Hi everyone,
I ran into some issues with reboot and shutdown today. I am not 100% sure if these problems were related to the newest updates I received earlier this day. But at least after that current update I noticed there is a problem so I post it here.
Some general system information:
ystem:
Kernel: 6.6.19-1-MANJARO arch: x86_64 bits: 64
Desktop: Cinnamon v: 6.0.4 Distro: Manjaro Linux
Type: Laptop System: ASUSTeK product: Vivobook_ASUSLaptop N7401ZE_N7401ZE
v: 1.0 serial: <superuser required>
Mobo: ASUSTeK model: N7401ZE v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: N7401ZE.301 date: 06/02/2022
ID-1: BAT0 charge: 67.1 Wh (99.3%) condition: 67.6/70.0 Wh (96.5%)
Info: 14-core (6-mt/8-st) model: 12th Gen Intel Core i7-12700H bits: 64
type: MST AMCP cache: L2: 11.5 MiB
Speed (MHz): avg: 531 min/max: 400/4600:4700:3500 cores: 1: 784 2: 400
3: 400 4: 400 5: 830 6: 400 7: 832 8: 413 9: 956 10: 400 11: 454 12: 400
13: 400 14: 400 15: 400 16: 400 17: 635 18: 400 19: 732 20: 589
Device-1: Intel Alder Lake-P GT2 [Iris Xe Graphics] driver: i915 v: kernel
Device-2: NVIDIA GA107M [GeForce RTX 3050 Ti Mobile] driver: nvidia
v: 550.54.14
Device-3: Logitech Logitech Webcam C925e driver: snd-usb-audio,uvcvideo
type: USB
Device-4: Sonix USB2.0 FHD UVC WebCam driver: uvcvideo type: USB
Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.4 driver: X:
loaded: modesetting,nvidia dri: iris gpu: i915 resolution: 1: 3840x2160~60Hz
2: 2880x1800~120Hz
API: EGL v: 1.5 drivers: iris,kms_swrast,nvidia,swrast
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.0.2-manjaro1.1
renderer: Mesa Intel Graphics (ADL GT2)
Device-1: Intel Alder Lake PCH-P High Definition Audio
driver: sof-audio-pci-intel-tgl
Device-2: NVIDIA driver: snd_hda_intel
type: USB
Device-4: Focusrite-Novation Scarlett 2i2 3rd Gen driver: snd-usb-audio
type: USB
API: ALSA v: k6.6.19-1-MANJARO status: kernel-api
Server-1: PulseAudio v: 17.0 status: active
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
IF: enp0s13f0u1u4u4 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: eth0 state: down mac: <filter>
Device-1: Intel AX211 Bluetooth driver: btusb type: USB
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
Local Storage: total: 953.87 GiB used: 104.84 GiB (11.0%)
ID-1: /dev/nvme0n1 vendor: Micron model: 3400 MTFDKBA1T0TFH
ID-1: / size: 953.57 GiB used: 104.84 GiB (11.0%) fs: btrfs
dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.4 MiB used: 576 KiB (0.2%) fs: vfat
dev: /dev/nvme0n1p1
ID-3: /home size: 953.57 GiB used: 104.84 GiB (11.0%) fs: btrfs
dev: /dev/nvme0n1p2
ID-4: /var/log size: 953.57 GiB used: 104.84 GiB (11.0%) fs: btrfs
dev: /dev/nvme0n1p2
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%)
file: /swap/swapfile
System Temperatures: cpu: N/A mobo: N/A
Fan Speeds (rpm): cpu: 2000
Memory: total: 16 GiB note: est. available: 15.32 GiB used: 3.56 GiB (23.2%)
Processes: 419 Uptime: 6m Shell: Bash inxi: 3.3.33
I checked the last boot for errors via journalctl and got the following result:
Mär 06 20:35:22 VivoLinux kernel: ACPI BIOS Error (bug): Could not resolve symbol [\CTDP], AE_NOT_FOUND (20230628/psargs-330)
Mär 06 20:35:22 VivoLinux kernel: ACPI Error: Aborting method \_SB.IETM.IDSP due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
Mär 06 20:35:22 VivoLinux kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN1._CRT.S1CT], AE_NOT_FOUND (20230628/psargs-330)
Mär 06 20:35:22 VivoLinux kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN1._CRT due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
Mär 06 20:35:22 VivoLinux kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN1._HOT.S1HT], AE_NOT_FOUND (20230628/psargs-330)
Mär 06 20:35:22 VivoLinux kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN1._HOT due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
Mär 06 20:35:22 VivoLinux kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN1._PSV.S1PT], AE_NOT_FOUND (20230628/psargs-330)
Mär 06 20:35:22 VivoLinux kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN1._PSV due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
Mär 06 20:35:22 VivoLinux kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN1._AC0.S1AT], AE_NOT_FOUND (20230628/psargs-330)
Mär 06 20:35:22 VivoLinux kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN1._AC0 due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
Mär 06 20:35:22 VivoLinux kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN2._CRT.S2CT], AE_NOT_FOUND (20230628/psargs-330)
Mär 06 20:35:22 VivoLinux kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN2._CRT due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
Mär 06 20:35:22 VivoLinux kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN2._HOT.S2HT], AE_NOT_FOUND (20230628/psargs-330)
Mär 06 20:35:22 VivoLinux kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN2._HOT due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
Mär 06 20:35:22 VivoLinux kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN2._PSV.S2PT], AE_NOT_FOUND (20230628/psargs-330)
Mär 06 20:35:22 VivoLinux kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN2._PSV due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
Mär 06 20:35:22 VivoLinux kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN2._AC0.S2AT], AE_NOT_FOUND (20230628/psargs-330)
Mär 06 20:35:22 VivoLinux kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN2._AC0 due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
Mär 06 20:35:22 VivoLinux kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN3._CRT.S3CT], AE_NOT_FOUND (20230628/psargs-330)
Mär 06 20:35:22 VivoLinux kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN3._CRT due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
Mär 06 20:35:22 VivoLinux kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN3._HOT.S3HT], AE_NOT_FOUND (20230628/psargs-330)
Mär 06 20:35:22 VivoLinux kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN3._HOT due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
Mär 06 20:35:22 VivoLinux kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN3._PSV.S3PT], AE_NOT_FOUND (20230628/psargs-330)
Mär 06 20:35:22 VivoLinux kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN3._PSV due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
Mär 06 20:35:22 VivoLinux kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN4._CRT.S4CT], AE_NOT_FOUND (20230628/psargs-330)
Mär 06 20:35:22 VivoLinux kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN4._CRT due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
Mär 06 20:35:22 VivoLinux kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN4._HOT.S4HT], AE_NOT_FOUND (20230628/psargs-330)
Mär 06 20:35:22 VivoLinux kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN4._HOT due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
Mär 06 20:35:22 VivoLinux kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN4._PSV.S4PT], AE_NOT_FOUND (20230628/psargs-330)
Mär 06 20:35:22 VivoLinux kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN4._PSV due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
Mär 06 20:35:22 VivoLinux kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN4._AC0.S4AT], AE_NOT_FOUND (20230628/psargs-330)
Mär 06 20:35:22 VivoLinux kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN4._AC0 due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
Mär 06 20:35:23 VivoLinux kernel: ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-70)
Mär 06 20:35:23 VivoLinux kernel: iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
Mär 06 20:35:25 VivoLinux kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
Mär 06 20:35:25 VivoLinux kernel: iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
Mär 06 20:35:25 VivoLinux bluetoothd[1317]: src/device.c:set_wake_allowed_complete() Set device flags return status: Invalid Parameters
Mär 06 20:35:26 VivoLinux kernel: iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
Mär 06 20:35:34 VivoLinux lightdm[2062]: gkr-pam: unable to locate daemon control file
Mär 06 20:58:04 VivoLinux kernel: usb 3-1.2: Unable to submit urb #2: -19 at snd_usb_queue_pending_output_urbs
Mär 06 20:58:04 VivoLinux kernel: usb 3-1.2: cannot submit urb 0, error -19: no device
Mär 06 20:58:04 VivoLinux kernel: usb 3-1.2: 1:0: usb_set_interface failed (-19)
Mär 06 20:59:51 VivoLinux dbus-broker-launch[1310]: Activation request for 'org.freedesktop.Avahi' failed.
Mär 06 20:59:51 VivoLinux pulseaudio[2268]: org.bluez.BatteryProviderManager1.UnregisterBatteryProvider() Failed: org.freedesktop.DBus.Error.NoReply:Remote peer disconnected
Mär 06 20:59:52 VivoLinux dbus-broker-launch[1310]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
Mär 06 20:59:53 VivoLinux dbus-broker-launch[1310]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
I assume the problem is the last item in this list, just because obiviously it is the one thing the system could not handle. I did some research in this forum and on the internet in general and as far as I understand it, it has to do with the network manager. But I was not able to find a working solution. Does somebody know what to do?
