After the 2024-07-29/2024-08-08 stable updates my Signal Desktop 7.18.0-1 upon start reports that “a database failure” happened (I’m not using it every day) - button “copy fault and terminate” gives:
Unhandled Promise Rejection
Error: Not initialized
at MainSQL.close ([REDACTED]/ts/sql/main.js:104:13)
at BrowserWindow.<anonymous> ([REDACTED]/app/main.js:690:15)
The pop-up offers for immediate fix “erase the data and restart.”
While this happens on my asrock desktop, I can start Signal Desktop on my hp laptop with this same database - the Signal folder is symlinked to a folder in a Veracrypt container on a USB storage that I attach when needed - thus the database is not faulty.
So it’s rather something with the computer or the system.
Please, advise, if possible - could it be caused by the CPU (Celeron J1900) lacking some capabilities, other hardware, by timing or rather by a dependency (which maybe the package installer didn’t check)?
Thank you,
Dirk
Signal app.log:
{"level":30,"time":"2024-08-12T11:14:26.810Z","msg":"Profile Service initialized"}
{"level":30,"time":"2024-08-12T11:14:27.413Z","msg":"libsignal net environment resolved to [Production]"}
{"level":30,"time":"2024-08-12T11:14:27.490Z","msg":"preload complete"}
{"level":30,"time":"2024-08-12T11:14:27.492Z","msg":"@signalapp/libsignal-client Initializing libsignal version:0.52.3 signal_node::logging rust/bridge/node/src/logging.rs:206"}
{"level":30,"time":"2024-08-12T11:14:27.492Z","msg":"@signalapp/libsignal-client Initializing connection manager for Prod... libsignal_bridge_types::net rust/bridge/shared/types/src/net.rs:70"}
{"level":30,"time":"2024-08-12T11:14:27.652Z","msg":"NotificationService initialized"}
{"level":50,"time":"2024-08-12T11:14:27.674Z","msg":"Top-level unhandled promise rejection: TypeError: Cannot destructure property 'getIsInCall' of 'window.Events' as it is undefined.\n at IpcRenderer.<anonymous> ([REDACTED]/resources/app.asar/preload.bundle.js:68:24607)\n at IpcRenderer.emit (node:events:519:28)\n at Object.onMessage (node:electron/js2c/renderer_init:2:8837)"}
main.log:
{"level":30,"time":"2024-08-12T11:14:22.036Z","msg":"got fast localeOverride setting null"}
{"level":30,"time":"2024-08-12T11:14:22.039Z","msg":"app.ready: hour cycle preference: UnknownPreference"}
{"level":30,"time":"2024-08-12T11:14:22.039Z","msg":"app.ready: preferred system locales: de-DE, de"}
{"level":30,"time":"2024-08-12T11:14:22.040Z","msg":"locale: Supported locales: af-ZA, ar, az-AZ, bg-BG, bn-BD, bs-BA, ca, cs, da, de, el, en, es, et-EE, eu, fa-IR, fi, fr, ga-IE, gl-ES, gu-IN, he, hi-IN, hr-HR, hu, id, it, ja, ka-GE, kk-KZ, km-KH, kn-IN, ko, ky-KG, lt-LT, lv-LV, mk-MK, ml-IN, mr-IN, ms, my, nb, nl, pa-IN, pl, pt-BR, pt-PT, ro-RO, ru, sk-SK, sl-SI, sq-AL, sr, sv, sw, ta-IN, te-IN, th, tl-PH, tr, ug, uk-UA, ur, vi, yue, zh-CN, zh-HK, zh-Hant"}
{"level":30,"time":"2024-08-12T11:14:22.041Z","msg":"locale: Preferred locales: de-DE, de"}
{"level":30,"time":"2024-08-12T11:14:22.041Z","msg":"locale: Locale Override: null"}
{"level":30,"time":"2024-08-12T11:14:22.048Z","msg":"locale: Matched locale: de"}
{"level":40,"time":"2024-08-12T11:14:22.191Z","msg":"intl.onWarn [@formatjs/intl] \"defaultRichTextElements\" was specified but \"message\" was not pre-compiled. \nPlease consider using \"@formatjs/cli\" to pre-compile your messages for performance.\nFor more details see https://formatjs.io/docs/getting-started/message-distribution"}
{"level":30,"time":"2024-08-12T11:14:22.192Z","msg":"locale: Text info direction for de: ltr"}
{"level":30,"time":"2024-08-12T11:14:22.195Z","msg":"getSQLKey: decrypting key"}
{"level":30,"time":"2024-08-12T11:14:22.197Z","msg":"getSystemTraySetting got value DoNotUseSystemTray"}
{"level":30,"time":"2024-08-12T11:14:22.197Z","msg":"getSystemTraySetting returning DoNotUseSystemTray"}
{"level":30,"time":"2024-08-12T11:14:22.201Z","msg":"app ready"}
{"level":30,"time":"2024-08-12T11:14:22.202Z","msg":"starting version 7.18.0"}
{"level":30,"time":"2024-08-12T11:14:22.202Z","msg":"media access status [object Undefined] [object Undefined]"}
{"level":30,"time":"2024-08-12T11:14:22.212Z","msg":"got fast theme-setting value system"}
{"level":30,"time":"2024-08-12T11:14:22.222Z","msg":"got fast theme-setting value system"}
{"level":30,"time":"2024-08-12T11:14:22.222Z","msg":"got fast spellcheck setting false"}
{"level":30,"time":"2024-08-12T11:14:22.224Z","msg":"Initializing BrowserWindow config: {\"show\":false,\"width\":1360,\"height\":703,\"minWidth\":300,\"minHeight\":200,\"autoHideMenuBar\":false,\"titleBarStyle\":\"default\",\"backgroundColor\":\"#3a76f0\",\"webPreferences\":{\"devTools\":false,\"spellcheck\":false,\"enableBlinkFeatures\":\"CSSPseudoDir,CSSLogical\",\"enablePreferredSizeMode\":true,\"nodeIntegration\":false,\"nodeIntegrationInWorker\":false,\"sandbox\":false,\"contextIsolation\":true,\"preload\":\"[REDACTED]/preload.bundle.js\",\"backgroundThrottling\":true,\"disableBlinkFeatures\":\"Accelerated2dCanvas,AcceleratedSmallCanvases\"},\"icon\":\"[REDACTED]/images/signal-logo-desktop-linux.png\",\"x\":0,\"y\":28}"}
{"level":30,"time":"2024-08-12T11:14:22.371Z","msg":"spellcheck: user locales: [\"de-DE\",\"de\"]"}
{"level":30,"time":"2024-08-12T11:14:22.371Z","msg":"spellcheck: available spellchecker languages: [\"af\",\"bg\",\"ca\",\"cs\",\"cy\",\"da\",\"de\",\"de-DE\",\"el\",\"en\",\"en-AU\",\"en-CA\",\"en-GB\",\"en-GB-oxendict\",\"en-US\",\"es\",\"es-419\",\"es-AR\",\"es-ES\",\"es-MX\",\"es-US\",\"et\",\"fa\",\"fo\",\"fr\",\"fr-FR\",\"he\",\"hi\",\"hr\",\"hu\",\"hy\",\"id\",\"it\",\"it-IT\",\"ko\",\"lt\",\"lv\",\"nb\",\"nl\",\"pl\",\"pt\",\"pt-BR\",\"pt-PT\",\"ro\",\"ru\",\"sh\",\"sk\",\"sl\",\"sq\",\"sr\",\"sv\",\"ta\",\"tg\",\"tr\",\"uk\",\"vi\"]"}
{"level":30,"time":"2024-08-12T11:14:22.371Z","msg":"spellcheck: setting languages to: [\"de-DE\",\"de\"]"}
{"level":40,"time":"2024-08-12T11:14:23.113Z","msg":"MainSQL: Database log code=26: file is not a database in \"PRAGMA journal_mode = WAL\""}
{"level":30,"time":"2024-08-12T11:14:23.113Z","msg":"MainSQL: migrateDatabase: Migration without cipher change failed"}
{"level":40,"time":"2024-08-12T11:14:23.351Z","msg":"MainSQL: Database log code=26: statement aborts at 2: [PRAGMA user_version] file is not a database"}
{"level":50,"time":"2024-08-12T11:14:23.352Z","msg":"MainSQL: Database startup error: SqliteError: file is not a database\n at Database.pragma ([REDACTED]/node_modules/@signalapp/better-sqlite3/lib/methods/pragma.js:11:31)\n at getUserVersion ([REDACTED]/ts/sql/util.js:132:13)\n at migrateSchemaVersion ([REDACTED]/ts/sql/Server.js:394:54)\n at openAndMigrateDatabase ([REDACTED]/ts/sql/Server.js:425:3)\n at openAndSetUpSQLCipher ([REDACTED]/ts/sql/Server.js:440:14)\n at Object.initialize ([REDACTED]/ts/sql/Server.js:476:16)\n at MessagePort.<anonymous> ([REDACTED]/ts/sql/mainWorker.js:84:35)\n at [nodejs.internal.kHybridDispatch] (node:internal/event_target:820:20)\n at MessagePort.<anonymous> (node:internal/per_context/messageport:23:28)"}
{"level":50,"time":"2024-08-12T11:14:23.353Z","msg":"MainSQL: runCorruptionChecks: not running the check, no writable instance Error: getUnsafeWritableInstance: globalWritableInstance not set!\n at getUnsafeWritableInstance ([REDACTED]/ts/sql/Server.js:605:11)\n at Object.runCorruptionChecks ([REDACTED]/ts/sql/Server.js:4828:10)\n at respond ([REDACTED]/ts/sql/mainWorker.js:40:29)\n at MessagePort.<anonymous> ([REDACTED]/ts/sql/mainWorker.js:115:5)"}
{"level":50,"time":"2024-08-12T11:14:23.354Z","msg":"Failed to get zoom factor {}"}
{"level":30,"time":"2024-08-12T11:14:25.071Z","msg":"got fast theme-setting value system"}
{"level":50,"time":"2024-08-12T11:14:27.652Z","msg":"sql.initialize was unsuccessful; returning early"}
{"level":30,"time":"2024-08-12T11:14:27.654Z","msg":"close event {\"readyForShutdown\":false,\"shouldQuit\":false}"}
{"level":30,"time":"2024-08-12T11:14:27.654Z","msg":"maybeRequestCloseConfirmation: Checking to see if close confirmation is needed"}
{"level":50,"time":"2024-08-12T11:15:20.762Z","msg":"onDatabaseError: Quitting application"}
{"level":30,"time":"2024-08-12T11:15:20.765Z","msg":"main window closed event"}
{"level":30,"time":"2024-08-12T11:15:20.766Z","msg":"quit event {\"hasEventBeenPrevented\":false,\"windowCount\":0,\"mainWindowExists\":false}"}
{"level":50,"time":"2024-08-12T11:15:20.775Z","msg":"Error occurred in handler for 'sql-channel': {}"}
{"level":50,"time":"2024-08-12T11:15:20.776Z","msg":"maybeRequestCloseConfirmation: Response never received; continuing with close."}
{"level":50,"time":"2024-08-12T11:15:20.779Z","msg":"Unhandled Promise Rejection: Error: Not initialized\n at MainSQL.close ([REDACTED]/ts/sql/main.js:104:13)\n at BrowserWindow.<anonymous> ([REDACTED]/app/main.js:690:15)"}
asrock inxi -Fz:
Kernel: 6.10.3-1-MANJARO arch: x86_64 bits: 64
Desktop: Xfce v: 4.18.1 Distro: Manjaro Linux
Type: Desktop Mobo: ASRock model: Q1900B-ITX serial: <superuser required>
UEFI: American Megatrends v: P2.20 date: 02/12/2019
Info: quad core model: Intel Celeron J1900 bits: 64 type: MCP cache:
L2: 2 MiB
Speed (MHz): avg: 1333 min/max: 1333/2416 cores: 1: 1333 2: 1333 3: 1333
4: 1333
Device-1: Intel Atom Processor Z36xxx/Z37xxx Series Graphics & Display
driver: i915 v: kernel
Display: x11 server: X.Org v: 21.1.13 driver: X: loaded: modesetting
dri: crocus gpu: i915 resolution: 1360x768~60Hz
API: EGL v: 1.5 drivers: crocus,swrast
API: OpenGL v: 4.5 compat-v: 4.2 vendor: intel mesa v: 24.1.5-manjaro1.1
renderer: Mesa Intel HD Graphics (BYT)
Device-1: Intel Atom Processor Z36xxx/Z37xxx Series High Definition Audio
driver: snd_hda_intel
API: ALSA v: k6.10.3-1-MANJARO status: kernel-api
Server-1: PulseAudio v: 17.0 status: active
driver: r8169
IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: ASIX AX88179 Gigabit Ethernet driver: cdc_ncm type: USB
IF: enp0s20u1u2c2 state: down mac: <filter>
Local Storage: total: 465.76 GiB used: 395.72 GiB (85.0%)
ID-1: /dev/sda vendor: SanDisk model: SDSSDH3 250G size: 232.89 GiB
ID-2: /dev/sdb vendor: SanDisk model: Ultra Luxe size: 232.88 GiB
type: USB
ID-1: / size: 232.54 GiB used: 214.47 GiB (92.2%) fs: btrfs dev: /dev/sda3
ID-2: /boot/efi size: 319.3 MiB used: 308 KiB (0.1%) fs: vfat
dev: /dev/sda2
ID-3: /home size: 232.54 GiB used: 214.47 GiB (92.2%) fs: btrfs
dev: /dev/sda3
ID-4: /var/log size: 232.54 GiB used: 214.47 GiB (92.2%) fs: btrfs
dev: /dev/sda3
ID-1: swap-1 type: file size: 6 GiB used: 1.11 GiB (18.5%)
file: /@swapfile/swapfile
System Temperatures: cpu: 55.0 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 4 GiB note: est. available: 3.54 GiB used: 2.38 GiB (67.4%)
Processes: 268 Uptime: 1h 28m Shell: Bash inxi: 3.3.35
hp inxi -Fz:
Type: Laptop System: HP product: HP EliteBook 840 G5 v: N/A
Mobo: HP model: 83B2 v: KBC Version 04.6E.00 serial: <superuser required>
UEFI: HP v: Q78 Ver. 01.25.00 date: 06/16/2023
ID-1: BAT0 charge: 36.7 Wh (100.0%) condition: 36.7/50.2 Wh (73.1%)
Info: quad core model: Intel Core i5-8350U bits: 64 type: MT MCP cache:
L2: 1024 KiB
Speed (MHz): avg: 450 min/max: 400/1700 cores: 1: 400 2: 400 3: 400 4: 400
5: 400 6: 400 7: 400 8: 800
Device-1: Intel UHD Graphics 620 driver: i915 v: kernel
dri: iris gpu: i915 s-res: 1368x768 resolution: 1920x1080
API: EGL v: 1.5 drivers: iris,swrast platforms: gbm,x11,surfaceless,device
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.1.5-manjaro1.1
renderer: Mesa Intel UHD Graphics 620 (KBL GT2)
Device-1: Intel Sunrise Point-LP HD Audio driver: snd_hda_intel
Device-1: Intel Ethernet I219-LM driver: e1000e
IF: enp0s31f6 state: down mac: <filter>
Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi
Local Storage: total: 471.35 GiB used: 237.87 GiB (50.5%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLB256HAHQ-000H1
ID-2: /dev/sda vendor: SanDisk model: Ultra Luxe size: 232.88 GiB
type: USB
ID-1: / size: 63.94 GiB used: 56.55 GiB (88.4%) fs: btrfs
dev: /dev/nvme0n1p4
ID-2: /boot/efi size: 96 MiB used: 72.6 MiB (75.6%) fs: vfat
dev: /dev/nvme0n1p1
ID-3: /home size: 63.94 GiB used: 56.55 GiB (88.4%) fs: btrfs
dev: /dev/nvme0n1p4
ID-4: /var/log size: 63.94 GiB used: 56.55 GiB (88.4%) fs: btrfs
dev: /dev/nvme0n1p4
ID-1: swap-1 type: file size: 3 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 37.0 C pch: 33.5 C mobo: N/A
Memory: total: 8 GiB note: est. available: 7.6 GiB used: 1.37 GiB (18.1%)
Processes: 290 Uptime: 1h 28m Shell: Bash inxi: 3.3.35
