Signature is invalid
ok mirror list updated for stable.
I found unexpected that (a) does not work. Can’t understand why. Please open a separate thread for it in AUR sub-section (AUR - Manjaro Linux Forum)
Perhaps, we did all for the thread: only need to re-build AUR packages to make them use new packages you just got recently.
I think we done in this topic. Do you think the same?
Yes it’s solved. New issue here
@alven what if I want to switch from stable to testing branch? Is it advisable or eventually signatures break and I am better off with stable?
If to switch between branches of updates (stable, testing, unstable), then it will not break local keyring you already had before.
Expected behavior of stable → testing or testing → unstable switch is only that you will get a more fresh packages versions and therefore less known / less tested in Manjaro OS, so possibly less stable. It is not recommended to switch for not experienced users. Please search and read several articles about branch switching to understand it and be warned more detailed.
If you feel a power that you can try to handle possible issues there, you can try to switch.
After you switched branches, it is absolutely essential to run sudo pacman -Syyu to force to refresh local package databases (core, extra, community, multilib) according to their state in new branch you switched to.
Thanks a lot. Very thorough information.
