Signature is invalid
Now
sudo pacman-key --list-keys 39F0EC1AE50B37E5F3196F09DAD3B211663CA268 02FD1C7A934E614545849F19A6234074498E9CEE
sudo pacman-key --list-keys 02FD1C7A934E614545849F19A6234074498E9CEE
Was it without error?
to remove a package answer any y or n - no matter
Mainly - you imported the whose two keys by installation attempt of those two packages.
yes without error
Good.
Do not publish:
see the [ full ] phrase 3 times?
2 on Bernhard Landauer
and one on Christian Hesse
I do not see any full only [ ultimate ] and [ unknown ]
My fault, please do this:
sudo pacman-key --lsign-key 39F0EC1AE50B37E5F3196F09DAD3B211663CA268
sudo pacman-key --lsign-key 02FD1C7A934E614545849F19A6234074498E9CEE
and re-check for [ full ] sub-string
Perfect now I see 1x[ultimate] and 3x[ full ]
Stage 3
Installation of packages:
sudo pacman -Sy manjaro-keyring archlinux-keyring
With success?
yes with success
Good. We got fresh keyring packages (with keys inside).
Stage 4
Let’s clear all our temp stuff we made - removing temp local keyring we created before:
sudo rm -r /etc/pacman.d/gnupg
initialize new local keyring:
sudo pacman-key --init
Show output of
~/Desktop ❯ sudo pacman-key --list-keys | wc -l
6
Good.
Install keys from Arch linux and Manjaro keyring packages we got earlier:
sudo pacman-key --populate
Show the
1041
Perfect. You have all main keys. Let;s update it from the Internet key servers:
Now request updates from a keyserver for all keys that already exist on the local keyring. This is useful for updating a key with the latest signatures, user IDs, etc.:
sudo pacman-key --refresh-keys
This will took 7-10 minutes. You will see runtime error (it is normal) while some servers may not respond to key updates procedure.
After it was done: Let’s check count of lines:
You should see a bit more lines than was (> 1041)
How many you have?
1067 lines
Amazing!
This was the pure and secure way to get all public keys (and automatically (by packages algorithms) setup their trust level/locally sign them).
Now they are ready to use.
Now switch to the initial issue of the topic:
pamac update
Do you see signature or any other errors?
Were the cantarell-fonts and pango updated now?
Any other issues?
Everything works fine now, pamac update had no errors, and pamac reinstall cantarell-fonts pango completed successfully.
2 maintenance things remaining:
a) to rebuid all your AUR packages (you got updates, now time AUR packages to be re-builded against those new packages you got (if AUR packages you installed actually use them as dependencies))
 pamac build $(pamac list -qm)
b) to switch the servers of updates to the ones closer to you (just to speed up download speed)
sudo pacman-mirrors --api --set-branch stable --proto https --country X,Y,Z
X,Y,Z - are countries you prefer separated with comma: Sweden,Finland,Norway…
to show list of avail. countries:
pacman-mirrors -l
2.a doesn’t work:
❯  pamac build $(pamac list -qm)
Error: target not found: google-play-music-desktop-player-bin
Error: target not found: libopenaptx
Error: target not found: mhwd-nvidia-340xx
Error: target not found: linux-latest-virtualbox-host-modules
Error: target not found: breath2-wallpaper
Error: target not found: popcorntime-ru-bin
Error: target not found: linux-latest-headers
For now do (b) please (country switch or leave Germany if you want)
