Silencing Network Notifications
I just re-installed Manjaro Cinnamon and I can’t seem to be able to silence the network notifications. Whenever I get connected to / disconnected from the wifi network, a notification pops up. I then click on “Don’t show this message again”, but it keeps coming back. It was working fine before I re-installed.
Does anyone know where this setting is saved? Maybe I have a permission issue. Journalctl doesn’t show any error.
Note: the only thing I’ve done on this system is removing xdg-dekstop-gnome, otherwise Firefox takes 30s to start. It’s pretty fresh and vanilla.
Yes its in privacy its called check connectivity and is enabled by default.
Thanks for the tip. I turned it off but I still receive the notifications on joining/disconnecting wifi.
Those happen when my laptop wakes up from sleep (it automatically reconnects to the network).
connected
disconnected
Maybe:
https://wiki.archlinux.org/title/Cinnamon#Configuration
Specifically the Disable the NetworkManager applet section at the bottom of the page.
Oh, that’s nm-applet. Thanks to you, I’ve found the corresponding parameter with dconf:
image-1
For some reason, clicking on “Don’t show this message again” does not change the configuration of nm-applet. Disabling it with dconf works. Thanks a lot.
