813f5, 2020-09-07)">
<metadata
id="metadata8">
<rdf:RDF>
<cc:Work
rdf:about="">
<dc:format>image/svg+xml</dc:format>
<dc:type
rdf:resource="http://purl.org/dc/dcmitype/StillImage" />
<dc:title></dc:title>
</cc:Work>
</rdf:RDF>
</metadata>
<defs
id="defs6">
<filter
inkscape:collect="always"
style="color-interpolation-filters:sRGB"
id="filter985"
x="-0.071198094"
width="1.1423962"
y="-0.036209762"
height="1.0724195">
<feGaussianBlur
stdDeviation="23.740331"
id="feGaussianBlur987" />
</filter>
</defs>
<sodipodi:namedview
pagecolor="#ffffff"
bordercolor="#666666"
borderopacity="1"
objecttolerance="10"
gridtolerance="10"
guidetolerance="10"
inkscape:pageopacity="0"
inkscape:pageshadow="2"
inkscape:window-width="1920"
inkscape:window-height="1051"
id="namedview4"
showgrid="false"
inkscape:zoom="0.4311099"
inkscape:cx="836.66411"
inkscape:cy="425.35117"
inkscape:window-x="0"
inkscape:window-y="0"
inkscape:window-maximized="1"
inkscape:current-layer="layer2" />
<g
inkscape:groupmode="layer"
id="layer2"
inkscape:label="background">
<rect
style="opacity:0.58015;fill:#007055;fill-opacity:1;stroke:none;stroke-width:1;stroke-miterlimit:4;stroke-dasharray:none"
id="rect1009"
width="1977.9685"
height="1094.047"
x="-42.271221"
y="-8.8268881" />
</g>
<g
inkscape:label="Copie de Image"
id="g998"
sodipodi:insensitive="true">
<path
style="fill:#000000;fill-opacity:1;stroke:none;stroke-width:1;stroke-linecap:butt;stroke-linejoin:miter;stroke-miterlimit:4;stroke-dasharray:none;stroke-opacity:1;filter:url(#filter985)"
d="M 1059.1973,327.27705 274.70293,-448.94949 258.93997,1124.5708 Z"
id="path992"
sodipodi:nodetypes="cccc"
transform="matrix(1.8842291,0,0,1.8842291,-918.07388,-272.87422)" />
<g
id="g996"
transform="matrix(1.8842291,0,0,1.8842291,-427.87239,-264.68193)"
style="fill:#008800;fill-opacity:1">
<path
style="mix-blend-mode:normal;fill:#008800;fill-opacity:1;stroke:none;stroke-width:1;stroke-linecap:butt;stroke-linejoin:miter;stroke-miterlimit:4;stroke-dasharray:none;stroke-opacity:1"
d="M 786.60878,296.54378 2.1144314,-479.68276 -13.648523,1093.8375 Z"
id="path994"
sodipodi:nodetypes="cccc" />
</g>
</g>
<g
inkscape:label="right"
id="g1006">
<path
id="path1000"
transform="matrix(-1.8842291,0,0,-1.8842291,2764.6189,1943.2457)" />
<g
id="g1004"
transform="matrix(-1.8842291,0,0,-1.8842291,2274.4174,1935.0534)"
<path
id="path1002"
</g>
</g>
<g
inkscape:label="left"
id="g10">
<path
d="M 799.03704,322.92923 14.542688,-453.29731 -1.2202662,1120.223 Z"
id="path971"
<g
id="g990"
style="fill:#008080">
<path
style="mix-blend-mode:normal;fill:#008080;stroke:none;stroke-width:1;stroke-linecap:butt;stroke-linejoin:miter;stroke-miterlimit:4;stroke-dasharray:none;stroke-opacity:1"
id="path867"
</g>
</g>
</svg>
EDIT: bad shadows with kde ???
papajoke:
My test is : 5ko !
I have no idea what that means, but from the looks of it, you have not checked your Telegram window yet. I sent the file to you there as an SVG.
