On usual Linux distributions, shutting down produces a list of debug messages.
On my current installation of Manjaro, I just see the logo of my Laptop vendor.
I would prefer to see system log messages.
How do I achieve that?
Edit /etc/default/grub and remove quiet behind GRUB_CMDLINE_LINUX_DEFAULT
After that sudo grub-update and your done
I’ve marked the below answer as the solution to your question as it is by far the best answer you’ll get.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or
or
if you agree)
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
