I install john (1.9.0.jumbo1-6)
via pamac successfully. When I try to use 7z2john. It turns out those:
[kearney@xx ]$ 7z2john
Can't locate Compress/Raw/Lzma.pm in @INC (you may need to install the Compress::Raw::Lzma module) (@INC contains: /usr/lib/perl5/5.34/site_perl /usr/share/perl5/site_perl /usr/lib/perl5/5.34/vendor_perl /usr/share/perl5/vendor_perl /usr/lib/perl5/5.34/core_perl /usr/share/perl5/core_perl) at /usr/bin/7z2john line 6.
BEGIN failed--compilation aborted at /usr/bin/7z2john line 6.
That is quite easy to know the solution is install Lzma. Then I install perl-compress-raw-lzma (2.101-2) form AUR via pamac. Then it finally works.
Usage: /usr/bin/7z2john <7-Zip file>...
So I am curious about whether perl-compress-raw-lzma is the depend of john
pacman -Si john
Repository : community
Version : 1.9.0.jumbo1-6
Description : John the Ripper password cracker
Architecture : x86_64
URL : https://www.openwall.com/john
Licenses : GPL2 custom
Groups : None
Provides : None
Depends On : openssl gmp libpcap openmpi gcc-libs opencl-icd-loader
libxcrypt libcrypt.so=2-64
Optional Deps : bash-completion: completion for bash
lua: lua based john scripts
perl: perl based john scripts
ruby: ruby based john scripts
python: python based john scripts
Conflicts With : None
Replaces : None
Download Size : 16.54 MiB
Installed Size : 69.54 MiB
Packager : Caleb Maclennan <alerque@archlinux.org>
Build Date : Sat 25 Dec 2021 05:10:41 AM EST
Validated By : MD5 Sum SHA-256 Sum Signature
Thanks for your reply. There are 8 depends and 5 optional depends. None of them is perl-compress-raw-lzma.
not really know what is the ponit
